Tiguan 2 ESP OFF switch possible?
brundozg
Austria
C?ID=427444
Hello everyone,
I would like to install a button for turning ESP off/on. Currently the only option is to go through Infotainment menu to turn it off/on. I have blank spaces in the console next to gearshift lever and I found button 5NG927137A that could fit the console. Does anyone have an idea if such a tweak is possible?
car -> https://forums.ross-tech.com/index.php?threads/29196/#post-247075
@brundozg: according to THIS, registering the ESC button (after installation) with the hex03 module is done by setting the software switch on Byte 28, Bit 6.
Westbury, UK
I not convinced that even with the switch and coding you can actually turn ESP off - in most cases the options are ESP on and ESP Sport (i.e. still on but with higher thresholds). Having said that I believe that some Audi RS models could turn ESP fully off.
TBAx
C?ID=287144
You are right. The infamous ESC off setting pushes the thresholds even further, but still does not completely disable it.
brundozg
Austria
C?ID=427444
Sorry for incorrectly specifying my question. I wanted to say that if with button I can achieve the same functionality as via infotainment system, then I am happy.
@DV52 Thanks for your answer, I already ordered the button. I assume wiring diagram can be found on erWin?
@brundozg: With the sage caution as advised by @PetrolDave (and as confirned by @TBAx) understood, Yes erWin is your friend for the wiring changes.
PS: I created the very simplified wiring diagram below some time ago for another forum - it shows the general arrangement on MQB platform cars for the ESC button.
