Hi All,
I have been working my way up to performing this retrofit since i got the passat almost 3 years ago! I purchased the replacement headlights as below.
3AC 941 043
3AC 941 044
A friend helped install the headlight and the main beam, cornering lights and auto levelling work just fine with the replacements. The issue is that after enabling Dynamic Light Assist in controller A5, we receive message "Fault: light assist" in MFD and the high beams don't work however High Beams probably due to light assist not working as it is now a roller instead of shutters.
So far the following Coding has been performed
Controller A5, Byte 2, Check Bit 1
Controller 09, Byte 11, Check Bit 3
I am sure that something is missing, does anyone have any ideas on this? I believe that we are almost there with coding.
Here is a scan of my car.
Appreciate if anyone would help.
3AC 941 043
3AC 941 044
Scan: 01 02 03 08 09 10 13 14 15 16 17 19 22 25 2E 36 37 3C 42 44
46 47 4C 4F 52 53 55 56 61 62 6C 6D 72 77 A5
Address 01: Engine (0-32-BWS ) Labels: None
Part No SW: 03H 906 023 L HW: 03H 907 309 A
Component: 3,6 FSI EU5 H04 2758
Revision: MFH04--- Serial number: 00000000000000
Coding: 001D0012246600000000
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_ECM36FSI01103H906023L 002011
ROD: EV_ECM36FSI_VW46.rod
VCID: 2B7BCFF142A687460A7
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 014 R HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3504
Revision: 05551213 Serial number: 00001207280543
Shop #: WSC 05311 000 00000
VCID: 21672DD9F86A5D16A0B
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 BL HW: 3AA 614 109 BL
Component: J104 C2 450M VEED 0024
Revision: --H07--- Serial number: 00000006051700
Coding: 0116644
VCID: 78D120BD0B70FCDEB75
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 3AA 907 044 AG HW: 3AA 907 044 AG
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0014002002
ROD: EV_ClimaAutoBasis_SK35.rod
VCID: 75CF2989D46281B6AC3
Address 09: Cent. Elect. (J519) Labels: 3AA-937-087.clb
Part No SW: 3AA 937 087 H HW: 3AA 937 087 H
Component: BCM PQ47 H+ 421 0465
Revision: BC421001
Coding: 0008000000000000009802885400297423F50088626D8D60E48046240049
VCID: 3FA38BA1AEDE0BE6B6F
Subsystem 1 - Part No: 3AC 955 119
Component: Wischer 22081 26 0612
Coding: 00B795
Component: RLS 240812 05 54 0403
Coding: 0230ED
Address 10: Park/Steer Assist (J791) Labels: 3AA-919-475.clb
Part No SW: 3AA 919 475 L HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0025
Revision: -------- Serial number: 56261223302939
Coding: 349106
ASAM Dataset: EV_EPHVA2C000000000 002008
ROD: EV_EPHVA2C000000000_VN35.rod
VCID: 44A9844DCF38683EEBD
Address 13: Auto Dist. Reg Labels: None
Part No SW: 3AA 907 567 A HW: 3AA 907 567
Component: AC201 RDW A 036 0170
Revision: 00036000 Serial number: 00000000557555
Coding: 0010000
VCID: 3851E0BD4BF03CDE775
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0071
Revision: 00000000 Serial number: 21081202880002
Coding: 030180
Shop #: WSC 05311 000 08193
VCID: 277333C1564EA326EEF
Part No SW: 5N0 959 655 T HW: 5N0 959 655 T
Component: J234__11E VW10 HI 2118
Revision: 24017000 Serial number: 003LDPH7QJGI
Coding: 0012613
VCID: 4EBDA665D974926E4D9
Subsystem 1 - Serial number: 6332MTS652821872
Subsystem 2 - Serial number: 6342MTS627401982
Subsystem 3 - Serial number: 6351HTS6J102MAKR
Subsystem 4 - Serial number: 6361HTS6QM61MAKR
Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
Part No SW: 3C9 953 501 BM HW: 5K0 953 569 T
Component: LENKS.MODUL 014 0140
Revision: FF010041 Serial number: 20120821200971
Coding: 399AA50000
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 830000
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C8 920 880 K HW: 3C8 920 880 K
Component: KOMBI H04 0407
Coding: 761F01
ROD: EV_Kombi_UDS_VDD_RM09_SK25.rod
VCID: 3449D48D9F98D8BE5BD
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AA HW: 7N0 907 530 G
Component: J533 Gateway H41 1632
Revision: H41 Serial number: 150712F2000976
Coding: 462007
VCID: 6FC31BE1BE3EBB6666F
Address 22: AWD Labels: Redir Fail!
Part No SW: 0BS 907 554 C HW: 0BS 907 554 C
Component: Haldex 4Motion 4016
Coding: 0000005
VCID: 46AD9E4531045A2EF59
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 045 0400
Revision: 00045000 Serial number: VWZCZ000000000
VCID: F6CDAE8581640AAE259
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Revision: A1001003 Serial number: 7663323860
Coding: 010100
VCID: 2A75CAF5455C9E4EF11
Address 36: Seat Mem. Drvr (J810) Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 C HW: 3C8 959 760 C
Component: Sitzmemory H05 2901
Revision: 00H05000
Coding: 000039
Shop #: WSC 40022 666 40022
VCID: 354FE9899CE2C1B66C3
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 D HW: 1T0 035 680 D
Component: RNS-MID H70 4120
Revision: AB001001 Serial number: VWZ6Z7M2232091
Coding: 04050002010000A00011
VCID: 2F43DBE17EBEFB6626F
Subsystem 1 - Part No: 7L6 919 859 G
Component: AUNZ V5 7679
Address 3C: Lane Change Labels: None
Part No SW: 3AA 907 566 C HW: 4G0 907 566
Component: J769 SWA MasterH02 0010
Revision: 00H02000 Serial number: 6PZ 010 316-09
Coding: 0001172
VCID: 3957E5B970FA25D688B
Subsystem 1 - Part No: 3AA 907 568 C
Component: J0770_SWA_Slave_H02 0010
Subsystem 2 - Serial number: 6PZ 010 316-29
Subsystem 3 - Serial number: 5F22.08.1200H020003C930988ÿ
Subsystem 4 - Serial number: 930988ÿ
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0534
Revision: 12110009 Serial number: 0005378077
Coding: 0013B7
Shop #: WSC 05311 115 08193
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 354FE98994E2C1B66C3
Slave Driver:
Subsystem 1 - Part No SW: 3AA 959 704 A HW: 3AA 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0501
Serial number: 00000003076163
Coding: 010290
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 210 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 3753E38146EE33A67EF
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ47 ELV 045 0634
Coding: 01900A00D2830E7634089C1D7008DFCE105801
Component: Neigungssensor 004 0611
Address 47: Sound System Labels: None
Part No SW: 3AA 035 456 B HW: 3AA 035 456 B
Component: DSP 10 Kanal 0030
Revision: 00H07001 Serial number: 75819000183802
VCID: 2E7DC6E5B9B4F26E2D9
Address 4C: Tire Pressure II
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 G
Component: EZE_2 H41 1632
Coding: 050B0508
VCID: EFC39BE13E3E3B66E6F
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H03 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H03 0220
Subsystem 3 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0004
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0534
Revision: 14110009 Serial number: 0005382459
Coding: 0013B6
Shop #: WSC 05311 115 00000
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 364DEE8589E4CAAE659
Slave Passenger:
Subsystem 1 - Part No SW: 3AA 959 703 A HW: 3AA 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0501
Serial number: 00000003072895
Coding: 010290
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000000396105
Coding: 0022157
VCID: 364DEE8541E4CAAE659
Address 55: Xenon Range (J745) Labels: 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 023E00000B000200
ROD: EV_HeadlRegulVWAFSPt.rod
VCID: 3753E3818EEE33A67EF
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 G
Component: Batt.regelung H41 1632
Coding: 33261172
VCID: F1C79D99280A2D96F0B
Subsystem 1 - Part No SW: 3AA 915 181 A HW: 3AA 915 181 A
Component: J367-BDM H08 0181
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3C9 907 441 HW: 3C9 907 441
Component: J772__Rearview 0020
Revision: 00H11000 Serial number: 525PA8-J272457
Coding: 0020007
VCID: E8F1F0FDDBD0EC5EA75
Address 6D: Trunk Elect. Labels: None
Part No SW: 3C9 827 383 K HW: 3C9 827 383 K
Component: J605 HECKDECKEL 0830
Revision: 00H52001
Subsystem 1 - Part No: 3C9 827 384 K
Component: J756 HECKDECKEL 0830
Subsystem 2 - Serial number: 1200H52001001C0190ÿ
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 J HW: 7P6 035 730 J
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663278037
Coding: 0A11000000010101
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3957E5B9B8FA25D688B
Address A5: Frt Sens. Drv. Assist (R242) Labels: None
Part No SW: 3AA 980 654 D HW: 3AA 980 654 A
Component: MFK_Gen1 H08 0300
Serial number: 0179095039
Coding: 010002000102020D0200000000010100
ASAM Dataset: EV_47X 001639
ROD: EV_47X.rod
End ---------------------------------------------------------------------
