AUDI Q7 Central convenience component protection help
Gavra
Melbourne/Belgrade
C?ID=240855
Hi guys, first time doing this on and I need a little help :)
Here is autoscan
Thursday,14,May,2015,13:43:00:48102
VCDS Version: 14.10.2.0
Data version: 20150311
VIN: WAUZZZ4L1DD020906   License Plate:
Mileage: 59190km-36778mi   Repair Order: Jackie Q7
Chassis Type: 4L (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 28 42 46 47 4F 52 55 56
          5F 62 6C 6D 6F 72
VIN: WAUZZZ4L1DD020906   Mileage: 59190km-36778miles
46-Central Conv. -- Status: Malfunction 1010
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine (J623-CRCA)       Labels: None
   Part No SW: 4L2 910 401 B    HW: 4L0 907 401 C
   Component: 3.0TDI EDC17  H40 0002
   Revision: 53H40---    Serial number:
   Coding: 2A2A4012A52701020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0114L2910401B 001002
   ROD: EV_ECM30TDI0114L1910401H.rod
   VCID: 2345D1462A6E1E3953D-8076
Address 02: Auto Trans (J217)       Labels: 0C8-927-750.clb
   Part No SW: 0C8 927 750 AL    HW: 0C8 927 750 AL
   Component: AL1000 AISIN  001 2096
   Coding: 001578
   Shop #: WSC 08860 001 1048576
   ROD: EV_TCMAL991031_AU56.rod
   VCID: 76E3D812C97CDB91443-8023
Address 03: ABS Brakes        Labels: 4L0-910-517-V2.clb
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 2196593
   VCID: 3467221A57808981BA7-8061
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
   Component: FBSAUDIC6 ELV   H08 0200
   Revision: 00H08000    Serial number: 10603702034410
   Coding: 0000151
   VCID: 2541CF5EEC5AE0093D9-8070
   Subsystem 1 - Part No: 4F0 910 132 C
   Component: FBSAUDIC6 EZS   H04 0020
   Component: FBSAUDIC6 KSG   H03 0020
   Subsystem 3 - Part No: 4F0 910 220 F
   Component: FBSAUDIC6 IDG   H01 0053
                    Reset counter: 152
                    Mileage: 59159 km
                    Date: 2015.05.13
                    Time: 13:06:07
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AN
   Revision: 00---031    Serial number: 00000000354922
   Coding: 01029456
   VCID: 2541CF5E2C5AE0093D9-8070
   Part No SW: 4F0 910 279 AH    HW: 4F0 907 279 D
   Component: ILM Fahrer      H31 0400
   Coding: 0023121
   VCID: 6FEDED767E26EA59875-803A
   Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H13 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Reset counter: 152
                    Mileage: 59156 km
                    Date: 2015.05.13
                    Time: 13:06:00
Address 10: Park/Steer Assist (J446)       Labels: None
   Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
   Component: PARKHILFE 8K  H07 0011
   Revision: 11001001    Serial number: 55931232816711
   Coding: 28031F
   ASAM Dataset: EV_EPHVA18AU7160000 001001
   ROD: EV_EPHVA18AU7160000.rod
   VCID: 3467221A9F808981BA7-8061
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 70 AIRBAG AUDI8RH43 0230
   Revision: 04H43000    Serial number: 00399D09UU5M
   Coding: 0014128
   VCID: 2E533072B9ACA351CC3-807B
   Subsystem 1 - Serial number: 6332QSME1627387AJ
   Subsystem 2 - Serial number: 6342QSME1627425CF
   Subsystem 3 - Serial number: 6352QSME1F273940I
   Subsystem 4 - Serial number: 6362QSME07260E4EP
   Subsystem 5 - Serial number: 63734SME5D251F526
   Subsystem 6 - Serial number: 63834SME5D250C646
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
   Component: J0527               0830
   Revision: 00H08000    Serial number: 90026121880065
   Coding: 0102142
   VCID: 285FC66A9B48FD6106F-807D
   Component: E0221           H03 0040
Address 17: Instruments (J285)       Labels: 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 933 H    HW: 4L0 920 933 H
   Component: KOMBIINSTR.   H35 0316
   Revision: 00000000    Serial number: NGA51HMCD
   Coding: B356630400000008010704
   VCID: 326B24026D9487B1A8B-8067
Address 18: Aux. Heat        Labels: None
   Part No SW: 4L0 910 105     HW: 4L0 815 071 H
   Component: Heizgeraet      H10 0140
   Revision: 0000000A    Serial number: 00000009024928
   Coding: 0000101
   VCID: 60CF9E4AB3F845210EF-8035
Address 19: CAN Gateway (J533)       Labels: 4F0-907-468.clb
   Part No SW: 4F0 907 468 R    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0058
   Revision: LB600036    Serial number: 3600L12B2801E7
   Coding: 00CF07
   VCID: 3E730032A9CC53D15C3-806B
   Component: J367-BDM  H07 0125
                    Reset counter: 152
                    Mileage: 57723 km
                    Date: 2015.04.30
                    Time: 14:29:08
                    Bin. Bits:    00000
                    Voltage: 12.50 V
                    Count: 11
                    Bin. Bits:    10010
                    Time: 1.90 s
            000 -  -  - Intermittent
                    Reset counter: 152
                    Mileage: 57723 km
                    Date: 2015.04.30
                    Time: 14:33:26
                    Bin. Bits:    10111
                    Voltage: 12.20 V
                    Count: 7
                    Text: FFFFFFFFFFFFFFF06C6D00FFFFFF82FFFFFFE100
                    Raw, Index/Key Err.: 240 108 109
                    Raw, Form. N/A: 000 130 225
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AD
   Revision: 00---011    Serial number: 00000000355361
   Coding: 0000006
   VCID: 68DF866A5BC83D61C6F-803D
Address 42: Door Elect, Driver (J386)       Labels: 4F0-959-793.clb
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000046942750
   Coding: 011C52204041440004
   VCID: 489F66EAFB081D61E6F-801D
                    Reset counter: 152
                    Mileage: 57723 km
                    Date: 2015.04.30
                    Time: 14:29:11
02123 - Door Warning Light / Entry Light
                    Fault Status: 00101100
                    Fault Frequency: 11
                    Reset counter: 154
                    Mileage: 57761 km
                    Date: 2015.04.30
                    Time: 19:34:06
Address 46: Central Conv.        Labels: 4L0-910-289.lbl
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H12 0130
   Revision: 0130 ---    Serial number: 01884645120000
   Coding: 3277197
   VCID: 387F162A4BE86DE196F-806D
                    Fault Status: 00101001
                    Reset counter: 125
                    Mileage: 57723 km
                    Date: 2015.04.30
                    Time: 14:26:05
03073 - Rear Lid Closed Sensor 1
                    Reset counter: 142
                    Mileage: 58388 km
                    Date: 2015.05.08
                    Time: 09:12:02
   Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H04 0160
   Revision: CH004000    Serial number: 00000000009076
   Coding: 030000
   VCID: 2959C36E4042C469191-807C
   Part No SW: 4F0 910 280     HW: 4F0 907 280
   Component: ILM Beifahrer   H16 0100
   Revision:             Serial number: 00000000659367
   Coding: 0011001
   VCID: 5EB3A0B2898C73D13C3-800B
                    Reset counter: 152
                    Mileage: 59156 km
                    Date: 2015.05.13
                    Time: 13:06:00
                    Voltage: 12.500 V
                    Temperature: 17.0°C
Address 52: Door Elect, Pass. (J387)       Labels: 4F0-959-792.clb
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000046952700
   VCID: 479D65D6F6161219EF5-8012
                    Reset counter: 152
                    Mileage: 57723 km
                    Date: 2015.04.30
                    Time: 14:29:11
                    Fault Frequency: 11
                    Reset counter: 149
                    Mileage: 57723 km
                    Date: 2015.04.30
                    Time: 14:38:34
Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
   Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
   Serial number: 121129-0002-050
   Coding: 1147A71010000500
   ROD: EV_HeadlRegulBasic.rod
   VCID: 428B74C2D534373138B-8017
   Part No SW: 4G1 035 053 G    HW: 4G1 035 053
   Component: Radio U Basic H41 0121
   Revision: AB001007    Serial number: 227LF0C7667579
   Coding: 040003010000000000
   VCID: 2345D146226E1E3953D-8076
   Part No SW: 4L2 035 764 C    HW: 4L2 035 764 D
   Component: H-BNT-RW      H45 0639
   Revision: --------    Serial number: 222LZ0C7506515
   Coding: 180A0106000483EF010003456F6320035C0000000000000000
   VCID: 2E53307279ACA351CC3-807B
   Subsystem 1 - Part No: 8R0 060 884 AS
   Component: ROW 2013  0506
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
   Component: E0380 Bedient  H01 0060
   Component: CD-Database  4949
Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000046963240
   Coding: 010850204041230004
   VCID: 468368D2F11C0B11143-8013
Address 6C: Back-up Cam. (J928)       Labels: None
   Part No SW: 4L0 907 428     HW: 7P6 907 441 D
   Component: TopView       H05 0293
   Revision: 11001001    Serial number: 82330JF0065782
   Coding: 020C010001000100000102000000
   ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
   ROD: EV_CamSysteCorneViewAUDI.rod
   VCID: 6ED3F072B12CE3518C3-803B
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Revision: --H57001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6CD7FA7A4F301141A27-8039
   Subsystem 2 - Serial number: 3"ó
   Subsystem 3 - Serial number: RD03.12.12--H57001002F0401ÿ
   Subsystem 4 - Serial number: 2F0401ÿ
                    Reset counter: 125
                    Mileage: 55864 km
                    Date: 2015.03.30
                    Time: 16:07:55
Address 6F: Centr. Conv. II        Labels: 4L0-910-290.lbl
   Part No SW: 4L0 910 290     HW: 4L0 907 290
   Component: ILM HINTEN 2    H08 0080
   Revision: AAH08080    Serial number: 129773020-----
   Coding: 0000001
   VCID: 65C18F5EACDA2009FD9-8030
                    Fault Frequency: 9
                    Reset counter: 152
                    Mileage: 55864 km
                    Date: 2015.03.30
                    Time: 16:07:58
Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000046963241
End-------------------------(Elapsed Time: 03:58)--------------------------
This codes gives me trouble
Thursday,14,May,2015,14:23:52:48102
Mileage:    Repair Order: q7 46 cp
Control Module Part Number: 4L0 910 289 K    HW: 4L0 907 289 K
  Component and/or Version: Komfortgeraet   H12 0130
           Software Coding: 3277197
            Work Shop Code: WSC 00000 000 00000
02084 - Component Protection
                    Fault Status: 01100101
                    Reset counter: 115
                    Time Indication: 1
            000 -  -
                    Reset counter: 115
                    Mileage: 59159 km
                    Date: 2015.05.13
                    Time: 12:26:48
Is there any solution for this to resolve with VCDS or I must take it to the dealer?
Thank you for any information provided.
Zenerdiode
Newcastle, England
C?ID=24330
Hello and welcome to the forum. ;)
Have you or a previous owner changed that module (46)? There are also lots of other modules complaining that they have lost comes with it too; suggesting it was disconnected with the battery still connected.
Either way, once Component Protection is activated; it may only be removed at a dealership with an online connection to the 'mothership'.
Have you got any other unusual symptoms? Devices not working as they should?
Gavra
Melbourne/Belgrade
C?ID=240855
They replaced module with 2 second hand ones with wrong index and then they bought new one and installed it. I was asked to transfer coding but boot closing isn't working with new 46,the rest is fine. This info is valuable to me because I don't like to waste time for nothing. Once again thank you for help with this problem ;)
