FEC/SWaP (Enabling APPCONNECT Apple/Android) in MIB unit possible to add codes with OBD11 and ODIS but not VCDS--- WHY?
   #41
golfi_vend
Tartu, Estonia
C?ID=195131
Tried it with Release 22.3 and still it only allows 1 Byte to be inserted.
Other inconvenience is that when pasting the bytestring it has to be separated by spaces.
Yes I can use Notepad++ and regex( find: (..) replace \1 ) to make the spaces, but still.
   #42
Spacewalker
Poland
C?ID=159607
..............is a time to enable EOL in VCDS ?
   #43
welshkaiboy
C?ID=654838
Just wondering if this has been looked at and will it become a feature on VCDS?
   #45
swenak
Czech Republic
C?ID=236893
Any news about this?;)
   #47
EOL is available, only data field lenght have to be fixed ;-)
This should be fixed in the latest 22.3.1.4 version on our download page. Feedback would be appreciated.
AINils
Germany (AIB)
C?ID=56975
Will try later after work If iam back at home
AINils
Germany (AIB)
C?ID=56975
Can't test it yesterday because was late at home. Will give it a try today
   #50
AINils
Germany (AIB)
C?ID=56975
Tried it yesterday in my Navigation System in Golf GTI MK7.5 with Discover Pro, and it worked like a charm. Thanks for applying it into VCDS. Next Step is uploading Dataset ;-)
   #52
welshkaiboy
C?ID=654838
So I have tried to do this but I keep getting channel out of range, can anyone help me please?
Tuesday,03,May,2022,13:31:11:65061
VIN: WVGZZZ5NZGW024863   License Plate: LATEST
Mileage: 136710km-84947mi   Repair Order:
Chassis Type: 5N-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 42 44 46 4C 52 53 5F 61 62
          72
VIN: WVGZZZ5NZGW024863   Mileage: 136710km-84947miles
Address 01: Engine (J623-CUVC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 CM    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 1842
   Revision: 8AH20---    CVN: FDC485C092F1EF3C
   Coding: 02190032042701082000
   ASAM Dataset: EV_ECM20TDI01104L906016CM 001004
   ROD: EV_ECM20TDI01104L906016CL_001_VW36.rod
   VCID: 76B5E5D23848DFEBE53-8022
   VINID: 9E65EAAAA15EA979C00842060C96D29303
   Part No SW: 5N0 614 109 BN    HW: 5N0 614 109 BN
   Component: J104   C6 450M VD63 0021
   Revision: --H07---    Serial number: 00000008933702
   Coding: 0040254
   VCID: 78A9EBEA3EDCA99BF7F-802C
   Part No SW: 1K8 907 044 AC    HW: 1K8 907 044 AC
   Component: Climatronic   H05 0304
   Revision: 00001K03
   Coding: 0010004003
   VCID: 70B9D3CA5A2CF1DB3FF-8024
   Part No SW: 5K0 937 086 T    HW: 5K0 937 086 T
   Component: BCM PQ35 M    122 0183
   Revision: BC122001
   Coding: 48180A3FE83FE1C040A800C0310081E44FF9AA88437D85206480C7000041
   VCID: 45D7521E35AE0473BC9-8010
   Subsystem 1 - Part No SW: 5N2 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 23071  013 0204
   Serial number: N2955119   °204!
   Coding: 009F95
   Component: RLS 140715 05  54  0403
   Coding: 06304D
   Subsystem 3 - Part No: 5C0 951 171
                    Fault Status: 00101010
                    Fault Frequency: 125
                    Reset counter: 139
                    Mileage: 134150 km
                    Date: 2016.08.02
                    Time: 09:31:23
                        Term 15 Off
                    Voltage: 12.35 V
                    Fault Frequency: 89
                    Reset counter: 137
                    Mileage: 134187 km
                    Date: 2016.08.03
                    Time: 09:54:20
                    Voltage: 10.20 V
                    Fault Frequency: 48
                    Reset counter: 110
                    Mileage: 134356 km
                    Date: 2016.08.05
                    Time: 08:03:40
                    Voltage: 11.60 V
   Part No SW: 1K8 919 475 B    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0479
   Revision: --------    Serial number: 39431519202835
   Coding: 0131061041
   ASAM Dataset: EV_EPHVA2CVW364GP00 001010
   ROD: EV_EPHVA2CVW364GP00.rod
   VCID: 392F2EEE49D67093C81-806C
   Component: J234__20E VW10 HI   2718
   Revision: 30021000    Serial number: 003L7PE3N9M+
   Coding: 0012357
   VCID: 7CA1F7FA0AE485BB937-8028
   Subsystem 1 - Serial number: 6332MTS628311805
   Subsystem 2 - Serial number: 6342MTS648971795
   Subsystem 3 - Serial number: 6351HTS6FTP5QDKJ
   Subsystem 4 - Serial number: 6361HTS6REA2QDKR
   Part No SW: 5K0 953 521 GF    HW: 5K0 953 569 BG
   Revision: FF010042    Serial number: 20150703300707
   Coding: 1082140000
   ROD: EV_SMLSNGVOLWSR8C.rod
   Serial number: 0857419
   Coding: 820000
   Part No SW: 5N0 920 983 K    HW: 5N0 920 983 K
   Component: KOMBI         H04 1007
   Coding: 111F010000
   VCID: 3D273AFE5DFE4CB3E49-8068
   Part No SW: 7N0 907 530 BE    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1674
   Revision:   H58       Serial number: 070715F1001918
   Coding: 356033
   Shop #: WSC 34274 001 1048576
   VCID: 74B1DFDA2EB4CDFBDB7-8020
   Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7531
   Serial number: HA1-00008.06.15
   Coding: 0001
   VCID: 52FD7942F460A3CB29B-8006
   Component: IMMO          H04 1007
   VCID: 6A8DC1A27CF00B0B71B-803E
   Part No SW: 5N0 959 701 G    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0504
   Revision: 12110009    Serial number: 0009876331
   Coding: 0212B6
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  009 1504
   Serial number: 00000009457409
   Coding: 000090
   Part No: 5N0 909 144 R
   Component: EPS_ZFLS Kl. 202    3501
   Revision: 00H22000
   Shop #: WSC 01324 785 00200
   VCID: 40D9430A268C215B8FF-8014
   Part No SW: 5N0 959 702 G    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0504
   Revision: 14110009    Serial number: 0009894372
   Coding: 0213B6
   VCID: 3A2D31E24CD07B8BC1B-806E
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  009 1504
   Serial number: 00000009460543
   Coding: 000090
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000000799618
   Coding: 0026167
   VCID: 38292BEA7E5C699B37F-806C
   Part No SW: 5C0 035 680 G    HW: 5C0 035 680 C
   Component: MU-S-ND-ER    H20 0478
   Serial number: VWZAZ2R8734444
   Coding: 02730601FF00000011111101008808001F0100C600208100CF
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 2517F29ED56EE4739C9-8070
   Subsystem 1 - Part No SW: 5NA 919 866 BS    HW: -----------
   Component: ECE1 2022/23  --- 1810
   Component: Batt.regelung H58 1674
   Coding: 030F1873
   VCID: 71BFD6CE51A6F8D3301-8024
   Component: J367-BDM  H07 0180
   Serial number: 32190159201496382227
End----(Elapsed Time: 01:26, VBatt start/end: 12.1V/12.1V. VIgn 12.0V)-----
   #53
welshkaiboy
C?ID=654838
Sorry @Uwe I was rushing.
I enter the security access code (not shown by VCDS) as 20103 and it is accepted.
I then try IDE04330 SWAP file activation and I get a channel out of range message.
I also looked at basic settings IDE04327-Activation on Swap and got the same error.
So I can't upload the 360 character SWAP code.
   #55
I suspect you're missing an important step and you might need to re-read the thread from the very beginning. ;)
welshkaiboy
C?ID=654838
I don't have Odis so can't unlock but I think this is the missing step:-
About IDE04331 - I mean, that this is for opening "possibility to transferring codes". This is not for entering that long installing code. If I remember, default is 00000000 and must be changed to FFFFFFFF before I can sending by other adaptation channel that long code.
Mine already shows FF FF FF FF but I will try to send again and then see if the error goes away.
   #57
AINils
Germany (AIB)
C?ID=56975
As I got some PN about proof and information, here are some Screenshot
   #59
swenak
Czech Republic
C?ID=236893
Maybe I do something wrong, but I still see only in IDE04330 "Error: Channel not Available". I have activated Developer mode, I have entered FF FF FF FF in IDE04331 (this I have changed in ODIS, in VCDS cant change it to 00 00 00 00). I have entered S12345 Security Code. I try to use S20103 too, but it is not accepted. When I try change some adaptation, that need to have entered Security Code and enter 20103, it work.
   #60
welshkaiboy
C?ID=654838
You need to speak nicely to Uwe via PM :D
