- Nov 24, 2021
- 7
- 0
- Vancouver, WA, USA
- C?ID=498559
Hello all happy holidays I hope this thread is in the right one. I have a 2005 vw golk mk4 automatic bew engine. I'm having troubles with limp mode that ABS/BRAKE light keep flashing on it. The old abs module was not responding to the ECM it was dead I still have original old module. A local junkyard had same matching part # module so I purchased it swapped it out and now I'm here. I tried coding with factory numbers the vcds gives you. The new module is responding with the ecu as I can see when hooked up to the vcds its picking it up and reading the module compared to other one when I would try and troubleshoot it would be dead this one is actually coming up on vcds. I think I maybe messed something up when trying to code the first time.? Please help! I also have a log of the car before I took of original module. Ive tried looking up videos lots of research online but seems like each car needs its own coding.
Wednesday,24,November,2021,16:22:15:25264
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
VIN: 9BWGR61J864007946 License Plate: AOM9503
Mileage: 326520km-202890mi Repair Order:
76
VIN: 9BWGR61J864007946 Mileage: 326520km-202890miles
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 038 906 016 AG HW: 028 101 181 2
Component: R4 1,9L EDC G000AG 7000
Revision: 12345678 Serial number: VWZ7Z0E2385448
Coding: 0150034
Shop #: WSC 00000 785 00200
VCID: 59EF85B9950F59C380F-5160
VINID: 2529D788605A206100007244185C70597D
18057 - Powertrain Data Bus
P1649 - 000 - Missing Message from ABS Controller
RPM: 1932 /min
Torque: 120.0 Nm
Speed: 11.0 km/h
Load: 44.3 %
Voltage: 14.21 V
Bin. Bits: 00001100
Torque: 274.0 Nm
Bin. Bits: 00000000
Readiness: 1 1 1 1 1
Address 02: Auto Trans Labels: 09A-927-750.lbl
Part No: 09A 927 750 BL
Component: AG5 Getriebe 09A 0262
VCID: 76B5EE0501D116BB8DD-508A
49-00 - No Communications
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 00066 000 00000
VCID: 33331711572343936A3-5160
01312 - Powertrain Data Bus
Part No: 1C0 909 605 F
Component: 08 AIRBAG VW61 0202 0003
Coding: 12344
VCID: 270BF34196FB3F33C6B-513C
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 907 F
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 15234
VCID: 2C010C6D8F1D1C6B2B9-513C
9BWGR61J864007946 VWZ7Z0E2385448
00771 - Fuel Level Sensor (G)
01335 - Drivers Seat/Mirror Position Control Module (J543)
01304 - Radio
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Coding: 00006
VCID: 70B9D81D63B5388B571-513C
01304 - Radio
Part No: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00066
VCID: 372B2301465BAFB356B-4B1E
Component: 8C Tõrsteuer.FS KLO 0202
Component: 8C Tõrsteuer.BF KLO 0202
Component: 8C Tõrsteuer.HL KLO 0202
Component: 1H Tõrsteuer.HR KLO 0009
54-00 - Incorrectly Equipped
35-10 - - - Intermittent
End----------(Elapsed Time: 05:11, VBatt start/end: 14.0V/13.9V)-----------
