- Oct 25, 2021
- 6
- 2
- Fayetteville, GA, USA
- C?ID=193546
Hi, everyone new to this forum. I have been using vcds for very long time just haven't been on forum. I'm having problem with coding new abs module from dealer. Part #S are the same except the last letters AH 1K0-907-375-AH. Tried to re code with old long number & also added two digits at end of the string making it 38 numbers, still won't accept it. old # 113b400d49250003880c02ed922200413000. vin: 3VWRM71K69M039199. I did ck engine , instruments , & immobilizer for correct vin coding. Can anyone help me with this problem, please!
Tuesday,26,October,2021,10:35:55:36288
VCDS Version: 21.9.0.2 (x64) HEX-NET2 CB: 0.4555.4
VIN: 3VWRM71K69M039199 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRM71K69M039199 Mileage: 217860km-135371miles
15-Airbags -- Status: Malfunction 1010
Address 01: Engine (CBT) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 Q HW: 07K 906 055 M
Component: 2,5l R5/4V G 3256
Revision: G6H02--- Serial number: VWX7Z0H724C0AT
Coding: 0000071
Shop #: WSC 00066 000 00000
VCID: BC2ADCF77A63FBEB3B9-80E8
VINID: 0E69E274705B1897400C904924DB3DFA0F
049441 - No Communication with ABS Brake Control Module
U0121 - 000 - - Intermittent
Fault Frequency: 221
Mileage: 217851 km
Time: 00:44:49
RPM: 770 /min
Load: 18.8 %
Temperature: 87.0°C
Temperature: 60.0°C
Absolute Pres.: 970.0 mbar
Voltage: 13.081 V
049153 - Powertrain Databus
U0001 - 000 - Unspecified Malfunction - Intermittent
Mileage: 217851 km
Time: 01:01:44
Temperature: 85.0°C
Temperature: 57.0°C
Absolute Pres.: 960.0 mbar
Voltage: 11.430 V
U0155 - 000 - - Intermittent
Mileage: 217851 km
Time: 01:12:27
Temperature: 79.0°C
Temperature: 54.0°C
Voltage: 12.700 V
049682 - Steering Column Control Module
U0212 - 000 - No Communications - Intermittent
Mileage: 217851 km
Time: 01:12:27
Temperature: 79.0°C
Temperature: 54.0°C
Voltage: 12.700 V
006481 - Radiator Fan 2 (V177)
P1951 - 000 - Movement Restricted / Jammed - Intermittent
Mileage: 217851 km
Time: 23:20:39
RPM: 685 /min
Load: 18.8 %
Temperature: 86.0°C
Temperature: 78.0°C
Voltage: 13.081 V
049489 - No Communications with Airbag Control Module
U0151 - 000 - - Intermittent
Mileage: 217867 km
Time: 00:21:49
RPM: 751 /min
Load: 21.2 %
Temperature: 52.0°C
Temperature: 19.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.462 V
Readiness: 0000 0100
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H31 0107
Revision: 00H31001
VCID: F8A200E702DB17CB1F1-80AC
00003 - Control Module
Fault Status: 01100101
Count: 16387
Count: 1
Count: 16896
Count: 143
Count: 22016
Count: 65280
Count: 16387
Count: 1
Count: 16896
Count: 195
Count: 22016
Count: 65280
Reset counter: 175
Count: 16387
Count: 1
Count: 16896
Count: 279
Count: 22016
Count: 65280
Reset counter: 175
Count: 16387
Count: 1
Count: 16896
Count: 295
Count: 22016
Count: 65280
Reset counter: 175
Count: 16387
Count: 1
Count: 16896
Count: 270
Count: 22016
Count: 65280
Part No SW: 1K0 820 047 HS HW: 1K0 820 047 HS
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: FCAA1CF73AE33BEB7B9-80A8
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000001048603
Coding: 14058E234004150007140000001400000008730B5C000120000000000000
VCID: B236F2CFA8273D9BE15-80E6
Component: Wischer 260808 021 0501
Coding: 00038805
Shop #: WSC 00066
Fault Status: 00100001
Reset counter: 214
Mileage: 217867 km
Voltage: 17.60 V
Reset counter: 211
Mileage: 217851 km
Voltage: 5.00 V
Reset counter: 212
Mileage: 217851 km
Voltage: 5.00 V
00154 - Windshield Wiper Motor; Passenger Side (V217)
Reset counter: 215
Mileage: 217851 km
Voltage: 9.00 V
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
Reset counter: 215
Mileage: 217851 km
Voltage: 9.00 V
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0402057
Coding: 0000100
VCID: B338F7CB573D3493EA3-80E6
7 Faults Found:
Fault Status: 00101110
Reset counter: 192
Mileage: 127227 km
Time: 16:15:12
Reset counter: 215
Mileage: 217867 km
Time: 00:02:43
Voltage: 17.70 V
Reset counter: 214
Mileage: 217867 km
Time: 22:40:25
Voltage: 8.40 V
Reset counter: 214
Mileage: 217867 km
Time: 22:40:25
Voltage: 8.40 V
Reset counter: 214
Mileage: 217867 km
Voltage: 19.20 V
Fault Frequency: 27
Reset counter: 65
Mileage: 155660 km
Time: 22:43:54
01304 - Radio
Fault Frequency: 88
Reset counter: 52
Mileage: 205103 km
Time: 12:03:41
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M06GSEK
Coding: 0013889
VCID: EC8A2CB74A83AB6BEB9-80B8
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME375438618
Subsystem 3 - Serial number: 6342MSME3B326B56J
Subsystem 4 - Serial number: 6351HSME174A2D74F
Subsystem 5 - Serial number: 6361HSME173F0B34C
Subsystem 6 - Serial number: 63727SME17456533.
Subsystem 7 - Serial number: 63827SME1747151E1
Part No SW: 1K0 953 549 BR HW: 1K0 953 549 BR
Component: J0527 051 0101
Coding: 0000021
VCID: 8358670B471D44133A3-80D6
015 - Cannot Be Tested at this Time - MIL ON
Part No SW: 1K0 920 954 S HW: 1K0 920 954 S
Component: KOMBIINSTRUMENT 3HL 1222
Revision: V0003000 Serial number: VWX7Z0H724C0AT
Coding: 0023203
Fault Frequency: 24
Reset counter: 215
Mileage: 217859 km
Time: 01:27:59
Reset counter: 215
Reset counter: 214
Mileage: 217867 km
Time: 22:28:54
Reset counter: 214
Mileage: 217867 km
Time: 00:00:05
Reset counter: 214
Mileage: 217867 km
Time: 22:28:54
Reset counter: 214
Mileage: 217867 km
Time: 00:21:49
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 010708F2001075
Coding: E9807F070003021002
VCID: B53CC9D359492AA3C47-80E0
Fault Status: 00110100
Fault Frequency: 28
Reset counter: 215
Mileage: 217859 km
Time: 01:28:00
Reset counter: 214
Mileage: 217867 km
Time: 00:21:50
01304 - Radio
Reset counter: 173
Mileage: 217851 km
Time: 23:17:46
Reset counter: 214
Component: IMMO 3HL 1222
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000796688806
Coding: 0001205
VCID: EFB03BBB7B955073CEB-80BA
Reset counter: 215
Mileage: 217867 km
Reset counter: 214
Mileage: 217867 km
Reset counter: 176
Mileage: 217851 km
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 69 2301
Revision: 00H15000
VCID: AA06EAAF80F7755B595-80FE
Fault Frequency: 11
Reset counter: 225
Mileage: 217867 km
Time: 04:27:12
Voltage: 13.63 V
DU
Temperature: 23.0°C
RPM: 826 /min
Speed: 50.0 km/h
Speed: 50.0 km/h
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 13.8 V
PD
Temperature: 21.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 13900F880186281B0904058FB0880F0488DCA0
VCID: 845A64174213432B039-80D0
Reset counter: 215
Mileage: 217851 km
Time: 02:58:12
Reset counter: 214
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 00000045888724
Coding: 0001204
VCID: F0B238C766AB4F8BD71-80A4
Reset counter: 215
Mileage: 217851 km
Reset counter: 214
Mileage: 217867 km
Reset counter: 176
Mileage: 217867 km
Address 56: Radio
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003383239
Coding: 0001168
VCID: F6BE0EDF04CF61BB0DD-80A2
Component: RDK 0450
Coding: 0100101
00625 - Vehicle Speed Signal
Fault Status: 00111000
Reset counter: 215
Mileage: 217867 km
Time: 00:01:12
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003384522
Coding: 0001168
VCID: F7A003DB03C518B316B-80A2
End----------(Elapsed Time: 01:42, VBatt start/end: 12.1V/12.2V)-----------
