HVAC control unit in dash not showing any lights or displays
atikovi
C?ID=115538
But they work fine. 2005 Jetta MK5. Fan speed and temp change as I turn the knob but none of the lights in the knobs or buttons work and neither do the two small display screens. This just started recently.
This is the connector diagram:
There is 12V on the T20 connector pin 20. Are there other pins I should check for? Here is the scan:
Thursday,28,October,2021,12:25:23:53717
VCDS Version: 21.9.0.2 (x64)
VIN: 3VWDF71K95M643828   License Plate:
Mileage: 205140km-127468mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 47 52 56 62
          72
VIN: 3VWDF71K95M643828   Mileage: 205140km-127468miles
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 06A 906 032 QE    HW: Hardware No
   Component: 2.5l R5/4V      G   6656
   Revision: 00000000    Serial number: VWZ7Z0E2151112
   Coding: 0000003
   Shop #: WSC 00066 000 00000
   VCID: 71E323F86878CF033C-8024
Readiness: 0010 1100
   Part No: 09G 927 750 AS
   Component: AQ 250 6F           0649
   Coding: 0000008
   VCID: 02017C345DDEC49957-8056
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0021122
   VCID: 3A71C4D4758E4C594F-806E
   Part No: 1K0 907 044 AG
   Component: ClimatronicPQ35 066 0505
   VCID: 6CDD328C4F5A22E98D-8038
            002 - Lower Limit Exceeded
   Part No SW: 1K0 937 049 C    HW: 1K0 937 049 C*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000000070338
   Coding: F40D8E02400418000014000000140000002077035C
   VCID: 2F67E580BECC99F1E8-807A
   Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
   Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
   Component: SDAR XM         H03 0060
   Revision: 00000000    Serial number: AUZ4Z7E3024049
   VCID: 2B5FF1908AD4E5D1C4-807E
                    Fault Frequency: 8
                    Reset counter: 154
                    Mileage: 204656 km
                    Time: 02:34:51
   Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
   Component: 1S AIRBAG VW8R  024 6300
   Revision: 03024000    Serial number: 0037KD01Y0XP
   Coding: 0012627
   VCID: 2E59F884B9C690F9E3-807A
   Subsystem 1 - Part No: 1K0 959 339 B
   Component: BF-Gewichtsens. 006 0003
   Subsystem 2 - Serial number: 6332MSME08584B0AH
   Subsystem 3 - Serial number: 6342MSME085C5A6DV
   Subsystem 4 - Serial number: 6351HSME067D1A70B
   Subsystem 5 - Serial number: 6361HSME070A1007-
   Subsystem 6 - Serial number: 63727SME065A62683
   Subsystem 7 - Serial number: 63827SME065A4122Y
   Part No SW: 1K0 953 549 AC    HW: 1K0 953 549 AC
   Component: J0527           010 0045
   Coding: 0012041
   VCID: 73EF29F01264FD114C-8026
   Component: E0221           007 0050
   Part No: 1K0 920 971 C
   Component: KOMBIINSTRUMENT 3HL 2120
   Coding: 0023203
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H11 0110
   Revision: 11          Serial number: 290010532104F6
   Coding: 3F7F03620F1002
   VCID: 29530B988028F7C136-807C
   Part No SW: 1K5 919 965     HW: 1K5 919 965
   Component: Kompass         002 0001
   Revision: 00002000    Serial number: 0371356TP4DQ03
   VCID: 78F51EDC0B029E4979-802C
   Component: IMMO            3HL 2120
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 A    HW: 3C0 959 760 A
   Component: Sitzverstellung     0601
   Revision: 00002000    Serial number: 00000000000000
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2339
   Coding: 0001271
   VCID: 3669D0E44196A839AB-8062
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.3       1502
   VCID: 3065E6FCA3F28609F1-8064
   Part No SW: 1K0 959 433 AT    HW: 1K0 959 433 AT
   Component: 01 KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 13100F880106281B0906050FA0080F0490A540
                    Reset counter: 114
                    Mileage: 205143 km
                    Time: 00:16:21
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No: 1K6 035 456
   Component: 08K Audioverst.     0003
   Revision: 00002000    Serial number: 00000000029577
   VCID: 69D34B9840A837C1F6-803C
   Part No: 1K0 959 702 K
   Coding: 0001271
   VCID: 3777DDE0469C5131B0-8062
Address 56: Radio        Labels: 1K0-035-1xx-56.clb
   Part No SW: 1K0 035 180     HW: 1K0 035 180
   Component: Radio ZSW       015 0016
   Revision: 00015000    Serial number: VWZ5Z7E6277901
   Coding: 0010010
   VCID: 5DBB6F4884E05B610A-8008
00856 - Radio Antenna
                    Fault Frequency: 52
                    Reset counter: 114
                    Mileage: 204656 km
                    Time: 02:37:20
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2416
   Coding: 0000144
   VCID: 3163E3F8A8F88F01FE-8064
   Part No: 1K0 959 704 D
   Coding: 0000144
   VCID: 3261ECF4ADFEB41987-8066
End-------------------------(Elapsed Time: 02:02)--------------------------
NZDubNurd
New Zealand
C?ID=230482
These things have been known to fail like that - not super common, but I've seen it on forums several times.
For how cheap the control panel should be (used), it may be easier to buy a cheapo and try it anyway?
You need one for a heater with 2 re-circ motors (Generally, if it still has the ECON button, you should be fine. Later ones usually had the AC button instead and won't work correctly).
Since you have a fault that says, "Supply Voltage B+ -- Lower Limit Exceeded" I'll ask, did you load-test that wire?
Just because has 12V when it's unplugged from the module doesn't mean it can actually supply a the requisite amount of current.
Oh, and check your ground connection too.
atikovi
C?ID=115538
Ok I'll check that under load. And which pin is ground? I assume it would also be the only other large one next to #20 but there is no mention of pin #19 although it IS a ground. I'll check under load too. And #17 is sensor ground and #14 in T16g is potentiometer ground. Check those too?
$35 at the junk yard. Thought I might open this one up first to see if there are any cold solder joints or burned components.
atikovi
C?ID=115538
Nothing obvious internally. Would this one work? Has the DUAL button which mine doesn't.
atikovi
C?ID=115538
Got one from the junk yard. Works fine now.
