2018 Crafter DUAB error P0236, P0237
Marekkgb
C?ID=373174
Hi.
Crafter with P0236,P0237 error. We replaced MAP sensor, intake manifold and EGR.
After replaced reset system and live data showing 100 kPa manifold pressure.
For first 5-10 min drive ok but after on idle an errors appears and car loosing power.
Errors presents even on ignition On. Error detail showing :
,,Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 370 mbar''
Is the above pressure read by the MAP sensor?
The car haven't got charge pressure sender (boost sensor) - G447 - I was checked this with VW local dealer.
However with MAP sensor removed from intake manifold but connected only electrical and engine running and accelerate I can see with vcds ,,charge air pressure value is going up from 370 kPa to to 670 kPa.
Should I focus on MAP sensor ? I already checked 5 [V] reference and earth to connector is ok.
I can not find wiring diagram for this engine- If I know which pin of ecu connector is signal form MAP I possible can by-pass and test.
Or this is related to heater resistance in wiring
Thanks for any help
Marek
Tuesday,26,October,2021,17:54:01:31001
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: WV1ZZZSYZJ9037728   License Plate:
Chassis Type: SY-VN54 (3Q0)
Scan: 01 03 08 09 13 15 16 17 19 42 44 52 5F
VIN: WV1ZZZSYZJ9037728   Mileage: 136127km-84585miles
Address 01: Engine (J623-DAUB)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 NE    HW: 04L 907 445 C
   Component: R4 2.0l TDI   H01 5240
   Revision: 23201001
   Coding: 001940106324050800000000000000000000000000000000
   Shop #: WSC 00069 790 00034
   ASAM Dataset: EV_ECM20TDI03004L906056NE 005003
   ROD: EV_ECM20TDI03004L906056NE.rod
   VCID: 7DA7F9D30D76FF73CC7-8028
   VINID: 9E606AAAA8E9A9A2400C71C220BEC18DF6
30251 - Manifold Pressure / Boost Sensor (G31)
          P0236 00 [100] - Implausible Signal
                    Mileage: 136127 km
                    Date: 2021.10.26
                    Time: 17:48:20
                    Engine RPM: 0.00 /min
                    Coolant temperature: 78 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 12.484 V
                    Air filter outlet: pressure sensor 1 bank 1: raw value: 1000 mbar
                    Turbocharg.2 compress.outlet: press.sensor 1 bank 1: raw value: 0 mbar
                    Ambient air pressure sensor 1 bank 1: raw value: 1.011 bar
                    Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
                    Engine status: Stop
                    Outside temperature sensor 1: B1: raw value: 16.5 °C
                    Filtered value of IN_Dpf_dp_raw-CDPF Delta Pressure in hPa: 3.000 hPa
                    Particle filter: air pressure sensor 1 bank 1: raw value: 3.1 mbar
                    Accelerator pedal travel: raw value: 0.00 %
15985 - Manifold Pressure / Boost Sensor (G31)
          P0237 00 [167] - Signal too Low
                    Mileage: 136127 km
                    Date: 2021.10.26
                    Time: 17:29:37
                    Coolant temperature: 89 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 12.523 V
                    Ambient air pressure sensor 1 bank 1: raw value: 1.010 bar
                    Engine status: Stop
                    Outside temperature sensor 1: B1: raw value: 15.5 °C
                    Filtered value of IN_Dpf_dp_raw-CDPF Delta Pressure in hPa: 3.250 hPa
                    Particle filter: air pressure sensor 1 bank 1: raw value: 3.2 mbar
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 2N0 907 379 C    HW: 2N0 907 379 C
   Component: ESC_base      H02 0850
   Serial number: 08508403180318
   Coding: 29A824774840B689944E2462124B6D063DF10078
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN54X 701028
   ROD: EV_Brake1ESP90iBOSCHVN54X_701.rod
   VCID: 363526FF68C0EC2B4DD-8062
Address 08: Auto HVAC (J65)       Labels:* None
   Part No SW: 7C0 907 184 K    HW: 7C0 907 184 K
   Component: Heizung       H01 0301
   Coding: A03110000800030001000800500101000000000000000000000000000000
   Shop #: WSC 00069 790 00040
   ASAM Dataset: EV_AirCondiBHTCVN54X 003018
   ROD: EV_AirCondiBHTCVN54X_003_VN54.rod
   VCID: 323D1AEF84A8F00B615-8066
   Part No SW: 5Q0 937 084 CM    HW: 5Q0 937 084 CD
   Component: BCM MQBAB B   H36 0253
   Serial number: 01001807500758
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0557913365A6B7B3947-8050
   Component: ACCCONTIMQB   H02 0233
   Coding: 2A00400100FF8448949C814D003007
   VCID: 3E253EDF40F0246B95D-806A
   Part No SW: 3Q0 959 655 BG    HW: 3Q0 959 655 BG
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W3P5WHK19
   Coding: 800080000000000040000000008800000065
   ROD: EV_AirbaVW21TS6VW48X_VN54.rod
   VCID: 04518C376E9C8EBB839-8050
   Subsystem 1 - Part No SW: -----------    HW: 454 801 602 18
   Component: FrontSensor_D  305 0109
   Serial number: 35500D18C2C13000000M
   Subsystem 2 - Part No SW: -----------    HW: 454 801 602 18
   Component: FrontSensor_P  305 0109
   Serial number: 3560096F22C13000000L
   Part No SW: 5Q0 953 521     HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20180328400375
   Coding: 0000
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 6FBBD39B571A9DE34EB-803A
   Part No SW: 7C0 920 941 A    HW: 7C0 920 941 A
   Component: KOMBI         204 0310
   Coding: 27A411002080260001882A010400000000000000
   ROD: EV_DashBoardVDDMQBAB_VW27.rod
   VCID: 2411ECB7CE5C6EBBE39-8070
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007608203
   Coding: 030100044F05730000000000000F00010001070000000000000000000000
   GVL: 01503C0000000000400C80000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW27.rod
   VCID: 382928C762D41A5B5F1-806C
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 39180000248740128081
   Coding: 28FFFF
   Subsystem 3 - Part No SW: 2N0 915 181     HW: 2N0 915 181
   Serial number: 7588490000180306052F
   Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
   Serial number: 0000309641100
   Coding: 00300B208001040100001000
   VCID: 45D75133252677B3D47-8010
Address 44: Steering Assist (J500)       Labels:| 2N0-909-143.clb
   Part No SW: 2N0 909 143 E    HW: 2N0 909 143 C
   Component: EPS_MQB_ZFLS  701 7021
   Coding: 0107
   ASAM Dataset: EV_SteerAssisMNB 002001
   ROD: EV_SteerAssisMNB.rod
   VCID: 2F3B139B979ADDE30EB-807A
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Serial number: 0000311361708
   VCID: 44D14C372E1C4EBBC39-8010
   Part No SW: 3Q0 035 842 C    HW: 3Q0 035 842 C
   Component: MU-S-D-ER     722 0867
   Coding: 064500003C00000051110101008808001F0500C60120050003
   ROD: EV_MUStd4CDELP_VW27.rod
   VCID: 2D0709939D96AFF33C7-8078
   Subsystem 1 - Part No SW: 7C0 919 606     HW: 7C0 919 606
   Component: ABT_HIGH  H55 1031
   Serial number: VWZ8Z9V4U004B6
End----------(Elapsed Time: 00:45, VBatt start/end: 12.4V/12.4V)-----------
VWT6
Finland
C?ID=295527
For DAUB engine the reported sensor G31 (GX9) signal wire (green/purple all the way) connects into ECU connector T60e pin 39. Sorry but I'm not sure what's the referred MAP sensor.
However, I'm more inclined that the culprit is the sensor below
Engine stopped (or even idling) the raw value should read close ambient air pressure - near 1000 mbar.
I'm fairly confident the value doesn't curently change at all even engine is revved. I believe it can be read at IDE07738 also on this engine.
Marekkgb
C?ID=373174
VWT6- thanks for info -I will test signal wire tomorrow.
Marekkgb
C?ID=373174
VWT6 thanks for help. signal wire chafing against gearbox. Problem solved.Thanks
