Tuesday,02,November,2021,12:51:46:44946
VCDS Version: 21.9.0.2 (x64) HEX-NET2 CB: 0.4555.4
Data version: 20210903 DS330.0
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
76
Mileage: 335070km-208202miles
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 C
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 01317 785 00200
VCID: 2A066AD990E5D07BD95-5184
01312 - Powertrain Data Bus
014 - Defective
Part No: 6Q0 909 605 F
Component: 03 AIRBAG VW6 0202 0003
Coding: 12339
Shop #: WSC 01317
VCID: 3A265A99654560FBA95-5184
00532 - Supply Voltage B+
01222 - Crash Sensor Side Airbag; Passenger Side (G180)
37-00 - Faulty
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 905 J
Component: A4-KOMBIINSTR. VDO V04
Coding: 07232
Shop #: WSC 61120
VCID: 2E0E66C9A90DBC5B05D-5184
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0Y2617939
IMMO-IDENTNR: VWZ7Z0Y2617939
00771 - Fuel Level Sensor (G)
01316 - ABS Control Module
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.clb
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 01317
VCID: 70B2B8B173B9EAAB571-5184
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 01317
VCID: 065EFE69613DD41B9DD-4B1E
Subsystem 1 - Part No: 1J1959801C
Component: Tõrsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802D
Component: Tõrsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: Tõrsteuerger. HL0002r
Subsystem 4 - Part No: 1J4959812C
Component: Tõrsteuerger. HR0002r
11 Faults Found:
00949 - Central Locking Motor - tailgate (V53); LOCK
25-10 - Unknown Switch Condition - Intermittent
00953 - Interior Light Time limit
25-00 - Unknown Switch Condition
35-00 - -
00912 - Window Regulator Switch; Front Left (E40)
28-10 - Short to Plus - Intermittent
35-00 - -
Address 56: Radio Labels: 1J0-035-18x-56.clb
Part No: 1J0 035 180 D
Component: RADIO 3CP 0002
Coding: 02401
Shop #: WSC 01319
VCID: 201288F1E3D91A2B871-4B3C
End----------(Elapsed Time: 06:02, VBatt start/end: 12.1V/12.1V)-----------
