Incorrect chassis
jaysonjay
Ryde, Isle of Wight
C?ID=438403
hi iv been having the same issue for some time iv been gathering fault codes mainly incorrect chassis no
the keys were lost iv changed the main ecu comfort ecu and dash board car starts and runs ok apart from the problems i know about the egr and butterfly which i have new one to fit my main issue is can any one tell me how to correct or recode the units which say incorrect chassis no
many thanks
audi a4 2007 2.0 avant s line tdi
Monday,27,September,2021,16:55:34:48113
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: WAUZZZ8E86A203753   License Plate:
          67 69 75 76 77
VIN: WAUZZZ8E86A203753   Mileage: 333950km-207506miles
Address 01: Engine        Labels: 03G-906-016-BLB.clb
   Part No SW: 03G 906 016 JD    HW: 028 101 265 4
   Component: R4 2,0L EDC  000SG  9643
   Revision: --H02---    Serial number:
   Coding: 0000072
   Shop #: WSC 00006 210 81007
   VCID: 6E85C41DCC9CBA6B45D-803A
   VINID: 9D196AAAA2152064420031C50C7529C3C6
001031 - EGR Sensor 2
               P0407 - 000 - Signal too Low
                    Mileage: 333952 km
                    Lambda: -0.8 %
                    Mass Air / Rev.: 1050.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
                    Bin. Bits: 00000000
012547 - Motor for Intake Manifold Flap (V157)
               P3103 - 000 - Malfunction - Intermittent
                    Fault Frequency: 20
                    Mileage: 333952 km
                    Voltage: 12.31 V
                    Bin. Bits: 00000100
                    Torque: 0.0 Nm
                    Torque: 351.4 Nm
Readiness: 1 2 0 0 1
   Part No SW: 8E0 910 517 H    HW: 8E0 614 517 BF
   Component: ESP8 FRONT      H06 0140
   Coding: 0004401
   Shop #: WSC 06335 000 00000
   VCID: 2C010E153A00887B2B9-8078
                    Fault Status: 01100101
                    Hex Value: 0x0000
                    Hex Value: 0x0222
                    Hex Value: 0x001E
                    Hex Value: 0x3E90
                    Hex Value: 0x0001
   Part No: 8E0 820 043 BL
   Component:   A4 Klimaautomat   3233
   Coding: 00000
   VCID: 6C81CE15FF90487B6B9-513C
00716 - Air recirculation Flap Positioning Motor (V113)
            41-00 - Blocked or No Voltage
01794 - Control Module - Incorrect Chassis (VIN) Number
            35-00 - -
   Part No: 8E0 907 279 K
   Component: int. Lastmodul  ECE 0704
   Coding: 10001
   Shop #: WSC 06325
   VCID: 3A2D384DC54426CBA95-4B00
01494 - Bulb for Parking Lamps; Left (M1)
            30-00 - Open or Short to Plus
01498 - Bulb for Parking Lamps; Right (M3)
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H14 4230
   Revision: 91H14423    Serial number: 0036M00CNTY0
   Coding: 0031612
   Shop #: WSC 12345 000 00000
   VCID: 3B233D49CF6E1FC3B23-806E
   Subsystem 1 - Serial number: 6332DRB4065E0F0E.
   Subsystem 2 - Serial number: 6342DRB40692949F
   Subsystem 3 - Serial number: 6352ARB402268DC3S
   Subsystem 4 - Serial number: 6362ARB403382978N
   Subsystem 5 - Serial number: 63729RB40309B956Q
   Subsystem 6 - Serial number: 63829RB40309B867S
            000 - - - MIL ON
                    Fault Status: 11100000
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0601
   Coding: 02012
   Shop #: WSC 00186
   VCID: 41DF4FA1A8927513E8F-4B00
00888 - Wiper Switch for Intermittent Operation (E22)
            37-00 - Faulty
01304 - Radio
            49-00 - No Communications
            35-00 - -
   Part No SW: 8E0 920 951 E    HW: 8E0 920 951 E
   Component: KOMBI+WFS 4     H14 0110
   Revision: 0110        Serial number: 00000000000000
   Coding: 0006418
   Shop #: WSC 12345 067 57207
   VCID: 2C010E153A10887B2B9-5184
01304 - Radio
   Coding: 0006418
01304 - Radio
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0804
   Coding: 00001
   VCID: 6B83CD09FA9E4F43623-5118
   Part No: 8E0 959 433 CQ
   Component: Komfortgerát T3B    4336
   Coding: 07151
   Shop #: WSC 06335
   VCID: 025D80ADED14AE0BB15-4B00
   Subsystem 1 - Part No: 8E2959802F
   Component: Tõrsteuer.FS BRM 0606
   Subsystem 2 - Part No: 8E2959801F
   Component: Tõrsteuer.BF BRM 0606
   Component: Tõrsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tõrsteuer.HR BRM 0606
00955 - Key 1
            35-00 - -
00956 - Key 2
            35-10 - - - Intermittent
Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
   Part No SW: 8E0 919 283 D    HW: 8E0 919 283 D
   Component: Parkhilfe 4-Kan H06 0010
   Revision: 00H06000    Serial number: 00067802030800
   Coding: 0000114
   VCID: 313F1F611D02E59318F-50F4
   Part No SW: 8P1 862 335 A    HW: 8P1 862 335
   Component: FSE_256x BT     H44 0660
   Revision: 00000000    Serial number: 00000005651226
   Coding: 0011802
   Shop #: WSC 12345 121 121233
   VCID: 35372B71E96AC9B3447-50D0
01523 - Microphone for Telephone (R38)
                    Reset counter: 204
                    Time Indication: 15
01304 - Radio
                    Fault Frequency: 19
                    Reset counter: 232
                    Time Indication: 15
End----------(Elapsed Time: 05:31, VBatt start/end: 12.3V/12.3V)-----------
jaysonjay
Ryde, Isle of Wight
C?ID=438403
Hi jef thank you for your reply I am a total beginner using vcds I don’t suppose you have a total beginners guid on how I get there to change that value and also the radio has no communication through also again incorrect chassis no many thanks jay
So instead of getting new key(s) matched, you installed an ECU and Cluster that have the wrong VIN in them?
<SMH>
[Select]
[15-Airbags] (or one of the other modules that have this fault)
[Adaptation]
Type 81 into the channel number on that screen, then click
[Read]
Put the correct value (02905 for the airbag module, others will be different) in the box labelled New value.
[Test]
[Save]
jaysonjay
Ryde, Isle of Wight
C?ID=438403
thanks for your reply and thanks also for the guide
yes lost keys and i tried our only locksmith first for some keys but for some reason he couldnt cut and code new keys im not sure why but where im from he is our only locksmith so i went down the rout of ecu and key set wish there was an easier way for me regards jay
jaysonjay
Ryde, Isle of Wight
C?ID=438403
<SMH>
[Select]
[Adaptation]
[Read]
[Test]
[Save]
i have all the genuine ecus still could i ask what would you do in this situation the easiest way would be to get a new key and recoded to the car but like i say he said he couldnt do that i dont know why he didint really explain him self very clear my problem is where i live he is the only one i would love to here from you uwe on what the best way forward before i change any coding regards jay
jaysonjay
Ryde, Isle of Wight
C?ID=438403
Hi again ok so been on the diagnostic pretty much for day working my way around vag thanks uwe and jef iv managed to code airbags and lights gone off the last 2 I’m struggling with is 00778 steering angle sensor adress 03 and the other one is 01304 radio no communication any help would be appreciated regards jay
