Need ABS code and 01314 code question for Tiguan TDI
vwztips
C?ID=189
I have installed a TDI with 6 speed 4 motion manual into my 2010 Tiguan. Have everything worked out except the ABS where I have 2 codes.
Scan is below. For code 01314 it just says "Engine control module". When I look up the code in WIKI it also shows "Communication error". How do I interpret the code it is giving me? Is it a communication error or something else?
The second code of 01044 is for incorrect coding. Based on a good bit of research using 10 scans of various Tiguans and reaching out to people in Europe, fairly certain 0002353 is for a 110kw TDI 4motion manual application.
Really would like to see a scan of a pre 4/2010 build Tiguan TDI 4motion manual if anyone happens to have one. Any help is appreciated.
Tuesday,21,September,2021,22:47:58:45329
VCDS Version: 21.9.0.2 (x64)
VIN: WVGBV7AX7AW001395   License Plate:
Mileage: 244890km-152167mi   Repair Order: 2010 blue tig tdi scan 9-21-21
Chassis Type: AX-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 22 25 36 42 44 46 4F 52 53 56 62
          65 69 72 77
VIN: WVGBV7AX7AW001395   Mileage: 244890km-152167miles
   Part No SW: 03L 906 019 EE    HW: 03L 907 309 AA
   Component: R4 2,0L EDC G000SG  8177
   Revision: 12H14---    Serial number:
   Coding: 0350072
   VCID: 72E0C18B6D1E301947-8026
   VINID: 9E65D29874681D19C00010C914634BEF2E
Readiness: 0 0 0 0 X
Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
   Part No SW: 5N0 614 517 N    HW: 5N0 614 517 N
   Component: J104    C2 450 V2   0008
   Revision: --H13---    Serial number: 00000002318331
   Coding: 0002353
   Shop #: WSC 01324 020 00200
   VCID: 397236A770E8834146-806C
                    Reset counter: 134
                    Mileage: 244891 km
                    Date: 2021.09.21
                    Time: 03:37:19
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 215
                    Hex Value: 0x0000
                    Reset counter: 135
                    Mileage: 244895 km
                    Date: 2021.09.21
                    Time: 04:33:15
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 165
                    Hex Value: 0x0000
   Part No SW: 1K0 820 047 JT    HW: 1K0 820 047 JT
   Component: Climatic PQ35   143 1515
   Revision: 00143034    Serial number: 00000000000000
   VCID: 7F0618BF2E4C6D7138-802A
00229 - Refrigerant Pressure
   Part No SW: 5K0 937 087 C    HW: 5K0 937 087 C
   Component: BCM PQ35 H+   008 3019
   Revision: BL008001
   Coding: 6D580A1B98232EC4808800851000050441015186524D8D605C8000000000
   VCID: 356A3A979CF06721A2-8060
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 134
                    Mileage: 244891 km
                    Date: 2021.09.21
                    Time: 03:13:32
                    Voltage: 12.55 V
01259 - Fuel Pump Relay (J17)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 134
                    Mileage: 244891 km
                    Date: 2021.09.21
                    Time: 03:13:29
                    Voltage: 12.60 V
   Part No SW: 5N0 959 655 K    HW: 5N0 959 655 K
   Component: J234__200 VW10 HI   1916
   Revision: 20013000    Serial number: 003E3PLVLACB
   Coding: 0012336
   VCID: 458A4A570C10F7A132-8010
   Subsystem 1 - Part No: 5N0 959 339 A
   Component: BF-Gewichtsens. 001 0004
   Subsystem 2 - Serial number: 00000000003QP1
   Subsystem 3 - Serial number: 0008.09.090000100000650015ÿ†63
   Subsystem 4 - Serial number: 650015ÿ†6332MTS627842719 ÿ†63
   Subsystem 5 - Serial number: 42719 ÿ†6342MTS615112759 ÿ†63
   Subsystem 6 - Serial number: 12759 ÿ†6351HTS6G31I19KJ ÿ†63
   Subsystem 7 - Serial number: I19KJ ÿ†6361HTS6JF2U56KR ÿ†63
   Subsystem 8 - Serial number: U56KR ÿ†63727TS6B5JM56KJ ÿ†63
   Subsystem 9 - Serial number: M56KJ ÿ†63827TS6SA0L56KR ÿ
   Subsystem 10 - Serial number: L56KR ÿ
03551 - Functional Restriction of Seat Occupied Recognition
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 244891 km
                    Date: 2021.09.21
                    Time: 03:44:32
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Coding: 0000332
   VCID: 7AF0E9AB356E48590F-802E
01426 - Controls in Steering Wheel (E221)
   Part No SW: 5N0 920 971 E    HW: 5N0 920 971 E
   Component: KOMBI         H03 0406
   Coding: 411E00
   VCID: 346C07939F8A7E2995-8060
   Part No SW: 1K0 907 530 AE    HW: 1K0 907 951
   Component: J533  Gateway   H06 0111
   Revision:   H06 01    Serial number: 101009F1000607
   Coding: F982FF47001603006002
   VCID: 6AD0D9EB45CEF8D9FF-803E
01304 - Radio
                    Reset counter: 175
                    Mileage: 244891 km
                    Date: 2021.09.21
                    Time: 00:12:26
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223T679704
   Coding: 0000002
   VCID: 7EF8E5BB2946647933-802A
   Part No SW: 0AY 907 554 C    HW: 0AY 907 554 C
   Component: Haldex 4Motion      0041
   Coding: 0000006
   VCID: 4B9E7C6F2A7401D1E4-801E
                    Reset counter: 138
                    Mileage: 244891 km
                    Date: 2021.09.21
                    Time: 00:15:07
   Component: IMMO          H03 0406
   VCID: 6AD0D9EB8DCEF8D9FF-803E
   Part No SW: 5N0 959 760 A    HW: 5N0 959 760 A
   Component: MEM-FS        H04 0032
   Revision: AA000000    Serial number: 00001001356874
   Coding: 20581300000044440011
   VCID: 387433A38BE29A49B9-806C
   Part No SW: 5N0 959 701 C    HW: 5N0 959 701 C
   Component: Tuer-SG         008 2005
   Coding: 0005559
   VCID: 356A3A975CF06721A2-8060
   Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.163 0703
   Revision: 1AH03273    Serial number: 00092430134502
   Coding: 0000258
   VCID: 3A7029AB75EE88594F-806E
01288 - Terminal 30; Steering Assist
                    Fault Status: 00101011
                    Fault Priority: 9
                    Reset counter: 174
                    (no units): 2.0
                    Voltage: 12.00 V
00576 - Terminal 15
                    Reset counter: 174
                    Mileage: 244891 km
                    Date: 2022.04.25
                    Time: 00:53:39
                    (no units): 4.0
                    Voltage: 12.20 V
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Component: EZE_2         H06 0111
   Coding: 050B0500
   VCID: 66C8ADDB91D6DCB9DB-8032
   Component: J245EE20SKB13  H01 0220
   Component: J394EE20SKB13  H01 0220
   Part No SW: 5N0 959 702 C    HW: 5N0 959 702 C
   Coding: 0005558
   VCID: 36683D9B41F66C39AB-8062
   Part No SW: 5N0 907 801 E    HW: 5N0 907 801 E
   Component: J540 EPB3  VW-13948 0008
   Revision:   H10       Serial number: 00000000059812
   Coding: 0000057
   VCID: 31620E87A8984B01FE-8064
                    Reset counter: 175
                    Mileage: 244891 km
                    Voltage: 12.10 V
                    Count: 75
                    Hex Value: 0x1271
                    Hex Value: 0x0001
                    Hex Value: 0x1010
Address 56: Radio
   Part No SW: 5N0 959 703 C    HW: 5N0 959 703 C
   Component: Tuer-SG         007 2001
   Coding: 0001168
   Shop #: WSC 01324 020 1012552
   VCID: 3776309F46FC9531B0-8062
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Component: RDK           008 0817
   Coding: 018705
02904 - Hard Warning 3
                    Mileage: 244520 km
                    Date: 2026.12.09
                    Time: 06:36:10
                    Text: 3447706096
                    Pressure: 2.10 bar
                    Pressure: 2.60 bar
                    Temperature: 25.2°C
                    Text: 00
                    Speed: 48.0 km/h
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H08 0080
   Revision: 3A002002    Serial number: 00000121867416
   Coding: 4200000100000000
   VCID: 2F6608FF7EAC5DF1E8-807A
   Part No SW: 5N0 959 704 C    HW: 5N0 959 704 C
   Coding: 0001168
   VCID: 387433A34BE29A49B9-806C
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 1Z0 035 729 C    HW: 1Z0 035 729 C
   Component: FSE_2P8x        H35 0170
   Revision: 00000000    Serial number: 00000005121853
   Coding: 0011070
01304 - Radio
                    Reset counter: 142
                    Mileage: 244463 km
                    Date: 2026.11.26
                    Time: 20:30:07
End-------------------------(Elapsed Time: 02:39)--------------------------
This may give you additional insight > HERE <.
vwztips
C?ID=189
Thanks for the reply. FWIW, I do have matching VIN in the ECU and Immobilizer for the Tiguan they are installed in. Hopefully iichel will see this post and provide insight.
Other points to note.
1. The ECU and IC are from TDI's. Again both have the correct VIN coded in.
2. This is my 3rd conversion. Previous 2 were Mk2 Tiguans with a later ABS version (C6 TRW 450m). Both took the took the proper coding for the set up installed. This Tiguan has an earlier ABS module (C2 TRW450).
3. All 3 conversions have used a Golf or Jetta CJAA ECU (EDC17CP14). The Tiguan gas ECUs are also EDC17CP14.
4. Golfs and Jettas did not have EPB. Tiguans do. Again, first 2 conversions had no issues with coding.
I'm not so sure this 03-ABS is going to play nice with that NAR market Golf/Jetta specific EDC but this scan may help:
That's right drive so we would need to convert 0014623 to 0010527
Edit, here's one with 0010527 that appears to be LHD:
