2005 VW GOLF MISSING MESSAGES FROM ABS CONTROLLER
rash323
Vancouver, WA, USA
C?ID=498559
Hello all happy holidays I hope this thread is in the right one. I have a 2005 vw golk mk4 automatic bew engine. I'm having troubles with limp mode that ABS/BRAKE light keep flashing on it. The old abs module was not responding to the ECM it was dead I still have original old module. A local junkyard had same matching part # module so I purchased it swapped it out and now I'm here. I tried coding with factory numbers the vcds gives you. The new module is responding with the ecu as I can see when hooked up to the vcds its picking it up and reading the module compared to other one when I would try and troubleshoot it would be dead this one is actually coming up on vcds. I think I maybe messed something up when trying to code the first time.? Please help! I also have a log of the car before I took of original module. Ive tried looking up videos lots of research online but seems like each car needs its own coding.
Wednesday,24,November,2021,16:22:15:25264
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: 9BWGR61J864007946   License Plate: AOM9503
Mileage: 326520km-202890mi   Repair Order:
          76
VIN: 9BWGR61J864007946   Mileage: 326520km-202890miles
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 038 906 016 AG    HW: 028 101 181 2
   Component: R4 1,9L EDC G000AG  7000
   Revision: 12345678    Serial number: VWZ7Z0E2385448
   Coding: 0150034
   Shop #: WSC 00000 785 00200
   VCID: 59EF85B9950F59C380F-5160
   VINID: 2529D788605A206100007244185C70597D
18057 - Powertrain Data Bus
            P1649 - 000 - Missing Message from ABS Controller
                    RPM: 1932 /min
                    Torque: 120.0 Nm
                    Speed: 11.0 km/h
                    Load: 44.3 %
                    Voltage: 14.21 V
                    Bin. Bits: 00001100
                    Torque: 274.0 Nm
                    Bin. Bits: 00000000
Readiness: 1 1 1 1 1
Address 02: Auto Trans        Labels: 09A-927-750.lbl
   Part No: 09A 927 750 BL
   Component: AG5 Getriebe 09A   0262
   VCID: 76B5EE0501D116BB8DD-508A
            49-00 - No Communications
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 L
   Component: ABS FRONT MK60      0101
   Coding: 0004097
   Shop #: WSC 00066 000 00000
   VCID: 33331711572343936A3-5160
01312 - Powertrain Data Bus
   Part No: 1C0 909 605 F
   Component: 08 AIRBAG VW61 0202 0003
   Coding: 12344
   VCID: 270BF34196FB3F33C6B-513C
   Part No: 1J0 920 907 F
   Component: KOMBI+WEGFAHRSP VDO V03
   Coding: 15234
   VCID: 2C010C6D8F1D1C6B2B9-513C
   9BWGR61J864007946     VWZ7Z0E2385448
00771 - Fuel Level Sensor (G)
01335 - Drivers Seat/Mirror Position Control Module (J543)
01304 - Radio
   Part No: 6N0 909 901
   Coding: 00006
   VCID: 70B9D81D63B5388B571-513C
01304 - Radio
   Part No: 1C0 959 799 C
   Component: 1H Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 00066
   VCID: 372B2301465BAFB356B-4B1E
   Component: 8C Tõrsteuer.FS KLO 0202
   Component: 8C Tõrsteuer.BF KLO 0202
   Component: 8C Tõrsteuer.HL KLO 0202
   Component: 1H Tõrsteuer.HR KLO 0009
            54-00 - Incorrectly Equipped
            35-10 - - - Intermittent
End----------(Elapsed Time: 05:11, VBatt start/end: 14.0V/13.9V)-----------
Quintus Rotam
EU
C?ID=490177
A model year 2006 VW Golf, to be more precise.
...seems like each car needs its own coding.
Do you have access to the car's PR-code sticker?
The PR Codes can be found in one of two places on the vehicle:
  1. On the sticker near the Spare Tire Well on the floor of the vehicle.
  2. The duplicate of that sticker on the 1st Page of the Service/Maintenance Manual in the Owner's Manual.
Moving to Car Repair Support.
Are you certain the old ABS module was a 1C0-907-379-L ? The letter(s) on the end matter!
That's not applicable to cars this old.
As no TDI is a "cable throttle" engine, I would try changing the ABS module's coding to 0001025.
rash323
Vancouver, WA, USA
C?ID=498559
Are you certain the old ABS module was a 1C0-907-379L ? The letter(s) on the end matter!
rash323
Vancouver, WA, USA
C?ID=498559
Yes I confirmed same part numbers before purchase. I still have original one if for what ever reason I need to send to get rebuild. ? I'm going to give it a try and change coding to 0001025. Im using same procedure as youtube video on rosstech for the Bosch 5.3 and 5.7 I know its not the same pump but learning from that video on how to code to my car Thank you guys!
MK60 is a Teves (ATE), not a Bosch. They are very different. Look here:
Your pictures show the mechanical/hydraulic components, not the control module. They do not tell us whether the original control module part number was 1C0-907-379-L.
rash323
Vancouver, WA, USA
C?ID=498559
Ok I'm going to try the coding codes you send in link I hope it works out. I also took a picture of original module this time the correct picture bad part is I don't have picture of the junkyard one that is currently installed in car if this coding does not work I will take off the one in car and make sure its same part number. Thank you UWE!
rash323
Vancouver, WA, USA
C?ID=498559
Ok I tried the coding I'm not sure if I'm doing it correctly. It gave me a message about coding accepted I did not move any numbers around I just went with numbers on screen called Software coding it was highlighted 0004097 work shop code 00066 importer number 000 equipment number 00000 I pressed do it! and it said coding accepted I then went back to fault codes and deleted the fault code 01312- Powertrain Data bus 014- defective and turned car off and back on and the fault code came back and abs and brake light are still flashing. Still not getting no where can it be I installed wrong part#? Or can it be that I'm doing the coding procedure wrong.?
If the module pictured in post #7 is the original one, then this one would appear to be correct, but since it's a junkyard part, it may well be NFG.
rash323
Vancouver, WA, USA
C?ID=498559
Ok I removed the unit and took picture.
Car is currently on jack stands not sure what my next step should be should I ship of the original one to get rebuilt I see some online websites offering services any reputable ones.?
