Coding not accepted, Request out of range
OwnerTR
Turkey
C?ID=493252
No coding accepted for 2021 Caddy
I was going to increase the number of comfort flasher.
ENG174381-MAS07991-light_control-Comfort flasher set point
Even though I unlocked SFD, I couldn't encode. Why do you think this error occurs?
Scan this;
Wednesday,29,September,2021,15:15:31:34165
VCDS Version: 21.9.0.2  HEX-V2 CB: 0.4555.4
VIN: WV1ZZZSKZMX050719   License Plate:
Chassis Type: SK-VN3S (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 3C 42 44 52 5F 6C 6D
          75 A5 D6 D7 811E 811F 8120 8121 C002 C003
VIN: WV1ZZZSKZMX050719   Mileage: 1757km-1091miles
Address 01: Engine (J623-DTRC)       Labels: None
   Part No SW: 05L 906 023 AA    HW: 05L 907 309 C
   Component: R4 2.0l TDI   H30 0672
   Revision: E3H30---    CVN: 0024DDC3746D3ABF66040229D51ED7E26604022943FB2DAA
   Coding: 012500320324050930000000000000000000000000000000
   Shop #: WSC 35110 377 00121
   ASAM Dataset: EV_ECM20TDI01105L906023AA 007002
   ROD: EV_ECM20TDI011_VN3S.rod
   VCID: 678BB270CFE5836306B-8032
   VINID: 9E606AAAA8DBA9DA001401C124E091EE83
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0GC 906 555 F    HW: 0GC 300 045 F
   Component: GSG DQ381     H06 4161
   CVN: E8811639
   ASAM Dataset: EV_TCMDQ381062 001001
   ROD: EV_TCMDQ381062.rod
   VCID: 3E253714F0FFE2AB95D-806A
   Subsystem 1 - Part No SW: 5WA 713 033 AN    HW: 610 5
   Component: ZSB_SB_AUTO    H08 1034
   Serial number: 20210423000066799700
   Subsystem 2 - Part No SW: 7T0 713 052 D    HW: 7T0 713 052 D
   Component: ZSB_SB_mono    H01 0005
   Serial number: 03052104S00000005064
   Subsystem 3 - Part No SW: 0GC 927 373 M    HW: 0GC 927 373 M
   Component: SMOP DQ381     H04 0001
   Serial number: C7458810500002823512
   Part No SW: 5WA 614 517 BJ    HW: 5WA 614 517 N
   Component: ESC           H13 0131
   Serial number: 61201000001521  CVN: 76FDB284
   Coding: 340C2C9734252C6C427E50010ACC60066DB658F05AC8670820BCA23121CFF300001C38
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 013055
   ROD: EV_Brake1ESCEPBMQB37W_013.rod
   VCID: 117FBCA891E12DD338F-8044 SFD
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 C    HW: 5WA 959 436 C
   Component: Kessy IOBOX   070 0706
   Serial number: ---------------
   ASAM Dataset: EV_Kessy37w 003022
   ROD: EV_Kessy37w_003_VW38.rod
   VCID: 54F175BC6E7318FB539-8000
Address 08: Auto HVAC (J979)       Labels:* None
   Part No SW: 5WA 907 727 N    HW: 5WA 907 727 N
   Component: Climatronic   H02 0340
   Coding: 023010010210020000100000111001110000111110100000100000000000
   ASAM Dataset: EV_ACClimaBHBVW38X 005067
   ROD: EV_ACClimaBHBVW38X_VN3S.rod
   VCID: 5BE39E8003ADD783923-800E
   Interior temperature sensor:
   Subsystem 1 - Part No SW: 5WA 907 527     HW: 5WA 907 527
   Component: E857           H01 0103
   Serial number: 00001160321131147514
131076 - Function Restricted due to Insufficient Voltage
          U1400 00 [040] - -
                    Fault Frequency: 0
459533 - Databus
          U1123 00 [040] - Received Error Message
          [Databus_error_value_received_Botschaft_Airbag_02]
                    Fault Frequency: 0
          B10CD 00 [040] - -
          [Function limitation due to energy management 03]
                    Fault Frequency: 0
   Part No SW: 5WA 937 086 E    HW: 5WA 937 086 E
   Component: BCM 37W BOSCH 018 0159
   Serial number: BXJ53F070521940
   ASAM Dataset: EV_BCM37w 006001
   ROD: EV_BCM37w_006_VW38.rod
   VCID: 53F376A06B7D1FC34A3-8006 SFD
   Subsystem 1 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS           054 0206
   Serial number: S5Y21M04D27H05M04S13
   Subsystem 2 - Part No SW: 5H0 941 193 G    HW: 5H0 941 193 G
   Component: LiSi           H04 0513
   Serial number: TW571426042100010039
   Subsystem 3 - Part No SW: 5H0 925 200 P    HW: 5H0 925 200 P
   Component: DiETa          H06 0007
   Serial number: 92471UDL000IH
   Subsystem 4 - Part No SW: 5H0 959 561 AR    HW: 5H0 959 561 AR
   Component: -VW----LINDA-  502 0813
   Serial number: MW3LND16042100010087
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507 FL    HW: 5Q1 953 549 D
   Serial number: 00000021042104221295
15401216 - Secure Onboard Communication
          U14FE 00 [044] - Signature Verification Failed
          [Sichere on-board Kommunikation: Signaturüberprüfung fehlgeschlagen]
                    Fault Frequency: 11
                    Reset counter: 39
                    Mileage: 1748 km
                    Date: 2021.09.25
                    Time: 18:01:41
71168 - Front Left Ride-Height Sensor
          C1034 31 [046] - No Signal
          [Drehwinkelsensor vorn links: Leitungsunterbrechung]
                    Fault Frequency: 107
                    Mileage: 1719 km
                    Date: 2021.09.24
                    Time: 11:32:00
   Part No SW: 5WA 919 298 A    HW: 5WA 919 298
   Component: PLA 12K Kanal H04 0230
   Serial number: 000027022194560
   Coding: 8200026011
   ASAM Dataset: EV_EPHBO2CVW3800000 002028
   ROD: EV_EPHBO2CVW3800000_VW38.rod
   Part No SW: 5WA 907 572 B    HW: 5WA 907 572
   Component: ACC Bosch MQB H20 0395
   Coding: 0E0200070077404512474000000000044E4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 004017
   ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
   VCID: 4DC760D84D5949331C7-8018
Address 15: Airbags (J234)       Labels: 1EA-959-655.clb
   Part No SW: 1EA 959 655 CH    HW: 1EA 959 655 CH
   Component: VW40Airbag    009 0166
   Serial number: V119WmE0404
   Coding: 88CC008000E0C00000000000000000005154000020AA00005C00F680002B0065
   ASAM Dataset: EV_AirbaVW40ALVVW38X 001012
   ROD: EV_AirbaVW40ALVVW38X.rod
   VCID: 094F94C8F9B11513F0F-805C SFD
   Seat occupancy detection 1:
   Subsystem 1 - Part No SW: 2K7 959 760 B    HW: 2K7 959 760 B
   Component: wSBR F-SG      037 0166
   Serial number:         94DC4E023423
   Subsystem 2 - Part No SW: -----------    HW: 440 001 504 21
   Component: SideSensor_Df  00A 0887
   Serial number: 357CJ00000007AAC435B
   Subsystem 3 - Part No SW: -----------    HW: 440 001 904 21
   Component: SideSensor_Pf  00A 0887
   Serial number: 358CJ000000D0499945E
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 4 - Part No SW: -----------    HW: 440 001 704 21
   Component: Side_Sens_B_D  00A 0149
   Serial number: I0PCJ9F0146E13031002
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 5 - Part No SW: -----------    HW: 440 001 604 21
   Component: Side_Sens_B_P  00A 0149
   Serial number: I0QCJA301778B5341006
   Subsystem 6 - Part No SW: -----------    HW: 440 001 604 21
   Component: SideSensor_Dr  00A 0149
   Serial number: 351CJB3016DC75E2500X
   Subsystem 7 - Part No SW: -----------    HW: 440 001 704 21
   Component: SideSensor_Pr  00A 0149
   Serial number: 352CJ9F0146E1274A00S
   Subsystem 8 - Part No SW: -----------    HW: 440 001 702 21
   Component: FrontSensor_P  00A 014A
   Serial number: 355CJ2A636E87201700O
9444359 - Safety belt switch - driver side
          B101C 07 [047] - Mechanical Failure
1075977 - Databus
          U1123 00 [046] - Received Error Message
          [NWD: 0x102 ESC_50 error value ESP_v_ref]
                    Mileage: 1757 km
                    Date: 2021.09.29
                    Time: 11:18:22
   Part No SW: 5H0 920 340 A    HW: 5H0 920 340 A
   Component: KOMBI         203 3460
   Coding: 04A41447639C00080180220B2000000800101C00
   ASAM Dataset: EV_DashBoardVDDMQB37W 003032
   ROD: EV_DashBoardVDDMQB37W_003_VW38.rod
   VCID: 2019E96C6A4BB45B871-8074 SFD
16777018 - Control unit for information electronics 1
          U1054 00 [008] - No Communication
          [Audio_0x31 communication error bap_error_timeout heartbeat]
                    Reset counter: 127
                    Mileage: 1748 km
                    Date: 2021.09.25
                    Time: 16:34:22
16711686 - Secure Onboard Communication
          U14FE 00 [008] - Signature Verification Failed
          [SOK_signature_verification_failed]
                    Fault Frequency: 8
                    Mileage: 1748 km
                    Date: 2021.09.25
                    Time: 18:01:10
   Part No SW: 5WA 907 530 J    HW: 5WA 907 530 C
   Component: GW2020 High   752 7084
   Revision: --------    Serial number: 290160901174158
   Coding: 0000808D0700000000000000012303327301610902000100030100000001010000000000000000000000000000000000
   GVL: 3D000800020840CC80008002C800004004004000004000000000000000000044
   ASAM Dataset: EV_GatewMQB2020 004008
   ROD: EV_GatewMQB2020_VW38.rod
   VCID: 4FFB7AD047557B236EB-801A SFD
   Generator:
   Component: 5-00-15-00-04
   Subsystem 2 - Part No SW: 5WA 915 181 C    HW: 5WA 915 181 C
   Component: J367-BDMHella  H11 9080
   Serial number: 3034767205
   Inverter for electrical outlet:
   Subsystem 3 - Part No SW: 7C0 907 155     HW: 7C0 907 155
   Component: U13DCAC        H05 0870
   Serial number: A075085
   Subsystem 4 - Part No SW: 3G0 959 442 M    HW: 3G0 959 442 M
   Component: E221__MFL-PR6  H07 0110
   Serial number: PR6-0440036085213371
2097222 - No Communications with HVAC Control Module (J301)
          U0164 00 [040] - -
                    Reset counter: 39
                    Mileage: 1752 km
                    Date: 2021.09.27
                    Time: 17:31:35
8397569 - Quiescent Current
          U1406 00 [040] - Too High
                    Mileage: 1719 km
                    Date: 2021.09.24
                    Time: 16:52:22
8397571 - LV Energy Management
          B1802 F1 [040] - Warning Triggered
                    Mileage: 1757 km
                    Date: 2021.09.28
                    Time: 15:02:17
                    74
8466689 - VKMS
          B18B0 F0 [032] - Missing Adaptation
          [VKMS_new_download_container_required_due_to_vehicle_change]
                    Fault Frequency: 0
                    Reset counter: 0
   Part No SW: 5WA 909 059 H    HW: 3Q0 909 059 B
   Component: EBKV          H06 0112
   Serial number: BPA085030521013
   Coding: 5402C500090000000027C58800006DDBB66DDBB600
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 014027
   ROD: EV_BrakeBoostG2BoschVW37W_014.rod
   VCID: 55F788B8658901F3A47-8000 SFD
107024 - Transmission Control Module
          U14E4 00 [032] - Received Malfunction Value
          [Scl_Getriebe_11_GE_Fahrstufe_Error]
172400 - System Voltage
          P0562 00 [032] - Too Low
          [PSCUnderVoltageLevel1]
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H09 0040
   Serial number: 21000111684009
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 323D132434A736CB615-8066
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 E    HW: 2Q0 907 686 E
   Component: HRE_Master    H25 0284
   Serial number: 00000574013398
   Coding: 569545D0
   ASAM Dataset: EV_HREntryHellaGen3Mstr 001015
   ROD: EV_HREntryHellaGen3Mstr.rod
   VCID: 3C213D1CE6E3F0BBBB9-8068
   Subsystem 1 - Part No SW: 2Q0 907 685 E    HW: 2Q0 907 685 E
   Component: HRE_Slave      H25 0284
   Serial number: 00000575550677
   Part No SW: 5Q4 959 593 H    HW: 5Q4 959 593 H
   Component: TSG FS        010 0692
   Serial number: 0000441068811
   Coding: 00309320D000040100001020
   Shop #: WSC 35110 377 00141
   VCID: 4ACD6BC4BC375E0B395-801E
196726 - Motor for mirror fold-in
          B11F6 13 [008] - Open Circuit
                    Fault Frequency: 24
                    Reset counter: 129
                    Mileage: 1719 km
                    Date: 2021.09.24
                    Time: 11:25:12
   Part No SW: 5R3 907 146 A    HW: 5R3 907 146
   Component: BASGEN1MQB37  261 2040
   Serial number: 00839307
   Coding: 0000000100000000000102010100010000000101010101
   ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
   VCID: 36352F34D8CF2AEB4DD-8062
   Part No SW: 5Q4 959 592 H    HW: 5Q4 959 592 H
   Component: TSG BFS       010 0691
   Serial number: 0000441254350
   Coding: 00301120D000040100801000
   Shop #: WSC 35110 377 00133
   VCID: 49CF54C8B931551330F-801C
   Part No SW: 5H0 035 869     HW: 5H0 035 869
   Component: MU-E-D-ER     099 1325
   Serial number: CVRV59X1AEB0032
   Coding: 63521000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUEIMQB37w 001003
   ROD: EV_MUEIMQB37w_SE38.rod
   VCID: 6C81CD5CD603A03B6B9-8038 SFD
0021 - Functional Limitation due to Energy Management
          B10CD 00 [008] - -
          [Function restriction via shutoff stage Q2]
                    Fault Priority: 9
                    Mileage: 1750 km
                    Voltage terminal 30: 11.3 V
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 5WA 980 556 B    HW: 5WA 980 556 B
   Component: RV eCompact   H26 0254
   Serial number: FCLK20300321000
   Coding: 06037200E42800
   ASAM Dataset: EV_CamSysRVCCompaFicos 009020
   ROD: EV_CamSysRVCCompaFicos.rod
   VCID: 50F979AC5A6B64DB771-8004
   Part No SW: 5Q0 959 107 AA    HW: 5Q0 959 107 H
   Component: HDSG-Modul    H13 0272
   Revision: --------    Serial number: A2-C737-6331-9
   Coding: 4E00
   VCID: 77ABE2309F4513E396B-8022
   Part No SW: 5WA 035 286 A    HW: 5WA 035 286 A
   Component: OCU3HMQB37W   H12 0135
   Serial number: 0000000104VIHJ6
   Coding: 06359010106818008005460000500607
   ASAM Dataset: EV_OCU3HMQB37W 002012
   ROD: EV_OCU3HMQB37W_002_VW38.rod
   VCID: 46D55FF4A82FBA6BDDD-8012 SFD
   Part No SW: 5WA 980 653 A    HW: 5WA 980 653
   Component: MQB MFK 3.0   H06 3129
   Serial number: E57830711211130
   Coding: 000108900068C040409F00001020000002018000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005050
   ROD: EV_MFK3ValeoMQB_005_VW38.rod
   Part No SW: 992 941 571 AE    HW: 992 941 571 A
   Component: LED1L         H08 9202
   ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
   VCID: 6597B87835E99173347-8030
   Component: LED1R         H08 9202
Address 811E: Burglary Protection FL (J518)       Labels: 5WA-962-133.clb
   Part No SW: 5WA 962 133 B    HW: 5WA 962 133 B
   Component: Kessy RSAD    070 0636
   ASAM Dataset: EV_RSADVL37w 002013
   ROD: EV_RSADVL37w.rod
   VCID: 47CB52F0AF25A36326B-8012
Address 811F: Burglary Protection FR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADVR37w 002013
   ROD: EV_RSADHL37w.rod
Address 8120: Burglary Protection RL (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHR37w 002013
End----(Elapsed Time: 01:32, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
Map scan is here
I find it somewhat puzzling that so many modules (including the BCM) don't show a WSC in the scan. I wonder if this this normal for Mk.8 based cars. It's late here and I'm too tired to go searching for other scans. Maybe tomorrow.
OwnerTR
Turkey
C?ID=493252
Thanks, I'm waiting. It's 07 am here
NEtech
Denmark
C?ID=56995
It seems so on new models, on my ID.3, only [15] and [2B] reply on WSC.
  • Informative
NEtech
Denmark
C?ID=56995
Are you sure it is unlocked successfully?
You don't have DTC B184C, that become active when SFD is unlocked.
But you have U14FE
OwnerTR
Turkey
C?ID=493252
But you have U14FE
Above was pre-coding scan.
This is the post-coding scan today.
I wanted to trade on 09, 17 and 5F units.
I got the errors in this picture on unit 09 and 5F.
Thursday,02,December,2021,09:47:43:34165
Dealer/Shop Name: Ross-Tech LLC.
Workshop Code: 444 03743 000001
VIN: WV1ZZZSKZMX050719   Mileage: 2738km-1701miles
Readiness: 0 0 0 1 1
   CVN: E8811639
15403264 - Release / Enable Active
          B184C 00 [047] - -
          [Freischaltung aktiv]
                    Mileage: 2738 km
                    Date: 2021.12.02
                    Time: 10:43:54
   Coding: 8200026011
16711684 - Release / Enable Active
          B184C 00 [009] - -
                    Reset counter: 173
                    Mileage: 2738 km
                    Date: 2021.12.01
                    Time: 21:22:20
   Generator:
   Coding: 569545D0
   Coding: 00301120DC00040100801000
4112 - Release / Enable Active
          B184C 00 [009] - -
          [Unlock_protection_of_vehicle_diagnosis_active]
                    Mileage: 2738 km
                    Date: 2021.12.02
                    Time: 10:46:31
   Coding: 4E00
End----(Elapsed Time: 01:29, VBatt start/end: 11.3V/11.3V. VIgn 11.3V)-----
Hawkeye9723
C?ID=389466
Did you have the hood open?
Westbury, UK
Do I remember correctly that we have seen before that some modules reject the default WSC, Importer and Equipment numbers of 12345, 123 & 12345?
If so is it worth @OwnerTR changing the WSC, Importer and Equipment numbers in his VCDS installation and trying again?
OwnerTR
Turkey
C?ID=493252
Yes, it was given before and I didn't care because the sfd lock was not unlocked and I couldn't code.
I tried this 03743 444 00001 it gave the same error.
OwnerTR
Turkey
C?ID=493252
Interesting. I did the mirror download coding in reverse gear. But it doesn't work. In the first reverse gear, the mirror went down and did not go up.
The coding I made;
09 -Cent. Elect. activated.
ENG141635-ENG149218-Spiegelverstellung-Spiegellabsenkung_bei_Rueckwaertsfahrt
ENG141635-ENG258306-Spiegelverstellung-Menuesteuerung_Spiegellabsenkung
52-Door Elect. Pass
byte 4
Bit 2- mirror_lowering_with_rear_gear,active
Bit 3- position_memory_with_rear_gear,active
Last scan today;
Sunday,05,December,2021,09:53:29:34165
VIN: WV1ZZZSKZMX050719   Mileage: 2761km-1715miles
   CVN: E8811639
459533 - Databus
                    Mileage: 2761 km
                    Date: 2021.12.05
                    Time: 10:51:36
   Coding: 8200026011
   Coding: 04A51447639C00080180220B2000000800101C00
   Generator:
   Coding: 569545D0
   Coding: 00309320DC00040100001020
   Coding: 4E00
End----(Elapsed Time: 01:29, VBatt start/end: 11.3V/11.2V. VIgn 11.3V)-----
Westbury, UK
The mirror dip on reverse uses the seat memory module to remember the position and needs the motor with position feedback to work properly.
If you don't have both of those then at best the mirror returns to a semi-random position and at worse doesn't return at all.
OwnerTR
Turkey
C?ID=493252
I don't have a memory seat in my car.
In my previous 2015 Tiguan Lounge vehicle, there was no seat memory, but the mirror tilt was working.
Does it have to be a separate module? The mirror no longer turns.
Westbury, UK
I enabled mirror tilt on my previous Skoda Octavia, as that didn't have memeory seats the mirror would tilt down but return to a random position whch made mirrpr tilit useless so I disabled it. Many owners complained of the same priblem, one owner had to do a full retrofit of the new mirror motors and the set memory module to make it work correctly.
If your mirror no longer turns then you have another problem which needs solving first. Start by checking the changes you have made, and maybe reversing them back to the previous values - and also check the relevant fuse(s).
  • Agree
OwnerTR
Turkey
C?ID=493252
thank you so much.
I'll check if I can find the relevant fuse.
jasons6930
C?ID=304798
@OwnerTR
Did you get this working?
jasons6930
C?ID=304798
Thats a shame.
I am just looking through my 09 module from my 22 Caddy and i have found the adaptation, however i am just wondering if there is also a menu setting somewhere buried in the adaptations as i seem to remember a Golf 7.5 i had, had the option to turn comfort flashing on and off, and also select how many times.
Having said that, i may not be remembering correctly!
When you have time, would you post up an admap of your 09 module please?
OwnerTR
Turkey
C?ID=493252
Thats a shame.
All my maps are here. https://forums.ross-tech.com/index.php?threads/29405/
jasons6930
C?ID=304798
Great stuff, thanks.
