hello all
I have Skoda superb 2017 and I activated the sunroof widow to close on rain via screen but it doesn't close
anyone know how to do it, is it through adaptations or coding? I entered the output test on 09 control module but it doesn't close nor open on vcds
here is an auto-scan
Tuesday,30,November,2021,18:46:52:04619
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
VIN: TMBAJ9NP4H7530521 License Plate:
Chassis Type: NP-SK48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 2B 36 3C 42 44 47
4B 52 5F 69 6C 6D A5 CA
VIN: TMBAJ9NP4H7530521 Mileage: 89778km-55785miles
6C-Back-up Cam. -- Status: Cannot be reached 0100
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 FN HW: 04L 907 309 M
Component: R4 2.0l TDI H24 2011
Revision: B4H24--- CVN: C6EA7159D45710C1
Coding: 011D003A047405083000
Shop #: WSC 33361 790 00141
ASAM Dataset: EV_ECM20TDI01104L906026FN 004002
ROD: EV_ECM20TDI01104L906026FN_004.rod
VCID: 7BA3F1D783644063F23-802E
VINID: 91D4916897A01181C50C014204F1C13828
17159 - Databus
Mileage: 89349 km
Date: 2021.11.20
Time: 22:02:50
Engine RPM: 745.00 /min
Normed load value: 28.6 %
Coolant temperature: 90 �C
Intake air temperature: 71 �C
Voltage terminal 30: 13.480 V
Unlearning counter according OBD: 23
Engine status: COENG_RUNNING
Part No SW: 0D9 300 042 N HW: 02E 927 770 AS
Component: DQ250-6F MQB H54 5004
Revision: 06454104 Serial number: TFK01612270111 CVN: 00009775
ROD: EV_TCMDQ250021.rod
VCID: 2411EAAB5E5ADF9BE39-8070
11 Faults Found:
21153 - Gear 1
P072C 00 [002] - Not Selectable
21154 - Gear 2
P072D 00 [002] - Not Selectable
21155 - Gear 3
P072E 00 [002] - Not Selectable
21156 - Gear 4
P072F 00 [002] - Not Selectable
21157 - Gear 5
P073A 00 [002] - Not Selectable
21158 - Gear 6
P073B 00 [002] - Not Selectable
21159 - Gear R
P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
P174A 00 [002] - Electrical malfunction
10732 - Valve 3 in Transmission Part 2
P174E 00 [002] - Electrical malfunction
10657 - RPM Signal from ECU
P0726 00 [002] - Implausible Signal
10906 - Cooling Oil Valve
P179D 00 [002] - Electrical Malfunction
Part No SW: 5Q0 614 517 CH HW: 5Q0 614 517 AH
Component: ESC H62 0743
Revision: 00000000 Serial number: 60277000001269
Coding: 1D076A9C34230B6C477C060240C449B8562CD0E2600292753861F0F8C2A9420000000012121212B835351919323200
VCID: 79AFEBDF89587273E0F-802C
Part No SW: 3Q0 959 435 E HW: 3Q0 959 435 E
Component: VWKESSYMQB 036 0811
Revision: 00036000 Serial number: 0430456939
Coding: 032C0C0F03
ASAM Dataset: EV_KessyHellaMQBAB 004039
ROD: EV_KessyHellaMQBAB_004_SK25.rod
VCID: 3C2132CBC6EA875BBB9-8068
Subsystem 1 - Part No SW: 3AA 962 243 G HW: 3AA 962 243 G
Component: GEB.F.Heckoef H16 0903
Serial number: 84502204
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 3V0 907 044 DQ HW: 3V0 907 044 DQ
Component: AC Automat H34 4101
Revision: 20K07000 Serial number: 00000B00382627
Coding: 11010104004111011005100C0010110A
ASAM Dataset: EV_ACClimaPrehVW37X 002019
VCID: 06559023C8A60D8B9DD-8052
Humidity sensor: exterior:
Rear A/C control head:
Subsystem 2 - Part No SW: 3V0 907 049 E HW: 3V0 907 049 E
Component: E265KlimaHeck H02 0101
Serial number: 06051501850797
263425 - Air Quality Sensor
B10AF 04 [009] - Internal System Fault
Reset counter: 158
Mileage: 86172 km
Date: 2021.09.16
Time: 12:47:20
Outside temperature: 30.0 �C
Voltage terminal 30: 13.6 V
System run time-Engine running time: 253 s
Air quality status: Clean air
655628 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
[HeckBT - Sitzheizung - Komforteinschr�nkung wegen Eingriff Energiemanagement]
Reset counter: 164
Mileage: 89066 km
Date: 2021.11.13
Time: 23:11:55
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001701901043
Coding: 080000000000000000000000000000000000000000000000000000000000
Shop #: WSC 12345 123 61029
ROD: EV_BCMBOSCH_017.rod
VCID: 7F5B05C7977C5C43DEB-802A
Subsystem 1 - Part No SW: 3V1 955 119 HW: 3V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: 48x LL 170110 032 0121
Serial number: 00000001701060407081
Coding: 165DDD
Component: RLHS 042 0105
Serial number: S4Y17M01D31H09M29S14
Coding: 06084D
Part No SW: 5QA 919 298 B HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0038
Serial number: 000308417617023
Coding: 0271167151
ASAM Dataset: EV_EPHVA2CAU3700000 009032
ROD: EV_EPHVA2CAU3700000.rod
VCID: 4FFB7507675C0CC36EB-801A
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 C HW: 3Q0 907 572 C
Component: ACC BOSCH MQB H04 0195
Coding: 320067CB55FFC428949C8045
ASAM Dataset: EV_ACCBOSCHVW48X 001009
ROD: EV_ACCBOSCHVW48X.rod
VCID: 353727EFE5C05613447-8060
0932 - Transmission Temperature Monitoring
P1764 00 [008] - -
[FAULT_CLUTCH_TEMP_HIGH]
Fault Frequency: 8
Reset counter: 186
Mileage: 89483 km
Date: 2021.11.23
Time: 16:49:21
Control Module temperature: 44 �C
Voltage terminal 15: 13.3 V
Velocity_vehicle_reference: 1.11 m/s
Longitudinal_acceleration_vehicle_reference: 0.99 m/s�
0935 - Databus
[FAULT_TRAILOR_LIGHT_DEFECTIVE]
Reset counter: 181
Mileage: 89349 km
Date: 2021.11.20
Time: 22:02:51
Control Module temperature: 39 �C
Voltage terminal 15: 13.5 V
Longitudinal_acceleration_vehicle_reference: 0.00 m/s�
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Reset counter: 181
Mileage: 89349 km
Date: 2021.11.20
Time: 22:02:51
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 07011741350023
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 38292EDBF2D2AB7B5F1-806C
Part No SW: 5Q0 959 655 AS HW: 5Q0 959 655 AS
Component: AirbagVW21 003 0317
Serial number: 003TMR2JNNT5
Coding: 98FCC0C0000000005C5400CF000800000065
VCID: 117FB37FB1E85A3338F-8044
Left seat belt tensioner:
Serial number: 3V0857701C0026R00950
Coding: 80000D
Right seat belt tensioner:
Serial number: 3V0857702C0020R00696
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 002 701 17
Serial number: 35700000000670491122
Subsystem 4 - Part No SW: ----------- HW: 480 002 701 17
Serial number: 35800000000C9040A02A
Subsystem 5 - Part No SW: ----------- HW: 480 402 401 17
Serial number: 3510001C722EA2B34562
Subsystem 6 - Part No SW: ----------- HW: 480 402 701 17
Serial number: 35200019F236974525D5
Subsystem 7 - Part No SW: ----------- HW: 480 402 801 17
Serial number: 3550001BF244A6A31611
Part No SW: 5Q0 953 521 KS HW: 5Q0 953 569 B
Component: Lenks.Modul 100 0245
Revision: FF035035 Serial number: 20170126500821
Coding: 6014
ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
ROD: EV_SMLSVALEOMQBLRH.rod
VCID: 0D47AF0FADD07ED3DC7-8058
291104 - Temperature Sensor for Heated Steering Wheel
B1455 01 [008] - Electrical Failure
Reset counter: 198
Ubat 30 Voltage: 12.80 V
Internal error state: 0
LIN_Temp: 0
Isense: 0
Max.Leistung: 110
PWM: 0
Offset: 253
Slope: 133
kp: 18
OUT: 50
Temperatur Statisch: 30
p_t_soll_0: 34.00 �C
p_t_soll_1: 39.00 �C
p_t_soll_2: 44.00 �C
Part No SW: 3V0 920 751 A HW: 3V0 920 751 A
Component: KOMBI 305 8311
Coding: 07A5011A7F84000819886B0B5001000000000000
VCID: 323D1CF314AE412B615-8066
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 G HW: 5Q0 963 272 G
Component: STH-MQB 008 0075
Coding: 9309
VCID: 3A2D34D3CCDEB96BA95-806E
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000185244
Part No SW: 3Q0 907 530 C HW: 3Q0 907 530 C
Component: GW MQB High 515 5286
Serial number: 30011710800593
Coding: 0B0100345F087300EB00025E9C0F00010001070000000000000000000000
Shop #: WSC 33361 790 00132
GVL: 01563C0008000600C0DC80000006CC0010000000000200000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 2F3B1587079C6CC30EB-807A
Generator:
Subsystem 2 - Part No SW: 3V0 919 719 D HW: 3V0 919 719 D
Component: E221__MFL-PR6 H02 0160
Serial number: 000000000B1676200117
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 8142232904
Inverter for electrical outlet:
Subsystem 4 - Part No SW: 5Q0 907 155 B HW: 5Q0 907 155 B
Component: U13DCAC H25 0780
Serial number: 0018138
131689 - Rear View Camera System Control Module
U104C 00 [009] - No communication
[Timeout Knoten 0x69 / 6C - Steuerger�t f�r R�ckfahrkamerasystem]
Reset counter: 158
Mileage: 86172 km
Date: 2021.09.16
Time: 13:31:10
Terminal 30 power supply: 12.6 V
Terminal 15: OFF
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 17000018159009
ROD: EV_ELVMarquMQBB.rod
VCID: 71BFD3FFD1283A3358F-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B
Component: Sitzmemory H08 0021
Serial number: Y0006QAI20050
Coding: 0010000000000500018280808080000000008181000000D400
ASAM Dataset: EV_SeatMemorDriveSide 002021
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0429058799
Coding: 02012103
ROD: EV_HREntryHella_VW37.rod
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0428037240
Coding: 020121
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0032
Serial number: 0000237731290
Coding: 001D0920DE00048000001100
VCID: 47CB5D278F2CD48326B-8012
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000013061287
Coding: 110200
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2051
Revision: 00000000 Serial number: 0001376134
Coding: 01010011004001
ROD: EV_SteerAssisVWBSMQBA_009.rod
VCID: 40D9463BAA02E3BBE71-8014
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 223 HW: 81A 035 223
Component: MIB2_amp_P_SK H10 0410
Revision: 00000001 Serial number: SKZ8Z1GJE013X64
Coding: 0384010000AA002FAA0000000000
Shop #: WSC 33361 790 00113
ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001
ROD: EV_AMPMst16C5Gen2ALPI.rod
VCID: 59EF8B5F2998527380F-800C
0600 - Loudspeaker 1 in Double-Subwoofer
B130C 13 [008] - Open Circuit
Fault Frequency: 243
Reset counter: 198
Mileage: 80169 km
Date: 2021.06.23
Time: 12:52:54
Voltage terminal 30: 12.2 V
0605 - Loudspeaker 2 in Double-Subwoofer
B130D 13 [008] - Open Circuit
Reset counter: 198
Mileage: 80169 km
Date: 2021.06.23
Time: 12:52:54
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 001 0285
Serial number: 01021710521003
Coding: 000000020100066A06007F01000000000000000000000000000000000000
VCID: 72BDDCF3D42E012BA15-8026
Subsystem 1 - Part No SW: 4H0 941 329 HW: 4H0 941 329
Component: Leimo links H02 0013
Subsystem 2 - Part No SW: 4H0 941 329 HW: 4H0 941 329
Component: Leimo rechts H02 0013
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0032
Serial number: 0000238468976
Coding: 001D0320DE00048000001100
VCID: 46D550238826CD8BDDD-8012
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000013023046
Coding: 090200
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-HGH2.clb
Part No SW: 3V0 035 021 D HW: 3V0 035 021
Component: MU-H-LND-EU H50 0942
Serial number: A674A0HS018467
Coding: 03840101000000005111120200880A332F0100F4012001009E
ROD: EV_MUHig4CGen2HBAS_AU37.rod
VCID: 2809FE9B22723BFBCF1-807C
Subsystem 1 - Part No SW: 3V0 919 605 E HW: 3V0 919 605 E
Component: ABT_Std-2 H52 8130
Serial number: SKZ6ZHV1902978
Subsystem 2 - Part No SW: V03 959 801 JM HW: -----------
Component: ECE 2017 --- 0157
Compact disc data bank:
Component: Gracenote2--- --- 1013
B201A 00 [009] - -
Fault Frequency: 39
Reset counter: 156
Mileage: 86172 km
Date: 2021.09.16
Time: 14:12:48
Voltage terminal 30: 12.1 V
Status_Software_Version_Management-module_name: MDUK610/Main
2565 - GPS Antenna
B1054 13 [009] - Open Circuit
[GPS aerial - open circuit]
Reset counter: 249
Mileage: 86172 km
Date: 2021.09.16
Time: 14:12:44
1562 - Microphone 1
B129B 11 [008] - Short to Ground
Reset counter: 190
Mileage: 89510 km
Date: 2021.11.23
Time: 21:43:51
1564 - Microphone 1
B129B 13 [008] - Open Circuit
Reset counter: 198
Mileage: 89507 km
Date: 2021.11.23
Time: 21:40:30
3086 - Antenna for Telephone Mount
B1564 01 [009] - Electrical Failure
Reset counter: 58
Mileage: 86172 km
Date: 2021.09.16
Time: 14:12:42
Status of telephone-Antenna diagnostic: OK
Status of telephone-Telephone baseplate diagnostic: not connected
Status of telephone-Handset in handset holder (cradle): not selected
Status of telephone-Handset holder (cradle): not connected
Part No SW: 5Q0 907 383 H HW: 5Q0 907 383 C
Component: Anhaenger H21 0204
Revision: 8B001003 Serial number: 0428969382
Coding: 0100000202000000
655882 - Bulb for Brake Light on Trailer
C10F3 15 [008] - Open or Short to Plus
Reset counter: 181
Mileage: 89349 km
Date: 2021.11.20
Time: 22:02:50
656906 - Bulb for Left Turn Signal on Trailer
C10F7 15 [008] - Open or Short to Plus
Reset counter: 181
Mileage: 89349 km
Date: 2021.11.20
Time: 22:02:50
Address 6C: Back-up Cam.
Part No SW: 5Q0 959 107 L HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0261
Revision: -------- Serial number: 31150321700000
Coding: 1088
VCID: 41DF433FA108EAB3E8F-8014
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 30011712K20256
Coding: 020408010000040100222355C050A90098000E100040
Shop #: WSC 20993 004 1048576
VCID: 3B2331D7C3E48063B23-806E
Part No SW: 4M0 907 594 E HW: 4M0 907 594
Component: SAD_STG_1 012 0003
Coding: 608000648101
End----------(Elapsed Time: 02:04, VBatt start/end: 13.5V/13.4V)-----------
