Not able to group measuring blocks/ no turbo button hex v2
mattgrahn1
CT, USA
C?ID=445887
Hey everyone, I've had a couple VAG vehicles and work on my own stuff but have no experience with vcds. I was trying to do some data logging to figure out a boost issue on my c5 Allroad and I have no grouping button or turbo button for faster sampling. I'm using a hex v2 Dual-k & CAN USB interface with windows 10. The car is a 2003 Allroad 2.7t 01e transmission. I start by connecting the laptop and car with cable, switch key to on position, open vcds, select control module, engine, advanced measure blocks, and then pick a few blocks. the sample rate is super low 2-3 and there's no group selections button. Hopefully I'm just missing something simple. If anyone has any suggestions it would be much appreciated.
Yeah, you definitely can't "group" them since that ECU certainly doesn't use the newer UDS protocol. In fact, I'm pretty confident it doesn't even use KWP-2000; that it runs the very old-school KW1281, a protocol that was first used in the early 1990s and doesn't lend itself to the "Turbo" performance tweaks. The problem with KW1281 protocol is that each and every byte that the ECU sends must be acknowledged by the scan tool before the ECU will send the next one, and there's no mechanism to increase the bit rate either.
You may be able to get a little more buy tweaking things on the Options screen, but it won't be much:
mattgrahn1
CT, USA
C?ID=445887
Yeah my protocol reads kw1281, thanks for the responses! I did a few log sessions and it seems to make some sense even with the slower sample rate. I found groups of blocks when scrolling through the selections and if I pick blocks within the group it keeps the sample rate from dropping from 2.5 to ~1
mattgrahn1
CT, USA
C?ID=445887
Auto Scan would be welcome here. :cool:
I understand my problem but here's an Auto Scan anyways!
Tuesday,12,October,2021,19:47:25:00614
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: WA1YD64B73N063006   License Plate:
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
          75 76 77
Address 01: Engine        Labels: 078-907-551-AZA.lbl
   Part No: 4Z7 907 551 R
   Component: U25AN34.hex LEV G  x
   Coding: 07715
   Shop #: WSC 02334
   VCID: 52FD73143DFF67FB415-5160
   Subsystem 1 - Part No: XXYOUR
   Component: VIN HEREXX     XXXIMMO IDXXXX
   XXYOUR VIN HEREXX     XXXIMMO IDXXXX
16885 - Vehicle Speed Sensor
            P0501 - 35-10 - Implausible Signal - Intermittent
19718 - Oxygen (Lambda) Sensor B1 S2 / B2 S2 Connections Swapped
            P3262 - 35-10 -  - Intermittent
18010 - Power Supply Terminal 30
            P1602 - 35-10 - Voltage too Low - Intermittent
17834 - EVAP Purge Valve (N80)
            P1426 - 35-10 - Open Circuit - Intermittent
17947 - Clutch Pedal Switch (F36)
            P1539 - 35-00 - Implausible Signal
Readiness: 0010 0000
Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
   Part No: 4Z7 907 389 A
   Component: ABS/ESP allrad      D56
   Coding: 06495
   Shop #: WSC 12345
   VCID: 4ACD6B74D5AF2F3B395-5160
Address 08: Auto HVAC        Labels: 4B0-820-043-MY1.lbl
   Part No: 4B0 820 043 L
   Component: A6-Klimavollautomat D64
   Coding: 00160
   Shop #: WSC 02325
   VCID: 2313E6D012F5DE739A3-2596
01582 - Signal for Coolant Temperature
            30-00 - Open or Short to Plus
Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
   Part No: 4Z7 959 655 J
   Component: Airbag 8.4EP        2000
   Coding: 0000607
   Shop #: WSC 02325 785 00200
   VCID: 56F58F0414177BDBADD-5184
Address 16: Steering wheel        Labels: 4B0-907-487.lbl
   Part No: 4B0 907 487 F
   Component: Lenkradelektronik   D01
   Coding: 01002
   Shop #: WSC 02325
   VCID: 2F3B1AE04E3D6A130EB-5160
            80-00 - Single-Wire Operation
Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
   Part No: 4B0 920 981 P
   Component: KOMBI+WEGFAHRS. VDO D12
   Coding: 06264
   Shop #: WSC 85555
   VCID: 33331690A2254EF36A3-5160
   WA1YD64B73N063006     AUZ7Z0B2257663
01177 - Engine Control Unit
            49-00 - No Communications
01311 - Information Data Bus
Address 34: Level Control        Labels: 4Z7-907-553.lbl
   Part No: 4Z7 907 553 E
   Component:  - 2C1A1          D040
   Coding: 25500
   Shop #: WSC 01013
   VCID: 47CB5240C6BDD25326B-513C
01772 - Signal from Level Control Pressure Sensor (G291)
01780 - Sensor for Vehicle Leveling
            04-10 - Mechanical Malfunction - Intermittent
Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
   Part No: 4B0 962 258 M
   Component: Central Lock/Alarm  D37
   Coding: 14953
   Shop #: WSC 01013
   VCID: 33331690A2154EF36A3-4F0C
7 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
            35-00 - -
01559 - Drivers Door
            58-10 - Can't Lock - Intermittent
01561 - Rear left door
            59-00 - Can't Unlock
01562 - Rear right door
01574 - Alarm triggered by Door Contact Switch; Rear Right
            35-00 - -
01573 - Alarm triggered by Door Contact Switch; Rear Left
            35-00 - -
   Part No: 4B0 959 760 B
   Component: Sitzmemory R1 F     0102
   Coding: 00001
   VCID: 2C010DEC7F2B110B2B9-4B00
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00030
   Shop #: WSC 02325
   VCID: 0451854CB73B394B839-4B00
   Part No: 4B0 035 195 L
   Component: symphony II NP2    0051
   Coding: 00205
   Shop #: WSC 02445
   VCID: 290FF4F870D90423D0F-4E40
Address 76: Park Assist        Labels: 8Z0-919-283.lbl
   Part No: 8Z0 919 283
   Component: Parkingsyst. A6 RDW D08
   Coding: 01186
   Shop #: WSC 02325
   VCID: 025D8354AD2F377BB15-513C
End----(Elapsed Time: 04:45, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
In the interest of full disclosure, (from a User perspective only) your Auto-scan may help other readers/users on the RT forum OR , from what I understand, may help RT in advancing product development. So, thank you for your contribution! "happy scans" !
_Val
Latvia
C?ID=356659
Motronic version 7.1 but still slow as hell. :D
  • Agree
Hey, it could be worse. Some of the very first TDIs that used KW1281 did so at 240 bps. No, that's not a typo. Two Hundred Forty.
And there are transmissions that were still used in the early 2000s that ran at 1200 bps.
_Val
Latvia
C?ID=356659
Yes, some C4 ecu's are that slow that Hex-v2 can't connect them.
