Urshalana
- Oct 3, 2020
- 12
- 6
- USA
- C?ID=419806 NAC + HU-2H
I have a w12 D3 that i picked up last year. Now that I have finally ordered a new tail light after caving in - initially the Light Bulb light lit up and so did the "BRAKE LIGHT" error. I have now replaced the tail that was giving the issue but now have new issues :eye_roll:
Init. Symptoms:
Car was doing fine in the snow then boom BRAKE LIGHT and the light for the bulbs went on at the same time. Driver (US) trunk light popped a bulb and the qtr panel light went off as well. All lights returned to normal op after a restart. I replaced the bulbs in the trunk light with one from an extra i had laying around and all was fine until I shifted the car into reverse then got the BRAKE LIGHT error again. The light seemed to work (minus the 4 leds) for a bit but I noticed recently that the whole light just didnt work as soon as i was in reverse but worked while braking only. Now the light gives no errors even with the light on until I put the car in reverse, then I get the Light bulb light on I cant stand it anymore. What should I look at fixing or can i just code the check out? the light seems to be working fine.
Third scan after clearing the codes: Initial scan is lower.
FIRST SCAN BELOW:
Init. Symptoms:
Thursday,23,September,2021,13:55:40:23474
VCDS Version: 21.9.0.2 (x64)
VIN: WAUMR44E65N015999 License Plate:
Mileage: 252730km-157039mi Repair Order: 3rd scan after clearing
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 13 15 16 17 19 25 28 34
36 37 38 42 46 47 4F 52 53 55 56 61 62 65 66 67 69 72 76 77
VIN: WAUMR44E65N015999 Mileage: 252730km-157039miles
28-HVAC, Rear -- Status: Malfunction 1010
38-Roof Electronics -- Status: Malfunction 0010
66-Seat, Rear -- Status: OK 0000
Address 01: Engine Labels: 07C-910-018-BHT1.lbl
Part No SW: 4E0 910 018 B HW: 4E0 906 018
Component: 6.0L W12/4V A ª0050
Revision: --H01--- Serial number: AUX3Z0E1760000
Coding: 0007773
Shop #: WSC 26105 444 68434
VCID: 1E38330DC9EC677953-804A
VINID: 9D195D884115185780045249243EE03C8B
Readiness: 0010 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 J HW: 09E 927 156 A
Component: AG6 09E 6,0L4V USA 0060
Revision: --H01--- Serial number: 0053874
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 2A50EFDD85A49BD93F-807E
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 C HW: 4E0 614 517 BD
Component: ESP 5.7 allrad H44 0330
Coding: 0007637
Shop #: WSC 58117 000 00000
VCID: 234E02F9E28E4A917C-8076
00003 - Control Module
014 - Defective
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 D
Component: FBS AUDID3 H04 0140
Revision: 01404004 Serial number: AUX3Z0E1760000
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58B46515EB48D94959-800C
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940576
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 730 G HW: 4E0 035 729
Component: Interfacebox H43 1070
Revision: 00000000 Serial number: 346CK057520760
Coding: 0000003
VCID: 244C01E5E7804DA905-8070
Subsystem 1 - Part No: 4E0 910 609 C
Component: Bedienteil MMI H42 0100
Subsystem 2 - Serial number: 391CY057503899
Subsystem 3 - Serial number: 7401.03.0500000000291B0023ÿ
Subsystem 4 - Serial number: 1B0023ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 E
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000062516
Coding: 1126737
VCID: 1C3C3905DFF07569BD-8048
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO02032005065A000000000156ÿ†89
Subsystem 5 - Serial number: 000156ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO02032005065A00000000
Subsystem 7 - Serial number: 65A000000000162ÿ
00657 - Positioning Motor for Central Vents (V102)
Fault Status: 00100011
Reset counter: 152
Mileage: 252692 km
Date: 2021.09.21
Time: 18:44:28
Voltage: 12.90 V
Temperature: 22.0°C
(no units): 193.0
(no units): 192.0
Temperature: 18.0°C
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 22
Reset counter: 116
Mileage: 252083 km
Date: 2021.09.18
Time: 20:08:16
Temperature: 36.0°C
00713 - Centre Left Vent Positioning Motor (V110)
Reset counter: 155
Mileage: 243083 km
Date: 2021.01.07
Time: 16:40:24
Voltage: 12.40 V
Temperature: 13.0°C
(no units): 61.0
(no units): 63.0
Temperature: 5.0°C
00710 - Defroster Flap Positioning Motor (V107)
Reset counter: 121
Mileage: 249983 km
Date: 2021.07.30
Time: 06:00:28
Voltage: 12.70 V
Temperature: 23.0°C
(no units): 193.0
(no units): 192.0
Temperature: 22.0°C
Raw, Form. N/A: 000 000 000
00565 - Rear A/C Control Head (Climatronic) (E265)
Reset counter: 156
Mileage: 252735 km
Date: 2021.09.23
Time: 13:24:08
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 L HW: 4E1 955 113 B
Component: ILM Fahrer H12 0210
Coding: 0133123
VCID: 3162F8B1A872E801FE-8064
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000035
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 02313
00908 - Control Module for Wiper Motor
Reset counter: 156
Mileage: 252735 km
Date: 2021.09.23
Time: 12:38:44
Reset counter: 156
Mileage: 252735 km
Date: 2021.09.23
Time: 12:38:44
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBE7126214
VCID: 1B3E3A19DAFE7251B4-804E
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 E HW: 4E0 035 593 A
Component: SDAR XM
Serial number: AUZ4Z7D40
VCID: 295210D180A290C136-807C
Reset counter: 117
Mileage: 252735 km
Raw, Form. N/A: 000 000 075
Address 11: Engine II Labels: 07C-910-018-BHT2.lbl
Coding: 0007773
Address 13: Auto Dist. Reg Labels: 4E0-910-561.clb
Part No SW: 4E0 910 561 F HW: 4E0 907 561 F
Component: ABSTANDSREGELUNGH03 0020
Coding: 0041211
VCID: 254A1CE1ECBAB4A112-8070
013 - Check DTC Memory - Intermittent - MIL ON
Fault Status: 10111101
Reset counter: 156
Mileage: 252732 km
Date: 2021.09.23
Time: 13:24:00
Temperature: 24.0°C
Voltage: 9.34 V
Bin. Bits: 00100000
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530705
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H13 0040
Coding: 0012351
VCID: 65CA5CE1AC3A74A1D2-8030
Component: Lenkradmodul H06 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 980 H HW: 4E0 920 980 H
Component: KOMBIINSTR. VDO H58 0210
Revision: D06 Serial number: AUDID3E3000014
Coding: 0016233
Shop #: WSC 20524 004 1048576
VCID: 2C5CE9C58F5085E9CD-8078
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 B HW: 4E0 907 468 F
Component: Gateway H10 0080
Revision: 10 Serial number: 1800405217016C
Coding: FFFEFFFD1B7904
VCID: 275616E996B6A6B120-8072
Reset counter: 157
Mileage: 252735 km
Date: 2021.09.23
Time: 13:40:34
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 A
Component: KLIMA-STG. FOND 015 0210
Revision: 00000017 Serial number: 00000000025095
Coding: 0000000
VCID: 61C248F1B81218812E-8034
8 Faults Found:
00458 - Control Module for Battery Monitoring (J367)
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
VCID: 285415D59BA8A9C929-807C
Component: Sitzmemory FS H08 0060
Coding: 4071658
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H44 1100
Revision: 00000000 Serial number: 378CT057518307
VCID: 3874C5954B083949B9-806C
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H02 0090
Serial number: 00000502700106
Coding: 0003493
VCID: 1D3A3401C4EA7C614A-8048
00510 - Motor for Wind Deflector (V252)
Fault Status: 01101100
Reset counter: 117
Mileage: 252732 km
Date: 2021.09.23
Time: 13:40:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM002 0060
Coding: 0032492
VCID: 20440DF5F398518961-8074
02124 - Exterior Door Handle Switch
Fault Status: 01101000
Fault Frequency: 0
Reset counter: 0
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040503070078
Coding: 0065086
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H03 0020
00985 - Right Tail Light (M2)
Reset counter: 117
Mileage: 213654 km
Date: 2017.12.07
Time: 13:13:23
01828 - Bulb for Tail-Lamp; Left
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 116
Mileage: 245134 km
Date: 2021.03.16
Time: 02:55:46
Reset counter: 116
Mileage: 225106 km
Date: 2019.02.06
Time: 17:27:41
00984 - Left Tail Light (M4)
014 - Defective
Fault Status: 01101110
Reset counter: 117
Mileage: 244051 km
Date: 2021.02.17
Time: 11:13:57
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0440
Revision: PROD_01 Serial number: 00000000012204
Coding: 0000016
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000055100
Coding: 0010111
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T0MLYE
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM002 0060
Coding: 0032492
Mileage: 245312 km
Date: 2021.03.21
Time: 06:01:44
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000632
Shop #: WSC 58117 001 1048576
02596 - Rear Brake Pads Worn
Fault Status: 01111000
Reset counter: 161
Voltage: 9.52 V
Count: 61
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Coding: 0000004
VCID: 62C047FDBD14039937-8036
Part No SW: 4E0 910 541 F HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 396CU057505645
Coding: 0000002
Reset counter: 156
Mileage: 252735 km
Date: 2021.09.23
Time: 12:42:07
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0510
Revision: 00000000 Serial number: 00000000003114
Shop #: WSC 53178 001 1048576
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 00915105DL
Coding: 34453039313531303541205641303030393135313035444C
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0060
Coding: 0032492
Mileage: 245312 km
Date: 2021.03.21
Time: 06:01:44
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000900030802
Coding: 0232326
VCID: 5FC64E098E662E7118-800A
02214 - Tire Pressure Warning
Reset counter: 117
Mileage: 252735 km
Date: 2021.09.23
Time: 13:34:39
Temperature: 22.0°C
Error Code: 512
Pressure: 2.57 bar
Pressure: 2.20 bar
Pressure: 2.80 bar
Pressure: 2.85 bar
Address 66: Seat, Rear Labels: None
Part No SW: 4E0 910 860 HW: 4E0 959 860
Component: Sitz Fond H06 0050
Revision: 00000000 Serial number: 5DS 008 795-01
Coding: 0000510
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 753 S HW: 4E0 035 753 A
Component: SDS 3501 US H45 0550
Revision: 00000000 Serial number: 00000502250341
Shop #: WSC 12336 024 394758
VCID: 356ACCA15C1AC421A2-8060
Address 69: Trailer Labels: 4E0-910-383.lbl
Part No SW: 4E0 910 383 B HW: 4E0 907 383 B
Component: ANHAENGERELEKTR 003 0040
Coding: 0001001
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0060
Coding: 0032492
Fault Frequency: 0
Mileage: 243072 km
Date: 2021.01.06
Time: 17:10:12
Mileage: 245312 km
Date: 2021.03.21
Time: 06:01:44
02111 - Motor for Window Regulator
Fault Status: 00100101
Reset counter: 147
Mileage: 251856 km
Date: 2004.03.31
Time: 14:51:00
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08720505401172
Coding: 0001308
VCID: 214208F1F89258816E-8074
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 A HW: 4E0 862 335
Component: Handyvorb2 H10 0120
Revision: 00000000 Serial number: 00000007517376
Coding: 0010900
End-------------------------(Elapsed Time: 03:50)--------------------------
FIRST SCAN BELOW:
Coding: 0065086
Reset counter: 116
Mileage: 213654 km
Date: 2017.12.07
Time: 13:13:23
Reset counter: 116
Mileage: 245134 km
Date: 2021.03.16
Time: 02:55:46
Reset counter: 116
Mileage: 225106 km
Date: 2019.02.06
Time: 17:27:41
01503 - Bulb for 3rd Brake Light (M25)
Fault Status: 00101001
Reset counter: 156
Mileage: 252735 km
Date: 2021.09.23
Time: 12:53:39
014 - Defective
Reset counter: 116
Mileage: 244051 km
Date: 2021.02.17
Time: 11:13:57
Coding: 0065086
Reset counter: 116
Mileage: 213654 km
Date: 2017.12.07
Time: 13:13:23
Reset counter: 116
Mileage: 245134 km
Date: 2021.03.16
Time: 02:55:46
Reset counter: 116
Mileage: 225106 km
Date: 2019.02.06
Time: 17:27:41
Reset counter: 156
Mileage: 252735 km
Date: 2021.09.23
Time: 12:53:39
014 - Defective
Reset counter: 116
Mileage: 244051 km
Date: 2021.02.17
Time: 11:13:57
