E-tron : Disable automatic headlight/low beam?
Kenito
Norway
2019 Audi E-tron
Does anyone know if it's possible to disable the function that turns on headlights/low beam automatically?
I've tried lowering the value in <RLS_Night_Sensitivity> to 100 lux but headlights still come on to early imo.
Reading from another member/car :
Monday,05,July,2021,14:02:12:04552
VIN: WAUZZZGE2KB003361   License Plate:
Chassis Type: GE-AU58 (4K1)
Scan: 01 03 09 13 15 16 17 19 2B 36 42 44 46 51 52 5F 69 6C 6D 74
          75 81 8C A5 BB BC C5 C6 CD CE DE 8104
VIN: WAUZZZGE2KB003361   Mileage: 30128km-18720miles
51-Electric Drive -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: OK 0000
CD-Laser Scanner -- Status: OK 0000
CE-Drive Motor 2 -- Status: Malfunction 0010
8104-DC/DC Converter HV -- Status: OK 0000
Address 01: Engine (J623-    )       Labels: None
   Part No SW: 4KE 907 558 E    HW: 4KE 907 558
   Component: I99 99.9l XXX H02 0001
   Coding: 2A0A0012007E040034080000000000000000000000000000
   ASAM Dataset: EV_VCU00XXX0204KE907558E 001001
   ROD: EV_VCU00XXX0204KE907558E.rod
   VCID: 4BC36D2B63440CD32A1-801E
   Parking lock:
   Subsystem 1 - Part No SW: 0MA 341 601 B    HW: 0MA 341 601 B
   Component: V682 ParkLock  H23 0611
   Serial number: 2018.10.22.000000019
17179 - Databus
                    Mileage: 29915 km
                    Date: 2021.07.01
                    Time: 10:57:53
                    Engine RPM: 16383.75 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 215 °C
                    Intake air temperature: 215 °C
                    Ambient air pressure: 2550 mbar
                    Voltage terminal 30: 13.105 V
                    Unlearning counter according OBD: 33
                    Engine status: Stop
                    ECU_STATE: ENG_STOP
                    ACC variants (coding): ACC with braking until standstill / Stop & Go
                    Drivetrain coordinator: brake fault status-ESP system error: No
   Part No SW: 4KE 909 059 AC    HW: 4KE 909 059 G
   Component: ESC           H09 0078
   Revision: 00000000    Serial number: 63228000003028
   Coding: 008800BA3D940B9CD35308771878D2E025BEA10000BCD0CB10184B07A47D85
   Shop #: WSC 12000 205 00000
   ASAM Dataset: EV_BRSContiMKC1AU516 009376
   ROD: EV_BRSContiMKC1AU516_009.rod
   VCID: 0849922732B227CBC73-805C
16641 - Engine Control Module
          U1226 00 [044] - Implausible Message
          [DEM_RTC_MOTOR_TS_03_STA_FAIL]
                    Mileage: 28875 km
                    Date: 2021.06.14
                    Time: 17:37:21
                    Unlearning counter according OBD-OBD unlearning counter: 255
                    History Data-History data 1: 00
                    History Data-History data 2: 00
                    History Data-History data 3: 00
                    History Data-History data 4: 00
                    History Data-History data 5: 00
                    History Data-History data 6: 00
                    History Data-History data 7: 00
                    History Data-History data 8: 00
                    History Data-History data 9: 00
                    History Data-History data 10: 00
                    History Data-History data 11: 00
                    History Data-History data 12: 00
                    History Data-History data 13: 00
                    History Data-History data 14: 00
                    History Data-History data 15: 00
                    History Data-History data 16: 00
                    History Data-History data 17: 00
                    History Data-History data 18: 00
                    History Data-History data 19: 00
                    History Data-History data 20: 00
                    History Data-History data 21: 00
                    History Data-History data 22: 00
                    History Data-History data 0: 00
Address 09: Cent. Elect.
   Part No SW: 4KE 907 561 B    HW: 4K0 907 561
   Component: LRR4R         H04 0332
   Coding: 7E61FF4B58082C0001038020000000BA4A1246494481009E01
   Shop #: WSC 00046 412 00046
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_AU58.rod
   VCID: 42DD400F540ECD9BD97-8016
2342 - Databus
          [FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
                    Fault Frequency: 85
                    Reset counter: 254
                    Mileage: 28006 km
                    Date: 2021.05.27
                    Time: 09:04:08
                    Control Module temperature: 32 °C
                    Voltage terminal 15: 14.3 V
                    Vehicle speed: 5.70 m/s
                    Longitudinal acceleration: 1.20 m/s²
                    Adaptive distance regulation: status: ACC_reversible_error
                    Steering_angle-Data: 106.200 °
                    Yaw_rate-Data: 4.270 rad/s
                    adjustment_calculation: On
                    Misalignment angle: horiz: 0.072 °
                    Misalignment angle: horiz: fast algorithm: 0.167 °
                    Congestion pilot: status: OFF
                    Outside temperature: 13.50 °C
                    Sensor blindness: radar: no blindness detected
2102 - Databus
          [FAULT_ESP_CONTROL_FAIL]
                    Fault Frequency: 84
                    Reset counter: 254
                    Mileage: 28006 km
                    Date: 2021.05.27
                    Time: 09:04:07
                    Vehicle speed: 4.89 m/s
                    Longitudinal acceleration: 1.40 m/s²
                    Adaptive distance regulation: status: ACC_StandBy
                    Steering_angle-Data: 159.900 °
                    Yaw_rate-Data: 5.579 rad/s
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Reset counter: 234
                    Mileage: 29261 km
                    Date: 2021.06.18
                    Time: 21:36:46
                    Control Module temperature: 36 °C
                    Voltage terminal 15: 14.0 V
                    Vehicle speed: 11.32 m/s
                    Longitudinal acceleration: 1.23 m/s²
                    Steering_angle-Data: -7.600 °
                    Yaw_rate-Data: -0.581 rad/s
                    Misalignment angle: horiz: 0.027 °
                    Misalignment angle: horiz: fast algorithm: 0.136 °
                    Outside temperature: 26.00 °C
0935 - Databus
          [FAULT_TRAILOR_LIGHT_DEFECTIVE]
                    Reset counter: 250
                    Mileage: 29915 km
                    Date: 2021.07.01
                    Time: 10:57:53
                    Control Module temperature: 29 °C
                    Voltage terminal 15: 13.7 V
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s²
                    Steering_angle-Data: -193.200 °
                    Yaw_rate-Data: 0.007 rad/s
                    Misalignment angle: horiz: 0.095 °
                    Misalignment angle: horiz: fast algorithm: 0.168 °
                    Outside temperature: 22.00 °C
   Part No SW: 4KE 959 655     HW: 4KE 959 655
   Component: AirbagVW32    H36 3122
   Serial number: 003XPM00B22C
   Coding: AAFCF0C0002000009A5400FFF80D41A800C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001034
   ROD: EV_AirbaVW31SMEAU65x.rod
   VCID: 0B43AD2B23C44CD3EA1-805E
   Left seat belt tensioner:
   Serial number: 00AI2018338346700000
   Coding: 03F002
   Right seat belt tensioner:
   Serial number: 00AI2018346619500000
   Coding: 03F002
   Subsystem 3 - Part No SW: -----------    HW: 480 001 411 18
   Serial number: 35700000000A052CC53L
   Subsystem 4 - Part No SW: -----------    HW: 480 001 411 18
   Serial number: 3580000000077968953R
   Subsystem 5 - Part No SW: -----------    HW: 480 031 711 18
   Serial number: 351001C18E2E0250E87B
   Subsystem 6 - Part No SW: -----------    HW: 480 031 711 18
   Serial number: 352001C18E2E09402D48
   Subsystem 7 - Part No SW: -----------    HW: 480 021 211 18
   Component: FrontSensor_D  000 0149
   Serial number: 3550001102B81AA3011J
   Subsystem 8 - Part No SW: -----------    HW: 480 021 211 18
   Component: FrontSensor_P  000 0149
   Serial number: 3560001102B81AA4057V
   Crash sensor high-voltage system 1:
   Subsystem 9 - Part No SW: -----------    HW: 480 021 211 18
   Component: HVSensor_gSat  000 0149
   Serial number: 3510001062B81AA5070R
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 10 - Part No SW: -----------    HW: 480 021 211 18
   Component: SideSens_B_Df  000 0149
   Serial number: 3520001062B81AA6841Z
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 11 - Part No SW: -----------    HW: 480 022 410 18
   Component: SideSens_B_Pf  000 0149
   Serial number: 35500019F2BE26367328
1065478 - Databus
          [NWD: 0xTBD BV_SensorHeader error value BV2_Fehler_FGE]
                    Reset counter: 226
                    Mileage: 28856 km
                    Date: 2021.06.14
                    Time: 16:56:13
1065477 - Databus
          [NWD: 0xTBD BV_SensorHeader error value BV2_Fehler_MOD]
                    Fault Frequency: 22
                    Reset counter: 1
                    Mileage: 28030 km
                    Date: 2021.05.27
                    Time: 17:20:19
   Part No SW: 4N0 907 129 AJ    HW: 4N0 907 129 AJ
   ROD: EV_SMLSKLOAU736_AU58.rod
   VCID: 79AFE7E379584E43C8D-802C
   Part No SW: 4KE 920 795 B    HW: 4KE 920 795
   Component: FHybRDWACC--- H13 0031
   Coding: 850400C87C9000080CA6E170B284680008000000
   ROD: EV_DashBoardAU65X_001_AU58.rod
   VCID: 46D55C1F7826F1BBF5F-8012
16777046 - Charger for HV Battery
          U1139 00 [008] - No Communications
          [BAP_BatteryControl_0x25 communication error bap_error_timeout heartbeat]
                    Reset counter: 254
                    Mileage: 28435 km
                    Date: 2021.06.11
                    Time: 16:47:34
   Part No SW: 4K1 907 468 D    HW: 4K1 907 468 C
   Component: Gateway       H04 0322
   Serial number: 1DF06042425101
   Coding: 02030005000100C000810000005B01329C8A004718000000090000DE00000000
   Shop #: WSC 04100 205 00000
   ASAM Dataset: EV_Gatew31xAU65x 003170
   ROD: EV_Gatew31xAU65x_AU58.rod
   VCID: 36352CDF08C6613B65F-8062
   Subsystem 1 - Part No SW: 4N0 951 523 G    HW: 4N0 951 523 G
   Component: E221__MFL  H06 0003
   Subsystem 2 - Part No SW: 4N0 915 181 D    HW: 4N0 915 181 D
   Serial number: 7674960100181126050C
   Subsystem 3 - Part No SW: 4N0 419 508     HW: 4N0 419 508
   Component: J1158 KLR  H44 0030
   Serial number: 18289013306S00304401
262693 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [BAP_Timeout_BatteryControl]
                    Reset counter: 250
                    Mileage: 28101 km
                    Date: 2021.05.29
                    Time: 14:15:40
8913155 - Development Code 4
          B2F04 00 [009] - -
          [RWB_TME_Init_Abwurf_Dauerinit]
                    Reset counter: 162
                    Mileage: 28010 km
                    Date: 2021.05.27
                    Time: 09:54:08
8913156 - Development Code 5
          B2F05 00 [009] - -
          [RWB_BCME_Init_Abwurf_Dauerinit]
                    Reset counter: 162
                    Mileage: 28006 km
                    Date: 2021.05.27
                    Time: 09:03:48
16711991 - Ethernet Databus Branch 2
          U122D 00 [008] - No Communication
          [Ethernet_databus_no_communication_port_2]
                    Reset counter: 234
                    Mileage: 29263 km
                    Date: 2021.06.18
                    Time: 21:38:49
                    Ethernet counter checksum error: branch 2: 0
                    Ethernet counter connection interruptions: branch 2: 1
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 18000340825006
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VW53.rod
   VCID: 343116D71EBA732B5BB-8060
   Serial number: 00000356599657
   Coding: 00581A400000B4010003010101010000000000000000000000000000004000
   Part No SW: 4M0 959 593 M    HW: 4M0 959 593 J
   Component: TSG FS        007 0387
   Serial number: 0000353284485
   Coding: 001FCA0152000480A001B002
   ROD: EV_DCU2DriveSideMAXHCONT_VW38.rod
   Part No SW: 4N0 909 144 D    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H21 0504
   Coding: B4110101010000
   ASAM Dataset: EV_EPSVWBSAU426 009015
   ROD: EV_EPSVWBSAU426_009.rod
   VCID: 313F1FC3E1A8460330D-8064
   Part No SW: 8W0 907 064 GP    HW: 8W0 907 064 DP
   Component: BCM2 MLBevo   025 0424
   Coding: 017400030FB103616309A0040C00C80200004000804F02582F0400000504823B001F0100010F13
   Shop #: WSC 44528 004 104857
   ASAM Dataset: EV_BCM2HellaAU736 016016
   ROD: EV_BCM2HellaAU736_016.rod
   VCID: 1079BA474AE26F0B1F3-8044
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY182920YDR
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000045880885
   left tail lamp 1:
   Subsystem 3 - Part No SW: 4KE 945 423     HW: 4KE 945 423
   Component: T1 LH ECE HD  H10 0403
   Serial number: A1W700005X3
   Subsystem 4 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11340301
   Antenna for short-range communication:
   Subsystem 5 - Part No SW: 4N1 927 753     HW: 4N1 927 753
   Component: NFCTGS  H13 0050
   Serial number:            382823425
   Antenna 2 for short-range communication:
   Subsystem 6 - Part No SW: 4N0 959 428 A    HW: 4N0 959 428 A
   Component: NFCMIKO  H41 0034
   Serial number: 4418000231080016
   left tail lamp 2:
   Subsystem 7 - Part No SW: 4KE 945 429 B    HW: 4KE 945 429 B
   Component: T2 LH ECE HD  H12 0403
   Serial number: A1WK0002MWX
   Right rear tail lamp 1:
   Subsystem 8 - Part No SW: 4KE 945 424     HW: 4KE 945 424
   Component: T1 RH ECE HD  H10 0403
   Serial number: A1WD0000549
   Right rear tail lamp 2:
   Subsystem 9 - Part No SW: 4KE 945 430 B    HW: 4KE 945 430 B
   Component: T2 RH ECE HD  H12 0403
   Serial number: A1WL0002MWY
65732 - Databus
          [Engine control module: Motor_14: no signal/no communication]
                    Reset counter: 241
                    Mileage: 28870 km
                    Date: 2021.06.14
                    Time: 17:28:24
                    Supply voltages-Terminal 30 power supply: 13.560 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 13.628 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 13.587 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 00 80
                    general_additional_freeze_frame-Vehicle speed: Not available
65605 - Databus
          [Brake control module: ESP_21: no signal/communication]
                    Reset counter: 241
                    Mileage: 28043 km
                    Date: 2021.05.28
                    Time: 20:46:12
                    Supply voltages-Terminal 30 power supply: 12.827 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.908 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.854 V
65729 - Databus
          [Brake control module: ESP_05: no signal/communication]
                    Reset counter: 241
                    Mileage: 28029 km
                    Date: 2021.05.27
                    Time: 17:13:26
                    Supply voltages-Terminal 30 power supply: 12.609 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.663 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.609 V
   Part No SW: 0EF 907 080 G    HW: 0EF 907 080 C
   Component: CUFZD683Q0AD2 H02 0010
   Revision: --------    Serial number: -00103.10.18000
   Coding: 01000000000000000000
   Shop #: WSC 44528 004 1048576
   ASAM Dataset: EV_DMCMHITACAU516 003007
   ROD: EV_DMCM2HITACAU516_003.rod
   VCID: 3A2D38EF3CDE855B817-806E
13828096 - Component protection
          U1115 00 [047] - No basic setting for SHE key
          [CmpntPrtctn_SHEKeyNoCnfg]
                    Mileage: 28006 km
                    Date: 2021.05.27
                    Time: 08:50:31
   Part No SW: 4M0 959 592 M    HW: 4M0 959 592 J
   Component: TSG BFS       007 0387
   Serial number: 0000349865601
   Coding: 001FCA015E000480A001B000
   ROD: EV_DCU2PasseSideMAXHCONT_VW38.rod
   VCID: 45D75B134520FAA3FC5-8010
   Part No SW: 4K0 035 063 D    HW: 4KE 035 063
   Component: MU-H-LND-EU   046 2711
   Coding: 01157601FF0A000043111101C00802302F0001E4037008008E
   VCID: 2411E697AE5AE3ABCBB-8070
   Subsystem 1 - Part No: V03 959 807 SE
   Component: MIB2P_EU_Q420  0490
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4KE 919 605 C    HW: 4KE 919 605
   Component: DU AU516 High  H41 0147
   Serial number: INX00119091800130138
   Compact disc data bank:
   Component: Gracenote2  1009
   Volume Control 1:
   Subsystem 4 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Serial number: 00004418000229020010
   Multimedia System 5:
   Subsystem 5 - Part No SW: 4KE 919 603 A    HW: 4KE 919 603
   Component: DU AU516 Bot  H41 0147
   Serial number: INX00115091800140133
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051800690324010
6672 - Optical Data Bus for Display in Instruments
          U10CF 00 [008] - Intermittent Disruption
          [Optical data bus: sporadic open circuit in instrument cluster display]
                    Reset counter: 234
                    Mileage: 29263 km
                    Date: 2021.06.18
                    Time: 21:39:02
                    Voltage terminal 30: 14.2 V
                    Temperature of MOST transceiver-max.value: -50 °C
                    Temperature of MOST transceiver-min.value: 38 °C
                    Temperature of MOST transceiver-Up-to-date: 38 °C
7237 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Display configuration (0x45) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 216
                    Mileage: 30105 km
                    Date: 2021.07.05
                    Time: 12:54:45
                    BAP-BAP_Function_ID: 02
1561 - predictive route data
          B1630 02 [008] - Signal Failure
                    Reset counter: 234
                    Mileage: 29261 km
                    Date: 2021.06.18
                    Time: 21:36:46
   Part No SW: 4M0 907 383 E    HW: 4M0 907 383
   Revision: 9C001003    Serial number: 0500244408
   Coding: 0110000202000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
655882 - Bulb for Brake Light on Trailer
          C10F3 15 [008] - Open or Short to Plus
                    Reset counter: 250
                    Mileage: 29915 km
                    Date: 2021.07.01
                    Time: 10:57:52
   Component: RVC Compact   H15 0250
   Coding: 0215060103002005C20040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_VW53.rod
   VCID: 333315CB1BB47413421-8066
   Part No SW: 8W8 959 107 D    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0170
   Revision: --------    Serial number: A2-C744-8781-0
   Coding: 33B0
   VCID: 4ACD682F6C3E15DB117-801E
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 4KE 907 777 AD    HW: 4KE 907 777 A
   Component: Fahrwerk-SG   H52 2311
   Serial number: 0611181032
   Coding: 98D8607BDA4010
   ASAM Dataset: EV_ChassContrContiAU651 003018
   ROD: EV_ChassContrContiAU651_003.rod
   VCID: 0E45A43F50D679FB0DF-805A
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130436323
   Coding: 303030
   Part No SW: 4K1 035 282 D    HW: 4K1 035 282 B
   Component: ConBox        H09 0232
   Serial number: 005CCA11F110204
   Coding: 01C0E0FFC040800000
   ROD: EV_ConBoxAU651_002.rod
   VCID: 2809F2A7D27207CBE73-807C
   Part No SW: 4KL 713 041 A    HW: 4KL 713 041
   Component: GSM-LL H04 0036
   Serial number: 92145RLA00070
   ASAM Dataset: EV_GSMKLOAU516 001008
   ROD: EV_GSMKLOAU516.rod
   VCID: 3C213EF736EABB6B93B-8068
   Part No SW: 4KE 915 233 F    HW: 4KE 915 233 B
   Component: BMC_MLBCBEV   H15 0231
   ASAM Dataset: EV_BECM0842071 001004
   ROD: EV_BECM0842071_VW53.rod
   VCID: 41DF4F035108D683C0D-8014
   Battery interrupt switch:
   Subsystem 1 - Part No SW: 4KE 915 250 C    HW: 4KE 915 250 A
   Component: BJB_MLBBEV  H12 0369
   Cell module control module 1:
   Subsystem 2 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 2:
   Subsystem 3 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 3:
   Subsystem 4 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 4:
   Subsystem 5 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 5:
   Subsystem 6 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 6:
   Subsystem 7 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 7:
   Subsystem 8 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 8:
   Subsystem 9 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 9:
   Subsystem 10 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 10:
   Subsystem 11 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 11:
   Subsystem 12 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
   Cell module control module 12:
   Subsystem 13 - Part No SW: 4KE 915 215     HW: 4KE 915 215
H06 0107
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AB    HW: 4N0 907 107 G
   Component: zFAS Var B    H09 0291
   Coding: 0421840000000000000C060000D4462E189E57000000000000000000000000000019000000000000000000000000000000000000000000000000400000000000000078D80000009000800080000000000080400000A0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001.rod
   VCID: 7F5B09FB677C6073F69-802A
4107 - Databus
          [reversibler_Fehler_im_ACC_System]
                    Fault Frequency: 85
                    Reset counter: 254
                    Mileage: 28006 km
                    Date: 2021.05.27
                    Time: 09:04:08
   Part No SW: 4M0 959 595 M    HW: 4M0 959 595 J
   Component: TSG HFS       006 0387
   Serial number: 0000354796509
   Coding: 000FC80100000480A000B000
   ROD: EV_DCU2RearDriveMAXHKLO_VW53.rod
   VCID: 48C952277232E7CB073-801C
   Component: TSG HBFS      006 0387
   Serial number: 0000354796516
   ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
Address C5: Therm. mgt. (J1024)       Labels:* None
   Part No SW: 4KE 965 429 C    HW: 4KE 965 429
   Component: TME-Max       H08 0312
   Serial number: 0012129
   Coding: 00
   ASAM Dataset: EV_ThermContrVISAU49X 002036
   ROD: EV_ThermContrVISAU49X_AU58.rod
   Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G395 pT-Sens1  H11 0010
   Subsystem 2 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00104.6V.1A20370031
   A/C compressor sub:
   Subsystem 3 - Part No SW: 4G0 816 797 B    HW: 4G0 816 797 B
   Component: J842 EKK es33  H03 0004
   Serial number: 00000000018100200150
   A/C pressure/coolant temperature sensor 2:
   Subsystem 4 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G826 pT-Sens2  H11 0010
   Coolant heating:
   Subsystem 5 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00104.7V.4C20370097
   Expansion valve 2 for refrigerant:
   Subsystem 6 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000150492381
   Shut-off valve 2 for refrigerant:
   Subsystem 7 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N640 AV2_KaMi  H12 0102
   Serial number: 00000000000130452272
   Shut-off valve 3 for refrigerant:
   Subsystem 8 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N641 AV3_KaMi  H12 0102
   Serial number: 00000000000130452271
   Shut-off valve 4 for refrigerant:
   Subsystem 9 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N642 AV4_KaMi  H12 0102
   Serial number: 00000000000130452092
   Shut-off valve 5 for refrigerant:
   Subsystem 10 - Part No SW: 4M0 816 702 A    HW: 4M0 816 702 A
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 00000000000130452243
   Radiator shutter:
   Subsystem 11 - Part No SW: 95B 965 501 S    HW: 95B 965 501 S
   Component: V544KJS1  H12 0109
   Serial number: 20181114020103052736
   Radiator louver 2:
   Subsystem 12 - Part No SW: 95B 965 501 S    HW: 95B 965 501 S
   Component: V550KJS2  H12 0109
   Serial number: 20181110020103053781
   Coolant valve 1:
   Subsystem 13 - Part No SW: 4KE 963 375 K    HW: 4KE 963 375 K
   Component: N632 V1_KUEMI  010 0103
   Serial number: 00000000000000022208
   Coolant valve 2:
   Subsystem 14 - Part No SW: 4KE 963 375 J    HW: 4KE 963 375 J
   Component: N633 V2_KUEMI  010 0103
   Serial number: 00000000000000013520
   Coolant valve 3:
   Subsystem 15 - Part No SW: 4KE 963 375 H    HW: 4KE 963 375 H
   Component: N634 V3_KUEMI  010 0103
   Serial number: 00000000000000032532
   Coolant valve 4:
   Subsystem 16 - Part No SW: 4KE 963 375 N    HW: 4KE 963 375 N
   Component: N635 V4_KUEMI  010 0103
   Serial number: 00000000000000025527
   Part No SW: 5QE 915 684 J    HW: 5QE 915 684 J
   Component: OBC KOSTAL    H24 0023
   Serial number: ---------------
   Coding: 2B48844542080E000000
   ASAM Dataset: EV_OBC3Phase1KLOMLBev14B 002001
   ROD: EV_OBC2PhaseKLOMLBev14P.rod
   VCID: 56F58C5FA886413B85F-8002
   Flap 1 for charging socket:
   Subsystem 1 - Part No SW: 4KE 862 277 A    HW: 4KE 862 277 A
   Component: F496LKL1       004 0004
   Serial number: 20190703030206084246
2097938 - Charging Socket B; Charging Plug Lock
          P33E9 00 [032] - Mechanical Malfunction
13705549 - Databus
          U1121 00 [040] - Missing Message
          [DCDC_01_Timeout]
                    Reset counter: 34
                    Mileage: 29830 km
                    Date: 2021.06.28
                    Time: 18:01:10
13709330 - Unknown Error Code
          U15C9 00 [032] - -
          [LMSF_intervention]
Address CD: Laser Scanner (J1122)       Labels: None
   Part No SW: 4K8 907 660 B    HW: 4N0 907 660
   Component: LASER_SCANNER H36 0202
   ASAM Dataset: EV_LaserScannAU651 013013
   ROD: EV_LaserScannAU651_013.rod
   VCID: 35372BD315C06A236C5-8060
Address CE: Drive Motor 2 (J944)       Labels: None
   Part No SW: 0EF 907 180 J    HW: 0EF 907 180 C
   Component: CUBZE683Q0AD2 H02 0010
   Revision: --------    Serial number: -00118.10.18000
   ASAM Dataset: EV_DMCM2HITACAU516 003007
   VCID: 3E2534FF20F6A97BBDF-806A
                    Mileage: 28006 km
                    Date: 2021.05.27
                    Time: 08:50:31
Address DE: Charger 1 for mobile dev (J1146)       Labels:* None
   Part No SW: 4N0 035 773 A    HW: 4N0 035 773 A
   Component: WLC Front NFC H11 0061
   Coding: 808000
   VCID: 2C010EB7C68A2BEB03B-8078
Address 8104: DC/DC Converter HV (A19)       Labels: None
   Part No SW: 4KE 907 171 B    HW: 4KE 907 171 B
   Component: DCDC Wandler H10 0400
   ASAM Dataset: EV_DCDCHVTDKAU516 001004
   ROD: EV_DCDCHVTDKAU516.rod
   VCID: 3FDB49FB27FCA073B69-806A
End----------(Elapsed Time: 02:43, VBatt start/end: 13.1V/13.1V)-----------
