Loose connector in D Pillar
RobM75
Cleveland, OH, USA
C?ID=497342
Hi all,
My first post here. My car is a 2014 Audi A4 premium (concert radio).
VCDS scan (below) shows code 02983 - Open connection between Window Antenna and impedance converter 1
I pulled the right D pillar trim and found a loose connector from the window antenna. Before I took the pic, the connector was just sitting inside the square hole that's above it. I'm confused because it looks like it wasn't connected to anything. Could it have been connected to a wire harness that has fallen down inside the pillar? If so, is there any way to retrieve it? Thanks for any tips/help. Rob
Thursday,21,October,2021,18:37:04:22093
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: WAUBFAFL8EN036640   License Plate:
Mileage: 109280km-67903mi   Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 44 46 47 52 53 56 62 72
          77
VIN: WAUBFAFL8EN036640   Mileage: 109280km-67903miles
Address 01: Engine (DET-CPMB)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115 N    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0005
   Revision: ECH09---    CVN: FE64ECCA
   Coding: 4A2A0013242600062000
   Shop #: WSC 06243 002 1048576
   ASAM Dataset: EV_ECM20TFS0118K5907115N 001006
   ROD: EV_ECM20TFS0118K5907115N.rod
   VCID: 3D2731518DF4CA338C7-8068
   VINID: 9D195259159C2157800C61840042937478
   Part No SW: 8K0 927 158 T    HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H16 1005
   Revision: --H16---    CVN: 1A6EAFCC
   Coding: 000002
   VCID: 47CB53B9DF2890E326B-8012
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 2D1D1801
   Shop #: WSC 02391 785 00200
   VCID: 094F9581893C2693F0F-805C
   Part No SW: 8K0 907 064 JL    HW: 8K0 907 064 JL
   Component: BCM2 2.0      H14 0650
   Coding: 09814040000000000000
   VCID: 035387A9AB107CC3BA3-8056
   Subsystem 1 - Part No SW: 8K0 959 754 F    HW: 8K0 959 754 F
   Serial number: 0514000034468003
   Serial number: 0214000041893003
   Part No SW: 8K1 820 043 R    HW: 8K1 820 043 R
   Component: KLIMA 1 ZONE  H02 0123
   Revision: A1000000    Serial number: 01050320141892
   Coding: 6480208000
   VCID: 372B2379AF48E06356B-8062
   Part No SW: 8K0 907 063 DF    HW: 8K0 907 063 DF
   Revision: 06016001    Serial number: 00000064192702
   Coding: 26000091863CAFC00000480300003D0D0F1C530822090221000004004000030100000000000000
   VCID: 76B5EE7DE8C2596B8DD-8022
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA140214  H18 0461
   Serial number: 1402130703035
   Coding: 004577
   Serial number: 22340776
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000103140455
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555RADX403
   Subsystem 5 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: 81A80717000000000001
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003KJDC020XG
   Coding: 303844354730303030304A55304C384B3053
   Shop #: WSC 10125 002 1048576
   VCID: 4ACD6A8DCC3A6D8B395-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R140000JENK
   Serial number: 6334MSME422D6941E
   Serial number: 6344MSME422D1877I
   Serial number: 6352QSME1D3F2078Q
   Serial number: 6362QSME2E434174H
   Serial number: 63732SME613E414A%
   Serial number: 63832SME693E41767
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NC7001HE
   Coding: 000016
   VCID: 48C95085D2B69F9B2F1-801C
   Part No SW: 8K0 920 951 E    HW: 8K0 920 951 E
   Component: KOMBIINSTR.   H09 0564
   Revision: 00200000    Serial number: ZA162663F
   Coding: 8B9609000301D705020000
   VCID: 323D126D442A054B615-8066
   Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0060
   Revision: 1V090029    Serial number: 2941V142240712
   Coding: 80C303FF00
   Serial number: 2355382703
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020302
   VCID: 392F2541995CF613A0F-806C
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 011C03204000410001
   VCID: 56F58EFD0802396BADD-8002
   Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
   Component: RCEPS         H40 0508
   Revision: 00001000    Serial number: 0001355184
   Coding: 100000000001
   ASAM Dataset: EV_RCEPSAU48X 008015
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 35372971B5C41273447-8060
   Revision: 00002001    Serial number: 0329506629
   Coding: 0106023A00FA400480B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000808859
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 98
                    Mileage: 109211 km
                    Date: 2021.10.19
                    Time: 16:57:15
   Part No SW: 8R1 035 223 A    HW: 8R1 035 223
   Component: DSP STD       H08 0230
   Revision: 26S00000
   Coding: 0203010102
   VCID: 2B030F0963005483223-807E
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   VCID: 55F789F115043273A47-8000
   Component: EPB-4         H01 0005
   Revision: --------    Serial number: 30000000178726
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2D3A4D9CDAFD0BA95-806E
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8R1 035 186 Q    HW: 8R1 035 186 Q
   Component: Con3 Sirius   H09 0471
   Revision: 00000003    Serial number: AUZ5Z6N2016039
   Coding: 04020002010185004159070800
   VCID: 43D347A9EB90BCC3FA3-8016
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
02983 - Connection between Impedance Converter 1 and Window Antenna
                    Reset counter: 98
                    Mileage: 109211 km
                    Date: 2021.10.19
                    Time: 16:57:20
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0305
   Coding: 010C03204000210001
   VCID: 59EF85C1791C161380F-800C
   Component: TSG HR        H07 0305
   Part No SW: 8T0 862 336 F    HW: 8T0 862 336 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005337578
   Coding: 0010370
   VCID: 3E25365D8C72D12B95D-806A
End----------(Elapsed Time: 01:43, VBatt start/end: 12.4V/12.4V)-----------
HI, I have a feeling that someone disconnected it (?). The question then becomes why . I'm not familiar with the "impedance converter 1" Did you purchase this car new? Once you find the other end of the harness for this plug , connect it and monitor your sound system performance closely. If you can't find the other end of the harness, the "box" (IC) may have been removed ??? See if you can find a pic or a car like yours to compare ; or an exploded diagram . Perhaps there was window tint film at one time and it was disconnected for that process?????
RobM75
Cleveland, OH, USA
C?ID=497342
Thanks for you reply. It is very strange to me as the shop manual shows aerial amplifier 2 - R111 and there isn't anything there. I am the second owner of this car, I bought it from a dealer in 2017 - It was a leased car. I might be able to see inside the pillar with a small bore snake I have (if I can fit it through one of the holes there). My FM stations are ok, I just would like to get rid of the annoying code. I'm thinking I might not be able to.
RobM75
Cleveland, OH, USA
C?ID=497342
Just following up on this if anyone else runs into/searches this issue. The missing connector on the passenger side is because there is no amplifier on that side for MY model car. Other models may vary. So, the problem possibly lies in the antenna amplifier on the driver side of the car. I ordered a new antenna amplifier and will see if the dtc code goes away. I will follow up once again to report if the issue persists or is solved.
Excellent! Since the repair info was as clear as mud I dropped some notes into a new Wiki page:
That's not my best work but it may help the next guy.
Side note, after stumbling across the other possible Impedance Converter DTC (R111 which was not in your car) I think this RoW model had them on both sides: https://forums.ross-tech.com/index.php?threads/28997/
