00778 - Steering Angle Sensor (G85): No or Incorrect Basic Setting / Adaptation
Ionutz
Luxembourg
C?ID=384700
I must apologize, was looking in Basic setting instead of Measuring Blocks. Do you know if I can adjust the EGR flow so to let less gases in intake. Apparently the Coding II-11 doesnt have 12233 as login code. Thank you!
   #22
Ionutz
Luxembourg
C?ID=384700
Thank you for reply. Yes, although the Access Security accepts 12233, under Adaptation there us nothing related to EGR. Like you mentioned this is not something it can be done to this engine.
   #24
Ionutz
Luxembourg
C?ID=384700
I think I need to replace the injectors soon. I was reading the codes from new injectors must be saved to ECU when replacing. Would this be possible on this ECU? When to Adaptation under Engine then channel 71 for cylinder 1. Instead of showing the code of injector 1 was showing error - not available. Could be this isn't required for this ECU? Thank you!
   #25
That's the case for engines with Common Rail injection. Assuming we're still talking about the same engine that this thread started with, which is a Pumpe Duese (Unit Injectors) engine, that's not applicable.
Ionutz
Luxembourg
C?ID=384700
Hi, thank you! The same engine indeed BXE. So, a replacement with similar injectors and should work.
   #27
