MK60EC1 coding help please
T11ner
C?ID=35181
Sorry for the newbie post! I'd guess I've been using VCDS for 20 years or so but never registered on here :facepalm:.
So I've had a Leon FR come in with the ABS and handbrake lights flashing and sure enough the coding string is a row of zeros :rolleyes:.
The owner bought the car like this so I have no history whatsoever on it I'm afraid.
I've done a full scan and got this -
Wednesday,20,October,2021,09:29:09:10327
VCDS Version: 21.3.0.0 (x64)
VIN: VSSZZZ1PZ9R025495   License Plate:
Mileage: 180880km-112393mi   Repair Order:
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: VSSZZZ1PZ9R025495   Mileage: 180880km-112393miles
Address 01: Engine        Labels: 03G-906-018-BMN.clb
   Part No SW: 03G 906 018 GQ    HW: 03G 906 018 GQ
   Component: R4 2.0l PPD1.2 G    2280
   Revision: --H52---    Serial number: SEX7Z0H63130AO
   Coding: 0050072
   Shop #: WSC 66565 257 00032
   VCID: 7AF1C2E235F70E5B8D-802E
005213 - Exhaust Gas Temperature Sensor 3
               P145D - 006 - Short to Plus - MIL ON
                    Fault Status: 11100001
                    Mileage: 169397 km
                    Time: 00:08:17
                    Torque: 0.0 Nm
                    Temperature: 39.0°C
                    Text:   32    C
                    Text:   16    C
                    Text: 1000    C
                    Ign. Timing: -0.0 °ATDC
Readiness: N/A
   Part No SW: 1K0 907 379 AT    HW: 1K0 907 379 AT
   Component: ESP MK60EC1   H30 0105
   Revision: 00H30001
   VCID: 040DBC1A873348ABE7-8050
03306 - Coding Not Valid
                    Reset counter: 233
                    Mileage: 180884 km
                    Count: 3
                    Count: 2
                    Count: 29184
                    Count: 4161
                    Count: 44288
                    Reset counter: 233
                    Mileage: 180884 km
                    Count: 16391
                    Count: 24576
                    Count: 195
                    Count: 44544
                    Fault Status: 01100101
                    Reset counter: 233
                    Mileage: 180884 km
                    Count: 3
                    Count: 2
                    Count: 29184
                    Count: 279
                    Count: 44288
                    Reset counter: 233
                    Mileage: 180884 km
                    Count: 3
                    Count: 2
                    Count: 29184
                    Count: 295
                    Count: 44288
                    Reset counter: 233
                    Mileage: 180884 km
                    Count: 3
                    Count: 2
                    Count: 29184
                    Count: 270
                    Count: 44288
   Part No: 1P0 907 044 D
   Component: ClimatronicPQ35 011 0702
   VCID: 2D5B39BEB43969E358-8078
            013 - Check DTC Memory
   Revision: 00H54000    Serial number: 00000005861023
   Coding: 81880F2F00041000431D00000000000000007F075C400000000000000000
   Shop #: WSC 06402 785 00200
   VCID: 336F2FC6521D3F130E-8066
   Subsystem 1 - Part No: 1P0 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 300608 022  0601
   Coding: 00056208
   Shop #: WSC 06402
   Component: J234__A03 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPBNDQ82
   Coding: 0012339
   VCID: 3B7F07E67A4DF753D6-806E
   Subsystem 1 - Serial number: 6333FTS661011648
   Subsystem 2 - Serial number: 6343FTS603611648
   Subsystem 3 - Serial number: 6353ETS6I0OAUVNP
   Subsystem 4 - Serial number: 6363ETS6Q033UVNH
   Part No SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
   Component: J0527           752 0101
   Coding: 0002042
   VCID: 040DBC1A473348ABE7-8050
   Component: E0221           001 0010
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
   Part No: 1P0 920 947 C
   Component: KOMBIINSTRUMENT VO3 0750
   Coding: 0002401
   Shop #: WSC 06403 067 57207
            010 - Open or Short to Plus
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K0862504E9
   Coding: E9807F060006020203
   VCID: 356B11DE5C69212320-8060
01304 - Radio
                    Reset counter: 233
                    Mileage: 180884 km
                    Time: 17:43:16
   Component: IMMO            VO3 0750
   Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1518
   Revision: 71009005    Serial number: 00000568388519
   Coding: 0004784
   VCID: 4085700A13AB948B83-8014
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 142    2301
   Revision: 00H15000
   VCID: 2A5132A285D77EDBBD-807E
   Coding: 988000005283CC7F0006850560085F86107C00
   Shop #: WSC 00000 000 2088960
   VCID: 030FBF06423D4F93DE-8056
   Subsystem 5 - Part No: 1P0 951 171
   Component: Innenraumueberw.010 4971
   Coding: 00000000
   Subsystem 6 - Component:   Sounder No Answer
   Subsystem 7 - Component:       NGS n.mounted
                    Reset counter: 233
                    Mileage: 180884 km
                    Time: 17:45:13
   Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1518
   Revision: 71009005    Serial number: 00000541288513
   Coding: 0004784
   VCID: 4183750E18A19D838C-8014
Address 56: Radio
   Part No SW: 1K0 959 703 AF    HW: 1K0 959 795 S
   Component: J388   TUER-SG HL   1401
   Revision: 11006001    Serial number: 00000003292413
   Coding: 0000144
   VCID: 74EDECDA1793782BD7-8020
   Part No SW: 1K0 959 704 AF    HW: 1K0 959 794 S
   Component: J389   TUER-SG HR   1401
   Revision: 11006001    Serial number: 00000003299015
   Coding: 0000144
   VCID: 75EBD1DE1CE96123E0-8020
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 5P0 862 335 B    HW: 5P0 862 335 B
   Component: FSE_2P5x        H30 0110
   Revision: 00000001    Serial number: 00000005051267
   Coding: 0000555
   VCID: 32612AC2AD07361B05-8066
01304 - Radio
                    Reset counter: 233
                    Mileage: 180884 km
                    Time: 17:43:12
End-------------------------(Elapsed Time: 01:44)--------------------------
And by a small miracle the sticker wasn't totally destroyed -
https://flic.kr/p/2mCVizS
It is RHD and does have the tyre pressure reset button on the centre console.
Can anyone help me out with a coding suggestion?
Steve
Check Advanced ID in the ECU, the Instrument Cluster, and the Immobilizer to see if they all match each other and the physical VIN of the car please.
T11ner
C?ID=35181
Hi Uwe, thanks for the reply
Advanced ID isn't helping me a lot there, the chassis number showing on the engine ecu is a different format altogether and the VCID does not match the instruments and immob (which do appear to be the same)
https://flic.kr/p/2mD1xw4
https://flic.kr/p/2mCV9kD
https://flic.kr/p/2mCZqDM
and the ABS is different again
https://flic.kr/p/2mD4Ta3
The physical ID is the same front and back and does line up with the original scan.
Am I reading this wrong or am I working on Frankenstein's monster? :eek:
VCID isn't expected to match. The VIN is what I was looking for. It should show up as "Chassis Number" in Advanced ID. I'm a bit puzzled by what I'm seeing there.
Let's try MVB 081 instead, in 01-Engine, 17-Instruments, and 25-Immo. 03-ABS won't have it.
Not sure yet.
n4s
Portugal
C?ID=351319
suggestion to start
143BC012892400FF280F03ED911E0040440000
T11ner
C?ID=35181
Thanks N4S, it appears to accept that code but then flags faults for incorrect coding and if I cycle the ignition it reverts to a bunch of zeros on the coding. Do I need to complete the adaptions to make it retain the coding??
T11ner
C?ID=35181
Thanks you are, of course, absolutely right ;)
So tried coding again, did all the basic settings, the flashing handbrake/abs lights are no longer an issue and the coding is holding in the unit correctly. But I can't seem to get the TPMS light to reset with the button and I do still have two fault codes in the ABS module (although no warning light on).
https://flic.kr/p/2mDj4bc
https://flic.kr/p/2mDhZ1p
I don't think the owner will actually care that the codes are there but we probably do need the TPMS light off to get an MOT pass, might that be related to the incorrect coding fault code?
Looks to me like the coding isn't quite 100% right.
T11ner
C?ID=35181
Yep, makes sense.
Anyone got any tweaks or alternatives?
@T11ner , I'll take shot at this and report back with any suggestions.
I do not believe the correct ABS module is installed. The factory path should have been: 1K0 907 379 AD > 1K0 907 379 AN > 1K0 907 379 AH
The installed 1K0 907 379 AT unit looks like it came from a 2010/2011 MY car.
ASSuming that doesn't backfire on us I built this based on a vehicle in factory-like condition:
163B6012092400FF680F06ED901E00823400
That will not be accepted due to the incorrect coding length in the installed module but adding a pair of 00's on the end of the string may:
163B6012092400FF680F06ED901E0082340000
Vehicle Identification No. VSSZZZ1PZ9R025495
Model Leon FR
LE
Date of production 04.09.2008
Year 2009
Sales type 1P1561
Engine Code BMN
Transmission Code KNY
G0K 6-speed manual transmission
L0R Right-hand drive
0YC Weight range 3 installation control only, no requirement forecast
1N3 Speed-related variable steering assist (Servotronic)
2UC Sports version
1AT Electronic stability control (ESC)
1LJ Disc brakes in front
1KD Disc brakes in rear
7K6 Tire pressure monitoring system
UG0 Without hill start assist/hill descent control/comfort driving assist
T11ner
C?ID=35181
Hi Dana
Nicely done, I just tried that code string and it has worked perfectly! All warning lights off and no fault codes present :cool:.
Thanks for the help everyone, I'm not sure this thing of beauty was actually worth saving but the owner believes it is and they are now one step closer! :thumbs:
