C7.5 A6 MMI - Enabling Green Menu
Exie
C?ID=162093
Hi Folks,
Chasing down this age old issue - I still cannot access the "green" menu in MMI.
The reason I want to access the green menu is to change the standby time for when we go to the drive in cinema.
Per the title, I have a 2017 A6 Allroad (C7.5). The MMI unit is a 3G+ (I think) running MHI2_ER_AU57x_P3634
The internet seems to be full of guides to do this, but I still haven't found one that works in my car. A lot of these are based on the old versions of VCDS which describe 5F -> Adaptation 10 -> Channel 06.
As far as I can tell (please correct me if I'm wrong) the green screen is also known as "IDE02112-Developer Mode"
So when I go into VCDS, selecting "5F - Information Electr." and try to activate this, I get "Request out of range" per:
So the question is - Can anyone help me enable the green screen to set the timeout for the radio ?
Exie
C?ID=162093
Just to add to above, I know there are a bunch of posts about this here in these forums too.
I did go into security access, I had to use the 5 digit code "20103" not the 6 digit "S12345" for me.
It seemed to accept the security code, but still not luck setting the adaptation. Here's the log if that helps.
Tuesday,23,March,2021,18:26:18:15999
VIN: WAUZZZ4G0JN038919   License Plate:
Control Module Part Number: 4G1 035 052 J
  Component and/or Version: MU-H-LND-RW   054 0910
           Software Coding: 017542080000000013511102000A00102F000AE6F17001045E
            Work Shop Code: WSC 02391
                      VCID: 2517FBFD8562E1D3DC5-8070
Advanced Identification/FAZIT
     Serial number: A739H0HS001011
     Identification: JTH-076
     Date: 26.08.17
     Manufacturer number: 3407
     Test stand number: 00B8
Flash Status
     Programming Attempts(application): 0/0
     Programming Attempts(data): 65535/1/1/1/1/1/0/0/0/1/65535/65535/65535/0/0/0/1/0/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535
     Successful Attempts(data): 65535/1/1/1/1/1/0/0/0/1/65535/65535/65535/0/0/0/1/0/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535/65535
     Flash Date: 00.01.01
     Flash Tool Code(data): 00200 785 02391
Misc.
     Hardware number: 4G1 035 052 D
     Workshop System Name: J794
     Equipment/PR Code: 0000004FF8374D0EE1F402FD
     Dataset Number: 4G1909545J
     Dataset Version: 0043
     ASAM Dataset: EV_MUHig6C3Gen2HBAS
     ASAM Dataset Revision: 001115
Car Info
     Chassis Number: WAUZZZ4G0JN038919
VCDS Info:
       Labels: None
Saturday,23,October,2021,16:46:11:15999
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
Dealer/Shop Name: Ross-Tech LLC.
Workshop Code: 444 03743 000001
UDS Adaptation Channel (1B): IDE02122-Developer mode
Stored value not activated
Saturday,23,October,2021,16:47:27:15999
UDS Adaptation Channel:
Stored value Please select a channel
Address 5F,4G1 035 052 J,channel IDE02122-Developer mode,adapted from,not activated ,to,activated ,
TBAx
C?ID=287144
You need to do this in Engineering Session (4F).
Currently there is no label, so there is no S12345 login (which does change the session) available. Basically the label provides this login. You’ll need to do the change the session yourself (E-Mail RT for a "how to") or wait for a label to be implemented.
Exie
C?ID=162093
Thanks for the tip @TBAx
I went digging and found this thread here:
Where `Backspace` suggests renaming one of the existing label files could work.
In the end I copied `...VCDS\Labels\4G1-035-MIB-HGH2.clb` to `...VCDS\Labels\User\4G1-035-052.clb`
Then opening VCDS, 5F -> Security -> S12345 -> Adaptaton-10 -> IDE02112-Developer Mode -> Enabled -> Do It!
With this sorted, I was able to access the Green and Red menus per the Facelift buttons
<Back> + <Top left Silver> = Red "Enginerring" Menu
<Back> + <Bottom left Solver> = Green "Developer" Menu
