Tiguan changed Byte 18
Tomasitas69
Lithuania
C?ID=198354 (NRRT)
I have VW Tiguan (2012) with Bi-Xenon lights.
Using Ross-Tech VCDS I've changed Central electric 9 Byte 18 from "00
Lighting: Standard/Parameter Settings (EEPROM)" to "30 Lighting: VW
Tiguan (5N1/VW316) Rest of World (RoW)", but now LED lights doesn't work
and changing back to "00 Lighting" doesn't help.
Is it possible to restore old settings?
A car crash is the reason so many errors it is.
VCDS Version: Release 12.12.2
Data version: 20140212
Friday,04,April,2014,17:30:52:13054
Chassis Type: 5N (7N0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 22 25 2E 37 42 44 46 4C 52
          53 55 56 62 69 72 77
VIN: WVGZZZ5NZCW062630
22-AWD -- Status: Cannot be reached 1100
55-Xenon Range -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 LG    HW: 03L 907 309 AD
   Component: R4 2,0l EDC   H24 2075
   Revision: 42H24---    Serial number: 00000000000000
   Coding: 00250012043600080000
   Shop #: WSC 01324 020 00200
   ASAM Dataset: EV_ECM20TDI01103L906018LG 003006
   ROD: EV_ECM20TDI01103L906018LG.rod
   VCID: 7AFB0626FDEDA7CED53-802F
14627 - Fuel Pump Control Module
          P025A 00 [167] - Electrical Fault
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:48
Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
   Part No SW: 0BH 300 011 K    HW: 0BH 927 711 C
   Component: DSG DQ500-7A  H05 1706
   Revision: 00H05V01
   ROD: EV_TCMDQ500021_SE36.rod
   VCID: 2A5BF6664DCDD74EE53-807F
   Part No SW: 5N0 614 109 AP    HW: 5N0 614 109 AP
   Component: J104   C6 450M VD8B 0005
   Revision: --H07---    Serial number: 00000005210972
   Coding: 0005441
   VCID: 79F9192A30EBACD6DC9-802C
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:48
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 11.75 V
                    Bin. Bits: 00011111
                    Count: 2
                    Hex Value: 0x0000
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:48
                    Hex Value: 0x0000
                    Voltage: 11.75 V
                    Bin. Bits: 00011111
                    Count: 3
                    Hex Value: 0x0000
01324 - Control Module for All Wheel Drive (J492)
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:49
                    Hex Value: 0x0000
                    Voltage: 11.75 V
                    Bin. Bits: 00011111
                    Count: 256
                    Hex Value: 0x0000
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:58
                    Hex Value: 0x0000
                    Voltage: 11.25 V
                    Bin. Bits: 00011111
                    Count: 191
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
   Component: Climatronic   H18 1112
   Revision: 00001004
   Coding: 0000004002
   ROD: EV_ClimaAutoBasis_SE36.rod
   VCID: 800FF4CE1B317D1E1B7-80D5
13701520 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:48
13701536 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:48
   Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
   Component: BCM PQ35 M    021 0064
   Revision: BC021001
   Coding: 40180A3BA0251AC0400800C0340009E44B552F08736D8560E48400000040
   VCID: 3E73CA36A9454BEEA9B-806B
   Subsystem 1 - Part No: 5N1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS 120112 03  32  0010
   Coding: 009795
   Component: RLS 050112 05  54  0403
   Coding: 02304D
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:49
                    Voltage: 12.00 V
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:49
                    Voltage: 12.00 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:53
                    Voltage: 12.00 V
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:53
                    Voltage: 12.00 V
Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
   Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0025
   Revision: --------    Serial number: 56261202000687
   Coding: 158103
   ASAM Dataset: EV_EPHVA2C000000000 002008
   ROD: EV_EPHVA2C000000000_VW36.rod
   VCID: 4487B8DECFA9213EFFF-8011
13637396 - Databus
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:48
13637397 - Databus
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:48
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 02011200480002
   Coding: 010180
   VCID: 275D0F5256DFEA26FAD-8072
03263 - Functional Restriction
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:47
                    Error Code: 7
                    Bin. Bits: 00000000
03262 - Comfort Restriction
                    Reset counter: 179
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:47
                    Error Code: 2
                    Bin. Bits: 00000000
00141 - Rear Body Acceleration Sensor (G343)
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:47
00774 - Level Control System Sensor; Rear Left (G76)
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:47
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__206 VW10 HI   1918
   Revision: 23016000    Serial number: 003K0P0JBD49
   Coding: 0012342
   VCID: 4C9790FE2FF9E97E37F-8019
   Subsystem 1 - Serial number: 6332MTS657403501
   Subsystem 2 - Serial number: 6342MTS642123501
   Subsystem 3 - Serial number: 6351HTS6U17AV9KJ
   Subsystem 4 - Serial number: 6361HTS6JBFM0AKJ
01589 - Igniter for Head-Airbag; Passenger Side (N252)
                    Fault Status: 11100001
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:49
01588 - Igniter for Head-Airbag; Drivers Side (N251)
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:49
01218 - Side Airbag Igniter; Passenger Side (N200)
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:49
01217 - Side Airbag Igniter; Driver Side (N199)
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:49
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:49
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:49
   Part No SW: 5K0 953 501 AT    HW: 5K0 953 569 H
   Revision: FF010040    Serial number: 20120120201837
   Coding: 198A140000
   VCID: 7CF7003EF7D999FEC7F-8029
   Component: E221__MFL-TAS  H09 0013
   Coding: 820000
   Part No SW: 5N0 920 882 C    HW: 5N0 920 882 C
   Component: KOMBI         H04 0417
   Coding: 111F01
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
   VCID: 3365EB029A079686565-8066
9453074 - Fuel Level Sensor 1
          B103E 1B [009] - Resistance Too High
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:48
9459739 - Fuel Level Sensor 2
          B1058 1B [009] - Resistance Too High
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:48
   Part No SW: 7N0 907 530 M    HW: 1K0 907 951
   Component: J533  Gateway H42 1623
   Revision:   H42       Serial number: 030112F1000862
   Coding: 356002
   VCID: 3A7BC626B56D67CE953-806F
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:49
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:49
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:49
   Component: IMMO          H04 0417
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EADBB6660D4D974EA53-80BF
   Part No SW: 1T0 035 680 H    HW: 1T0 035 680 H
   Component: RNS-MID       H64 4120
   Revision: AB001001    Serial number: VWZ6Z7M8212073
   Coding: 0400040204000080000C
   Shop #: WSC 00862 461 85084
   VCID: 3365EB0292079686565-8066
                    Reset counter: 139
                    Mileage: 45184 km
                    Reset counter: 139
                    Mileage: 45184 km
                    Reset counter: 139
                    Mileage: 45184 km
00877 - Treble Speaker Rear Right (R16)
                    Reset counter: 139
                    Mileage: 45184 km
01523 - Microphone for Telephone (R38)
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:57
03138 - Input AUX IN
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:04:52
   Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0503
   Revision: 13110009    Serial number: 0004045133
   Coding: 0000B4
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 387FDC2E836175DE637-806D
65538 - Local Data Bus
          U10BA 00 [009] - No Communication
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:48
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.287 1002
   Revision: 1AH03836    Serial number: 00113570257101
   Coding: 0000258
   VCID: 3C77C03E7F5959FE87F-8069
                    Fault Status: 11101101
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:48
                    (no units): 4.0
                    Voltage: 12.00 V
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0503
   Revision: 15110009    Serial number: 0004037751
   Coding: 0000B4
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 3979D92AB86B6CD69C9-806C
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:48
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000584975
   Coding: 0026157
   VCID: 3561D51A5C7388B6781-8060
                    Fault Status: 01101101
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:48
                    Voltage: 12.00 V
                    Count: 104
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
02432 - Supply Voltage for Left Parking Brake Motor (V282)
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:48
                    Voltage: 12.00 V
                    Count: 29
                    Hex Value: 0x1270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
02433 - Supply Voltage for Right Parking Brake Motor (V283)
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:48
                    Voltage: 12.00 V
                    Count: 30
                    Hex Value: 0x1270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
Address 55: Xenon Range (J745)       Labels: 5M0-907-357-V3.clb
   Component: AFS-ECU       H04 0111
   Coding: 043A00000B000200
   ROD: EV_HeadlRegulVWAFSPt.rod
   VCID: 377DDF128E7F7AA66AD-8062
   Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329
   Component: LeiMo links  H02 0008
   Coding: 140000
   Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329
   Component: LeiMo rechts  H02 0008
   Coding: 140000
13705985 - Databus
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:48
13705987 - Databus
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:48
13705991 - Databus
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:48
                    Reset counter: 139
                    Mileage: 45184 km
                    Reset counter: 139
                    Mileage: 45184 km
                    Reset counter: 139
                    Mileage: 45184 km
                    Reset counter: 139
                    Mileage: 45184 km
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:01:57
                    Reset counter: 139
                    Mileage: 45191 km
                    Date: 2024.14.29
                    Time: 00:04:52
Address 69: Trailer (J345)       Labels: 1K0-907-383-MY8.lbl
   Revision: 3A001001    Serial number: 00008030012249
   Coding: 410D000100000000
   VCID: 306FE40E6311AD9E2B7-8065
Thank You
00 is not the original setting. When you see 00 in Byte 18, it is there to "mask" or "hide" the real setting. It should be possible to restore the original setting if it is known. Hopefully somebody will know it (I don't).
bambazonke
Mackay Qld Australia
C?ID=240542
Here are all of the Tiguan values for Byte 18:
2F | VW Tiguan (VW316) | Halogen/Xenon | RoW | TFL_0
30 | VW Tiguan (VW316) | Halogen/Xenon | RoW | TFL_S
50 | VW Tiguan (VW316) | Halogen/Xenon | NAR | TFL_1
51 | VW Tiguan (VW316) | Halogen/Xenon | NAR | TFL_S
8A | VW Tiguan (VW316/416) | Halogen/Xenon | RoW/Ska | TFL_1_Ska
TFL_0: TFL mit NSL u. RFL (daytime running lights and rear fog light, reversing light)
TFL_1: mit TFL TFL-Outputs (daytime running lights with daytime running light outputs)
TFL_S: TFL Skandinavien Abblendlicht m (daytime running lights via Scandinavia low beam lights)
Tomasitas69
Lithuania
C?ID=198354 (NRRT)
"bambazonke" I got one of them to write instead of the 00 value xenon and LED should light?
bambazonke
C?ID=240542
Sorry Tomas I don't quite understand your response. The Tiguan depending on what country it is sold in, can have any of the 5 codes listed above. If it was me, it would be either the first, second or the last option. That is 2F, 30 or 8A. Try all three and see what happens and then choose one that is applicable for your current rear lights setup. I seriously doubt you car would have been set up for the North American (NAR) market judging by your autoscan you posted (VIN number and workshop codes) and seeing your current BCM configuration in longcoder helper.
