A friend has a UK B6 VW Passat (manufactured 2009). Recently it has had an engine warning light come up on the dash. We connected up my VCDS and found that there was an EGR valve fault.
The fault indicated on VCDS was:-
001027 - EGR Valve (N18)
P0403 - 000 - Malfunction
I have attached an auto-scan taken after the engine fault light came on:-
We removed the EGR valve and cleaned it in an ultrasonic bath taking care to keep the electrics clear of the water. After plugging the valve in electrically we carried out a VCDS Output test on it. There was a high pitched buzzing sound each time the valve tried to open, but the valve barely moved (possibly only a fraction of a mm).
We removed the plastic gear case cover and operated the gears by hand. The valve lifted freely over its full stroke (at least an estimated 6mm) against firm spring pressure. We put the plastic gearcase cover back on and carried out the VCDS Output test again. Still the same. The valve barely moved.
We then carried out a Basic Setting on Group 123 (as indicated by the menu system for EGR valve basic setting). It appeared to attempt a calibration before Basic Setting automatically turned off. Again the valve barely moved.
The four fields in the Basic Settings window (Group 123) showed the following on completion of the calibration activity:- 0.0%, 00000100, 00000010, 0.684V
We noted that there is an EGR valve RESET function in the Adaptations menu. We did not activate this as we were uncertain of its purpose and whether its use would be appropriate.
Finally, we re-installed the EGR valve and cleared DTC’s. There are currently no engine faults showing on the auto-scan. We believe it is most likely that the EGR fault will soon re-appear.
Sunday,17,October,2021,16:20:30:27553
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
VIN: WVWZZZ3CZ9E098608 License Plate:
Mileage: 309650km-192407mi Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 6C
VIN: WVWZZZ3CZ9E098608 Mileage: 309650km-192407miles
Address 01: Engine (CBD) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 BT HW: 03L 907 309
Component: R4 2,0L EDC 0000SG 6214
Revision: 13H01--- Serial number: VWZCZ000000000
Coding: 0000071
Shop #: WSC 00363 210 85044
VCID: 78AAE15AFED5F1DB9F1-802C
VINID: 9E69EAAAA0D3A8954024818020F8E835AA
001299 - Incorrect Immobilizer Key
P0513 - 000 - - Intermittent
Mileage: 309476 km
Date: 2016.03.09
Time: 21:26:36
RPM: 989 /min
Voltage: 11.63 V
Absolute Pres.: 1009.8 mbar
Absolute Pres.: 969.0 mbar
Temperature: 18.9∞C
Temperature: 18.9∞C
Mileage: 309648 km
Date: 2016.03.09
Time: 07:37:04
RPM: 1702 /min
Speed: 42.0 km/h
Load: 16.9 %
Lambda: 27.6 %
Mass Air / Rev.: 275.0 mg/str
Temperature: 81.0∞C
Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 T HW: 3C0 614 109 T
Component: J104 C4 440 V2 0013
Revision: --025--- Serial number: 00000786438999
Coding: 0001286
Shop #: WSC 05311 000 00000
VCID: 2F381A064B1BF6630EB-807A
Part No SW: 1K0 820 047 JD HW: 1K0 820 047 JD
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000
VCID: 6FB8DA068B9BB6634EB-803A
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000009125181
Coding: 00880F0700041A00470A00000F000000000859435C000120000000000000
Shop #: WSC 05124 000 00000
VCID: 323E13725829DB8B615-8066
Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 201108 022 0601
Coding: 00046997
Shop #: WSC 05124
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__00Q VW10 HI 1815
Revision: 19013000 Serial number: 0039DPQZAV1O
Coding: 0012369
VCID: 3B203E568F631AC3B23-806E
Subsystem 1 - Serial number: 6333FTS691633018
Subsystem 2 - Serial number: 6343FTS635553408
Subsystem 3 - Serial number: 6353ETS6R6PVVVNR
Subsystem 4 - Serial number: 6363ETS6RQ45V5KJ
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AT HW: 3C0 953 549 AT
Component: J0527 0030
Revision: 00034000 Serial number: 3C9953507CE
Coding: 0000004
Shop #: WSC 05314 000 00000
VCID: 7EA6F742DCF1CFEBD5D-802A
Part No SW: 3C0 920 971 R HW: 3C0 920 971 R
Component: KOMBI H04 0107
Coding: 460F00
Shop #: WSC 05314 115 00000
VCID: 3432156AAEBDD5BB739-8060
Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 L HW: 3C0 907 951
Component: J533__Gateway H13 0152
Revision: H13 Serial number: 3300P08C0804AD
Coding: F9801F06404202002003
VCID: 2A0E0B1270F9934BD95-807E
Part No SW: 3C0 959 433 AQ HW: 3C0 959 433 AQ
Component: IMMO 044 0383
Revision: 00044000 Serial number: VWZCZ000000000
VCID: 79ACE45EC5DFE8D3E0F-802C
Component: ELV 027 0380
3C0905861G ELV 027 0380
02861 - Electronic Steering Column Lock Check Sum Error
Reset counter: 182
Mileage: 308037 km
Date: 2016.03.09
Time: 21:08:50
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 BX
Component: RNS-MID H03 5238
Revision: AB001001 Serial number: VWZ6Z7H6306026
Coding: 00010400000000000000
VCID: 37282266BF4B3EA356B-8062
Component: EU West V16 8536
00823 - Line-Output; Front Left
007 - Short to Ground
Fault Status: 01100111
Reset counter: 151
Mileage: 293872 km
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1518
Revision: 72009005 Serial number: 00000628989110
Coding: 0000565
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 195 2501
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2C020D0A7A0D8D7B2B9-8078
00750 - Warning Lamp
Fault Status: 00101101
Reset counter: 201
Mileage: 302237 km
Date: 2016.03.09
Time: 06:07:42
Voltage: 11.38 V
DD
Temperature: 8.0∞C
RPM: 1229 /min
Component: KSG PQ46 ELV 044 0612
Coding: 0191020851030E763004941570085BCE103C01
Subsystem 1 - Component: Sounder No Answer
Component: Neigungssensor 004 0611
Fault Frequency: 14
Reset counter: 168
Mileage: 302236 km
Date: 2016.03.09
Time: 09:27:45
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1518
Revision: 72009005 Serial number: 00000513489111
Coding: 0000564
VCID: 70BAD97A96A5A99B571-8024
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 009 Serial number: 00000000217648
Coding: 0000057
VCID: 280AF11A6EF5A15BCF1-807C
Fault Status: 00101100
Fault Frequency: 12
Reset counter: 171
Mileage: 307046 km
Date: 2016.03.09
Time: 06:21:09
Voltage: 9.70 V
Count: 93
Hex Value: 0x12E1
Hex Value: 0x0001
Hex Value: 0x1010
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Reset counter: 151
Mileage: 293872 km
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3C0 907 441 HW: 3C0 907 441
Component: J772__Rearview 0042
Revision: 00H05000 Serial number: PA8 J8X0064
Coding: 0000007
VCID: 5F98AAC67B3B26E3FEB-800A
End----(Elapsed Time: 01:09, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
- Should the EGR valve do a full stroke when tested using the VCDS Output test? We assume that it should.
- Any suggestions as to what we can do next to resolve our issue with the EGR valve?
