No ASAM data found locally.
PinoySaMI
MI
C?ID=220597
I am getting this warning message even after downloaded the update...or the update failed?
Bruce
Near Philadelphia, PA, USA
@stefdds I highly doubt the issues are the same as those present 5 years ago.
@PinoySaMI , please allow the office to open and let others have a look at what is going on. We ask your patience.
In the meantime, posting an autoscan may give some clues as to what is going on.
Five years ago? There are several in that link/search from 2019,20, and 21 .
What module(s) are you getting it on, and on what car?
Given that your HEX-NET is seven years old, you may want to clear the ROD data set entirely, let VCDS-Mobile do an Auto-Scan (which won't won't find any RODs at all) and then do another update.
PinoySaMI
MI
C?ID=220597
Thanks to your previous comments, I was able to partition my Mac and now I have a windows 10. I was able to update my hex-net for the first time.
It is now up to date.
PinoySaMI
MI
C?ID=220597
I am getting this no ASAM found message in our 2018 Audi Q5.
how come after I did the ASAM update using my iPhone, it says “no update available or I’m up to date” but when I used an iPad it says “no ASAM found”.
it is different from one gadget to another?
Shaun
Based on what I see, sometimes the VIN is missing and then the ASAM data can not be correctly located. You might want to try [Options]->[Clear Dataset Cache] and also clear rod files in VCDS-Mobile to make sure it is not a conflict with old data.
There is also an alpha CB on the testing channel with several VIN related fixes, if you want to test this we could put your interface on the alpha channel and it might help fix the cases where the VIN is missing.
spanzo
C?ID=392003
I also have trouble with ASAM update at newer car. I tried with deleting ROD files and also cleared dataset cache. I'm already on BETA channel. This doesn't help.
I always get into endless loop, to make ASAM update.
I already loaded files into cloud, if you like to have a look.
winmarc
Luxembourg
C?ID=496686
I encountered exactly the same problem.
Shaun
spanzo you are missing some rods because the VIN isn't always retrieved. I put your interface onto the alpha release channel, there is an update there for the vin retrieval, please update to that and then autoscan again and try the asam update.
Shaun
winmarc you also have cases of a missing vin. I put your interface on the alpha channel as well, please test that update as per above.
spanzo
C?ID=392003
Sorry for my late feedback. I couldn't check at many different cars, but for one this update solved my problem too.
Thanks for your support!
alexnoe
Taufkirchen, Germany
C?ID=418771
A few days ago, I finally got my new Škoda Superb 2.0 TDI, and I'm having a problem that pretty well matches this thread's title.
After doing an auto scan, VCDS Mobile told me that it needed to download ASAM data. I used my mobile phone with tethering, so that the HEX-NET could access internet via 5G of my mobile phone. It downloaded 1007 kB of data and extracted some 80 files. Then, I tried to access the engine control unit. It told me it needed to download ASAM data, downloaded 1007 kB of data, extracted some 80 files... and still said it had no ASAM data. The dataset that is mentioned in the auto scan ("EV_ECM20TDI01105L906022F"), however, was not downloaded:
I connected the interface to the Windows PC and tried to update there. It said it needed some rod files, but the DS update fails with "gs timeout". In this state, the SD card is mounted as USB drive, so I can see that there are in fact a lot of rod files. Given that I cleared the rod files before attempting this for the first time, I assume that these are the files that were downloaded, but in the rods folder on the SD card there is nothing for "EV_ECM...". The following directories exist on the sd card in the rods directory (extracted with "dir /ad /b /on"):
EV_AC
EV_AL
EV_AM
EV_BR
EV_CA
EV_DA
EV_DC
EV_DR
EV_EL
EV_EP
EV_GA
EV_HR
EV_KE
EV_LL
EV_MF
EV_MU
EV_OC
EV_SE
EV_ST
EV_TC
EV_TR
IV_EV_ACClima
IV_EV_AMPEthM
IV_EV_Brake1U
IV_EV_DashBoa
IV_EV_EPHVA14
IV_EV_EPHVA18
IV_EV_GatewA0
IV_EV_GatewNF
IV_EV_LLPGen3
IV_EV_MUOIMQB
IV_EV_OCUGen3
What I actually wanted to do is checking if VCDS Mobile drops columns also in the new car, because if Shaun asks me to test another potential fix, I need to know if the problem of dropping columns also happens with the new car, otherwise the test would not be conclusive.
With VCDS on Windows, there is no problem. I can access the engine control unit and see an endless list of advanced measuring values, at least half of which are related to NOx and DEF.
Auto scan of the car:
Wed,Jan,05,2022,19:41:30
VCDS Mobile 0.4610.0.4
VCDS Mobile: 0.4610
Data Version: 20000062
VIN: TMBLR9NP4N7008484
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 23 2B 36 3C 42 44 47
     4B 52 5F 69 6C 6D 75 A5 BB BC D6 D7
BB-Door Rear Drv Side -- Status: OK 0000
BC-Door Rear Pass Side -- Status: OK 0000
Address 01: Engine  (DTUA J623)    Labels: 05-01.lbl
    Part No SW: 05L 906 022 F    HW: 05L 907 309 B
    Component: R4 2.0l TDI   H30 0987
    Revision: E3H30---
    Coding: 012504120476050830000000000000000000000000000000
    Shop #: WSC 00033 790 00175
    ASAM Dataset: EV_ECM20TDI01105L906022F 006004
    ROD: N/A
    VCID: 2A17A1ABD3CEA13BE2B6F19-807F
    No ASAM data for: "EV_ECM20TDI01105L906022F"
030078 - ROD - Unknown faultcode
030075 - ROD - Unknown faultcode
038784 - ROD - Unknown faultcode
028494 - ROD - Unknown faultcode
Address 02: Auto Trans  (J743)    Labels: 0G-02.clb
    Part No SW: 0GC 300 014 K    HW: 0GC 927 711 H
    Component: GSG DQ381     H06 2802
    Revision: 00H06V13
    ASAM Dataset: EV_TCMDQ381061 001001
    ROD: N/A
    VCID: 2D1DAAB7E220B60307D4D2D-8078
    No ASAM data for: "EV_TCMDQ381061"
No fault codes found.
Address 03: ABS Brakes  (J104)    Labels: 5Q-03.clb
    Part No SW: 5Q0 614 517 GD    HW: 5Q0 614 517 BR
    Component: ESC           H82 0114
    Revision: 00000000
    Coding: 1E077A9C31203B74477B070860C748785E8CDCE2E0061275B86150F8F2A94A0B0043010312121212B435351919323200
    ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
    ROD: N/A
    VCID: 79B54EE766E8DAA3DBAC16D-802C
    No ASAM data for: "EV_Brake1UDSContiMK100IPB"
Address 05: Acc/Start Auth.  (J518)    Labels: 5Q0-959-435.clb
    Part No SW: 3Q0 959 435 Q    HW: 3Q0 959 435 Q
    Component: VWKESSYMQB    037 1400
    Revision: 00037000
    Coding: 0F20000723
    ASAM Dataset: EV_KessyHellaMQBAB 004055
    ROD: N/A
    VCID: 48D3FB236D82732B14C23B1-801D
    No ASAM data for: "EV_KessyHellaMQBAB"
Address 08: Auto HVAC  (E87)    Labels: 3V0-907-044.clb
    Part No SW: 3V0 907 044 FM    HW: 3V0 907 044 FM
    Component: AC Automat    H34 4901
    Revision: 20K10000
    Coding: 12010104002410011005000D00109036
    ASAM Dataset: EV_ACClimaPrehVW37X 002030
    ROD: N/A
    VCID: 844BAF13912A174B383A8F1-80D1
    No ASAM data for: "EV_ACClimaPrehVW37X"
    Subsystem 1 -     Part No SW: 5Q0-907-659-E
    Component: G238 _AQS    H32 0120
    Serial Number: 129749918
Address 09: Cent. Elect.  (J519)    Labels: 5Q-09.clb
    Part No SW: 5Q0 937 084 EC    HW: 5Q0 937 084 EC
    Component: BCM MQBAB H   H44 0511
    ASAM Dataset: EV_BCMMQB 022001
    ROD: N/A
    VCID: 7DBD5AF772C0E683F7F442D-8028
    No ASAM data for: "EV_BCMMQB"
    Subsystem 1 -     Part No SW: 3V1-955-119-A    Labels: 5Qx-955-119-V1.clb
    Component: 48x LL 270521039 0122
    Serial Number: 00000002105250300881
    Coding: 164DDD
    Subsystem 2 -     Part No SW: 5Q0-955-547-C    Labels: 5Q0-955-547.clb
    Component: RLHS         054 0206
    Serial Number: SBY21M06D17H14M34S37
    Coding: 0088DF
    Subsystem 3 -     Part No SW: 5Q1-953-521-LC
    Component: Lenks.Modul  H34 0190
    Serial Number: 0100210620210C300147
Address 10: Park/Steer Assist  (J791)    Labels: 5Q0-919-298.clb
    Part No SW: 5QA 919 298 K    HW: 5QA 919 298 A
    Component: PLA 3.0 12K   H08 0073
    Coding: 8C71255951
    ASAM Dataset: EV_EPHVA2CAU3700000 009055
    ROD: N/A
    VCID: 58F32B63BD22E3AB8462EB1-800D
    No ASAM data for: "EV_EPHVA2CAU3700000"
Address 13: Auto Dist. Reg  (J428)    Labels: 5Q0-907-572.clb
    Part No SW: 5Q0 907 572 S    HW: 3Q0 907 567 A
    Component: ACC BOSCH MQB H02 0780
    Coding: 32057FDA5DFFC728949C812481400680000000000000000066
    ASAM Dataset: EV_ACCBOSCHVW416 003015
    ROD: N/A
    VCID: 47D1F81F609C7C531DD8305-8012
    No ASAM data for: "EV_ACCBOSCHVW416"
Address 14: Susp. Elect.  (J250)    Labels: 5Q0-907-376.clb
    Shop #: WSC 00000 000
    ROD: N/A
    VCID: 38338BE31D6203AB64224B1-806D
    No ASAM data for: "EV_DRCONTITEMIC"
Address 15: Airbags  (J234)    Labels: 5Q0-959-655.clb
    Part No SW: 5Q0 959 655 CH    HW: 5Q0 959 655 CH
    Component: AirbagVW21    008 0421
    Coding: 98FCC0C0000000005C5400CF004800000065
    ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
    ROD: N/A
    VCID: 8853BB23AD02332B5442FB1-80DD
    No ASAM data for: "EV_AirbaVW20SMEVW37X"
    Subsystem 1 -     Part No SW: 4M0-980-945-A
    Component: BeltPretRevFL106 1062
    Serial Number: 3V0857701C0175V00691
    Coding: 802006
    Subsystem 2 -     Part No SW: 4M0-980-946-A
    Component: BeltPretRevFR106 1062
    Serial Number: 3V0857702C0173V00188
    Coding: 802006
    Subsystem 3 -     Part No SW: --------------
    Component: SideSensor_Df001 0887
    Serial Number: 3570000000063401E55A
    Subsystem 4 -     Part No SW: --------------
    Component: SideSensor_Pf001 0887
    Serial Number: 35800000000613C4075B
    Subsystem 5 -     Part No SW: --------------
    Component: SideSensor_Dr003 6149
    Serial Number: 3510001C1043A892363S
    Subsystem 6 -     Part No SW: --------------
    Component: SideSensor_Pr003 6149
    Serial Number: 3520001A9043A893A382
Address 17: Instruments  (J285)    Labels: 5G0-920-XXX-17.clb
    Part No SW: 3V0 920 790 G    HW: 3V0 920 790 G
    Component: KOMBI         523 6170
    Coding: 05A5081AFF8C0008018C634B3001000800600000
    ASAM Dataset: EV_DashBoardVDDMQBA0 001046
    ROD: N/A
    VCID: 3B3994EF2C5428B38940AC5-806E
    No ASAM data for: "EV_DashBoardVDDMQBA0"
Address 19: CAN Gateway  (J533)    Labels: 3Q0-907-530-V1.clb
    Part No SW: 3Q0 907 530 AL    HW: 3Q0 907 530 E
    Component: GW MQB High   524 5463
    Coding: 0B0900345F287300AB1362DE9A0F00010001070000000000000000000000
    ROD: N/A
    No ASAM data for: "EV_GatewNF"
    Subsystem 1 -     Component: 4-00-05-00-04
    Subsystem 2 -     Part No SW: 5E3-919-719-E
    Component: E221__MFL-PR6H02 0100
    Serial Number: PR6-0440062171210947
    Coding: 270000
    Subsystem 3 -     Part No SW: 5Q0-915-181-K
    Component: J367-BDMHellaH11 9070
    Serial Number: 7370827705
    Subsystem 4 -     Part No SW: 5Q0-907-155-B
    Component: U13DCAC      H27 0810
    Serial Number: 2290098
8526361 - ROD - Unknown faultcode
Address 22: AWD  (-----)    Labels: None
    Part No SW: 5WA 907 554 P    HW: 5WA 525 130
    Component: 4Motion       H65 0724
    Coding: 0301
    ASAM Dataset: EV_AllWheelContrHA1VW37X 005001
    ROD: N/A
    VCID: 5BF9346FCC1408B3A980CC5-800E
    No ASAM data for: "EV_AllWheelContrHA1VW37X"
Address 23: Brake Booster  (J539)    Labels: None
    Part No SW: 3Q0 909 059 AC    HW: 3Q0 909 059 C
    Component: EBKV          H09 0207
    Coding: 0102C500300000C618638C31000049922449922400
    ASAM Dataset: EV_BrakeBoostG2BoschVW48X 015024
    ROD: N/A
    VCID: 78B34BE35DE2C3ABA4A20B1-802D
    No ASAM data for: "EV_BrakeBoostG2BoschVW48X"
108400 - ROD - Unknown faultcode
172400 - ROD - Unknown faultcode
Address 2B: Steer. Col. Lock  (J764)    Labels: 5Q0-905-861.clb
    Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
    Component: ELV-MQBB      H09 0040
    Coding: 0800000000000000
    ROD: N/A
    VCID: 3227B9CBFB1EE9FB5AE6099-8067
    No ASAM data for: "EV_ELVMarqMQBA0"
Address 36: Seat Mem. Drvr  (J810)    Labels: None
    Part No SW: 5Q0 959 760 F    HW: 5Q0 959 760 F
    Component: Sitzmemory    H10 0026
    Coding: 0010000000000500018280808080000000008181000000D440
    ASAM Dataset: EV_SeatMemorDriveSide 002022
    ROD: N/A
    VCID: 40C3E30345B24B6BDC92E31-8015
    No ASAM data for: "EV_SeatMemorDriveSide"
13893632 - ROD - Unknown faultcode
Address 3C: Lane Change  (J1086)    Labels: None
    Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
    Component: HRE3_Kl15_Mst H06 0150
    Coding: 62954640
    ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
    ROD: N/A
    VCID: 39358EE726681AA39B2C56D-806C
    No ASAM data for: "EV_HREntryHellaGen3Kl15"
Address 42: Door Elect, Driver  (J386)    Labels: 5Q-42.clb
    Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 P
    Component: TSG FS        011 0912
    Coding: 001D8920DE00028000001100
    Shop #: WSC 00033 790 00187
    ROD: N/A
    VCID: 52E7D94B9BDEC9FB7A26A99-8007
    No ASAM data for: "EV_DCU2DriveSideMAXHCONT"
Address 44: Steering Assist  (J500)    Labels: 5Q0-910-143.clb
    Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
    Component: MQB_VWBS_GEN2 212 2211
    Coding: 0101001100400110
    ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
    ROD: N/A
    VCID: 2B19A4AFDC34B83319A0FC5-807E
    No ASAM data for: "EV_SteerAssisVWBSMQBGen2"
Address 47: Sound System  (J525)    Labels: None
    Part No SW: 3G0 035 466    HW: 3G0 035 466
    Component: AMPeth16C     H08 3031
    Coding: 34800000000000000000000000000000000000000000000000
    ASAM Dataset: EV_AMPEthMQB 001005
    ROD: N/A
    VCID: E287898B6B7EB97B6AC6999-80B7
    No ASAM data for: "EV_AMPEthMQB"
Address 4B: Multifunc. Module  (J745)    Labels: 3Q0-907-338-V2.clb
    Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
    Component: FCM MQB Low   003 0367
    Coding: 00000007090008F206003D10010000000000000000000000000000000000
    ROD: N/A
    VCID: 373188DF107C0CD36D38405-8062
    No ASAM data for: "EV_MultiModulContiVW48X"
Address 52: Door Elect, Pass.  (J387)    Labels: 5Q-52.clb
    Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 P
    Component: TSG BFS       011 0912
    Coding: 001D8120DE00028000001100
    ROD: N/A
    VCID: 51E5D6479ED8B2E3433C5ED-8004
    No ASAM data for: "EV_DCU2PasseSideMAXHCONT"
Address 5F: Information Electr.  (J794)    Labels: 3V-5f.clb
    Part No SW: 3V0 035 820 F    HW: 3V0 035 820 F
    Component: MU-O-ND-EU    H22 0302
    Coding: 34826000000020000000000000000000000000000000000000
    ASAM Dataset: EV_MUOIMQB 001001
    ROD: N/A
    VCID: 3125B6C7FE18D2E323FC3ED-8064
    No ASAM data for: "EV_MUOIMQB"
000021 - ROD - Unknown faultcode
Address 69: Trailer  (J345)    Labels: None
    Part No SW: 5H1 907 383    HW: 5H1 907 383
    Component: Anhaenger     H10 0057
    Coding: 0100000202001300
    ASAM Dataset: EV_TrailFunctGener3Hella 001012
    ROD: N/A
    VCID: EC9BE7B399BAFF0BD02A071-80B9
    No ASAM data for: "EV_TrailFunctGener3Hella"
Address 6C: Back-up Cam.  (J928)    Labels: 5Q-6c.lbl
    Part No SW: 5Q0 907 556 D    HW: 5Q0 907 556
    Component: Areaview 2    H23 0609
    Coding: 04840201A30FA0000060480C
    ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
    ROD: N/A
    VCID: 3A3791EB236E11BB9256A19-806F
    No ASAM data for: "EV_CamSysRVAV2ARCE2MQBAB"
Address 6D: Trunk Elect.  (J605)    Labels: None
    Part No SW: 5WC 959 107    HW: 5WC 959 107
    Component: HDSG-Modul    H04 0430
    Revision: --------
    Coding: 0D88
    ASAM Dataset: EV_DeckLidCONTIAU536 001001
    ROD: N/A
    VCID: 0E5F0D3B4F66ED1B1E9EBD9-805B
    No ASAM data for: "EV_DeckLidCONTIAU536"
Address 75: Telematics  (J949)    Labels: None
    Part No SW: 5WA 035 284 E    HW: 5WA 035 284 B
    Component: OCUGen3High   H20 0139
    Coding: 034820101969A8819025460161052E07
    ASAM Dataset: EV_OCUGen3High 003007
    ROD: N/A
    No ASAM data for: "EV_OCUGen3High"
Address A5: Frt Sens. Drv. Assist  (R242)    Labels: None
    Part No SW: 2Q0 980 653 C    HW: 2Q0 980 653
    Component: MQB MFK 3.0   H16 1301
    Coding: 00020898117E4020089F10001030008001418000000000000000000000000000
    ASAM Dataset: EV_MFK3ValeoMQB 007042
    ROD: N/A
    VCID: 352D82D70A70FEC37F046AD-8060
    No ASAM data for: "EV_MFK3ValeoMQB"
Address BB: Door Rear Drv Side  (J388)    Labels: None
    Part No SW: 5Q4 959 595 P    HW: 5Q4 959 595 P
    Component: TSG HFS       008 0911
    Coding: 001C81208000028000001100
    ROD: N/A
    VCID: 54EBDF53A1CAC7CB685ABF1-8001
    No ASAM data for: "EV_DCU2RearDriveMAXHCONT"
Address BC: Failed to respond
Address D6: Light Ctrl Left 2  (A31)    Labels: 7PP-941-572.clb
    Part No SW: 992 941 571 AA    HW: 992 941 571 A
    Component: LED1L         H08 9002
    ROD: N/A
    VCID: 61850687EE782263F3DC0ED-8034
    No ASAM data for: "EV_LLPGen3LKEBODPO68X"
Address D7: Light Ctrl Right 2  (A27)    Labels: 7PP-941-572.clb
    Component: LED1R         H08 9002
    ROD: N/A
    No ASAM data for: "EV_LLPGen3RKEBODPO68X"
End--(Elapsed Time: 04:02, VBatt start/end: 12.5/12.3 Vign: 12.2)-
How can I get the missing files?
Shaun
The missing engine rod is because it looks like there is a problem with retrieving the vin. If you want to help debug that, you could make a debug log like this: power the interface from the usb side. Open VCDS-Mobile, [Options] -> enter debug level 111f -> [Submit]. Now with interface still powered over usb, plug in the dlc end to the vehicle and turn the ignition on. Give it a couple seconds to do its thing and there should be a debug log generated.
Also, you should try using VCIConfigV2.271 that can be found with the beta 21.12 vcds release. That should prevent the gs timeout error.
alexnoe
C?ID=418771
Yes, I want to help to debug that :)
I've put the debug files that were on the HEX-NET in my google drive:
The link should be public, i.e. no login required.
alexnoe
C?ID=418771
The gs timeout still happens with VCIConfig 2.271. I've added a screenshot to the folder I linked above.
EDIT after a long time, it suddenly says "Update completed successfully".
