Can the ESP-disable button be made to light up orange?
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
You know you spend too much time and money on Volkswagens when your dealer calls you with questions. :D But they're great people and I live for weird questions.
In this particular case, they had a customer with a Mk7.5 GTI or R (I forget which), and C/S the ESP disable button doesn't switch to orange when ESP was in sport or disable mode. They didn't have another one on the lot, and so my service advisor wanted to know if mine behaved that way as well. I had no idea, so I walked out there and checked with her on the phone, and sure enough, the backlight color doesn't change like the others do (mode/profile, start/stop disable, park assist) when in non-default states.
So that's the factory state. But is that tunable anywhere? Without tracing WDs, I'm not even sure what control module these buttons are wired to.
Obligatory:
Thursday,14,October,2021,10:53:04:50497
VCDS Version: 21.9.0.1 (x64)  HEX-NET2 CB: 0.4555.4
Data version: 20210824 DS330.0
VIN: WVWVF7AU2JW177386   License Plate: 2018GOLFR
Mileage: 84479km-52492mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 39 3C 42 44
          47 4B 52 5F 75 A5 A9 D6 D7
VIN: WVWVF7AU2JW177386   Mileage: 84479km-52492miles
Address 01: Engine (J623-DJJA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 P    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---    CVN: A2E3C47F
   Coding: 0A2500122466010E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259P 001003
   ROD: EV_ECM20TFS0208V0906259P.rod
   VCID: CDCC827DFD5DCA739C4-8098
   VINID: 9E69E658746509A9C11C70C818AC092F66
22008 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [032] - -
   Part No SW: 0GC 300 012 A    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 1403
   Revision: 00H06V07    CVN: 3F2CB79C
   ROD: EV_TCMDQ381061.rod
   VCID: A1140ECDD1453E1308C-80F4
   No subsystems:
   Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
   Component: ESC           H25 0523
   Revision: 00000000    Serial number: 63627000001098
   Coding: 01FA6BA154272173457A030860C96980D62A84A2C0069677384250D8C2A8430B00000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 835864456B99CC033A0-80D6
8400 - Databus
          [FCAN: AB_Gurt_FA signal is invalid]
                    Reset counter: 54
                    Mileage: 81934 km
                    Date: 2021.09.20
                    Time: 20:06:12
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0464858592
   Coding: 032C0C
   VCID: BC2ADFB956E773FB3BA-80E8
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0002000420010201110501401211142A
   Shop #: WSC 08607 444 00001
   VCID: ED8C22FD5D1D2A73FC4-80B8
   Air quality sensor:
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 01001735200577
   Coding: 000000000000080000000000000000000000000000000000000000000000
   ROD: EV_BCMBOSCH_018.rod
   VCID: 865E7D5158ABF92B1DE-80D2
   Component: WWS    171209  043 0551
   Serial number:         171213061443
   Component: RLHS  047 0105
   Serial number: S4Y18M01D10H22M47S41
   Coding: 00A8DD
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 225
                    Mileage: 81089 km
                    Date: 2021.08.24
                    Time: 15:40:26
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418918005
   Coding: 0471155811
   ROD: EV_EPHVA18AU3700000.rod
   VCID: CBC88C650349C443820-809E
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 3318C7E2DDFFCF28949C832580401600000000000000000000
   Shop #: WSC 08607 444 00005
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: BE2ED5B140FB61EB15E-80EA
0790 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
          C1103 00 [008] - -
          [FAULT_MISALIGNMENT_HORIZONTAL]
                    Reset counter: 76
                    Mileage: 83749 km
                    Date: 2021.10.09
                    Time: 09:50:00
                    Control Module temperature: 30 °C
                    Voltage terminal 15: 13.2 V
                    Velocity_vehicle_reference: 18.28 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.03 m/s²
                    Status_ACC_System: ACC_activ_controlled
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Fault Frequency: 51
                    Reset counter: 72
                    Mileage: 83354 km
                    Date: 2021.10.08
                    Time: 13:29:17
                    Voltage terminal 15: 14.4 V
1236 - Databus
          [FAULT_TIMEOUT_BV1_POSITION]
                    Reset counter: 65
                    Mileage: 81623 km
                    Date: 2021.09.08
                    Time: 15:22:22
                    Control Module temperature: 49 °C
                    Voltage terminal 15: 14.0 V
                    Velocity_vehicle_reference: 2.29 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.86 m/s²
   Serial number: 24111741350693
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: B822C3A962DF5FDBDF2-80EC
   Serial number: 003GCR09SK3W
   VCID: C7C0B0551F212023A68-8092
   Serial number: IBH000000000008EZ3AU
   Coding: 303344
   Subsystem 2 - Part No SW: -----------    HW: 480 000 501 18
   Serial number: 35700000000198194A2G
   Subsystem 3 - Part No SW: -----------    HW: 480 000 201 18
   Serial number: 358000000007D82D1A2T
   Subsystem 4 - Part No SW: -----------    HW: 480 402 312 17
   Serial number: 3510001C9284E2D6869H
   Subsystem 5 - Part No SW: -----------    HW: 480 402 712 17
   Serial number: 3520001AB288D0F4E33G
   Subsystem 6 - Part No SW: -----------    HW: 480 402 212 17
   Serial number: 3550001C7284E2D3A79J
   Subsystem 7 - Part No SW: -----------    HW: 480 402 212 17
   Component: FrontSensor_P  000 6149
   Serial number: 3560001C7284E2D20755
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 28121704221561
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_018_VW37.rod
   VCID: 8944766D49B5965370C-80DC
   Part No SW: 5G1 920 891 A    HW: 5G1 920 891 A
   Component: KOMBI         408 3195
   Coding: 03AD301A7F88CF0502886B0B54010000A0000000
   VCID: AB08ECE5A389E443A20-80FE
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007198325
   Coding: 030100047F085902FB00827ADC0F00010001070000000000000000000000
   GVL: 01D63C100000060040CC80008000CC0000000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW37.rod
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Serial number: 29170002448880057427
   Coding: 35FFFF
   Serial number: 3640416404
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Ruhestrom oberer Grenzwert überschritten]
                    Fault Frequency: 45
                    Reset counter: 85
                    Terminal 30 power supply: 12.3 V
                    Terminal 15: OFF
   Serial number: HA1-00003.11.17
   Coding: 0001
   VCID: CCDECC67F647C37B8BA-FFFE
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   Revision: 00000000    Serial number: 17000376691003
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: B43AF7997EB7BBBBF3A-80E0
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Component: HRE_Master    H12 0080
   Serial number: 0464678659
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: BD2CD2BD4DFD7AF30C4-80E8
   Component: HRE_Slave  H12 0080
   Serial number: 0465504023
   Coding: 020111
   Serial number: 021217EL138903
   Coding: 003E13208000040000000000
   VCID: C3D8A4452B190C037A0-8096
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000018361075
   Coding: 111000
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: BB28DCA553E974C3320-80EE
24320 - Steering
          C10AC 07 [009] - Mechanical Failure
          [Belastungszähler hat 99% überschritten Belastungszähler hat 100% erreicht]
                    Reset counter: 225
                    Mileage: 81083 km
                    Date: 2021.08.24
                    Time: 15:24:54
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 13.25 V
                    Temperature: 74.0 °C
                    KFC: 5F
                    KFA: 00 00
                    Freeze frame conditions: 5F
                    uioUdNotFilt_xdu16: 13.42 V
                    uAdSensI_SwitchedKl30_xdu16: 13.31 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
21760 - Databus
          [HCA_01 Botschaft - CAN-Timeout]
                    Reset counter: 16
                    Mileage: 81265 km
                    Date: 2021.08.28
                    Time: 14:07:44
                    Motor status: 02
                    Supply voltage: 13.00 V
                    Temperature: 46.0 °C
                    KFC: 55
                    KFA: 00 00
                    Freeze frame conditions: 20
                    uioUdNotFilt_xdu16: 13.08 V
                    uAdSensI_SwitchedKl30_xdu16: 12.99 V
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1HMD01KBFQ
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: AE0EE5F1909B916B85E-80FA
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 21121710521279
   Coding: 000000050100165207713F07020000000000000000000000000000000000
   VCID: F2B631814423F58B216-80A6
   Serial number: 101217ELA06139
   Coding: 003E13208000040000800000
   VCID: C2D6A1413403050B716-8096
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000018233831
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    851 0867
   Coding: 027310020000000051220002001808009F0507F401200405C6
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: B338F4857BB9BC83EA0-80E6
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZJW0601020
   Subsystem 2 - Part No SW: 3G0 919 866 BP    HW: -----------
   Component: NAR 2018  --- 0715
   Component: OCULowMQBUS   009 0570
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
9458451 - Cellular Antenna
          B1053 13 [008] - Open Circuit
          [GSM antenna open load]
                    Fault Frequency: 23
                    Reset counter: 64
                    Mileage: 81115 km
                    Date: 2021.08.24
                    Time: 18:43:13
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 0272
   Serial number: 22121712P20035
   Coding: 00030700000002010022135481568900D9000E200120
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 171206201656
   VCID: AF30F8F5979198638E8-80FA
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: B924C6AD59D546D320C-80EC
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
End----------(Elapsed Time: 03:54, VBatt start/end: 14.1V/14.3V)-----------
TBAx
C?ID=287144
Hmm, never noticed this behavior. I am pretty sure the button is illuminated in my O3.
Is there any way you could provide an adpmap of the module 03?
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
blockmap
;SW:5Q0-614-517-CR   HW:5Q0-614-517-AD ---  ABS Brakes
;Component:ESC           H25 0523, Coding:01FA6BA154272173457A030860C96980D62A84A2C0069677384250D8C2A8430B00000012121212B835351919323200
;EV_Brake1UDSContiMK100IPB,037009,EV_Brake1UDSContiMK100IPB_037_VW37.rod
;Thursday,14,October,2021,15:45:54:50497
;VCDS Version: Release 21.9.0 (x64)  Data version: 20210824 DS330.0
;VCID: 835864456B99CC033A0-80D6
Group,Description,Actual
IDE00609-MAS01155,Communication status of data bus 1-Control module,Engine Electronics,
IDE00609-MAS01156,Communication status of data bus 1-Communication status,active,
IDE00780,Mode,running_mode,
IDE02270-IDE00086,CAN input signal(s) status-Accelerator pedal position,0, %
IDE02270-IDE02049,CAN input signal(s) status-Trailer detected,Malfunction,
IDE02270-IDE02713,CAN input signal(s) status-Brake lamp switch,Not operated,
IDE02270-MAS00025,CAN input signal(s) status-Driver seat belt switch,not connected,
IDE02270-MAS00218,CAN input signal(s) status-Driver door,closed,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,operated,
IDE02270-MAS00364,CAN input signal(s) status-Shift lever / selector lever position,Neutral,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamp,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,AU77386,
IDE02270-MAS03992,CAN input signal(s) status-Clutch pedal switch: interlock position,active,
IDE02271-IDE03311,CAN output signal(s) status-Emergency braking display,not active,
IDE02271-IDE03660,CAN output signal(s) status-Longitudinal acceleration,0.12500, m/s²
IDE02492,Start/Stop Function: coding information,Start-stop function in control module active,
IDE02986-IDE04431,Indicator lamps-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,Indicator lamps-Tire press monitoring display indictor lamp,OFF,
IDE02986-IDE04498,Indicator lamps--AUTO HOLD- Indicator Lamp,OFF,
IDE02986-IDE04771,Indicator lamps-Indicator lamp for electro-mechanical parking brake malfunction,OFF,
IDE02986-MAS00253,Indicator lamps-ABS indicator lamp,OFF,
IDE02986-MAS00556,Indicator lamps-Electromechanical parking brake indicator lamp,OFF,
IDE02986-MAS01206,Indicator lamps-Hill descent control indicator lamp,Not available due to specific system,
IDE02986-MAS02925,Indicator lamps-Brake system indicator lamp,OFF,
IDE02986-MAS03234,Indicator lamps-ESP_off indicator lamp,OFF,
IDE03008-IDE05181,Stop process prevented-Emerg.brake,not active,
IDE03008-MAS04513,Stop process prevented-ABS control module pump running,not active,
IDE03008-MAS04515,Stop process prevented-Roll back detection,not active,
IDE03009-IDE04446,Start process requested-Hill descent control,not active,
IDE03009-IDE06139,Start process requested-AUTO HOLD slippage recognition,not active,
IDE03009-MAS02515,Start process requested-System malfunction,not active,
IDE03009-MAS04485,Start process requested-ESP function deactivation,not active,
IDE03009-MAS04515,Start process requested-Roll back detection,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,0,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.brake,0,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,3,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,25,
IDE03010-MAS04513,Number of prevented stop processes-ABS control module pump running,65535,
IDE03010-MAS04515,Number of prevented stop processes-Roll back detection,0,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,3,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,959,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,0,
IDE03011-MAS02515,Number of requested start processes-System malfunction,0,
IDE03011-MAS04485,Number of requested start processes-ESP function deactivation,1,
IDE03011-MAS04515,Number of requested start processes-Roll back detection,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2021,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,9,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,1,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,25,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,5,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,17,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,19,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,22,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,14,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,22,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,38,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,26,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,30,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,6,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,8,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,7,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,18,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,9,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,13,
IDE03127,Prevented stop processes (ring memory),Initial value,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2021,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2000,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2126,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,0,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,10,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,14,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,0,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,13,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,0,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,30,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,21,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,62,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,0,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,20,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,0,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,62,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,37,
IDE03128,Requested start processes (ring memory),Unknown (6),
IDE03128,Requested start processes (ring memory),Initial value,
IDE03207,Hardware version for suppliers,Freescale,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,No release by coordinator,
IDE03527-IDE02070,CAN signals-Wake-up cause,1,
IDE03527-IDE02445,CAN signals-Transmission type,24,
IDE03651,Bleed brake system (rework bleeding),0.00, s
IDE03680-IDE00018,Supply voltages-Voltage terminal 15,On,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,5.005, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,0.014, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,14.107, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,On,
IDE04422-IDE04442,Brake system sensor-Vacuum sensor,-965, mbar
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,0.00, bar
IDE04422-IDE04494,Brake system sensor-Brake pressure sensor 1: uncond voltage 1,Not available due to specific system,
IDE04422-IDE04495,Brake system sensor-Brake pressure sensor 1: uncond voltage 2,Not available due to specific system,
IDE04422-MAS00179,Brake system sensor-Brake lamp switch,Not operated,
IDE04422-MAS02152,Brake system sensor-EPB clutch pedal travel,Not available due to specific system,
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.0, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,Malfunction,
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Wheel speed: right front,0.0, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,Malfunction,
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.0, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.0, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04442-IDE00009,Vacuum sensor-Date of manufacture,KW 40 2017,
IDE04442-IDE00010,Vacuum sensor-Serial number,06 8B 33 05 87,
IDE04442-IDE00104,Vacuum sensor-DTC,0,
IDE04442-IDE02955,Vacuum sensor-System status,available.,
IDE04442-IDE03205,Vacuum sensor-Manufacturer code,0,
IDE04442,Vacuum sensor,-965, mbar
IDE04442-MAS12759,Vacuum sensor-Type of individual vacuum sensor,2,
IDE04443-IDE02241,Slip control system sensor-Lateral acceleration sensor 1,-0.30411, m/s²
IDE04443-IDE02538,Slip control system sensor-Longitude Acceleration Sensor,-0.16677, m/s²
IDE04443-IDE04429,Slip control system sensor-Lateral acceleration sensor 1: offset,-0.00000, m/s²
IDE04443-IDE04430,Slip control system sensor-Longitudinal acceleration sensor: offset,0.12500, m/s²
IDE04443-IDE04449,Slip control system sensor-Rotation rate sensor 1: Z-axis,0.226, °/s
IDE04443-IDE04460,Slip control system sensor-Steering angle sensor: offset straight line running,-0.569, °
IDE04443-MAS00815,Slip control system sensor-Steering angle sensor,-0.569, °
IDE04446-IDE01599,Hill descent control-Incline,0, %
IDE04446-IDE03664,Hill descent control-Button for driving program,not activated,
IDE04446-MAS03095,Hill descent control-Function status,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,Not operated,
IDE04452-IDE03663,Brake system button--AUTO HOLD- Button,Not operated,
IDE04452-IDE03664,Brake system button-Button for driving program,Not operated,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,Not operated,
IDE04452-IDE04769,Brake system button-Electro-mechanical parking brake button: status,Not operated,
IDE04456-IDE02955,Brake disk drying-System status,available.,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,83741, km
IDE04461-IDE03208,Internal measured values-Software version for suppliers,MYERAC00063,
IDE04461-IDE03649,Internal measured values-Fill/bleed brake system,not completed successfully,
IDE04461-MAS01481,Internal measured values-Temperature in control module,36, °C
IDE04461-MAS04484,Internal measured values-Flashloader version, TSCBAB00008,
IDE04499-IDE02955,Sensor for roof rack recognition-System status,Not available due to specific system,
IDE04499-MAS03095,Sensor for roof rack recognition-Function status,not detected,
IDE04508-IDE02955,Hydraulic brake booster-System status,available.,
IDE04508-IDE04442,Hydraulic brake booster-Vacuum sensor,-965, mbar
IDE04508-IDE04450,Hydraulic brake booster-Brake pressure sensor 1,0.00, bar
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04508-MAS04002,Hydraulic brake booster-Low intake manifold pressure,576, mbar
IDE04644-IDE02955,Roll-over protection-System status,Not available due to specific system,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,0, km
IDE04645-IDE00003,Electromechanical parking brake-Coding,will be performed.,
IDE04645-IDE00902,Electromechanical parking brake-Automatic distance control: status,activated,
IDE04645-IDE02652,Electromechanical parking brake-Start-stop status,activated,
IDE04645-IDE02955,Electromechanical parking brake-System status,available.,
IDE04645-IDE03493,Electromechanical parking brake-Driver's door status,activated,
IDE04645-IDE04871,Electromechanical parking brake-Dynamic starting assist,activated,
IDE04645-IDE04944,Electromechanical parking brake-Brake pedal evaluation,activated,
IDE04645-IDE04948,Electromechanical parking brake-Fall-back level,0,
IDE04645-IDE05711,Electromechanical parking brake-Automatic application during engine stalling,activated,
IDE04645-IDE06590,Electromechanical parking brake-Play protection counter: button for electromech. parking brake,0,
IDE04645-MAS02666,Electromechanical parking brake-Seat belt buckle scan,activated,
IDE04645-MAS03998,Electromechanical parking brake-Delay interface for electro-mechanical parking brake,6,
IDE04646-IDE02657,Electromechanical parking brake: parking brake motors-Cut-off current: left: reached,0.00, A
IDE04646-IDE02658,Electromechanical parking brake: parking brake motors-Cut-off current: right: reached,0.00, A
IDE04646-IDE04496,Electromechanical parking brake: parking brake motors-Left parking brake motor: status,Open,
IDE04646-IDE04497,Electromechanical parking brake: parking brake motors-Right parking brake motor: status,Open,
IDE04646-IDE04506,Electromechanical parking brake: parking brake motors-Calculated left rear brake temperature,27.5, °C
IDE04646-IDE04507,Electromechanical parking brake: parking brake motors-Calculated right rear brake temperature,27.5, °C
IDE04646-IDE04647,Electromechanical parking brake: parking brake motors-Left parking brake motor: current,0.00, A
IDE04646-IDE04648,Electromechanical parking brake: parking brake motors-Right parking brake motor: current,0.00, A
IDE04646-IDE05048,Electromechanical parking brake: parking brake motors-Left parking brake motor: actuation counter,2685,
IDE04646-IDE05049,Electromechanical parking brake: parking brake motors-Right parking brake motor: actuation counter,2685,
IDE04765-IDE02955,Counter steer support-System status,available.,
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,83182, km
IDE04772-IDE03530,Indicator light in the button for electromech. parking brake-Monitoring status,7,
IDE04772-MAS03745,Indicator light in the button for electromech. parking brake-Function light,OFF,
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,Not available due to specific system,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,0, km
IDE04871-IDE01599,Dynamic starting assist-Incline,1, %
IDE04871-IDE02445,Dynamic starting assist-Transmission type,automatic,
IDE04871-MAS01447,Dynamic starting assist-Act.val.,normal,
IDE04871-MAS03995,Dynamic starting assist-Clutch pedal threshold: initial value,60, %
IDE04871-MAS03996,Dynamic starting assist-Clutch pedal threshold: learned value,0, %
IDE04871-MAS04734,Dynamic starting assist-Required engine torques: current slope (TARGET),0, Nm
IDE04871-MAS04735,Dynamic starting assist-Current engine torques (ACTUAL),0, Nm
IDE04871-MAS04736,Dynamic starting assist-Expected achievable engine torques,0, Nm
IDE04939-IDE02955,Tire Pressure Monitoring System (TPMS)-System status,available.,
IDE04939-IDE04248,Tire Pressure Monitoring System (TPMS)-Left front tire pressure diffusion indicator,255,
IDE04939-IDE04249,Tire Pressure Monitoring System (TPMS)-Right front tire pressure diffusion indicator,255,
IDE04939-IDE04250,Tire Pressure Monitoring System (TPMS)-Left rear tire pressure diffusion indicator,254,
IDE04939-IDE04251,Tire Pressure Monitoring System (TPMS)-Right rear tire pressure diffusion indicator,254,
IDE04939-IDE04432,Tire Pressure Monitoring System (TPMS)-Tire Pressure Monitoring Display Button,Not operated,
IDE04939-IDE04946,Tire Pressure Monitoring System (TPMS)-Odometer reading at last adaptation,83354, km
IDE04939-IDE04947,Tire Pressure Monitoring System (TPMS)-Odometer reading of last warning,62304, km
IDE04939-MAS04538,Tire Pressure Monitoring System (TPMS)-Odometer reading two adaptations ago,73586, km
IDE04939-MAS04539,Tire Pressure Monitoring System (TPMS)-Odometer reading three adaptations ago,70522, km
IDE04939-MAS04540,Tire Pressure Monitoring System (TPMS)-Odometer reading four adaptations ago,68374, km
IDE04939-MAS04541,Tire Pressure Monitoring System (TPMS)-Odometer reading of next-to-last warning,61829, km
IDE04939-MAS04542,Tire Pressure Monitoring System (TPMS)-Odometer reading of third-to-last warning,46415, km
IDE04939-MAS04543,Tire Pressure Monitoring System (TPMS)-Odometer reading of fourth-to-last warning,18750, km
IDE04939-MAS04544,Tire Pressure Monitoring System (TPMS)-Left front flat tire indicator,255,
IDE04939-MAS04545,Tire Pressure Monitoring System (TPMS)-Right front flat tire indicator,255,
IDE04939-MAS04546,Tire Pressure Monitoring System (TPMS)-Left rear flat tire indicator,255,
IDE04939-MAS04547,Tire Pressure Monitoring System (TPMS)-Right rear flat tire indicator,255,
IDE05712-IDE02955,AUTO HOLD-System status,available.,
IDE05712-IDE03530,AUTO HOLD-Monitoring status,7,
IDE05712-IDE04498,AUTO HOLD--AUTO HOLD- Indicator Lamp,OFF,
IDE05712-IDE04561,AUTO HOLD-Switch-on and shut-off conditions,Condition met,
IDE05712-IDE05333,AUTO HOLD-Indicator light in AUTO HOLD button,OFF,
IDE05712-MAS00025,AUTO HOLD-Driver seat belt switch,not connected,
IDE05712-MAS03095,AUTO HOLD-Function status,not active,
IDE05712-MAS04006,AUTO HOLD-Operating mode,Last setting,
IDE05712-MAS04409,AUTO HOLD-Active hold,not active,
IDE05712-MAS04411,AUTO HOLD-Hydraulic pressure transfer to electro-mechanical parking brake,No,
IDE06591-ENG118150,Pump load counter-Comp_Rotatation_of_pump_motor,467795,
IDE06591-ENG118152,Pump load counter-Load_on_feeding_side_of_Pump,1868733,
IDE06591-ENG118151,Pump load counter-Load_on_suction_side_of_Pump,8086,
IDE06591-ENG118153,Pump load counter-Pump_motor_start_counter,46478,
IDE07280-IDE04775,Multiple collision brake-Odometer reading of last activation,0, km
IDE07280-IDE06609,Multiple collision brake-Odometer reading of last deactivation,0, km
IDE07280-MAS00106,Multiple collision brake-Year,2126,
IDE07280-MAS00107,Multiple collision brake-Month,14,
IDE07280-MAS00108,Multiple collision brake-Day,0,
IDE07280-MAS00109,Multiple collision brake-Hours,30,
IDE07280-MAS00110,Multiple collision brake-Minutes,62,
IDE07280-MAS00111,Multiple collision brake-Seconds,62,
IDE07280-MAS07659,Multiple collision brake-Frequency counter for multi-collision brake active,0,
IDE07280-MAS07660,Multiple collision brake-Frequency counter for multi-collision brake deactivated,0,
IDE07280-MAS07661,Multiple collision brake-Frequency counter function deactivated by driver,0,
IDE07280-MAS07662,Multiple collision brake-Mileage reading of the last deactivation by driver,0, km
IDE80101,Analysis 101,A3 32 38 35 31 35 37 38 38 34 31 33 30 30 30 30 36 31 37 43 32 38 30 30 34 34 41 2F 02 2A 1E 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80102-ENG122580,Analysis 102-value_1_percentaged,94.5252, %
IDE80102-ENG122579,Analysis 102-value_1_quantity,0,
IDE80102-ENG122582,Analysis 102-value_2_percentaged,97.65, %
IDE80102-ENG122581,Analysis 102-value_2_quantity,0,
IDE80102-ENG122584,Analysis 102-value_3_percentaged,92.9628, %
IDE80102-ENG122583,Analysis 102-value_3_quantity,8384,
IDE80102-ENG122586,Analysis 102-value_4_percentaged,96.8688, %
IDE80102-ENG122585,Analysis 102-value_4_quantity,7858,
IDE80102-ENG122588,Analysis 102-value_5_percentaged,96.4782, %
IDE80102-ENG122587,Analysis 102-value_5_quantity,2062,
IDE80102-ENG122590,Analysis 102-value_6_percentaged,99.9936, %
IDE80102-ENG122589,Analysis 102-value_6_quantity,3623,
IDE80103-MAS00976,Analysis 103-Counter,0,
MAS00121-IDE02955,Electronic Differential Lock-System status,available.,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,27.5, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,27.5, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,27.5, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,27.5, °C
MAS00121-MAS00179,Electronic Differential Lock-Brake lamp switch,Not operated,
MAS00121-MAS01853,Electronic Differential Lock-Left front,available.,
MAS00121-MAS01854,Electronic Differential Lock-Right front,available.,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,available.,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,available.,
MAS00210-IDE80007,Parking Brake-Analysis 7,0, km
MAS00210-IDE80008,Parking Brake-Analysis 8,81291, km
MAS00210-IDE80009,Parking Brake-Analysis 9,80027, km
MAS00210-IDE80010,Parking Brake-Analysis 10,81128, km
MAS00210-IDE80011,Parking Brake-Analysis 11,83354, km
MAS00210-IDE80012,Parking Brake-Analysis 12,8F 0A 11 10 02 0C,
MAS00210-ENG36680,Parking Brake-ActDbg_ECR_EvCnt,0,
MAS00210-ENG36681,Parking Brake-ActDbg_ESA_EvCnt,0,
MAS00210-ENG36682,Parking Brake-ActDbg_OTH_EvCnt,0,
MAS00210-ENG36683,Parking Brake-ActDbg_SAR_EvCnt,0,
MAS00210-ENG36684,Parking Brake-ActDbg_UV_EvCnt,0,
MAS00210-ENG36685,Parking Brake-ActDbg_UVE_EvCnt,0,
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,available.,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch: status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Fully open,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,0, Nm
MAS02138-IDE02955,Hill-start assistant-System status,Not available due to specific system,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,not connected,
MAS02138-MAS00218,Hill-start assistant-Driver door,closed,
MAS02138-MAS03095,Hill-start assistant-Function status,not active,
MAS02426-MAS00580,Text display in instrument cluster-Electromechanical parking brake text 1,0,
MAS02426-MAS03359,Text display in instrument cluster-Text,0,
MAS02672-IDE02955,Start-stop-System status,available.,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE03215,Start-stop-Engine start using start-stop function,not active,
MAS02672-MAS00025,Start-stop-Driver seat belt switch,not connected,
MAS08072-MAS13685,Driving profile selection-Actual value of downhill driving assistant,0,
MAS08072-MAS13686,Driving profile selection-Actual value uphill driving assistant,0,
MAS08072-MAS13687,Driving profile selection-Actual value of differential lock,0,
MAS08072-MAS13688,Driving profile selection-ESC actual value,0,
MAS08072-MAS13689,Driving profile selection-Compatibility of downhill driving assistant,Yes,
MAS08072-MAS13690,Driving profile selection-Compatibility of uphill driving assistant,Yes,
MAS08072-MAS13691,Driving profile selection-Compatibility of differential lock,Yes,
MAS08072-MAS13692,Driving profile selection-ESC compatibility,Yes,
MAS08072-MAS13693,Driving profile selection-Spec. value of downhill driving assistant,0,
MAS08072-MAS13694,Driving profile selection-Spec. value of uphill driving assistant,0,
MAS08072-MAS13695,Driving profile selection-Spec. value of differential lock,0,
MAS08072-MAS13696,Driving profile selection-ESC spec. value,0,
MAS08072-MAS13697,Driving profile selection-System status of downhill driving assistant,available.,
MAS08072-MAS13698,Driving profile selection-System status uphill driving assistant,Not available,
MAS08072-MAS13699,Driving profile selection-System status of differential lock,Not available,
MAS08072-MAS13700,Driving profile selection-ESC system status,available.,
MAS08072-MAS13701,Driving profile selection-Switchover status of downhill driving assistant,Shifting carried out,
MAS08072-MAS13702,Driving profile selection-Switchover status of uphill driving assistant,Shifting carried out,
MAS08072-MAS13703,Driving profile selection-ESC switchover status,Shifting carried out,
MAS08072-MAS13704,Driving profile selection-Switchover status_differential lock,Shifting carried out,
ENG26281-IDE01011,HBV_Event_Counter-Data record,0,
Elapsed Time: 00:14
adpmap
;Thursday,14,October,2021,15:46:08:50497
IDE00252-Brake system vacuum pump,5 ,1
IDE00820-Activating and deactivating all development messages,0 ,1
IDE01763-Dimming,not activated ,1
IDE02332-Deactivate production mode,Deactivating ,3
IDE03493-Driver's door status,activated ,1
IDE03659-Roller test bench mode,Manual activation: possible ,1
IDE04456-Brake disk drying,Medium ,1
IDE04508-Hydraulic brake booster,8 ,1
IDE04643-Overboost in brake system,activated ,1
IDE04645-Electromechanical parking brake,not activated ,1
IDE04774-Vehicle and trailer stabilization,not activated ,1
IDE04871-Dynamic starting assist,normal ,1
IDE04939-Tire Pressure Monitoring System (TPMS),2 ,1
IDE04944-Brake pedal evaluation,activated ,1
IDE04949-Engine drag torque control,activated ,1
IDE04951-Brake Boost,4 ,1
IDE04952-Braking torque boost for distance regulation,3 ,1
IDE05055-Hydraulic brake assistant,normal ,1
IDE05057-Brake prefill,activated ,1
IDE05161-Straight ahead brake stabilization,activated ,1
IDE05263-AUTO HOLD functionality,not activated ,1
IDE05264-AUTO HOLD increase threshold: reduced tensioning force,0 %,1
IDE05265-AUTO HOLD increase threshold: full tensioning force,10 %,1
IDE05286-Expanded electronic differential lock,Standard ,1
IDE05711-Automatic application during engine stalling,activated ,1
IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7 ,2
IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button,7 ,2
IDE06139-AUTO HOLD slippage recognition,activated ,1
IDE06505-Electromechanical parking brake: delay level,6 ,1
IDE07006-Tire pressure monitoring display: tire selection,2 ,1
IDE07292-Brake pre-filling,not completed successfully ,1
IDE07565-ABS in lower speed range,activated ,1
IDE07848-Thresholds for brake performance,activated ,1
IDE12030-Rough road optimization,activated ,1
MAS00122-Electronic Stability Program,not activated ,1
MAS00970-Running manufacturer number,activated ,1
MAS01180-AUTO HOLD functional status,Last setting ,1
MAS01299-Offroad,0 ,1
MAS02080-XCP calibration protocol,not activated ,1
MAS02138-Hill-start assistant,normal ,1
MAS02666-Seat belt buckle scan,activated ,1
MAS09008-MAS00988-Plausibility check-Reverse gear,activated ,3
MAS09008-MAS09009-Plausibility check-Neutral gear sensor,activated ,3
MAS09008-MAS10668-Plausibility check-Clutch movement,activated ,3
MAS11606-Electromechanical parking brake: emergency braking,activated ,1
ENG118148-Developer_Function_1,0 ,1
ENG130301-Developer_Function_121,not activated ,1
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
ENG122844-ENG99557-dimming_characteristic_1-X2,10 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,50 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,100 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,220 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,253 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,6 ,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 ,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,8 ,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,12 ,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 ,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 ,12
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,12
ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,12
ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,12
ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,12
ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,6 ,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,6 ,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,8 ,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,12 ,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,80 ,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 ,12
Elapsed Time: 00:16
hmm................ here's my very cut-down version of the wiring for the button (it's the same for mk7.5 and it's from RoW - but Shirley it's the same on NAR)
So - according to the BCM pin-out T73c /62 is the Terminal 58xd rail (i.e. general dashboard lighting). This strongly suggests that the LED in the button can't be used to mimic the switch status (i.e. it's raison d'etre is background illumination only)- alas.
Cuzoe
C?ID=279487
It is the same on NAR... I added these switches to my car.
Now then, pin 5 is unused... could there be an orange LED in there not depicted on the drawing, haha. I would guess no, but it wouldn't matter anyway since you need a dedicated output from the BCM for the orange light, as is present for Driving Mode and Start/Stop.
@Cuzoe: Thanks for confirming. Yes, I agree - the chance of pin #5 secretly hiding an orange LED anode terminal (which happens to be internally connected via a ballast resistor to the earth terminal on pin #1) is infinitesimally low!
Interesting that the hex03 Blockmap has this:
  • IDE02986-IDE04431,Indicator lamps-ASR and ESP indicator lamp > OFF
Cuzoe
C?ID=279487
Well now you've got my attention... not that I ever turn off traction control, haha. But I suppose we aren't "missing out" anything with the ESC button not having an orange indicator, the dash does a fine job of letting you know if something has been turned off. And the previous semi-related threads were all about people wanting to turn off the orange function of the other buttons.
@Cuzoe: Brilliant suggestion!! Yes, I suspect that you are correct that the Blockmap channel in my post above is indeed probably the hex03 module's (CAN?) message to the hex17 module - which mimics the status of the ESP switch on the dash display!
