Golf MK5 GTI mirror dipping in reverse
NetStef
Greece
C?ID=496274
Hello all, new to VCDS, today i enabled the first tweaks in my Golf MK5 GTI.
I would like also to enable the mirror dipping in reverse gear, i've read many things around but i could not get a clear answer if this can be done.
Some tips, i have DSG, i don't have foldable mirrors and seats with memory.
This is my auto-scan:
Sunday,17,October,2021,12:35:55:50950
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: WVWZZZ1KZ7W06113  License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WVWZZZ1KZ7W061132   Mileage: 120800km-75061miles
   Part No SW: 1K0 907 115 J    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0030
   Revision: --H14---    Serial number: VWZ7Z0F8091395
   Coding: 040300031C070160
   Shop #: WSC 01080 207 87243
   VCID: 2D070111C11D4E033C7-8078
   VINID: 9E69EAAAA05BA879C01810430848BF8330
   Part No SW: 02E 300 043 C    HW: 02E 927 770 AE
   Component: GSG DSG         070 1111
   Revision: 04507000    Serial number: 00000607230300
   Shop #: WSC 01279 785 00200
   VCID: 1471B4F54277FFCB139-8040
   Revision: 00H11001
   Coding: 0004738
   VCID: 73B3D76967B958F3AA3-8026
   Part No SW: 1K0 907 044 BH    HW: 1K0 907 044 BH
   Component: ClimatronicPQ35 090 0909
   Revision: 00090016    Serial number: 00000000000000
   VCID: 6E85C61D0C9B751B45D-803A
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Revision: 00H37000    Serial number: 00000005994002
   Coding: E58D0F2700041500001400001400000000097F075C
   Shop #: WSC 00000 785 00200
   VCID: 2B030F09FF094033223-807E
   Component: Wischer 260706 020  0501
   Coding: 00038805
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     081706 020  0103
   Coding: 00208933
   Component: 37 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0P2EGK
   Coding: 0013111
   Shop #: WSC 01269 785 00200
   VCID: 3D273151117DDE838C7-8068
   Subsystem 1 - Serial number: 6332MSME12247E0AB
   Subsystem 2 - Serial number: 6342MSME12227341.
   Subsystem 3 - Serial number: 6352QSME14590B0DK
   Subsystem 4 - Serial number: 6362QSME112E456BM
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           636 0070
   Coding: 0012142
   VCID: 015F8DA12D057A63A8F-8054
   Part No SW: 1K6 920 863     HW: 1K6 920 863
   Revision: V0003000    Serial number: VWZ7Z0F8091395
   Coding: 0003103
   Shop #: WSC 80093 222 69422
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 31001067240619
   Coding: 3F0F034007000000
   VCID: 2C010C15FA07470B2B9-8078
                    Reset counter: 81
                    Mileage: 120805 km
                    Time: 12:34:11
   Component: IMMO            VDD 1610
   Component: Tuer-SG         005 0967
   Coding: 0000052
   VCID: 382920453E5FFBAB5F1-806C
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.074 H07 1806
   Shop #: WSC 00000 028 00001
   VCID: 3431147522371FCB739-8060
   Part No: 1K0 959 433 AJ
   Coding: 18C802087F2D8405484A01E010CC
   Shop #: WSC 00006 207 76781
   VCID: 78A9E0457EDF3BAB9F1-802C
   Coding: 0000052
   VCID: 392F25410555E2A3A0F-806C
Address 56: Radio        Labels:
   VCID: 55F789F18C0D26C3A47-FFFE
End----------(Elapsed Time: 01:11, VBatt start/end: 13.7V/13.8V)-----------
Could you please advise?
Thanks in advance.
You have PR:6XN mirrors, I can’t check the Pr code definitions without ETKA but I think you need the 6XT spec motor.
TBAx
C?ID=287144
Correct, the passenger side module is not able to dip the mirror.
NetStef
Greece
C?ID=496274
Hello Crasher and TBAx,
Thanks a lot for your answers.
For avoiding any misunderstanding, just to mention that the function i need is the mirror down in reverse.
Is this related to folding mirrors?
The folding mirrors has a specific motor, t he adjustment unit can be changed and I get the number as 3D0 959 578 C but I suspect the harness from the door controller will not have the wiring
siLc
Tallinn, Estonia
C?ID=330192
Not the door controller, but the door mirror harness. For running those, there should be wiring kits available from the well-known oriental bazaar.
Yes, the wiring from the controller to the mirror. On the wiring diagram and parts system I can’t see that reverse dip was offered that early
