VW Transporter (T 5) 2.5 TDI: No response from controller
Mjøen
Norway
C?ID=448508
Hello.
After changing the clock spring on my car I was no longer able to use HEX-V2 to diagnose fault codes. When I go to Select Controle Module "No Response from Controller" pops on the display. However, when I perform Auto Scan, there are some controllers that get diagnosed, but far from all controllers. Before I changed the clock spring I was able to diagnose everything. The last time I was able to perform a proper Auto Scan, was before I upgraded the software to VCDS Release 21.9. If anyone has any idea on how to fix this problem I would be really grateful
Best regards Mjøen
Trowbridge, UK
We'll need to see both a previous Auto-Scan that showed all controllers, and a current one - please use the English version of VCDS (most of us don't speak Norwegian!) . If you're not using this already you can download from the Ross-Tech website and install it alongside any other language version you are using.
Mjøen
Norway
C?ID=448508
Thank you. Here are both the previous Auto-Scan and the current
Previous:
Saturday,07,August,2021,18:34:57:49333
VIN: WV2ZZZ7HZ5H069584   License Plate: UN 27458
Mileage: 71440km-44390mi   Repair Order:
          57 6E 76 77 78 7D
VIN: WV2ZZZ7HZ5H069584   Mileage: 71440km-44390miles
Address 01: Engine        Labels: 070-906-016-AXD.clb
   Part No SW: 070 906 016 AJ    HW: 028 101 156 8
   Component: R5 2,5L EDC 0000AG  7002
   Revision: 12345678    Serial number: VWZ7Z0E1329418
   Coding: 0001075
   Shop #: WSC 02756 785 00200
   VCID: 58E981CF7E0F609B973-513C
Readiness: 0 0 X X X
   Part No: 09K 927 750 H
   Component: AQ 250 6F           0620
   Coding: 0000008
   Shop #: WSC 02737 785 00200
   VCID: 3A2D3B47E043928B817-5118
Address 03: ABS Brakes        Labels: 7H0-907-37x-ESP-F.lbl
   Part No: 7H0 907 379 L
   Component: ESP FRONT MK25      0203
   Coding: 0006187
   Shop #: WSC 19616 003 1048576
   VCID: 3E253757FC6BBEABBDF-5118
Address 08: Auto HVAC        Labels: Redir Fail!
   Part No: 7H0 820 045 AC
   Component: CLIMA/AC            0303
   VCID: 6695BF37C47BC66B15F-5118
Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
   Part No: 7H0 937 049 L
   Component: BORDNETZ SGVER 1.0  1901
   Coding: 0000613
   VCID: 3B233E43EF79AB839A1-5118
   Part No: 1C0 909 605 A
   Component: 3C AIRBAG VW51      0008
   Coding: 13123
   Shop #: WSC 02756
   VCID: 221DE3276DD3FA4BB97-5118
            32-00 - Resistance Too High
01284 - Side Airbag; Drivers Side; Disabled
            35-00 - -
01285 - Side Airbag; Passenger Side; Disabled
            35-00 - -
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Part No: 7H0 920 850 S
   Component: KOMBI+WEGFAHRSP VDO V03
   Coding: 05112
   Shop #: WSC 35405
   VCID: 3A2D3B47E543928B817-5118
   WV2ZZZ7HZ5H069584     VWZ7Z0E1329418
Address 18: Aux. Heat        Labels: 7H0-819-008.clb
   Part No: 7H0 815 071 C
   Component: Standheizung        0207
   VCID: 2809F10F0EEF101BE73-5118
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 02756
   VCID: 70B9D96FF3BF18DB7F3-5118
Address 46: Central Conv.        Labels: 7H0-959-433.lbl
   Part No: 7H0 959 433 B
   Component: C2B Komfortgerát     0004
   Coding: 00073
   Shop #: WSC 02756
   VCID: 323D13673D336ACB497-4AE0
   Subsystem 1 - Part No: 7H1959801
   Component: Tõrsteuer.FS KLO 0203
   Subsystem 2 - Part No: 7H1959802
   Component: Tõrsteuer.BF KLO 0203
Address 6E: Ctrl Head Roof        Labels: Redir Fail!
   Part No: 7H5 919 044 E
   Component: DACHDISPLAY         0538
   Revision: 00800538    Serial number: 2009267.07
   Coding: 0000001
   VCID: 3431157FC22764FB5BB-5118
Address 76: Park Assist        Labels: 7H0-919-283.lbl
   Part No: 7H0 919 283
   Component: Parkingsyst. T5 T5N 401
   Coding: 01137
   Shop #: WSC 02756
   VCID: 6FBBDA13EE810723669-513C
Address 7D: Aux. Heat        Labels: None
   Part No: 7H0 819 002 K
   Component: Luftstandheizung, D 0426
   Revision: 00052426    Serial number:        0097616
   VCID: 2E0507172C0B4E2B2DF-4AE0
End----------(Elapsed Time: 05:33, VBatt start/end: 12.3V/12.2V)-----------
Current:
Monday,01,November,2021,21:31:03:49333
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
Mileage: 71509KM   Repair Order:
          57 6E 76 77 78 7D
   Coding: 0001075
   VCID: 58E981CF7E0F609BBF1-513C
   VINID: 9E60AAAAA1D8A85600189148103879FC82
   Coding: 0000008
   VCID: 3A2D3B47E043928BA95-513C
   Coding: 00073
   Shop #: WSC 02756
   VCID: 323D13673D336ACB615-4B00
   Coding: 01137
   Shop #: WSC 02756
   VCID: 6FBBDA13EE8107234EB-513C
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
            31-00 - Open or Short to Ground
01548 - Sensor for Parking Aid; Rear Right (G206)
   VCID: 2E0507172C0B4E2B05D-4B1E
End----------(Elapsed Time: 06:34, VBatt start/end: 14.3V/14.3V)-----------
I'm not seeing any obvious causes here. :confused:
DGMotors
C?ID=57532
Hello.
Best regards Mjøen
What about trying the old slip ring, or just disconnecting the new clock spring and try scanning again?
Mjøen
Norway
C?ID=448508
Thank you for the tip. The old slip ring was broken, due to a breakage of the wire. I have now done a scan with the new clock spring disconnected, but the result is the same as the scan I did Monday 1. Nov. Is there a chance there has been an error after updating the software? When the new clock spring is connected, the horn works. The horn did not function when the old clock spring was connected.
JMR
Romania , EU
C?ID=432218
:eek:What the hey is a clock spring on a T5 ??
JMR
Romania , EU
C?ID=432218
Aaa..jesus ...we call it " the spire " around here :))
