FEC/SWaP (Enabling APPCONNECT Apple/Android) in MIB unit possible to add codes with OBD11 and ODIS but not VCDS--- WHY?
AINils
Germany (AIB)
C?ID=56975
This is correct one, otherwise you can see it in MVB "individualization....."
But both should be same number
   #142
Pvrple
NJ, USA
C?ID=573861
If I pm you my VCRN, would you be able to tell me what the 10-digit version of it would be? Please and thank you.
   #143
AINils
Germany (AIB)
C?ID=56975
Number is nothing special, you can write in public, as this number is just a "checksum" from all member of component protection in your car
  • Informative
Pvrple
NJ, USA
C?ID=573861
It's E59C77754
   #145
AINils
Germany (AIB)
C?ID=56975
could you maybe write with spaces, which are shwon in screen?
   #146
Pvrple
NJ, USA
C?ID=573861
On mine there aren't actually any spaces
   #147
downtime
Finland
C?ID=280813
Vcds, 5F meas block, invidividualization characteristics. There you get the correct one
   #148
Pvrple
NJ, USA
C?ID=573861
Meas. Blocks is greyed out for me...
   #149
downtime
Finland
C?ID=280813
Meas values or something else then. But there it is
   #150
Pvrple
NJ, USA
C?ID=573861
Thanks! It's 6E 59 C7 77 54. Can anyone link a website to generate FEC codes?
   #151
Pvrple
NJ, USA
C?ID=573861
ok for anyone who wants to enable an option, mine was voice control
here is how
***************************speak with the boss man (Uwe) for this instructions as its not allowed public.
1 go into 5F
************************** to get into EOL mode for FEC/SWAP (accept enter new session)
2 go into security access 16
enter code 20103 (security access granted) ok
3 enter adaptation 10
search box "swap" choose "IDE04330 - transfer of release code for a swap function"
enter fec code into "new value" box press "Do IT!" vcds will complain about value length, click YES, then YES again to accept
then YES again to have VCDS to use default values of 12345/123/12345.......controller should then accept the request click OK
FEC code should now show in "Stored Value" click "Go Back" button
4 go into Basic Settings 04
drop down box select IDE04327 - Activation of SWap function, click GO.....finished correctly....STOP, Done, Go Back
Close Controller
If your in the FEC menu on the stereo you should see the new FEC pop up in there as valid.
5 hold power button on stereo for 15 seconds until it reboots
6 hold menu button to go into service menu and check fec codes are valid
hope this clears up some confusion
thanks
dave
For me it says "Not Running" when I press go to activate the function
   #152
downtime
Finland
C?ID=280813
Sent you PM
   #153
wim_rommens
Belgium
C?ID=346110
Je kent de (p)ACC-oplossing. Dit is dus een manier voor verschillende situaties waarin gebruikers dit kunnen doen
You know (p)ACC solution. So this is a way for different situtation user can do this
Hello AINils,
Can you help me further with the (p)ACC solution.
I would like to convert the CC in my Superb 3 to an ACC. I have a 3Q0 front radar from the factory with extra coded - lane assist & TSR.
Thanks in advance!
   #154
downtime
Finland
C?ID=280813
On 3Q0 radar ACC possible only. If you want predictive acc you need to swap the radar.
   #155
wim_rommens
Belgium
C?ID=346110
Could you help me with this? Or help me on my way with some information or persons, links?
   #156
downtime
Finland
C?ID=280813
If you have suitable dongle, yes I can help remotely
   #157
wim_rommens
Belgium
C?ID=346110
I have VCDS HEX V2
   #158
downtime
Finland
C?ID=280813
Not suitable for this work
   #159
wim_rommens
Belgium
C?ID=346110
What do i need then?
   #160
SteveG
C?ID=281406 (2)
I'm wondering if anyone can help? I have contacted Uwe and got the information to access the EOL. I am following the instructions he sent but i don't get the pop up box asking me to confirm. I am trying to activate wireless car play and voice control.
Tuesday,24,June,2025,20:52:24:03313
VCDS Version: 25.3.1.1 (x64)
Data version: 20250415 DS365.0
VIN: WV1ZZZ2KZJX041853   License Plate: GL67
Mileage: 236340km-146854mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 13 15 16 17 19 25 42 44 46 52 5F 61 65
VIN: WV1ZZZ2KZJX041853   Mileage: 236340km-146854miles
65-Tire Pressure -- Status: Not registered 0011
Address 01: Engine (J623-DFSD)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 MH    HW: 04L 907 309 K
   Component: R4 2.0l TDI   H20 4090
   Revision: 8AH20---    CVN: 1A412AAFB866C2AD
   Coding: 0111001204250D090000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM20TDI01104L906016MH 001001
   ROD: EV_ECM20TDI01104L906016MH.rod
   VCID: 7BF5896CF2E991439F-802E
   VINID: 9E606AAAA09BA9AA001012050CF6D0B24C
Readiness: 0 0 0 0 X
   Revision: 00000000    Serial number: 62637000001860
   Coding: 1079409B9266A47F087D027B498525E379F100
   Shop #: WSC 35110 790 50316
   VCID: 3F8D3D7CA6714D63F3-806A
   Part No SW: 1K8 907 426 AR    HW: 1K8 907 426 AR
   Component: AC Manuell    H21 0909
   Revision: 00001002
   Coding: 0010004003
   VCID: 0305F18C8A19E983D7-8056
          B10AB F0 [00001001] - Too Low
                    Reset counter: 171
                    Mileage: 236321 km
                    Date: 2025.06.23.
                    Time: 09:10:48
   Part No SW: 5K0 937 086 AA    HW: 5K0 937 086 AA
   Component: BCM PQ35 M+   122 0186
   Revision: BD122001
   Coding: 161A583E8825E16AC88800829400896C0375C20842208360E48487000045
   Shop #: WSC 35110 377 00143
   VCID: 73E5A14CD2B9D903C7-8026
   Subsystem 1 - Part No: 2K2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 13091  26  0512
   Coding: 009795
   Subsystem 2 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 190917 04  47  0106
   Coding: 0228DD
                    Fault Status: 00101010
                    Reset counter: 214
                    Mileage: 236348 km
                    Date: 2019.11.15.
                    Time: 19:08:60
                    Voltage: 12.10 V
                    Reset counter: 214
                    Mileage: 236348 km
                    Date: 2019.11.15.
                    Time: 19:08:60
                    Voltage: 12.15 V
                    Reset counter: 214
                    Mileage: 236348 km
                    Date: 2019.11.15.
                    Time: 19:08:60
                    Voltage: 12.15 V
                    Reset counter: 214
                    Mileage: 236348 km
                    Date: 2019.11.15.
                    Time: 20:38:49
                    Voltage: 11.25 V
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Reset counter: 214
                    Mileage: 236348 km
                    Date: 2019.11.15.
                    Time: 19:09:03
                    Voltage: 12.10 V
   Part No SW: 1K8 919 465 A    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0480
   Revision: --------    Serial number: 39231726201819
   Coding: 0001050001
   ASAM Dataset: EV_EPHVA14VW364GP00 001007
   ROD: EV_EPHVA14VW364GP00_VW36.rod
   VCID: 377D555C8E4175233B-8062
   Part No SW: 7N0 907 572 C    HW: 7N0 907 572
   Serial number: 1109170438A6E0 Dataset Number: 0001
   Coding: 00000000FE0339
   ROD: EV_ACCBEGVW361.rod
   VCID: 36635858894B8C2B20-8062
   Part No SW: 2K5 959 655 B    HW: 2K5 959 655 B
   Component: VW10Airbag00K H08 0018
   Revision: --------    Serial number: 003V1005NMUT Dataset Number: 2KC003V__A_ 0765
   Coding: 00000000000000000000000000000000304B
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3B75496CB2695143DF-806E
   Serial number: 3497ARB405N4TRO6M1JK
   Serial number: 3507ARB405N4TRO65PTT
   Part No SW: 5K0 953 521 GE    HW: 5K0 953 569 BF
   Revision: FF010042    Serial number: 20170918300213
   Coding: 1082460008
   ROD: EV_SMLSNGVOLWSR8C_VW32.rod
   VCID: 75E19F54D4CDC733E9-8020
   Subsystem 1 - Part No SW: 2K0 959 442     HW: 2K0 959 442   Labels: 3C8-959-537.CLB
   Serial number: 2551720452701407BA1B
   Coding: 280000
   Part No SW: 2K5 920 976 E    HW: 2K5 920 976 E
   Component: KOMBI         H04 1107
   Coding: 710A031200
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
   VCID: 387F5660835F7A5B32-806C
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 140917F1000812
   Coding: 357431
   VCID: 7BF5896CFAE991439F-802E
                    Mileage: 236348 km
                    Date: 2019.11.15.
                    Time: 19:39:02
   Component: IMMO          H04 1107
   VCID: 6ADBBC288D7318CB74-803E
   Part No SW: 2K5 959 701     HW: 2K5 959 701
   Component: Tuer-SG         009 2144
   Coding: 0131632
   VCID: 71E9AB4468A5EB1335-8024
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 140    3501
   Revision: 00H22000
   VCID: 3979536470556353CD-806C
   Part No SW: 2K5 959 702     HW: 2K5 959 702
   Coding: 0131632
   VCID: 72EBA4486DA3D00BCC-8026
   Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
   Component: MU-S-ND-ER    H41 0468
   Serial number: VWZAZ2T5398970 Dataset Number: V03935264QL 0001
   Coding: 063307013C00000011111101008808001F0100C600200100CF
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 25418F1424EDF7B399-8070
   Component: Batt.regelung H56 1682
   Coding: 030F7873
   VCID: 71E9AB44A8A5EB1335-8024
   Subsystem 1 - Part No SW: 2K0 915 181     HW: 2K0 915 181
   Serial number: 75885800001709270817
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Component: RDK           122 0821
                    Fault Status: 01100101
                    Mileage: 236348 km
                    Date: 2019.11.15.
                    Time: 19:39:01
End-------------------------(Elapsed Time: 03:07)--------------------------
------------------------------8 Faults Found-------------------------------
