EGR Valve Fault
Klaus Ludwig
C?ID=227092
A friend has a UK B6 VW Passat (manufactured 2009). Recently it has had an engine warning light come up on the dash. We connected up my VCDS and found that there was an EGR valve fault.
The fault indicated on VCDS was:-
001027 - EGR Valve (N18)
P0403 - 000 - Malfunction
I have attached an auto-scan taken after the engine fault light came on:-
Sunday,17,October,2021,16:20:30:27553
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
VIN: WVWZZZ3CZ9E098608 License Plate:
Mileage: 309650km-192407mi Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 6C
VIN: WVWZZZ3CZ9E098608 Mileage: 309650km-192407miles
Address 01: Engine (CBD) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 BT HW: 03L 907 309
Component: R4 2,0L EDC 0000SG 6214
Revision: 13H01--- Serial number: VWZCZ000000000
Coding: 0000071
Shop #: WSC 00363 210 85044
VCID: 78AAE15AFED5F1DB9F1-802C
VINID: 9E69EAAAA0D3A8954024818020F8E835AA
001299 - Incorrect Immobilizer Key
P0513 - 000 - - Intermittent
Mileage: 309476 km
Date: 2016.03.09
Time: 21:26:36
RPM: 989 /min
Voltage: 11.63 V
Absolute Pres.: 1009.8 mbar
Absolute Pres.: 969.0 mbar
Temperature: 18.9∞C
Temperature: 18.9∞C
Mileage: 309648 km
Date: 2016.03.09
Time: 07:37:04
RPM: 1702 /min
Speed: 42.0 km/h
Load: 16.9 %
Lambda: 27.6 %
Mass Air / Rev.: 275.0 mg/str
Temperature: 81.0∞C
Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 T HW: 3C0 614 109 T
Component: J104 C4 440 V2 0013
Revision: --025--- Serial number: 00000786438999
Coding: 0001286
Shop #: WSC 05311 000 00000
VCID: 2F381A064B1BF6630EB-807A
Part No SW: 1K0 820 047 JD HW: 1K0 820 047 JD
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000
VCID: 6FB8DA068B9BB6634EB-803A
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000009125181
Coding: 00880F0700041A00470A00000F000000000859435C000120000000000000
Shop #: WSC 05124 000 00000
VCID: 323E13725829DB8B615-8066
Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 201108 022 0601
Coding: 00046997
Shop #: WSC 05124
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__00Q VW10 HI 1815
Revision: 19013000 Serial number: 0039DPQZAV1O
Coding: 0012369
VCID: 3B203E568F631AC3B23-806E
Subsystem 1 - Serial number: 6333FTS691633018
Subsystem 2 - Serial number: 6343FTS635553408
Subsystem 3 - Serial number: 6353ETS6R6PVVVNR
Subsystem 4 - Serial number: 6363ETS6RQ45V5KJ
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AT HW: 3C0 953 549 AT
Component: J0527 0030
Revision: 00034000 Serial number: 3C9953507CE
Coding: 0000004
Shop #: WSC 05314 000 00000
VCID: 7EA6F742DCF1CFEBD5D-802A
Part No SW: 3C0 920 971 R HW: 3C0 920 971 R
Component: KOMBI H04 0107
Coding: 460F00
Shop #: WSC 05314 115 00000
VCID: 3432156AAEBDD5BB739-8060
Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 L HW: 3C0 907 951
Component: J533__Gateway H13 0152
Revision: H13 Serial number: 3300P08C0804AD
Coding: F9801F06404202002003
VCID: 2A0E0B1270F9934BD95-807E
Part No SW: 3C0 959 433 AQ HW: 3C0 959 433 AQ
Component: IMMO 044 0383
Revision: 00044000 Serial number: VWZCZ000000000
VCID: 79ACE45EC5DFE8D3E0F-802C
Component: ELV 027 0380
3C0905861G ELV 027 0380
02861 - Electronic Steering Column Lock Check Sum Error
Reset counter: 182
Mileage: 308037 km
Date: 2016.03.09
Time: 21:08:50
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 BX
Component: RNS-MID H03 5238
Revision: AB001001 Serial number: VWZ6Z7H6306026
Coding: 00010400000000000000
VCID: 37282266BF4B3EA356B-8062
Component: EU West V16 8536
00823 - Line-Output; Front Left
007 - Short to Ground
Fault Status: 01100111
Reset counter: 151
Mileage: 293872 km
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1518
Revision: 72009005 Serial number: 00000628989110
Coding: 0000565
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 195 2501
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2C020D0A7A0D8D7B2B9-8078
00750 - Warning Lamp
Fault Status: 00101101
Reset counter: 201
Mileage: 302237 km
Date: 2016.03.09
Time: 06:07:42
Voltage: 11.38 V
DD
Temperature: 8.0∞C
RPM: 1229 /min
Component: KSG PQ46 ELV 044 0612
Coding: 0191020851030E763004941570085BCE103C01
Subsystem 1 - Component: Sounder No Answer
Component: Neigungssensor 004 0611
Fault Frequency: 14
Reset counter: 168
Mileage: 302236 km
Date: 2016.03.09
Time: 09:27:45
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1518
Revision: 72009005 Serial number: 00000513489111
Coding: 0000564
VCID: 70BAD97A96A5A99B571-8024
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 009 Serial number: 00000000217648
Coding: 0000057
VCID: 280AF11A6EF5A15BCF1-807C
Fault Status: 00101100
Fault Frequency: 12
Reset counter: 171
Mileage: 307046 km
Date: 2016.03.09
Time: 06:21:09
Voltage: 9.70 V
Count: 93
Hex Value: 0x12E1
Hex Value: 0x0001
Hex Value: 0x1010
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Reset counter: 151
Mileage: 293872 km
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3C0 907 441 HW: 3C0 907 441
Component: J772__Rearview 0042
Revision: 00H05000 Serial number: PA8 J8X0064
Coding: 0000007
VCID: 5F98AAC67B3B26E3FEB-800A
End----(Elapsed Time: 01:09, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
We removed the EGR valve and cleaned it in an ultrasonic bath taking care to keep the electrics clear of the water. After plugging the valve in electrically we carried out a VCDS Output test on it. There was a high pitched buzzing sound each time the valve tried to open, but the valve barely moved (possibly only a fraction of a mm).
We removed the plastic gear case cover and operated the gears by hand. The valve lifted freely over its full stroke (at least an estimated 6mm) against firm spring pressure. We put the plastic gearcase cover back on and carried out the VCDS Output test again. Still the same. The valve barely moved.
We then carried out a Basic Setting on Group 123 (as indicated by the menu system for EGR valve basic setting). It appeared to attempt a calibration before Basic Setting automatically turned off. Again the valve barely moved.
The four fields in the Basic Settings window (Group 123) showed the following on completion of the calibration activity:- 0.0%, 00000100, 00000010, 0.684V
We noted that there is an EGR valve RESET function in the Adaptations menu. We did not activate this as we were uncertain of its purpose and whether its use would be appropriate.
Finally, we re-installed the EGR valve and cleared DTC’s. There are currently no engine faults showing on the auto-scan. We believe it is most likely that the EGR fault will soon re-appear.
  • Should the EGR valve do a full stroke when tested using the VCDS Output test? We assume that it should.
  • Any suggestions as to what we can do next to resolve our issue with the EGR valve?
Klaus Ludwig
C?ID=227092
Thanks @Crasher for your input.
If anyone else has some more technical feedback or advice on our problem it would be VERY much appreciated.
The car owner (a close relative) has purchased a new EGR valve. This also has similar symptoms to the original EGR valve when tested using the VCDS output test. It barely opens and vibrates when it does so.
We have just tried putting 12v dc directly on the motor terminals of the original EGR valve with the valve on a bench and the valve opens fully. As the new valve behaves in a similar way to the original valve it is looking more and more likely that we have a wiring or ECU issue (and by wiring I am including harness plug/socket faults).
I believe the EGR valve motor is 12v dc pulse width modulated fed by 2 wires and that the feedback is 0.5 to 5V via a Hall Effect Sensor mounted inside the EGR valve assembly. There are 3 wires connected to the valve position sensor. (0, 5V and signal). We have confirmed that there is 5V relative to earth on one of the 3 wires going to the position sensor.
This may be important:- For info, when measuring voltage relative to the battery negative terminal on the two wires in the plug that fits onto the EGR valve we measured +12v on BOTH wires with the plug disconnected from the EGR valve.
Hoping that someone out there has some ideas that may help us.
I suspect the problem is in the ECU, if there was something wrong with the 5v feed (yellow/blue to plug T6 pin 1) or the earth (brown/red to pin 3) you would expect codes in G81, G28, G69,G247 and G581. Test the continuity of the wires from the ECU to the EGR plug
Brown/white from the 60 pin plug at T6 pin 2, lilac/green T60/57 to T6/5 and blue/white T60/19 to T6/6. The 5v feed is from ECU T60/53 to T6/1, remember to disconnect G81, G28, G69,G247 and G581 to check the continuity. There is also the possibility that one of these devices is causing the problem. The 5v feed is from T60/25 to T6/1.
Klaus Ludwig
C?ID=227092
Thanks @Crasher. I will follow up on your advice and revert in due course. I don't suppose you (or anyone else) would know EXACTLY where I could get a wiring diagram to confirm ECU pins and harness plug pins etc. I downloaded a lot from ERWIN a few years ago, but looking through it I have not yet seen anything that I would call a wiring diagram unless I'm missing something. I have "Electrical System Workshop Manual" and "Electrical System General Information Workshop Manual" and lots more, but cannot find the relevant info. I'm not an auto electrician or any kind of electrician, but do have a general engineering background with general electrical experience of fault-finding (not on cars). If you are able to send me an electrical drawing that would be even better!
Quintus Rotam
EU
C?ID=490177
Yes they are called Current Flow diagrams on erWin.
Klaus Ludwig
C?ID=227092
Thanks! Different terminology to what I have experience of and for some reason I must have missed these. perhaps they are not in quite the same place as all the other documents I downloaded. I thought I had downloaded almost everything.
Klaus Ludwig
C?ID=227092
RE B6 2009 PASSAT
Hi @Crasher,
Very much appreciate the pin-out data for the ECU and EGR valve plug that you have given in words. I have tabulated my interpretation of it below. The car is at a relative’s address. I am not in front of it right now to refer to anything.
A few questions:-
  • As per my table below you appear to have given two different terminals on the ECU for the 5V feed to the position sensor. Does that mean that only one of them is correct - and if so which?
  • Which ECU pin if any is connected to EGR valve plug pin T6/2?
  • Which ECU pin if any is connected to EGR valve plug pin T6/3?
  • The EGR valve plug has two rows of 3 pins and the 2 motor pins were not adjacent to each other so may have been pins 4 & 6 rather than 5 and 6?
I looked in ERWIN again today and still could not find the “current flow diagrams” amongst the PDF’s of repair manuals, circuit diagrams etc . Are they in a diagnostics section of ERWIN?
I phoned VW Customer Service today and they were unable to help re ERWIN. I then phoned our local VW dealer service department and was told that they use ELSA and not ERWIN and would also not be sure where to find this info in ERWIN. If you know where to find it or can send it, it might give me a better overview. If not, then answers to my above 4 questions re the table below would be a big help.
Thanks in advance!
EGR PLUG ECU PLUG WIRE COLOUR FUNCTION
T6/1 FROMT60/53 OR T60/25 YELLOW/BLUE 5V FEED
T6/2 TO T60/?? BROWN/WHITE POSITION SENSOR SIGNAL
T6/3 FROM T60/?? BROWN/RED POSITION SENSOR EARTH
T6/4
T6/5 FROM T60/57 LILAC/GREEN EGR MOTOR
T6/6 FROM T60/19 BLUE/WHITE EGR MOTOR
Klaus Ludwig
C?ID=227092
EGR PLUGECU PLUGWIRE COLOURFUNCTION
T6/1FROM T60/53 OR T60/25YELLOW/BLUE5V FEED
T6/2TO T60/??BROWN/WHITEPOSITION SENSOR SIGNAL
T6/3FROM T60/??BROWN/REDPOSITION SENSOR EARTH
T6/4
T6/5FROM T60/57LILAC/GREENEGR VALVE MOTOR
T6/6FROM T60/19BLUE/WHITEEGR VALVE MOTOR
EGR PLUGECU PLUGWIRE COLOUR/CSAFUNCTION
T6/1T60/25YELLOW/BLUE 03.5mm5V FEED the junction is known a D174 at which point the feed to G247 is a yellow/grey
T6/2T60/4BROWN/WHITE 1.0mmI think this is the motor earth
T6/3T60/53BROWN/RED 0.35mmPOSITION SENSOR EARTH the junction is known as 85 where for G247 and G81 it changes to brown
T6/4 not usedNANAnone
T6/5T60/57LILAC/GREEN 0.35mmNot sure about this
T6/6T60/19BLUE/WHITE 1.0mmEGR VALVE MOTOR
Klaus Ludwig
C?ID=227092
Thanks @Crasher - much appreciated. We will progress as weather and other factors permit. Hopefully, we will be able to narrow the issue down to wiring or ECU fault.
Klaus Ludwig
C?ID=227092
Hi @Crasher,
Since found that the ERWIN document we needed had the word Climatronic in its title. I had ignored it assuming that it was something to do with air conditioning. Now know that it holds all the “current flow diagrams”
Your pin numbers for T6 & T60 were absolutely spot on. THANKS!!! 😊😊😊
Today we carried out a continuity check on all 5 links between T6 and T60. All found to be OK. Also did a check to earth on these 5 using the megohm scale on a digital multimeter – all OK. Did not use insulation test mode as was afraid we might fry something.
Tested each of 5 pins on T6 to each and every pin on T60 to check for any possible issues. Only “crossovers” to other pins found were as follows:-
T6/1 to T60/53 was 655.2 ohms
T6/1 to T60/58 was 166.6 ohms
Note that you did mention that we would need to unplug G81, G28, G69, G247 and G581 for testing. We are in the process of finding what they are so that we can do that!
Looks now almost certain that our EGR valve issue is a fault with the ECU. We are planning to make arrangements to send it off for checking ASAP. Meanwhile we will disconnect whatever other devices are necessary (as per your advice) to confirm that the two crossover resistances from T6/1 disappear – once we figure out what those G numbers are!
Will let you know how things go.
Quintus Rotam
EU
C?ID=490177
G28 Engine speed sender
G69 Throttle valve potentiometer
G81 Fuel temperature sender
G247 Fuel pressure sender
G581 Position sender for charge pressure positioner
Klaus Ludwig
C?ID=227092
Thanks for the confirmation @Quintus Rotam,
Already found their functions on the Current Flow Diagram very shortly after my last post, but as could not put my hands on them for real without a bit of a look around we have decided to send the ECU off for testing. Our tests to date indicate that the ECU is almost certainly where our issue is. We look forward to the feedback from our ECU specialist sometime next week.
Klaus Ludwig
C?ID=227092
Hi @Crasher,
As I believe you may have hinted at, I would have expected other faults to register on VCDS if any other actuators/sensors that share a feed with the EGR valve were faulty. As all continuity tests and tests to earth were good (even though I did not disconnect linked devices), it’s looking very much like an ECU fault.
The owner of the car is intending to use ecutesting.com
Assume that you have had a less than positive experience with ECU repair(s)?
I have absolutely no idea how much a new/exchange programmed ECU would cost from a main VW dealer. If you have a rough idea I would be interested to know. I believe parts and service departments of main dealers not open right now on a Saturday afternoon so cannot find out till Monday
What way forward would you choose if you don’t trust ECU repairers?
Ohh God no, not him… just upt A610 from ere, notorious in the Nottingham motor trade. I did a court report for another garage over a DQ200 Mechatronic cock up they did.
  • Informative
Klaus Ludwig
C?ID=227092
Hi @Crasher,
Finally put my hands on the exact circuit flow diagram for our B6 Passat. I hadn’t realised that the wiring PDF document contained a number of different current flow diagrams depending on engine code. Our engine code is CBDC.
Before committing to use a “charlatan” and now with the correct Current Flow Diagram, armed with a better understanding of the circuit we tested T6/3 to earth and found no continuity. Testing T6/3 to T60/53 gives continuity.
As you have mentioned, half a dozen devices share a common earth. I see that this is via “85 Earth connection 1 , in engine compartment wiring harness”.
We currently have no idea of where exactly to look for the open circuit fault between T6/3 and earth. Have not yet tested the other 5 devices to earth, but as you have also mentioned if other devices were not earthed then they would give DTC’s . They do not, so more inclined to focus on the EGR T6/3 earth.
Not certain if the common earth on “85” is daisy chained or if all 6 device earths go directly to “85 earth connection 1 in engine compartment wiring harness”
Currently have no idea where “85 earth connection 1 in engine compartment wiring harness” is. Any ideas of physically where this is or where to look for our fault appreciated!
