- Sep 14, 2021
- 3
- 1
- Boston MA, USA
- C?ID=131422
Hi all,
I've been VAG-Com user for 12 years and usually find answers online. My first post here:
I am rebuilding 2016 Audi TT Roadster that was involved in front end collision. I had B200 and B200F errors in the power steering tack (Address 44). From what I researched this are internal errors stored after crash that cannot be erased. I replaced the power steering rack (sw 505 5063) with used one (sw 506 5072). Both are with dynamic steering. The red power steering icon on the dashboard turned yellow and now I have assistant steering. However I still have G85 error and I see now component protection in the Gateway which I expected. I have Hex-V2 interface and from what I read here I can use AutoComSoft to do online coding. When I plug in the VIN and the part number they cannot find the combination in their database. Is my only option ODIS or I can use some other alternative solution? Here is a full scan f the vehicle as well as the original power steering rack module:
Original module:
New complete scan:
Original module:
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8102
Shop #: WSC 06385 790 00016
VCID: 3957FB29B8078A4C05-806C
9 Faults Found:
12289 - Supply voltage
Mileage: 68670 km
Date: 2020.09.30
Time: 14:14:30
Motor status: 02
Supply voltage: 5.75 V
Temperature: 36.0 °C
KFC: 30
KFA: 00 01
Freeze frame conditions: 21
uioUdNotFilt_xdu16: 5.34 V
uAdSensI_SwitchedKl30_xdu16: 5.33 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
16130 - Steering Angle Sensor
B1168 F2 [009] - Not Initialized
Reset counter: 0
Motor status: 00
Supply voltage: 6.75 V
Temperature: 26.0 °C
KFC: 3F
KFA: 00 02
Freeze frame conditions: 5F
uioUdNotFilt_xdu16: 6.88 V
uAdSensI_SwitchedKl30_xdu16: 6.88 V
4867 - Internal Fault
B200F F0 [008] - Unknown Error Elaboration
Motor status: 03
System status: Reset
Supply voltage: 12.75 V
Temperature: 16.0 °C
KFC: 13
KFA: 00 03
Freeze frame conditions: 71
nApplI_RotorSpeedFilt_xds16: 53 /min
mApplI_LimitedMotorTorque_xds16: 0.000 Nm
icuCurrentPhase_U_IRQ_xds16: 11.75 A
icuCurrentPhase_W_IRQ_xds16: 4.06 A
mApplI_TorsionBarTorque_xds16: 0.00 Nm
wrsCurrRotorPosIRQ_xdu16: 173.5 °
229504 - Internal Control Module Memory Check Sum Error
B2000 00 [153] - -
MIL ON - Confirmed - Not Tested Since Memory Clear
Motor status: 03
KFC: 13
KFA: 00 03
26885 - Comfort limitation
C10D7 00 [008] - -
Motor status: 00
Supply voltage: 0.00 V
Temperature: 80.0 °C
KFC: 69
KFA: 00 05
22272 - Databus
Reset counter: 185
Mileage: 68668 km
Date: 2020.11.30
Time: 21:16:24
Motor status: 00
Temperature: 19.0 °C
KFC: 57
KFA: 00 00
Freeze frame conditions: 20
uioUdNotFilt_xdu16: 0.19 V
uAdSensI_SwitchedKl30_xdu16: 0.20 V
22528 - Databus
Reset counter: 185
Mileage: 68668 km
Date: 2020.11.30
Time: 21:16:24
Motor status: 00
KFC: 58
KFA: 00 00
22784 - Databus
Reset counter: 185
Mileage: 68668 km
Date: 2020.11.30
Time: 21:16:24
Motor status: 00
KFC: 59
KFA: 00 00
23296 - Databus
Reset counter: 185
Mileage: 68668 km
Date: 2020.11.30
Time: 21:16:28
Motor status: 00
KFC: 5B
KFA: 00 00
New complete scan:
Monday,11,October,2021,11:24:56:65357
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
VIN: TRUT5CFV5G1028809 License Plate: TT SCAN 15
Mileage: 68670km-42669mi Repair Order:
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 26 3C 42 44 52 55 5F 6C
A6 A9
VIN: TRUT5CFV5G1028809 Mileage: 68670km-42669miles
A6-Microphone -- Status: OK 0000
Address 01: Engine (J623-CNTC) Labels:. 06K-907-425-V1.clb
Part No SW: 8S0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0001
Revision: --H13--- CVN: 9FCD43F9
Coding: 0A1D00324426000F3000
ASAM Dataset: EV_ECM20TFS0208S0906259A 001003
ROD: EV_ECM20TFS0208S0906259A.rod
VCID: 3B233C2BF3EA5403B23-806E
VINID: 9229641535A61570400882002445D338C9
Readiness: 1010 0101
Part No SW: 0D9 300 013 C HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4904
Revision: 06253104 Serial number: TFK01602251317 CVN: 0000E064
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 176BC09BAF02506376B-8042
Part No SW: 8S0 907 379 D HW: 8S0 907 379 D
Component: ESC H42 0522
Revision: 00000000 Serial number: 60376000000916
Coding: 72AA608D2A9B15B100990064829A9106234E0654A80000418960C4
ASAM Dataset: EV_Brake1UDSContiMK100IPB 060016
ROD: EV_Brake1UDSContiMK100IPB_060.rod
VCID: 42DD41CF940025CBF15-8016
0295 - Steering angle sensor
B1168 54 [137] - Missing Calibration / Basic Setting
Reset counter: 170
Date: 2021.10.11
Time: 11:20:58
C1146 02 [137] - Signal Failure
Reset counter: 170
Mileage: 68670 km
Date: 2021.10.11
Time: 11:21:07
Part No SW: 3Q0 959 435 C HW: 3Q0 959 435 C
Component: VWKESSYMQB 036 0710
Revision: 00036000 Serial number: 0396120313
Coding: 030C0C1720
VCID: 3A2D392FFCD06D0BA95-806E
12786206 - Databus
[Message Gateway_73 invalid Qbit received]
Reset counter: 209
Mileage: 68670 km
Date: 2021.09.15
Time: 16:56:50
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 8S0 820 043 HW: 8S0 820 043
Component: AC Automat H05 0030
Revision: 20009000 Serial number: 16040000009000
Coding: 500040100001041100
ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
ROD: EV_AirCondiVAPrehAU33x.rod
VCID: 6C81CF77C60403BB6B9-8038
Humidity sensor: exterior:
Rear A/C Control Head 1:
Subsystem 2 - Part No SW: 8S0 820 373 A HW: 8S0 820 373 A
Component: E774 BuA_1 H07 0020
Serial number: 00000000000000025984
Rear A/C Control Head 2:
Subsystem 3 - Part No SW: 8S0 820 359 A HW: 8S0 820 359 A
Component: E775 BuA_2 H07 0020
Rear A/C Control Head 3:
Subsystem 4 - Part No SW: 8S0 820 359 HW: 8S0 820 359
Component: E776 BuA_3 H07 0020
Rear A/C Control Head 4:
Subsystem 5 - Part No SW: 8S0 820 359 B HW: 8S0 820 359 B
Component: E777 BuA_4 H07 0020
Rear A/C Control Head 5:
Subsystem 6 - Part No SW: 8S0 820 373 B HW: 8S0 820 373 B
Component: E778 BuA_5 H07 0020
Part No SW: 5Q0 937 085 BL HW: 5Q0 937 085 AF
Component: BCM MQBAB HNA H24 0175
Serial number: 01061605000355
Coding: 040D5C46C00106FD41404004511007A80180000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 045187D7CE94EBFB839-8050
Subsystem 1 - Part No SW: 8S1 955 119 B HW: 8K1 955 119 B Labels: 5QX-955-119-V1.CLB
Component: 43x LL 160202 038 0371
Serial number: 00000001601280307625
Coding: 1BC7F7
Component: G397_RLFS H06 0004
Serial number: 61479748
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Serial number: 08 12 2015 00000059
Subsystem 4 - Part No SW: 4M0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H04 0040
Serial number: 0000009600335Z0O7V02
Coding: 150000
Garage door opener control head:
Subsystem 5 - Part No SW: 8S0 959 719 HW: 8S0 959 719
Component: GTO BF H05 0010
Serial number: 20160216134539 00242
Subsystem 6 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000034630196
545300 - Databus
Reset counter: 210
Mileage: 68670 km
Date: 2021.09.15
Time: 17:14:11
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391606806902
Coding: 0070150011
VCID: 43D344CB8B1A2CC3FA3-8016
1113107 - Front Parking Aid Sensor(s)
B10FC 13 [008] - Open Circuit
Reset counter: 210
Mileage: 68670 km
Date: 2021.09.18
Time: 14:46:14
13637426 - Databus
Reset counter: 169
Mileage: 68670 km
Date: 2021.09.04
Time: 16:07:21
Part No SW: 5Q0 959 655 R HW: 5Q0 959 655 R
Component: AirbagVW20 010 0830
Serial number: 003M9R003CLB
Coding: BFC0F00000800000A000001FC24800000065
VCID: 4FFB78FB5752D8A36EB-801A
Subsystem 1 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H10 0021
Serial number: IBH000000000004MTQJH
Coding: 303238
Subsystem 2 - Part No SW: ----------- HW: 480 001 503 16
Serial number: 35700000000445481A19
Subsystem 3 - Part No SW: ----------- HW: 480 001 503 16
Serial number: 35800000000935481A1E
Subsystem 4 - Part No SW: ----------- HW: 480 010 402 16
Component: SideSensor_Dr 004 0108
Serial number: 351001A05A82D5A37F4G
Subsystem 5 - Part No SW: ----------- HW: 480 402 710 15
Serial number: 3550002C11CCEA0372CF
Subsystem 6 - Part No SW: ----------- HW: 480 402 710 15
Component: FrontSensor_P 001 6149
Serial number: 3560002A31CCEA0351DE
Part No SW: 8S0 907 129 AJ HW: 8S0 907 129 AJ
Component: Lenks. Modul H07 0150
Revision: -------- Serial number: 91335PC801344
Coding: 2058
ASAM Dataset: EV_SMLSKLOMQB 050001
ROD: EV_SMLSKLOMQB_050.rod
VCID: 025D81CFD480E5CBB15-8056
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8S0 920 890 A HW: 8S0 920 890 A
Component: FBenUSA H35 0264
Coding: 086718412989D7050220E8C09800800000000000
ASAM Dataset: EV_DashBoardBOSCHAU33X 001020
ROD: EV_DashBoardBOSCHAU33X.rod
VCID: 38292327C2DC7F1B5F1-806C
Part No SW: 8S0 907 468 C HW: 8S0 907 468
Component: GW MQB TT3 012 0246
Revision: -------- Serial number: 08031610803390
Coding: 0301000424025A004B000228380000000000000000000000000000000001
GVL: 01D43C1000200400404C10000802C80000000000000000000000000000000000
ASAM Dataset: EV_GatewContiAU33X 011003
ROD: EV_GatewContiAU33X_011.rod
VCID: 40D94BC79A0C37DBE71-8014
Generator:
Subsystem 2 - Part No SW: 8S0 951 523 C HW: 8S0 951 523 C
Component: J453 MFL H07 0002
Serial number: 20160211040338 00388
Subsystem 3 - Part No SW: 8S0 915 181 A HW: 8S0 915 181 A
Component: J367-BDMHella H04 8050
Serial number: 0738637703
U1101 00 [008] - Active
Reset counter: 209
Mileage: 68670 km
Date: 2021.09.18
Time: 12:27:53
Terminal 30 power supply: 11.1 V
Terminal 15: On
8531970 - Quiescent Current
U1406 00 [008] - Too High
[Ruhestrom oberer Grenzwert überschritten]
Reset counter: 209
Mileage: 68670 km
Date: 2021.09.16
Time: 02:18:01
Terminal 30 power supply: 12.5 V
Terminal 15: OFF
Part No SW: 0CQ 907 554 C HW: 0CQ 525 130
Component: Haldex4Motion H52 7754
Serial number: HA1-00011.02.16
Coding: 0101
VCID: 45D75AD3852E12F3D47-8010
Address 26: Auto Roof () Labels:* None
Part No SW: 8S7 959 255 HW: 8S7 959 255
Component: VSG TT3H03 0120
Coding: A00000
ASAM Dataset: EV_ElectRoofContrWIMAU33X 001009
ROD: EV_ElectRoofContrWIMAU33X.rod
VCID: 05579AD3C5AED2F3947-8050
Part No SW: 8S0 907 566 HW: 4H0 907 566 F
Component: SWA Master H08 0050
Serial number: 0392791344
Coding: 030311
ROD: EV_LaneChangAssis_VW51.rod
VCID: 7CA1FF37B664933BFB9-8028
Subsystem 1 - Part No SW: 8S0 907 568 HW: 4H0 907 568 F
Component: SWA Slave H08 0050
Serial number: 0396085294
Coding: 030311
Component: TSG FS 020 0041
Serial number: 101115BK904572
Coding: 001E53725C08040100000402
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8102
ROD: EV_SteerAssisMQB_013.rod
15873 - Steering angle sensor
Reset counter: 170
Mileage: 68670 km
Date: 2021.09.21
Time: 17:14:43
Motor status: 00
Supply voltage: 11.75 V
Temperature: 34.0 °C
KFC: 3E
KFA: 00 01
uioUdNotFilt_xdu16: 11.72 V
uAdSensI_SwitchedKl30_xdu16: 11.72 V
RP_VALCNTSAV: not activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: not activated
RP_CNTERR: not activated
Component: TSG BFS 020 0041
Serial number: 301015BJU01997
Coding: 001E53725E08040100000402
Part No SW: 4H4 907 357 G HW: 7P6 907 357 B
Component: MxB-ECU 001 0115
Coding: 036A001123200400
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
VCID: 36352D1FC8C8896B4DD-8062
Coding: E01800
Coding: E01800
Component: LeiMo links
Subsystem 4 - Part No SW: 8S0 941 329 HW: 8S0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 S002
Coding: E01800
13705992 - Databus
[Empfangener Fehlerwert im Signal LWI_Lenkradwinkel: CAN Message LWI_01]
Reset counter: 169
Mileage: 68670 km
Date: 2021.09.18
Time: 14:37:24
5275953 - Power Output Module for Left Headlamp
C1081 31 [137] - No Signal
Reset counter: 169
Mileage: 68670 km
Date: 2021.09.18
Time: 14:37:24
Part No SW: 8S0 035 025 Q HW: 8S0 035 025
Component: MU-H-LNS-US 043 0414
Serial number: A263C0GB002377
Coding: 01330502FF08000013220001041A00102F0000E1007000047E
Subsystem 1 - Part No SW: V03 959 801 GE HW: -----------
Component: NAR 2016 --- 0048
Subsystem 2 - Part No SW: 8S0 919 614 J HW: 8S0 919 614 J
Component: ControlUnit_H H22 0136
Serial number: APVAK115011600010108
Compact disc data bank:
Component: Gracenote2 --- 3007
[Anti-theft protection - component protection active (0xEA6200)]
Reset counter: 209
Mileage: 68670 km
Date: 2021.09.18
Time: 12:27:53
Voltage terminal 30: 10.8 V
B11CF 53 [009] - Deactivated
Reset counter: 167
Mileage: 68670 km
Date: 2021.09.04
Time: 18:19:19
Voltage terminal 30: 12.5 V
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Part No SW: 5Q0 980 556 A HW: 5Q0 980 556
Component: RVC Compact H08 0172
Coding: 0233050102002001000040
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
ROD: EV_CamSysRVRVCPANAMQBAB_005.rod
Address A6: Microphone (J886) Labels:. 420-907-394.clb
Part No SW: 420 907 394 A HW: 420 907 394
Component: BELTMICBOX H10 0600
Coding: 0101020202
ASAM Dataset: EV_BeltMicPARAGAU335 003011
ROD: EV_BeltMicPARAGAU335_AU37.rod
Part No SW: 8S0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0006
Serial number: 160219200385
VCID: 3C213F37F6E4533BBB9-8068
End----------(Elapsed Time: 01:54, VBatt start/end: 13.3V/13.3V)-----------
