Audi A6 C7 BiTDi intake valve error / location?
BrownieMan
Europe
C?ID=324020
Problem is limp mode because of issue attached in log.
When I ran output test by VCDS both wastegate actuator on bigger turbo and electronic regulator on smaller turbo works fine, tryed operating wastegate actuator with vacuum pump and it holds well without any leak. But I am still getting this error and car is completely undriveable with this error.
I believe the problem is around the " Bypass valve f high press turboch turbine inlet" but no solid idea where to look at when looking from front of the car.
Can anybody help please?
Friday,27,August,2021,21:02:30:06850
VCDS Version: 21.8.0.0 (x64)  HEX-V2 CB: 0.4553.4
Data version: 20210731 DS330.0
VIN: xxx   License Plate: TURBO2
                Address 01: Engine       Labels: Redir Fail!
Control Module Part Number: 4G0 907 589 A    HW: 4G0 907 589
  Component and/or Version: 3.0BTD EDC17  H21 0004
           Software Coding: 122A401A057601020000
            Work Shop Code: WSC 00046 000 00000
              ASAM Dataset: EV_ECM30BTD0114G0907589A 001005 (AU57)
                       ROD: EV_ECM30BTD0114G0907589A.rod
                      VCID: 323CEAF254AECDBB657-8066
11876 - Control Circuit for Turbocharger Inlet Valve
          P22CF 00 [038] - Open Circuit
                    Mileage: 304722 km
                    Date: 2021.08.27
                    Time: 20:57:21
                    Engine RPM: 2082.00 /min
                    Normed load value: 99.6 %
                    Vehicle speed: 65 km/h
                    Coolant temperature: 87 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 14.420 V
                    Actuator for low press turbocharger: activation: 5.00 %
                    Bypass valve f high press turboch turbine inlet: target value: 102.00 %
                    Bypass valve f high press turboch turbine inlet: actual value: -1.11 %
                    Bypass valve f high press turboch turbine inlet: offset closed: 1.00 %
                    Bypass valve for high press turboch turbine inlet: activation: 5.00 %
                    Bypass valve for high press turboch turbine inlet: uncond volt: 796.6 mV
                    Charge air pressure: actual value: 1015.4 hPa
11873 - Turbocharger Inlet Valve
          P22D2 00 [167] - Stuck Open
                    Mileage: 304722 km
                    Date: 2021.08.27
                    Time: 20:57:11
                    Engine RPM: 3524.00 /min
                    Vehicle speed: 88 km/h
                    Coolant temperature: 91 °C
                    Voltage terminal 30: 14.460 V
                    Actuator for low press turbocharger: activation: 94.99 %
                    Bypass valve f high press turboch turbine inlet: target value: 101.00 %
                    Charge air pressure: actual value: 1255.2 hPa
Address 01: DTCs cleared
BrownieMan
Europe
C?ID=324020
Nobody? Not even a single hint?? :(
