Mk7 GTI Databus Error U112300
Brandon94
Brisbane, Australia
Hey guys,
Ive got a 2014 Mk7 GTI (manual) I purchased damaged. The damage is repaired now but has the following problems preventing me from getting the road worth certificate for vehicle registration.
  • The tyre pressure monitoring system doesn't function
  • The auto stop start system doesn't function
  • The auto hold park brake doesn't function
  • Fault codes from OBD11 scan as follows
OBDeleven vehicle history log
Date: 2021-11-07 15:33:03
VIN: WVWZZZAUZEW323053
Car:
Year: 2014
Body type: D5 Hatchback
Engine: CHHB kW ( hp) l
Mileage: 156434 km
Full scan
Control Units: 16
Fault count: 7
Control Units:
08 Air Conditioning
System description: Climatronic
Software number: 5G0907044AA
Software version: 0805
Hardware number: 5G0907044AA
Hardware version: H02
Faults:
No trouble codes found
14 Wheel Dampening
System description: DAEMPFUNGS-SG
Software number: 5Q0907376
Software version: 0115
Hardware number: 5Q0907376
Hardware version: H15
Faults:
15 Airbag
System description: AirbagVW20
Software number: 5Q0959655D
Software version: 0385
Hardware number: 5Q0959655D
Hardware version: 014
Faults:
16 Steering Column
System description: Lenks. Modul
Software number: 5Q0953507AA
Software version: 0070
Hardware number: 5Q0953549
Hardware version: 007
Faults:
17 Dashboard
System description: KOMBI
Software number: 5G6920870
Software version: 2210
Hardware number: 5G6920870
Hardware version: 314
Faults:
19 Gateway
System description: GW MQB High
Software number: 5Q0907530Q
Software version: 1164
Hardware number: 5Q0907530F
Hardware version: 125
Faults:
42 Driver Door
System description: TSG FS
Software number: 5Q0959593B
Software version: 0025
Hardware number: 5Q0959593B
Hardware version: 020
Faults:
44 Steering Assistance
System description: EPS_MQB_ZFLS
Software number: 3Q0909144F
Software version: 5043
Hardware number: 3Q0909144F
Hardware version: 503
Faults:
52 Passenger Door
System description: TSG BFS
Software number: 5Q0959592B
Hardware number: 5Q0959592B
Faults:
55 Headlight Regulation
System description: AFS-ECU
Software number: 7P6907357D
Software version: 0090
Hardware number: 7P6907357A
Hardware version: H07
Faults:
5F Multimedia
System description: MU-S-N-ER
Software number: 5G0035846A
Software version: 0430
Hardware number: 5G0035846A
Hardware version: 040
Faults:
A9 Structure Borne Sound
System description: SAS-GEN 2
Software number: 5G0907159
Software version: 0013
Hardware number: 4H0907159A
Hardware version: H06
Faults:
09 Central Electrics
System description: BCM MQBAB H
Software number: 5Q0937084AE
Software version: 0124
Hardware number: 5Q0937084AE
Hardware version: H16
Faults:
B126215 - Headlamp washer system activation
Open circuit/short circuit to B+
static
Priority - 4
Malfunction frequency counter - 1
Unlearning counter - 98
km-Mileage - 156434 km
Terminal 15 status - On
Terminal 50 status - Off
Voltage - 13.9 V
Outside air temperature - 26.5 °C
Status Bremslichtschalter (HW) - Off
Status Bremslichtschalter (CAN) - Off
Off - not activated
Parking light - not activated
Automatic high beam assist - operated
Low beam - not activated
Parking light left - not activated
Parking light right - not activated
Letzte Weckursache/ Werte [00;2E] - Pin A44 Klemme 15
CAN-Bus aktiv - On
date - 2021-10-29 20:22:26
03 Brakes
System description: ESC
Software number: 5Q0907379AA
Software version: 0457
Hardware number: 5Q0907379G
Hardware version: H31
Faults:
B116807 - Steering angle sensor
mechanical malfunction
static
Priority - 2
Freezeframes - 0002001812000000C4000000000000F702430D01010010
date - 2021-10-29 20:23:51
C114602 - Tire pressure monitoring display
Signal error
static
Priority - 6
Freezeframes - 0002001832000000C5000000000000F702430001010010
date - 2021-10-29 20:24:00
C102D00 - Tire pressure warning
static
Priority - 6
76 Parking Assistant
System description: PARKHILFE 8K
Software number: 5Q0919294F
Software version: 0142
Hardware number: 5Q0919294A
Hardware version: H03
Faults:
U112300 - Databus error value received
static
Priority - 6
date - 2021-10-29 20:26:49
01 Engine
System description: 2.0l R4 TFSI
Software number: 5G0906259
Software version: 0007
Hardware number: 06K907425B
Hardware version: H13
Faults:
P188800 - Coolant shut-off valve
Short circuit to B+
Intermittent
Priority - 2
Unlearning counter - 255
Engine speed - 809.75 1/min
Normed load value - 10.2 %
Vehicle speed - 0 km/h
Coolant temperature - 47 °C
Intake air temperature - 42 °C
Ambient air pressure - 1000 mbar
Voltage terminal 30 - 14.199 V
Dynamic environmental data - 209628110E0211EC0111DC000811ED2410A6019911EE2211DB04A1
date - 2021-10-29 23:47:21
static
Priority - 6
Engine speed - 697.25 1/min
Normed load value - 7.1 %
Coolant temperature - 83 °C
Voltage terminal 30 - 13.828 V
Dynamic environmental data - 20962841690000416A0004416B0004
date - 2021-10-29 20:23:33
I'm kind of hoping someone on here can provide some insight. At face value the steering angle sensor has malfunctioned but I'm curious to know if it would cause the other issues I'm experiencing.
Additionally, is the steering angle sensor part of the steering rack or the clock spring and does it require programming to replace?
Any help would be greatly appreciated.
RGH0
Australia
C?ID=433612
This is a VCDS specific forum. You need to post your query on a general Golf or OBD11 forum or purchase an original VCDS cable :). However I am surprised any of those issues a RWC faults in Queensland ?
cheers
Rohan
  • Agree
Brandon94
Brisbane, Australia
Rohan,
Apologies, its the ESC light on the dash that is the main issue for the rwc. Seeing as the car requires a WOVR inspection I can't get away without sorting the light out :(.
Closing this thread. This forum owned and operated by Ross-Tech, the makers of VCDS. If you're using some other tool, please assistance from the makers of that tool.
