Help - Dashboard retrofit 3AA...970E to 3AA...880A - Passat B7 Diesel
luisfa
Brazil
C?ID=206461
Hi guys,
I have a Passat Variant B7 2012 Sport 2.0 Tdi and today I replaced the black and white OEM dashboard 3AA920970E for 3AA920880A. Then come up the fault code 03194 on parking brake module 53, which is 801G.
Is that possible access the security code of module 53 and change it? Now it is coded as 022167, should I use 021167?
Monday,27,September,2021,13:27:00:33316
VCDS Version: 21.9.0.2 (x64)
Dealer/Shop Name: Andre Luis Freitas
VIN: WVWZZZ3CZCE114440   License Plate: 12C16375
Mileage: 178470km-110896mi   Repair Order: 27-Sep-21
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 53 55 56 61
          62 65 72
VIN: WVWZZZ3CZCE114440   Mileage: 178470km-110896miles
Address 01: Engine (J623-CFGB)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 PT    HW: 03L 907 309 AE
   Component: R4 2.0l TDI   H25 9980
   Revision: 41H25---    Serial number: 00000000000000 CVN: 3F0B6B78
   Coding: 00190012042501080000
   Shop #: WSC 00423 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906018PT 003008
   ROD: EV_ECM20TDI01103L906018PT.rod
   VCID: 0B1271A1A2C774D124-805E
   VINID: 9E69EAAAA0D3A9354104410400A4023285
   Part No SW: 3AA 614 109 AF    HW: 3AA 614 109 AF
   Component: J104   C2 450M V441 0023
   Revision: --H07---    Serial number: 00000005100199
   Coding: 0003001
   Shop #: WSC 05311 000 00000
   VCID: 71EE0349682B3E01BE-8024
   Part No SW: 3AA 907 044 B    HW: 3AA 907 044 B
   Component: Climatronic   H03 0101
   Revision: 00001K01
   Coding: 0014004803
   Shop #: WSC 00015 115 00000
   VCID: 2F6AC531769F68F1E8-807A
9481988 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
                    Reset counter: 105
                    Mileage: 178470 km
                    Date: 2021.09.27
                    Time: 00:16:24
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 H    HW: 3AA 937 087 H
   Component: BCM PQ47 H+   421 0464
   Revision: BC421001
   Coding: 000800000000000000180080140029F423D50088626D8160E480C7240041
   VCID: 3F8A9571AEFF987178-806A
   Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 28111  26  0612
   Coding: 00B795
   Component: RLS 071211 05  54  0403
   Coding: 0730ED
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__102 VW10 HI   1918
   Revision: 23016000    Serial number: 003K0PRCTGY.
   Coding: 0012338
   VCID: 4C90B2BD2F4933E9ED-8018
   Subsystem 1 - Serial number: 6332MTS671433251
   Subsystem 2 - Serial number: 6342MTS695893261
   Subsystem 3 - Serial number: 6351HTS6PNHA0AKJ
   Subsystem 4 - Serial number: 6361HTS6D7L50AKJ
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C9 953 501 BN    HW: 5K0 953 569 AB
   Revision: FF010040    Serial number: 20111208200195
   Coding: 1182250000
   VCID: 76E43055C94519396B-8022
   Coding: E20000
   Part No SW: 3AA 920 880 A    HW: 3AA 920 880 A
   Component: KOMBI         H02 0206
   Coding: 160F01
   Shop #: WSC 00028 028 00206
   VCID: 316EC34960AB7E01FE-8064
   Part No SW: 7N0 907 530 Q    HW: 1K0 907 951
   Component: J533  Gateway H41 1623
   Revision:   H41       Serial number: 191111F1002821
   Coding: 462007
   Shop #: WSC 05314 000 00000
   VCID: 3E74E875A9F5917973-806A
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0400
   Revision: 00043000    Serial number: VWZCZ000000000
   Shop #: WSC 24641 002 1048576
   VCID: 76E43055014519396B-8022
   Revision: A1001003    Serial number: 7661443547
   Coding: 020000
   VCID: 295E2B29407B06C136-807C
   Part No SW: 3C0 035 279 G    HW: 3C0 035 279 G
   Component: RNS315-EU   H35 0263
   Serial number: VWZAZ2L3887201
   Coding: 040004010400110000019002
   ASAM Dataset: EV_RNS315EUV2UDS A01004
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 275A2D115E6F30B120-8072
   Component: EUR_W_0038  0038
1048642 - Internal Control Module Memory Check Sum Error
          B2000 42 [009] - General Memory Failure
                    Mileage: 150095 km
                    Date: 2021.03.16
                    Time: 16:27:15
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0534
   Revision: 12110009    Serial number: 0004003913
   Coding: 0202B7
   Shop #: WSC 05311 115 00000
   VCID: 3566F75994C35221A2-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0407
   Serial number: 00000002604237
   Coding: 000290
   Part No: 1K0 909 144 N
   Component: EPS_ZFLS Kl. 196    3301
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 3566F7595CC35221A2-8060
   Component:    KSG PQ47 ELV 043 0634
   Coding: 1191020052834E763402941D7C085FCE105C01
   Component: Neigungssensor  004 0611
   Component: EZE_2         H41 1623
   Coding: 00000008
   VCID: 6FEA0531BE1F28F1A8-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0534
   Revision: 14110009    Serial number: 0004009434
   Coding: 0202B6
   VCID: 3664F05589C55939AB-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0407
   Serial number: 00000002617718
   Coding: 000290
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000490336
   Coding: 0022167
03194 - Incompatible Interface
                    Fault Status: 01110000
                    Reset counter: 65
                    Date: 2016.02.18
                    Time: 00:00:49
                    Voltage: 11.80 V
                    Count: 95
                    Hex Value: 0x1263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Component: AFS-ECU       H04 0111
   Coding: 029600000B000200
   ROD: EV_HeadlRegulVWAFSPt_VW46.rod
   VCID: 377AFD518ECFA031B0-8062
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H04 0011
   Coding: 230000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H04 0011
   Coding: 230000
   Component: Batt.regelung H41 1623
   Coding: 030F185A
   VCID: 71EE0349A82B3E01BE-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900261377
   Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
   Component: RDKBERU30     H09 0010
   Serial number: 10000000082517
   ASAM Dataset: EV_RDKBERU30 003012
   ROD: EV_RDKBERU30_003.rod
End-------------------------(Elapsed Time: 03:46)--------------------------
dieseltje
The Netherlands
C?ID=148044
If you place back the old b/w cluster, can you erase the error
dieseltje
The Netherlands
C?ID=148044
I understand, but to check if cluster is causing this issue you best should put back old cluster, if error returns, it is not caused by cluster.
Most of the time the parking brake failure is caused by bad or broken motordrive of the electronic parkingbrake.
luisfa
Brazil
C?ID=206461
Thanks! Good point I will do it, but I found a thread here that might be the same problem I’m experiencing. I’d need upgrade the parking brake módulo to index “J”.
luisfa
Brazil
C?ID=206461
dieseltje
The Netherlands
C?ID=148044
I should first swap back cluster to determine the cause of the fault before I should start flashing parts.
kamold
Australia
C?ID=241363
I think the cluster sw version is too low. What was the sw version of your original cluster?
luisfa
Brazil
C?ID=206461
3AA920970E SW0609 HW H03.
3AA920880A SW0206 H02.
luisfa
Brazil
C?ID=206461
All good. Just put it back and no fault codes on parking brake 53.
luisfa
Brazil
C?ID=206461
I could buy the parking brake index “J” and try it with 880A dash. If would work out. My point is: what I have to do after replace the parking brake module? Code parking brake 53 module and 03 ABS? Is that complicated?
dieseltje
The Netherlands
C?ID=148044
Parkingbrake coding is not so exiting.
And is you abs coding gone?
luisfa
Brazil
C?ID=206461
No all working properly. I’m just wondering if is something handy to perform with VCDS. Once EBP and ABS systems are critical to the car runs properly I don’t want mess with something.
Spacewalker
Poland
C?ID=159607
you can try to recode EPB
C10,0 = Display (P) RED OFF (< 3AA-907-801-E)
C11,1 = Display (P) ??? (3AA-907-801-G >)
or istall older EPB - compatibile with older cluster
or keep org EPB and do update your cluster
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
The cluster you install has Sw version for cars before 2012 , and you have after 2012 EPB.
So suggestion from post above is your key .
