Please Help with ABS Longcoding (MK60EC1)
Joe2k
Verified VCDS-User
Romania
C?ID=327551
Hello guys . I have removed the instrument cluster because some of the lights got burned . After i replaced them , plugged cluster back in and lost all coding on abs .
Car is golf 5 1.9 TDI BLS 2009.
Left hand drive
NO tpms
Wednesday,06,October,2021,06:50:33:40571
VCDS Version: 21.9.0.1 (x64)  HEX-V2 CB: 0.4555.4
Data version: 20210824 DS330.0
VIN: WVWZZZ1KZ9M359165   License Plate:
Mileage: 298120km-185243mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ9M359165   Mileage: 298120km-185243miles
25-Immobilizer -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 021 QJ    HW: 03G 906 021 AB
   Component: R4 1,9L EDC  000SG  1984
   Revision: --H11---    Serial number: VWXBZ0J5043263
   Coding: 0000071
   Shop #: WSC 00066 000 00000
   VCID: 77AB16A4F3C4A303968-8022
   VINID: 9E69EAAAA05BA8974314904614C41010AA
005488 - Engine Start Blocked by Immobilizer
               P1570 - 000 -  - Intermittent
                    Mileage: 266371 km
                    Time: 00:00:23
                    RPM: 1029 /min
                    Voltage: 11.78 V
                    Bin. Bits: 00000100
                    Bin. Bits: 11000000
                    (no units): 33.0
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0109
   Revision: 00H45001
   Coding: 000000000000000000000000000000000000
   Shop #: WSC 59602 002 104857
   VCID: 7EA50380D0FE924BD5E-802A
03306 - Coding Not Valid
                    Reset counter: 196
                    Mileage: 298120 km
                    Count: 3
                    Count: 2
                    Count: 12288
                    Count: 4161
                    Count: 41728
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 196
                    Mileage: 298120 km
                    Count: 3
                    Count: 2
                    Count: 12288
                    Count: 143
                    Count: 41728
                    Reset counter: 196
                    Mileage: 298120 km
                    Count: 7
                    Count: 2
                    Count: 12288
                    Count: 195
                    Count: 41472
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 196
                    Mileage: 298120 km
                    Count: 7
                    Count: 2
                    Count: 12288
                    Count: 288
                    Count: 41472
                    Reset counter: 196
                    Mileage: 298120 km
                    Count: 3
                    Count: 2
                    Count: 12288
                    Count: 291
                    Count: 41728
   Part No SW: 1K0 907 044 CT    HW: 1K0 907 044 CT
   Component: ClimatronicPQ35 133 1213
   Revision: 00133024    Serial number: 00000000000000
   VCID: 7BA30A94CFEC8763F20-802E
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000009499553
   Coding: 08890F2700041500470000001C00000000097B075C000120000000000000
   VCID: 323DE7B05826862B616-8066
   Component: Wischer 040609 021  0501
   Coding: 00038805
                    Fault Status: 00101001
                    Reset counter: 203
                    Mileage: 297081 km
                    Voltage: 12.40 V
                    Reset counter: 203
                    Mileage: 297081 km
                    Voltage: 12.35 V
00154 - Windshield Wiper Motor;  Passenger Side (V217)
                    Reset counter: 203
                    Mileage: 296220 km
                    Voltage: 10.40 V
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                    Reset counter: 203
                    Mileage: 296220 km
                    Voltage: 10.35 V
   Part No SW: 1K0 909 605 R    HW: 1K0 909 605 R
   Component: 37 AIRBAG VW8   018 2200
   Revision: 02018000    Serial number: 0038MD03CNB9
   Coding: 0013111
   Shop #: WSC 01372 785 00200
   VCID: 3B23CA948F6C4763B20-806E
   Subsystem 1 - Serial number: 6332MSME456631310
   Subsystem 2 - Serial number: 6342MSME4311664A7
   Subsystem 3 - Serial number: 6351HSME000D5E78E
   Subsystem 4 - Serial number: 6361HSME00297354+
   Part No SW: 1K0 953 549 DA    HW: 1K0 953 549 DA
   Component: J0527           053 0111
   Coding: 0000002
   VCID: 74B121A8E2B2C81BB3A-8020
   Part No SW: 1K0 920 854 R    HW: 1K0 920 854 R
   Component: KOMBIINSTRUMENT YJU 4005
   Revision: V0010000    Serial number: VWXBZ0J5043263
   Coding: 0000103
   Shop #: WSC 46091 003 104857
   VCID: 3A2DCF9080567E6BA96-806E
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533  Gateway   H07 0071
   Revision:   H07 01    Serial number: 300409F1001920
   Coding: E9807F06000202002002
   VCID: 372BD6A4B3446303568-8062
                    Fault Status: 00110100
                    Reset counter: 235
                    Reset counter: 203
                    Mileage: 297081 km
                    Time: 03:48:22
                    Reset counter: 203
                    Mileage: 297081 km
                    Time: 03:48:23
   Component: IMMO YJU            4005
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000915798522
   Coding: 0000180
   VCID: 6FBB2EC48B94EBC34E8-803A
                    Fault Status: 00100101
                    Reset counter: 221
00096 - Drivers Door Central Locking (Safe) Motor (V161)
                    Fault Status: 00101100
                    Reset counter: 236
                    Fault Status: 00111000
                    Reset counter: 235
00109 - Left Mirror Turn Signal Lamp (L131)
                    Fault Frequency: 131
                    Reset counter: 235
                    Mileage: 295583 km
                    Reset counter: 203
                    Mileage: 297081 km
                    Reset counter: 203
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 69     2501
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2C01F9C87A02D0DB2BA-8078
                    Fault Status: 11100101
                    Battery Volts: 11.9 V
                        PD
                    Temperature: 22.0°C
                    Count: 3
                    Steering Angle: 0.22°
                    Count: 1
                        SteerAng Init
   Coding: 8090020052830C7F2D04840560084F03E0FCA0
   VCID: 03537274B71CFFA3BA0-8056
                    Reset counter: 203
                    Mileage: 297081 km
                    Time: 03:48:22
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 09011315362102
   Coding: 0000180
   VCID: 70B92DB896AAF43B572-8024
00097 - Front Passengers Central Locking (Safe) Motor (V162)
                    Reset counter: 236
                    Reset counter: 216
                    Mileage: 297509 km
                    Reset counter: 203
                    Mileage: 297081 km
                    Reset counter: 203
   Part No SW: 1K0 035 156 B    HW: 1K0 035 156 B
   Component: Radio         H19 0056
   Revision: R0000000    Serial number: VWZAZ1I8804334
   Coding: 0000020002
   VCID: 221D17F004C616AB916-8076
   Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R
   Component: J388   TUER-SG HL   1401
   Revision: 11006001    Serial number: 00000003992965
   Coding: 0000144
   VCID: 75B71CACE9C8D113844-8020
   Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R
   Component: J389   TUER-SG HR   1401
   Revision: 11006001    Serial number: 00000003994966
   Coding: 0000144
   VCID: 76B51BA0F4CEDA0B8DE-8022
End----(Elapsed Time: 01:18, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Did you do an Auto-Scan on this car before you took it apart? If so, please look in your Scans sub-folder and it should have the coding you need. If not, you will do so the next time, right? ;)
Joe2k
Verified VCDS-User
Romania
C?ID=327551
I allready punsihed myself.. just want to sort it out :) i promise myself ill save them from now on :)
I'm confident someone will be along with codings for you to try.
As a registered HEX-V2 user, you can also try using vis4vag:
DjDvr
Romania
C?ID=267309
Try 113B400D89270003880C02EA911E0000A000 and report back :).
Joe2k
Verified VCDS-User
Romania
C?ID=327551
God bless you. Worked like charm
Spacewalker
Poland
C?ID=159607
try this one
113B400D0A270003880C02EA501E0040B000
Worked like charm
Please do let us know which coding works, ideally by posting a final Auto-Scan from the car.
