21’ GLI Autobahn DRL tweak
GLI21PR
Puerto Rico, USA
C?ID=14844
I performed the “LED and blinker lights in opposite phase” coding on my ‘21 GLI Autobahn (via VCDS) but it only works when the lights switch is in the “Parking Lights” and not in the “Auto” position. Did I missed something in the coding or is this because NA regulations??
Mari
C?ID=150535
Post original coding and the changed coding and preferably also a full and unedited autoscan for reference...
GLI21PR
Puerto Rico, USA
C?ID=14844
Wednesday,13,October,2021,18:49:38:09832
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: 3VW6T7BU4MM031603   License Plate:
Chassis Type: BU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 13 14 15 17 19 32 36 3C 42 44 47 52 5F 75
          A5 A9 BB BC CA
VIN: 3VW6T7BU4MM031603   Mileage: 12876km-8000miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DKFA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 T    HW: 06K 907 425 J
   Component: R4 2.0l TFS   H13 0003
   Revision: --H13---    CVN: 4429F15E
   Coding: 092500124464012FB000
   Shop #: WSC 00066 790 00308
   ASAM Dataset: EV_ECM20TFS0205G0906259T 001003
   ROD: EV_ECM20TFS0205G0906259T.rod
   VCID: 3FDB499327FFDA739EB-806A
   VINID: 0E69C69074A511D7400C11800C5395618F
   Part No SW: 0GC 300 020 N    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2803
   Revision: 00H06V11    CVN: A446B830
   ASAM Dataset: EV_TCMDQ381061 001001
   ROD: EV_TCMDQ381061.rod
   VCID: 2D0703DBFD9358E33C7-8078
   No subsystems:
21193 - No Communication with Cruise Control Module
          U0104 00 [040] - -
                    Mileage: 12839 km
                    Date: 2021.10.12
                    Time: 17:57:21
                    Engine RPM: 897.00 /min
                    Coolant temperature: 71 °C
                    Clutch: primary stat: Neutral
                    selected gear: GANG_R
                    Driving position: P
                    Engine torque: 4 Nm
                    Control Module temperature: 42 °C
                    Accelerator pedal position: 14.5 %
                    DTC memory status: 79
   Part No SW: 5Q0 614 517 GE    HW: 5Q0 614 517 BS
   Component: ESC           H82 0114
   Revision: 00000000    Serial number: 52970000000109
   Coding: 70FB6BA15023216D857D020060C6A90ED60A84A1400695761841F0D9D2A94B0B0000000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
   ROD: EV_Brake1UDSContiMK100IPB_049.rod
   VCID: 7AADF8877C5D3F5BE95-802E
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0558978009
   Coding: 132C0C0723
   Shop #: WSC 00066 790 00134
   VCID: 45D75B7B452380A3D47-8010
   Part No SW: 5GM 907 044 AM    HW: 5GM 907 044 AM
   Component: Climatronic   H05 2601
   Revision: 00001K04
   Coding: 0102001420011C001104014012111014
   ASAM Dataset: EV_ACClimaBHBVW37X 006151
   VCID: 0F7BB95357DF0AF32EB-805A
   Part No SW: 5Q0 937 085 CG    HW: 5Q0 937 085 CG
   Component: BCM MQBAB HNA H42 0411
   Serial number: 0327040901ÿÿÿÿ
   ASAM Dataset: EV_BCMMQB 021001
   ROD: EV_BCMBOSCH_021.rod
   VCID: 00598A6F1A81658BA71-8054
   Subsystem 1 - Part No SW: 81D 955 555 A    HW: 81D 955 555
   Component: G397_RLFSS  H06 0004
   Serial number: 40104694X81D955555A0
   Coding: 8000DE
   Steering Column Switch:
   Subsystem 2 - Part No SW: 5Q1 953 521 EH    HW: 5Q1 953 569 D
   Component: Lenks.Modul  H04 0180
   Serial number: 0300201120200C200474
   Subsystem 3 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0102
   Serial number: ESE2155144
   Subsystem 4 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE2148699
   Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE2154982
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE2161301
   Part No SW: 5Q0 907 572 R    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0771
   Coding: 330007C119FFC428949C810580301600000000000000000014
   ASAM Dataset: EV_ACCBOSCHVW416 003014
   ROD: EV_ACCBOSCHVW416_003_VW37.rod
   VCID: 46D55C7778258BBBDDD-8012
   Serial number: 19092041350869
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 3829228F02D1ED4B5F1-806C
   Part No SW: 5Q0 959 655 BM    HW: 5Q0 959 655 BM
   Component: AirbagVW21    008 0403
   Serial number: 003FGM0C55B3
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   VCID: 0C41AE5F26C931EBCB9-8058
   Component: BF-Gewichtss.  H14 0022
   Serial number: IBH00000000000EXMJ16
   Coding: 30344B
   Subsystem 2 - Part No SW: -----------    HW: 480 001 709 20
   Serial number: 35700000000931692C4I
   Subsystem 3 - Part No SW: -----------    HW: 480 001 809 20
   Serial number: 35800000000408C8EB4Y
   Subsystem 4 - Part No SW: -----------    HW: 480 402 309 20
   Component: SideSensor_Dr  004 6149
   Serial number: 35100011C63817F1A671
   Subsystem 5 - Part No SW: -----------    HW: 480 402 309 20
   Component: SideSensor_Pr  004 6149
   Serial number: 352000128636FBD323FC
   Subsystem 6 - Part No SW: -----------    HW: 480 402 610 20
   Serial number: 355000128638471352DX
   Subsystem 7 - Part No SW: -----------    HW: 480 402 610 20
   Component: FrontSensor_P  004 6149
   Serial number: 3560001286384712C44X
   Part No SW: 17A 920 420 A    HW: 17A 920 420 A
   Component: KOMBI         502 5178
   Coding: 09AC080877888F050288720B50000008A0600802
   ASAM Dataset: EV_DashBoardVDDMQBA0 001044
   ROD: EV_DashBoardVDDMQBA0_VW37.rod
   VCID: 1B63DD039327A653523-804E
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Reset counter: 38
                    Mileage: 12839 km
                    Date: 2021.10.12
                    Time: 17:58:56
16777056 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_SDS_0x46 keine Kommunikation]
                    Reset counter: 38
                    Mileage: 12839 km
                    Date: 2021.10.12
                    Time: 17:58:56
   Part No SW: 3Q0 907 530 AG    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5423
   Serial number: 02122000841710
   Coding: 030100047F085900FB0002F99C0F00010001070000000000000000000000
   GVL: 01403C500000040040DC80008080CC0010000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 74B1D6BF5E39492BB39-8020
   Generator:
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H12 0052
   Serial number: 29200001623430060356
   Coding: 2DFFFF
   Serial number: 5786527700
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H55 8043
   Serial number: HA1-00004.09.20
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52FD7027846D271B415-8006
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 F    HW: 5Q0 959 760 F
   Component: Sitzmemory    H10 0026
   Serial number: Y0007TJ321899
   Coding: 001000020000050001C480808000000000008101000000F400
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 40D94A6F5A01A58BE71-8014
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 11230027809320
   Coding: 5294C620
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15.rod
   VCID: 392F278B39DBF443A0F-806C
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H06 0150
   Serial number: 11230028740967
   Part No SW: 5Q4 959 593 N    HW: 5Q4 959 593 N
   Component: TSG FS        010 0820
   Serial number: 96028032403003
   Coding: 003D1B200200028000000000
   VCID: 50F97A2F8A61550B771-8004
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000007200905
   Coding: 011000
   Part No SW: 5QN 909 144 B    HW: 5QN 909 144 A
   Coding: 911F0000
   Shop #: WSC 00066 790 00251
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 51FF7F2B816B5C0378F-8004
   Part No SW: 5H0 035 456     HW: 5H0 035 456
   Component: AMPeth12C     H04 3327
   Serial number: A1129A00044753
   Coding: 24000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_AMPEthMQB 001005
   ROD: EV_AMPEthMQB_VW27.rod
   VCID: 6491A6FFEED9D9AB239-8030
   Part No SW: 5Q4 959 592 N    HW: 5Q4 959 592 N
   Component: TSG BFS       010 0820
   Serial number: 97028033000531
   Coding: 003D13200E00028000000000
   VCID: 4FFB7953975F4AF36EB-801A
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000007205814
   Coding: 091000
   Part No SW: 3G5 035 842     HW: 3G5 035 842
   Component: MU-O-NS-US    H56 0786
   Serial number: WG8LGM171020000
   Coding: 23710000000200000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001002
   ROD: EV_MUOIMQB_VW27.rod
   VCID: 6597BBFBE5E3A0A3347-8030
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2      261 8214
   Serial number: VWZ6ZMX3355876
   Subsystem 2 - Part No SW: V03 959 809 CR    HW: -----------
   Component: NAR 2021       --- 5041
   Part No SW: 5WA 035 285     HW: 5WA 035 285
   Component: OCUGen3High   H12 0306
   Serial number: 0000000011VIBB2
   Coding: 023710201968AC209005460160102E07
   ASAM Dataset: EV_OCUGen3High 003005
   ROD: EV_OCUGen3High_003_VW27.rod
   VCID: 0451867F0E9979AB839-8050
0081 - Databus
          [Ethernet Databus missing message - Infotainment Unit]
                    Reset counter: 37
                    Mileage: 12687 km
                    Date: 2021.10.11
                    Time: 11:56:03
                    Voltage terminal 30: 12.9 V
   Part No SW: 3Q0 980 654 S    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H14 0920
   Serial number: 30092012K21775
   Coding: 0003070100020201002213548146450084000E20012000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 47CB51737F2F92B326B-8012
   Part No SW: 5G0 907 159 F    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0004
   Serial number: 200913200499
   VCID: 313F1FABE1AB3C0318F-8064
Address BB: Door Rear Drv
Address BC: Door Rear Pass
   Part No SW: 4K0 907 594 AD    HW: 4K0 907 594
   Coding: 00800073710B
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 76B5ECB748455B3B8DD-8022
End----------(Elapsed Time: 01:47, VBatt start/end: 12.3V/12.2V)-----------
GLI21PR
Puerto Rico, USA
C?ID=14844
ORIGINAL CODING:
Leuchte2sl VLB10-Lichtfunktion G 2>>>Not Active
Leuchte2sl VLB10-Dimmwert GH 2>>>0
Leuchte2sl VLB10-Dimming Direction GH 2>>>MAXIMIZE
Leuchte3sl VRB21-Lichtfunktion G 3>>>Not Active
Leuchte3sl VRB21-Dimmwert GH 3>>>0
Leuchte3sl VRB21-Dimming Direction GH 3>>>MAXIMIZE
CHANGED CODING:
Leuchte2sl VLB10-Lichtfunktion G 2>>>Blinken Links Dunkelphase
Leuchte2sl VLB10-Dimming Direction GH 2>>>MINIMIZE
Leuchte3sl VRB21-Lichtfunktion G 3>>>Blinken Links Dunkelphase
Leuchte3sl VRB21-Dimming Direction GH 3>>>MINIMIZE
SINCE THE CHANGED CODING ABOVE DID NOT WORK I CHANGED THE CODING TO:
Leuchte2sl VLB10-Lichtfunktion G 2>>>Blinken Links Hellphase
Leuchte3sl VRB21-Lichtfunktion G 3>>>Blinken Links Hellphase
THIS LAST CODING WORKED, BUT ONLY WHEN THE LIGHT SWITCH IS IN THE "PARKING LIGHTS" POSITION, NOT IN THE "AUTO POSITION". NOTE: THE INSTRUCTIONS ABOVE WERE OBTAINED FROM A MK7 GTI FORUM, NOT A MK7 JETTA GLI AUTOBAHN
THANKS FOR YOUR HELP!
@GLI21PR: Hi.
I will let @Mari finish his analysis of your problem - but with his indulgence, I make a couple of observations from the data that you have provided:
1. Clearly since the changes apply to Leuchte3sl VRB21 & Leuchte2sl VLB10 - the car is fitted with LED style DRL assemblies. This normally means on MQB platform vehicles that the DRL fittings need 2 x separate Leuchte-sets per car side. The Leuchte-sets that you have modified are for the "Signal", but the (other) Leuchte-sets below provide the settings for the Power supply:​
Leuchte4TFL LB4 - Daytime running lights supply left​
Leuchte5 TFL RB32 - Daytime running lights supply right​
I'm not certain on your particular NAR car - but it is generally prudent when making changes to the functioning of the DRL lamps to set-up the power supply AS WELL AS make alterations to the "signal" Leuchte-sets​
2. I'm intrigued by how (or if) "DRL wink" coexists with the changes that you have made - this might explain why the tweak doesn't work with the LDS on some positions. Again, I'm not sure about your "Yankee" car - but I suspect that it was factory programmed with "DRL wink"; this is the function whereby the DRL lamp is turned-OFF on the car side of the blinker (only during daylight hours) - when the turn-signal is operated.​
At face value, there seems to be an inconsistency between the "DRL wink" function and your tweak because the former tells the lamp to switch off when the blinker is operated and the latter tells the lamp to counter-blink.​
Now, normally Leuchte-programming manages conflicts via positioning the command on a higher priority Lichtfunkion channel (which you have done by choosing Lichtfunktion G)- but in this case, the dichotomy is fundamental (meaning that it is binding and it can't be resolved). Hence your observation about the tweak only working on some LDS position - I think​
GLI21PR
Puerto Rico, USA
C?ID=14844
1. Don, thanks for the reply!. If I understood you correctly, y need to add to my coding:
Leuchte4TFL LB4-Lichtfunktion G 2>>>Blinken Links Hellphase
Leuchte4TFL LB4-Dimmwert GH 2>>>0
Leuchte4TFL LB4-Dimming Direction GH 2>>>MINIMIZE
Leuchte5 TFL RB32-Lichtfunktion G 3>>>Blinken Links Hellphase
Leuchte5 TFL RB32-Dimmwert GH 3>>>0
Leuchte5 TFL RB32-Dimming Direction GH 3>>>MINIMIZE
2. Yes, my “Yankee” car 🤣 from factory turned off the drl’s and only the blinkers worked when turning…at nighttime the drl’s remained on and the blinkers do their job.
With my new coding, drl’s are in phase with blinkers, however during daytime the lights switch must be in “parking lights” position, if switch is moved to “Auto” drl’s and blinkers work as from factory, as explained above…oddly enough at nighttime drl’s and blinkers are in phase with lights switch in “Auto” ( low beam on, of course).
Thanks again!
@GLI21PR: OK - my word-play with "Yankee" was used tongue-in-cheek because I have never understood your country's road rules for vehicle lighting (it's entirely my deficiency). Down here in the Antipodes, we have the Australian Design Rules - which are also difficult to understand. But compared to your DoT equivalent- our ADRs read like a child's picture book (IMO- and no offense intended)
So, again pending @Mari response and with the continuing caveat of my lack of understanding of the factory-setting on your NAR vehicle - I suspect (guess really) that the binding matter to successfully implementing your tweak will be its contradiction with "DRL wink". The other interesting aspect of your tweak instructions is that they don't consider the distinction between left-side and right-side blinking (i.e. only the "Links" command is used)
Once again I'm guessing - but the easiest way to (kind-of) achieve your wants, is to try this (please read "Note" below first):
  1. Return ALL settings to their factory values
  2. Left car-side: Search each of the Lichtfunktion channels on Leuchte2sl VLB10 and Leuchte4TFL LB4 for the Leuchte-command Blinken links aktiv (beide Phasen) and change to Blinken Links Hellphase
  3. Right car-side: Search each of the Lichtfunktion channels on Leuchte3sl VRB21 and Leuchte5 TFL RB32 for the Leuchte-command Blinken rechts aktiv (beide Phasen) and change to Blinken Rechts Hellphase
Note: the instructions above accept that it's NOT possible to operate both "DRL wink" and "Pace Car Effect" functions on the same lamps (they are simply incompatible lighting functions). This being so, the "DRL wink" function is sacrificed in preference for counter-blinking DRL lamps. This means that after completion, "DRL wink" won't work
Finally, and apropos of my opening paragraph - I suggest that you consider whether counter blinking DRLs on a "Yankee" vehicle is compliant with your DoT rules.
The liability that I accept for providing the suggestion above EXACTLY equals the financial payment that any (non-employee) member of this forum receives from Ross-Tech for doing so. And that amount = $0 AUD!!;)
So, whilst I am able to claim the position of "all care, but no responsibility" - alas, you don't have this luxury - you are responsible and accountable at law. I urge that you make an informed decision-please.
As a practical matter, enforcement of these rules/standards is practically nil once the car is sold. Oh sure, your lights have to work; if they don't, you'll get pulled over, but nobody checks if the manner that they work in is in compliance with the "rules".
Really? I'm surprised- your police might not be aware of the specifics of DoT - but Shirley it would be obvious to them from this tweak that something is different about the car to warrant their attention?
So, even accepting the lax practices of your plod - given the litigous nature of your culture - is there no risk of liability (in a practical sense) for the driver if an accident happens and an injured party claims that it was confusion caused by the "pace-car" effect that caused the accident? Or risk from an insurance company claiming that coverage is voided because of incompatibility with DoT?
Nope. They're not trained on the nuances of how the lights are supposed to work, nor do they see a 2021 Jetta GLI very often.
Headlights work? Tail lights work? Brake lights work? Blinkers work? Marker lights work? Good to go; have a nice day, sir.
Uesque
Kennywood, USA
C?ID=441428
This is from a 2021 R-Line but other than the fogs I think the channels are the same on the GLI.
Rear:
Leuchte17TFL R BLK SRB3TFL R BLK SR KC3 > Left inside LED rear running light, pos 0A
Leuchte16BLK SLB35BLK SL KC9 > Right inside LED rear running light, pos 1A
Leuchte23SL HLC10 > Left outside LED rear running light, pos 0A
Leuchte24SL HRA65 > Right outside LED rear running light 1A
Leuchte28RFL LC11> Left rear LED three boxes running, brake, turn light, pos 13
Leuchte27NSL RC6> Right rear LED three boxes running, brake, turn light, pos 23
Leuchte20BR LA71 > Left rear LED clear lens brake, turn light, pos 13
Leuchte21BR RC8 > Right rear LED clear lens brake, turn light, pos 23
Leuchte22BR MA57> Center brake light (CHML), pos
Leuchte25KZL HA59 > LED license plate lights, pos
Front:
ENG116948-ENG116100-Leuchte12NL LB45 Left fog light, pos 38
ENG116949-ENG116129-Leuchte13NL RB5 Right fog light, pos 42
ENG116938-ENG115916-Leuchte2SL VLB10 Left DRL Signal, pos 48
ENG116939-ENG115936-Leuchte3SL VRB21 Right DRL Signal, pos 4C
ENG116940-ENG115957-Leuchte4TFL LB4 Left DRL Supply, pos 3A
ENG116941-ENG115967-Leuchte5 TFL RB32 Right DRL Supply, pos 44
ENG116942-ENG116556-Leuchte6ABL LC5 Left Low Beam, pos 36
ENG116943-ENG116557-Leuchte7ABL RB1 Right Low Beam, pos 40
ENG116944-ENG116028-Leuchte8FL LB39 Left High Beam, pos 37
ENG116945-ENG116057-Leuchte9FL RB2 Right High Beam, pos 41
ENG116936-ENG115883-Leuchte 0 BLK VL B36 Left Turn Signal, pos 34
ENG116937-ENG116548-Leuchte1BLK VRB20 Right Turn Signal, pos 3E
BLK -> Blinker -> Turnsignals
SL -> Standlicht -> Parking lights (not used in FL)
TFL -> Tagfahrlicht -> Day running lights (used and dimmed for parking lights)
ABL -> Abblendlicht -> Dipped beam
FL -> Fernlicht -> High beam
Shutter -> Maskierung -> High beam shutter for Xenon lamps (not used in FL)
  • Informative
GLI21PR
Puerto Rico, USA
C?ID=14844
Don, many thanks, this worked like a charm!! 👍👍. Appreciate your help.
GLI21PR
Puerto Rico, USA
C?ID=14844
Rear:
Front:
Thanks Uesque! This comes very handy for my next coding which is disabling the front 3 tiny amber colored lights or side markers. I may be wrong but I don’t see those on the front channel list. I’ve had success in coding stuff using Mk7, Mk7.5 and Golf R instructions, however, lights are a bit tricky. I was able to follow Mk7 coding instructions to disable the front side markers and succeeded, however it affected the rear parking lights (oddly enough) so I undid the coding. You wouldn’t happen to know the correct coding to delete the front amber side markers on my GLI, would you? Many thanks.
