Hi everyone.
A few weeks ago, I was sitting in the parking garage in my 2016 MK7 while it was running before heading out, and suddenly the engine ran rough and the check engine light came on. I always have VCDS in my car, so I hooked it up and saw a misfire on cylinder 1. I tried to switch between the coil packs to see if it jumps in between cylinders, but the fault code never showed again. Since I replaced the spark plugs in my last maintenance, I figured it's time to replace the coil packs anyway (60,000 KM) since they looked pretty worn out and it's the number 2 cause for misfires.
I replaced them and haven't noticed any sudden behavior change, but the error never came back again. Today, I was sitting idle and my car didn't run rough but I heard a weird noise every few seconds that kept coming and going. I hooked up VCDS and noticed misfires fault codes that occurred exactly at the time I heard that sound.
Here's a full Auto-Scan. What do you guys think I should check next, considering both spark plugs and coil packs have been replaced and the wires look ok?
Thursday,23,September,2021,09:59:12:29935
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
VIN: WVWZZZAUZGW313595 License Plate:
Mileage: 56276km-34968mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 5F 6C
VIN: WVWZZZAUZGW313595 Mileage: 56276km-34968miles
Address 01: Engine (J623-CZDA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 HD HW: 04E 907 309 BH
Component: R4 1.4l TFS H25 3742
Revision: R7H25--- CVN: 65239CB2
Coding: 0125003223241D083000
Shop #: WSC 65535 000 00000
ASAM Dataset: EV_ECM14TFS01104E906027HD 001007
ROD: EV_ECM14TFS01104E906027HD.rod
VCID: 6D87CD34ED16B0937C7-8038
VINID: 9E69EAAAA465A979C304314914F8A8FD31
Center armrest control head 1:
17158 - Databus
Mileage: 55862 km
Date: 2021.09.04
Time: 18:42:48
Engine RPM: 1376.50 /min
Normed load value: 15.7 %
Coolant temperature: 32 °C
Intake air temperature: 31 °C
Voltage terminal 30: 11.261 V
Unlearning counter according OBD: 6
Acceleration: 0.000 m/s²
Cruise Control System (CCS): status-Bits 0-7: 0
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 130
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
Drivetrain coordinator: brake fault status-Bits 0-7: 4
U0428 00 [032] - -
Mileage: 55862 km
Date: 2021.09.04
Time: 18:42:48
Engine RPM: 1415.00 /min
Normed load value: 16.1 %
Outside temperature: 215 °C
Absolute intake pressure: 41 kPa abs
Engine torque: 16.7 Nm
Fuel level: 14.00 l
Oxygen sensor B1: sensor 1: specified value: 1.0105
Intake camshaft B1 active operating state-Bits 0-7: 0
Overrun cut-off-Bits 0-7: 0
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [039] - -
Mileage: 56276 km
Date: 2021.09.23
Time: 09:50:24
Engine RPM: 942.50 /min
Normed load value: 14.5 %
Coolant temperature: 93 °C
Intake air temperature: 57 °C
Voltage terminal 30: 13.829 V
Unlearning counter according OBD: 80
Long-term fuel trim bank 1 at idle: -2.53 %
Oxygen control: adaptation value at partial load: bank 1: 0.97009
Short term adaptation of mixture formation bank 1: 0.0 %
Outside temperature: 31 °C
Oxygen sensor test: bank 1: delta lambda: 0.00027
Fuel level: 36.00 l
10594 - Cylinder 4
P0304 00 [039] - Misfire Detected
Mileage: 56276 km
Date: 2021.09.23
Time: 09:50:24
Absolute intake pressure: 28 kPa abs
Fuel level: 36.00 l
Oxygen sensor B1: sensor 1: specified value: 1.0000
Part No SW: 0CW 300 040 H HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 0606
Revision: 00005005 Serial number: CU501604115169 CVN: 110D9D60
ROD: EV_TCMDQ200021_VW26.rod
VCID: 392F2964E9DEDC33A0F-806C
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 61016000003471
Coding: 01FA6AA12421116F077C060941C82980562488E0608294F30022507AC209
ROD: EV_Brake1UDSContiMK100IPB_034.rod
VCID: 79AFE964A95E1C33E0F-802C
0297 - Steering angle sensor
B1168 16 [008] - Voltage Too Low
Reset counter: 252
Mileage: 55862 km
Date: 2021.09.04
Time: 18:42:48
16412 - Display for Tire Pressure Monitoring
C1146 02 [008] - Signal Failure
Reset counter: 252
Mileage: 55862 km
Date: 2021.09.04
Time: 18:42:58
16413 - Display for Tire Pressure Monitoring
Reset counter: 252
Mileage: 55862 km
Date: 2021.09.04
Time: 18:42:58
Revision: 00021000 Serial number: 0400869638
Coding: 030C0C
VCID: 3A2D3668ECD8D72BA95-806E
Part No SW: 5G0 907 044 BC HW: 5G0 907 044 BC
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00020014100100001005004012101402
VCID: 698FB924D9FEACB310F-803C
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 CJ HW: 5Q0 937 084 AL
Component: BCM MQBAB M H24 0175
Serial number: 01061610401383
Coding: 00111842C2C102FB0BA44000000403081808000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 025D8E88C4885FEBB15-8056
Wiper motor control module:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 160401 043 0551
Serial number: 160409034812
Coding: 0E4DFD
Component: RLHS 037 0059
Serial number: S3Y16M04D20H07M54S03
Coding: 90A8DD
Sunroof control module:
Subsystem 3 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.403 H03 0004
Serial number: 0000FST000VUR7N00000
Coding: 181801
197644 - Control Circuit for Fuel Tank Flap
B1263 01 [009] - Electrical Failure
Fault Frequency: 15
Reset counter: 238
Mileage: 55811 km
Date: 2021.09.03
Time: 11:41:35
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39431726202033
Coding: 0031161051
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_EPHVA2CAU3700000 003021
ROD: EV_EPHVA2CAU3700000_003.rod
VCID: 47CB5F9CAF2ABAC326B-8012
1113875 - Parking Aid Indicator Lamp
B10FF 13 [008] - Open Circuit
Reset counter: 5
1113619 - Parallel Parking Assistance Indicator Lamp
B10FE 13 [008] - Open Circuit
Reset counter: 5
13637426 - Databus
Reset counter: 252
Mileage: 55862 km
Date: 2021.09.04
Time: 18:42:48
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 015 0388
Serial number: 003F6R1MUFND
VCID: 41DF4184810E84F3E8F-8014
Subsystem 1 - Part No SW: ----------- HW: 480 001 504 16
Serial number: 35767000000E65608A1Z
Subsystem 2 - Part No SW: ----------- HW: 480 001 304 16
Serial number: 358670000009D2B8B917
Subsystem 3 - Part No SW: ----------- HW: 480 400 904 16
Serial number: 3516502AB1FA34230342
Subsystem 4 - Part No SW: ----------- HW: 480 400 904 16
Serial number: 35265029B20414E500F2
Subsystem 5 - Part No SW: ----------- HW: 480 400 904 16
Serial number: 3556502AF20572856189
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 17041604220609
Coding: 0410
ASAM Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_018_VW37.rod
VCID: 074B9F9CEFAA7AC3E6B-8052
Part No SW: 5G1 920 740 A HW: 5G1 920 740 A
Component: KOMBI 202 6420
Coding: 07B519182390080C01083A001400000000000000
VCID: 2411E8107E5CB1DBE39-8070
Part No SW: 5Q0 907 530 AH HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2246
Revision: -------- Serial number: 06041610802133
Coding: 030100043F085700FB0002481C0F00010001050000000000000000000000
GVL: 01543C0000000600400C00000002C80000000000000000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 77ABEF5C9F4A0A4396B-8022
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 M HW: 5G0 959 442 M Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0103
Serial number: 29180001774290078337
Coding: 29FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 4139789903
U1101 00 [009] - Active
Fault Frequency: 20
Reset counter: 246
Mileage: 55642 km
Date: 2021.08.28
Time: 12:15:15
Terminal 30 power supply: 13.9 V
Terminal 15: On
8531970 - Quiescent Current
U1406 00 [008] - Too High
[Ruhestrom oberer Grenzwert überschritten]
Fault Frequency: 37
Reset counter: 33
Mileage: 55647 km
Date: 2021.08.28
Time: 16:47:01
Terminal 30 power supply: 12.7 V
Terminal 15: OFF
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000070365003
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 34311850CEBC215B739-8060
Component: TSG FS 020 0041
Serial number: 210316ECI10696
Coding: 00151220D000040000001000
VCID: 43D34B8C9B1296E3FA3-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000009751540
Coding: 110000
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1063
Coding: 0303
VCID: 44D148909E1C91DBC39-8010
12289 - Supply voltage
[Abschaltung wegen zu niedriger Versorgungsspannung Abschaltung aufgrund von Unterspannung (<5.5V für 3ms: KL50=0]
Reset counter: 40
Time: 00:00:00
Motor status: 00
Supply voltage: 7.00 V
Temperature: 33.0 °C
KFC: 30
KFA: 00 01
Freeze frame conditions: 21
uioUdNotFilt_xdu16: 4.98 V
uAdSensI_SwitchedKl30_xdu16: 4.99 V
26885 - Comfort limitation
C10D7 00 [008] - -
[Speicherinkonsistenz im Errorhandler]
Reset counter: 40
Motor status: 00
Supply voltage: 0.00 V
Temperature: 80.0 °C
KFC: 69
KFA: 00 05
Component: TSG BFS 020 0041
Serial number: 110416EDA03838
Coding: 00151020DE00040000801000
VCID: 42DD4E8884089FEBF15-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000009789778
Coding: 090000
Part No SW: 3Q0 035 840 C HW: 3Q0 035 840 C
Component: MU-S--ER 724 0890
Coding: 02730000FF00000051110001000938801F0103C40120010000
Shop #: WSC 00066 790 00405
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 2B03032C13827EA3223-807E
Subsystem 1 - Part No SW: 5G6 919 605 A HW: 5G6 919 605 A
Component: ABT_Std-2 H52 8130
Serial number: VWZ6ZJV1626432
B201A 00 [009] - -
[Check software version management]
Reset counter: 198
Mileage: 55642 km
Date: 2021.08.28
Time: 12:15:15
Voltage terminal 30: 13.8 V
Status_Software_Version_Management-module_name: C
[Anti-theft protection - component protection active (0xEA6100)]
Reset counter: 198
Mileage: 55642 km
Date: 2021.08.28
Time: 12:15:15
1637 - Interface for External Media
U11B8 00 [008] - No Communications
[USB - communication error]
Reset counter: 12
Mileage: 55863 km
Date: 2021.09.04
Time: 11:07:10
Voltage terminal 30: 13.9 V
Interface for external media: status-Status: Open circuit
Component: RVC Compact H18 0231
Coding: 01840201E2002017000040
ROD: EV_CamSysRVRVCPANAMQBAB.rod
13705478 - Databus
[message Parkhilfe_01 not received]
Reset counter: 198
Mileage: 55642 km
Date: 2021.08.28
Time: 12:15:15
passive
End----(Elapsed Time: 01:40, VBatt start/end: 13.9V/13.9V. VIgn 0.0V)------
