S3 8V VCDS coding
Frankyshiu
Hong Kong
C?ID=245708
Hi,
Audi emergency brake & RLFS both empty for S3 8V, any progress working ?
For emergency brake (previously in 09- C.E, Long coding Byte 16 ?)
For RLFS, i had a changed to 06885D, 06A8DD and 07E8DD ... still not working & empty under instrument.
Many thanks
Franky
auto scan here
Sunday,10,May,2015,09:21:21:35021
VCDS Version: 15.3.0.0
Data version: 20150314
VIN: WAUZZZ8V2EA105185   License Plate:
Mileage: 17661km-10974mi   Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 42 44 52 55 5F A9
VIN: WAUZZZ8V2EA105185   Mileage: 17661km-10974miles
Address 01: Engine (J623-CJXC)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 259     HW: 06K 907 425 A
   Component: 2.0l R4 TFSI  H09 0006
   Revision: --H09---
   Coding: 0A1D00322406010B3004
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM20TFS0218V0906259 001008
   ROD: EV_ECM20TFS0218V0906259.rod
   VCID: 7DB23179EC79A3D0AC-8028
   Part No SW: 0D9 300 011 R    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H52 4317
   Revision: 05852204    Serial number: TFK01311050883
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 2404241D2F53321883-8071
10657 - RPM Signal from ECU
          P0726 00 [002] - Implausible Signal
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Revision: 00000000    Serial number: 6318300000059E
   Coding: 32F193A254202A710178070841C8694CC92A5480E08296F6004100388608
   Shop #: WSC 32602 001 104857
   VCID: 7BB63F61F26DADE092-802E
8311 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 28
                    Date: 2015.05.03
                    Time: 16:21:57
   Revision: 00021000    Serial number: 0194742840
   Coding: 030C1C
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: 3A38FA65BDD754E8C9-806F
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Component: AC Automat    H13 0052
   Revision: 20026000    Serial number: 00000000194665
   Coding: 03100014110000011000000000001500
   VCID: 3228D24565A7ACA801-8067
   Part No SW: 5Q0 937 085 T    HW: 5Q0 937 085 T
   Component: BCM MQBAB HNA H16 0124
   Serial number: 00011330901169
   Coding: 07151C42C24106FD01844004B31C07A80800000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 4AD8AAA5ED37C46859-801F
   Slave 1:
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119
   Component: WWS370 131104  041 0580
   Serial number:         131107081908
   Coding: 0A47F7
   Slave 2:
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
   Serial number: 21965176
   Coding: 00006C
   Slave 3:
   Subsystem 3 - Part No SW: 8V0 941 531 G    HW: 8V0 941 531 G
   Serial number: 24 07 2013  00000487
   Serial number: 000000000ZY132802UQL
   Serial number: 00000000000028273518
   Subsystem 6 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.009  H02 0007
   Serial number:     WOO2530710Z
   Coding: 901E00
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H02 0033
   Revision: --------    Serial number: 94231332502157
   Coding: 0010050051
   ASAM Dataset: EV_EPHVA18AU3700000 002019
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 3B36FF61B2ED6DE0D2-806E
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8V0 907 376 B    HW: 8V0 907 376 B
   Component: DAEMPFUNGS-SG H08 0065
   Serial number:       071013943
   ASAM Dataset: EV_AudiMagneRide 002002
   ROD: EV_AudiMagneRide_AU37.rod
   VCID: 40CC888DDB0B0E3887-8015
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    011 0361
   Serial number: 003M2R0417UA
   Coding: 98CCC000000000005C54000000C800000065
   VCID: 4BD6AFA1E24DDD6062-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 003 010 13
   Serial number: 35767000000BAA982E06
   Subsystem 2 - Part No SW: -----------    HW: 480 003 010 13
   Serial number: 35867000000FAA982E0B
   Subsystem 3 - Part No SW: -----------    HW: 480 401 511 13
   Serial number: 3516502A11230BC2D20-
   Subsystem 4 - Part No SW: -----------    HW: 480 401 511 13
   Serial number: 3526502A11230BC4210R
   Subsystem 5 - Part No SW: -----------    HW: 480 400 410 13
   Serial number: 3556502AB1142C851263
   Part No SW: 8V0 953 521 CF    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 11111308490454
   Coding: 8418
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 004C488D9B8BCE38C7-8055
   Part No SW: 8V0 920 870 P    HW: 8V0 920 870 P
   Component: KOMBI         H03 2220
   Coding: 278D081ABB8000081801AA00100000
   VCID: 48DC90ADF33B36784F-801D
Address 19: CAN Gateway (J533)       Labels: Redir Fail!
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001276584
   Coding: 030100042B085A005B0002689C0B00000001000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_AU37.rod
   VCID: 3FCE8B71A6F571C0FE-806A
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 04 11 2013  E0280787
   Serial number: 3789161803
8531970 - Quiescent Current
          U1406 00 [008] - Too High
                    Reset counter: 74
                    Mileage: 17438 km
                    Date: 2015.05.03
                    Time: 16:33:29
Address 22: AWD
   Revision: 00000000    Serial number: 13000251275005
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 3424D45D9FB3A29813-8061
   Serial number: 09111304080358
   Coding: 005D1E205C01040000001002
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8103
   ROD: EV_SteerAssisMQB.rod
   VCID: 3522E95994C9BB9024-8060
   Serial number: 13111302090721
   Coding: 005D16205E01040000001002
   Part No SW: 7P6 907 357 B    HW: 7P6 907 357 B
   Component: AFS-ECU       H01 0040
   Coding: 01A600002B200200
   ASAM Dataset: EV_HeadlRegulLEDAFSMQB 001001
   ROD: EV_HeadlRegulLEDAFSMQB.rod
   VCID: 3E30F675A1FF78C8F5-806B
   Subsystem 1 - Part No SW: 7PP 941 472 E    HW: 7PP 941 472 E
   Component: LED LeiMo li.  H06 7520
   Coding: E00100
   Subsystem 2 - Part No SW: 7PP 941 472 E    HW: 7PP 941 472 E
   Component: LED LeiMo re.  H06 7520
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
   Component: LeiMo links  H01 7000
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M
   Component: LeiMo rechts  H01 7000
   Coding: E00100
   Part No SW: 8V0 035 850 B    HW: 8V0 035 850 B
   Component: MU-S--CN      040 0931
   Serial number: A3603010130619
   Coding: 017303000000000021150002000A00002F0002660100010000
   ROD: EV_MUStd4CPASE_AU37.rod
   Seat Adjustment Driver Side:
   Subsystem 1 - Part No SW: 8V0 919 603 B    HW: 8V0 919 603 B
   Component: DU Std  H48 0013
   Serial number: AUZ8Z9DM700KVY
   Sound System:
   Subsystem 2 - Part No SW: 8V0 919 614 C    HW: 8V0 919 614 C
   Component: ControlUnit_B  H33 0037
   Serial number: C1000006091300010106
6669 - Optical Data Bus for Digital Sound System
          U10CC 00 [008] - Intermittent Disruption
                    Reset counter: 69
                    Mileage: 17438 km
                    Date: 2015.05.07
                    Time: 21:09:06
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0008
   Serial number: 131029200095
End-------------------------(Elapsed Time: 02:55)--------------------------
Frankyshiu
Hong Kong
C?ID=245708
anyone can help for this .... ?
lala30
Croatia
C?ID=71949
in Audi you can not do it!
only skoda , vw and seat
in audi is different rain sensor...
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Correct, the installed Rain/Light Sensor doesn't support rain closing as far as we know. There's gonna be an updated Beta 15.5 soon, please try that and post a fresh Auto-Scan. :)
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Love the "seem" part. :) I see one statement that "some" module did accept the coding, no indication which part numbers and software levels we're talking about. In other words, not much to work with.
DJAlix
London, United Kingdom
C?ID=238277
I have managed to get Automatic Rain Closing for Windows only working on the 8V. All my information is in the forum post linked above, on page 23.
Currently there seems to be no obvious way of getting the Rain Closing feature to include a sunroof if you have one fitted.
Coding for the RFLS = 07006C:
Byte 0 = The Sum of all activated features and adjustments
Bit 0 = Highway Light Function
Bit 1 = Rain Light Function
Bit 2 = Rain Closing
Bits 3 to 5 = Light Activation Threshold earlier (+20% to +80%)
So 07 = Bits 0, 1 and 2 are Active.
Byte's 1 and 2 (combined) = Vehicle Model
XX9597 = A Seat Alhambra
XX805D = A Skoda Octavia
XXA8DD = A VW Golf (mk7)
XX006C = A Audi A3
*These are the only known Vehicle codes I have found so far.
There is also an issue with getting the MMI Menu Option for Rain Closing to display. I have not managed to do this yet :(
Sebastian, I am more than willing to supply any information that would assist in getting this working. Just need to know what you guys need.
m_bolc
San José, Costa Rica
C?ID=230356
I can confirm that automatic rain closing is possible with the 8V. I have an A3, but I do not think that Audi would fit a different sensor on the S3.
My coding is 06885D. Here is an autoscan from my car:
Wednesday,18,March,2015,18:16:45:29892
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: WAUZZZ8V2FA000583   License Plate: TRB043
Mileage: 16769km-10419mi   Repair Order:
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WAUZZZ8V2FA000583   Mileage: 16769km-10419miles
Address 01: Engine (J623-CJZA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 B    HW: 04E 907 309 A
   Component: 1.2l R4 TSI   H08 6387
   Revision: WAH08---
   Coding: 02110012230400082000
   ASAM Dataset: EV_ECM12TFS01104E906016B 001008
   ROD: EV_ECM12TFS01104E906016B.rod
   VCID: 2149CBAF30BD2E29405-8074
   Revision: 00000000    Serial number: 606040000015FD
   Coding: 10F16AA224200A6C017C060841C62508562450806082A4B2002100388608
   VCID: 7BF5D9C7F291A4F93A9-802E
16401 - Tire Pressure Warning
          C102D 00 [008] -  -
                    Reset counter: 25
                    Mileage: 16480 km
                    Date: 2015.03.11
                    Time: 17:35:57
Address 08: Auto HVAC (E87)       Labels: 8V0-820-047.clb
   Part No SW: 8V0 820 047 D    HW: 8V0 820 047 D
   Component: AC Manuell el H11 0052
   Revision: 20021000    Serial number: 00000000054640
   Coding: 00000004100000000000000000000100
   ASAM Dataset: EV_AirCondiFrontManAU37X 008018
   ROD: EV_AirCondiFrontManAU37X.rod
   VCID: 377D05F78E3940999E1-8062
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 084 AC    HW: 5Q0 937 084 AC
   Component: BCM MQBAB M   H16 0124
   Serial number: 00011406500433
   Coding: 04040842C001027D07044004F30407000000000000000000000000000000
   VCID: 79F9C3CFF8AD96E9285-802C
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119
   Component: WWS370 140225  041 0580
   Serial number:         140227184035
   Coding: 0A47F7
   Subsystem 2 - Part No SW: 8U0 955 559 A    HW: 8U0 955 559 A
   Component: G397_RLS  H06 0002
   Serial number: 20143063
   Coding: 06885D
   Subsystem 3 - Part No SW: 8V0 941 531 Q    HW: 8V0 941 531 Q
   Serial number: 29 11 2013  00001158
   Serial number: 000000000ZY140231TB1
   Serial number: 00000000000058976888
   Serial number: 003M2R05LNY8
   Coding: 98CCC000000000005C540000004800000065
   VCID: 4B954907E2B1D479CA9-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 001 702 14
   Serial number: 35767000000685500F0O
   Subsystem 2 - Part No SW: -----------    HW: 480 001 702 14
   Serial number: 35867000000885500F0R
   Subsystem 3 - Part No SW: -----------    HW: 480 400 703 14
   Serial number: 35165029F14D3E72E40M
   Subsystem 4 - Part No SW: -----------    HW: 480 402 802 14
   Serial number: 3526502C112F6291710.
   Subsystem 5 - Part No SW: -----------    HW: 480 400 702 14
   Serial number: 3556502C513013F3D10/
   Part No SW: 8V0 953 521 BM    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 07031404220752
   Coding: 0608
   VCID: 0603B833B953E911557-8053
227387 - Windshield Wiper/Washer Switch
          B1149 13 [009] - Open Circuit
                    Reset counter: 239
                    Mileage: 16474 km
                    Date: 2015.03.11
                    Time: 16:26:36
   Part No SW: 8V0 920 860 E    HW: 8V0 920 860 E
   Component: KOMBI         H02 2220
   Coding: 07850200238000080500BA00100000
   VCID: 3C771ADBB71F63C1733-8069
   Part No SW: 5Q0 907 530 P    HW: 5Q0 907 530 E
   Component: GW MQB Mid    124 1164
   Revision: --------    Serial number: 0001674704
   Coding: 01010008200864005B000208000B00000001000000000000000000000000
   ROD: EV_GatewLear.rod
   VCID: 3E7310D3A10371D15D7-806B
   Subsystem 2 - Part No SW: 8U0 951 528     HW: 8U0 951 528
   Serial number: 20 02 2014  B1311502
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 22021403110883
   Coding: 00100E20CD00040100001002
   Component: EPS_MQB_ZFLS  122 1043
   Coding: 0902
   ROD: EV_SteerAssisMQB_AU37.rod
   VCID: 41896B2FD0FD0E29205-8014
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 04031403110700
   Coding: 00100620CD00040100001002
   VCID: 3D7117DFAC056AC944D-8068
   Part No SW: 8V0 035 840 B    HW: 8V0 035 840 B
   Component: MU-S--ER      040 0420
   Serial number: A3E00403140672
   Coding: 01730000FF0A000021220001001A00002F0001440100010002
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE.rod
   VCID: 346732FB9F4FAB81BB3-8061
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0013
   Serial number: AUZ8Z9DY301DHC
   Sound System:
   Subsystem 2 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Serial number: C1000019021400010341
End-------------------------(Elapsed Time: 02:51)--------------------------
Frankyshiu
Hong Kong
C?ID=245708
great to hearing this...
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Frankyshiu, your car has the RLFS/RLHS (Rain, Light & Humidity Sensor). m_bolc, your car has the RLS (Rain, Light Sensor).
So we're still talking about different parts/sensors.
Frankyshiu; from the auto-scan report on your first post, it seems that your RLFS is 8U0 955 559 . This the same number as reported in a post by DJAlix who apparently owns an Audi A3 and who was able to get Auto rain-close to work on his car (albeit he had subsequent problems with his sun-roof closing). It might be of value reading this post HERE
m_bolc
C?ID=230356
Ahh, my bad.
What does the humidity sensor portion of the part do? I pressume it is for the climate control?
Frankyshiu
Hong Kong
C?ID=245708
Thanks Sebastian, DV52 and m_bolc , let me have a look and try tonight
Frankyshiu
Hong Kong
C?ID=245708
had a tried to code to 06885D/07006C , still no any item on screen, was blank....
how you can let the items popup ? DV52 .. i see your posted.
Frankyshiu: 您好 . Not certain that I entirely understand your question, but I'm assuming that you are asking how to show the options in the Long Coding Helper screen. What you need to do is to click on the "down-arrow" tab at the RHS of the screen. I have highlighted this on the picture below
Cheers
Frankyshiu
Hong Kong
C?ID=245708
My drives is S3, and i changed the code from 00006C to either 06885D or 07006C , still not showing anything under RLS
ie "Byte 0 - bit 0 - 5 empty ... Byte 1-2 Bit 0-15 empty as well...
Frankyshiu
Hong Kong
C?ID=245708
was blank, not as same as your attached.... Thanks again DV52
DJAlix
C?ID=238277
There is currently no label file for the A3/S3 RLFS :( You have to enter the coding manually and tick the bit's blind for the moment. Also there seems to be no way of getting / forcing the MMI Rain Closing Menu to show as there is no way to force a factory reset on the MMI "CAR" section.
I currently have my A3 coded, manually, as 07006C and rain closing works for all the windows but not the sunroof.
Frankyshiu
Hong Kong
C?ID=245708
Thanks guys !!
Frankyshiu
Hong Kong
C?ID=245708
any idea on "Audi emergency brake light" mate ? active when braking hard and flashing in rear lamps.
