Misfires on 2016 Golf MK7
Fraysa
Israel
C?ID=416169
Hi everyone.
A few weeks ago, I was sitting in the parking garage in my 2016 MK7 while it was running before heading out, and suddenly the engine ran rough and the check engine light came on. I always have VCDS in my car, so I hooked it up and saw a misfire on cylinder 1. I tried to switch between the coil packs to see if it jumps in between cylinders, but the fault code never showed again. Since I replaced the spark plugs in my last maintenance, I figured it's time to replace the coil packs anyway (60,000 KM) since they looked pretty worn out and it's the number 2 cause for misfires.
I replaced them and haven't noticed any sudden behavior change, but the error never came back again. Today, I was sitting idle and my car didn't run rough but I heard a weird noise every few seconds that kept coming and going. I hooked up VCDS and noticed misfires fault codes that occurred exactly at the time I heard that sound.
Here's a full Auto-Scan. What do you guys think I should check next, considering both spark plugs and coil packs have been replaced and the wires look ok?
Thursday,23,September,2021,09:59:12:29935
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: WVWZZZAUZGW313595   License Plate:
Mileage: 56276km-34968mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 5F 6C
VIN: WVWZZZAUZGW313595   Mileage: 56276km-34968miles
Address 01: Engine (J623-CZDA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HD    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H25 3742
   Revision: R7H25---    CVN: 65239CB2
   Coding: 0125003223241D083000
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM14TFS01104E906027HD 001007
   ROD: EV_ECM14TFS01104E906027HD.rod
   VCID: 6D87CD34ED16B0937C7-8038
   VINID: 9E69EAAAA465A979C304314914F8A8FD31
17158 - Databus
                    Mileage: 55862 km
                    Date: 2021.09.04
                    Time: 18:42:48
                    Engine RPM: 1376.50 /min
                    Normed load value: 15.7 %
                    Coolant temperature: 32 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 11.261 V
                    Unlearning counter according OBD: 6
                    Acceleration: 0.000 m/s²
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 130
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
          U0428 00 [032] - -
                    Mileage: 55862 km
                    Date: 2021.09.04
                    Time: 18:42:48
                    Engine RPM: 1415.00 /min
                    Normed load value: 16.1 %
                    Outside temperature: 215 °C
                    Absolute intake pressure: 41 kPa abs
                    Engine torque: 16.7 Nm
                    Fuel level: 14.00 l
                    Oxygen sensor B1: sensor 1: specified value: 1.0105
                    Intake camshaft B1 active operating state-Bits 0-7: 0
                    Overrun cut-off-Bits 0-7: 0
10203 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [039] - -
                    Mileage: 56276 km
                    Date: 2021.09.23
                    Time: 09:50:24
                    Engine RPM: 942.50 /min
                    Normed load value: 14.5 %
                    Coolant temperature: 93 °C
                    Intake air temperature: 57 °C
                    Voltage terminal 30: 13.829 V
                    Unlearning counter according OBD: 80
                    Long-term fuel trim bank 1 at idle: -2.53 %
                    Oxygen control: adaptation value at partial load: bank 1: 0.97009
                    Short term adaptation of mixture formation bank 1: 0.0 %
                    Outside temperature: 31 °C
                    Oxygen sensor test: bank 1: delta lambda: 0.00027
                    Fuel level: 36.00 l
10594 - Cylinder 4
          P0304 00 [039] - Misfire Detected
                    Mileage: 56276 km
                    Date: 2021.09.23
                    Time: 09:50:24
                    Absolute intake pressure: 28 kPa abs
                    Fuel level: 36.00 l
                    Oxygen sensor B1: sensor 1: specified value: 1.0000
   Part No SW: 0CW 300 040 H    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0606
   Revision: 00005005    Serial number: CU501604115169 CVN: 110D9D60
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 392F2964E9DEDC33A0F-806C
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 61016000003471
   Coding: 01FA6AA12421116F077C060941C82980562488E0608294F30022507AC209
   VCID: 79AFE964A95E1C33E0F-802C
0297 - Steering angle sensor
          B1168 16 [008] - Voltage Too Low
                    Reset counter: 252
                    Mileage: 55862 km
                    Date: 2021.09.04
                    Time: 18:42:48
16412 - Display for Tire Pressure Monitoring
          C1146 02 [008] - Signal Failure
                    Reset counter: 252
                    Mileage: 55862 km
                    Date: 2021.09.04
                    Time: 18:42:58
16413 - Display for Tire Pressure Monitoring
                    Reset counter: 252
                    Mileage: 55862 km
                    Date: 2021.09.04
                    Time: 18:42:58
   Revision: 00021000    Serial number: 0400869638
   Coding: 030C0C
   VCID: 3A2D3668ECD8D72BA95-806E
   Part No SW: 5G0 907 044 BC    HW: 5G0 907 044 BC
   Revision: 00001K08
   Coding: 00020014100100001005004012101402
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 698FB924D9FEACB310F-803C
   Air quality sensor:
   Part No SW: 5Q0 937 084 CJ    HW: 5Q0 937 084 AL
   Component: BCM MQBAB M   H24 0175
   Serial number: 01061610401383
   Coding: 00111842C2C102FB0BA44000000403081808000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 025D8E88C4885FEBB15-8056
   Component: WWS    160401  043 0551
   Serial number:         160409034812
   Coding: 0E4DFD
   Component: RLHS  037 0059
   Serial number: S3Y16M04D20H07M54S03
   Coding: 90A8DD
   Sunroof control module:
   Subsystem 3 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.403  H03 0004
   Serial number: 0000FST000VUR7N00000
   Coding: 181801
          B1263 01 [009] - Electrical Failure
                    Fault Frequency: 15
                    Reset counter: 238
                    Mileage: 55811 km
                    Date: 2021.09.03
                    Time: 11:41:35
   Part No SW: 5Q0 919 298 K    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0054
   Revision: --------    Serial number: 39431726202033
   Coding: 0031161051
   ASAM Dataset: EV_EPHVA2CAU3700000 003021
   ROD: EV_EPHVA2CAU3700000_003.rod
   VCID: 47CB5F9CAF2ABAC326B-8012
1113875 - Parking Aid Indicator Lamp
          B10FF 13 [008] - Open Circuit
                    Reset counter: 5
1113619 - Parallel Parking Assistance Indicator Lamp
          B10FE 13 [008] - Open Circuit
                    Reset counter: 5
13637426 - Databus
                    Reset counter: 252
                    Mileage: 55862 km
                    Date: 2021.09.04
                    Time: 18:42:48
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Component: AirbagVW20    015 0388
   Serial number: 003F6R1MUFND
   VCID: 41DF4184810E84F3E8F-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 504 16
   Serial number: 35767000000E65608A1Z
   Subsystem 2 - Part No SW: -----------    HW: 480 001 304 16
   Serial number: 358670000009D2B8B917
   Subsystem 3 - Part No SW: -----------    HW: 480 400 904 16
   Serial number: 3516502AB1FA34230342
   Subsystem 4 - Part No SW: -----------    HW: 480 400 904 16
   Serial number: 35265029B20414E500F2
   Subsystem 5 - Part No SW: -----------    HW: 480 400 904 16
   Serial number: 3556502AF20572856189
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 17041604220609
   Coding: 0410
   ASAM Dataset: EV_SMLSKLOMQB 020001
   ROD: EV_SMLSKLOMQB_018_VW37.rod
   VCID: 074B9F9CEFAA7AC3E6B-8052
   Part No SW: 5G1 920 740 A    HW: 5G1 920 740 A
   Component: KOMBI         202 6420
   Coding: 07B519182390080C01083A001400000000000000
   VCID: 2411E8107E5CB1DBE39-8070
   Part No SW: 5Q0 907 530 AH    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2246
   Revision: --------    Serial number: 06041610802133
   Coding: 030100043F085700FB0002481C0F00010001050000000000000000000000
   GVL: 01543C0000000600400C00000002C80000000000000000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 77ABEF5C9F4A0A4396B-8022
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29180001774290078337
   Coding: 29FFFF
   Serial number: 4139789903
          U1101 00 [009] - Active
                    Fault Frequency: 20
                    Reset counter: 246
                    Mileage: 55642 km
                    Date: 2021.08.28
                    Time: 12:15:15
                    Terminal 30 power supply: 13.9 V
                    Terminal 15: On
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Ruhestrom oberer Grenzwert überschritten]
                    Fault Frequency: 37
                    Reset counter: 33
                    Mileage: 55647 km
                    Date: 2021.08.28
                    Time: 16:47:01
                    Terminal 30 power supply: 12.7 V
                    Terminal 15: OFF
   Revision: 00000000    Serial number: 16000070365003
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311850CEBC215B739-8060
   Serial number: 210316ECI10696
   Coding: 00151220D000040000001000
   VCID: 43D34B8C9B1296E3FA3-8016
   Serial number: 00000000000009751540
   Coding: 110000
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 0303
   VCID: 44D148909E1C91DBC39-8010
12289 - Supply voltage
          [Abschaltung wegen zu niedriger Versorgungsspannung Abschaltung aufgrund von Unterspannung (<5.5V für 3ms: KL50=0]
                    Motor status: 00
                    Supply voltage: 7.00 V
                    Temperature: 33.0 °C
                    KFC: 30
                    KFA: 00 01
                    Freeze frame conditions: 21
                    uioUdNotFilt_xdu16: 4.98 V
                    uAdSensI_SwitchedKl30_xdu16: 4.99 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
26885 - Comfort limitation
          C10D7 00 [008] - -
          [Speicherinkonsistenz im Errorhandler]
                    Motor status: 00
                    Supply voltage: 0.00 V
                    Temperature: 80.0 °C
                    KFC: 69
                    KFA: 00 05
   Serial number: 110416EDA03838
   Coding: 00151020DE00040000801000
   VCID: 42DD4E8884089FEBF15-8016
   Serial number: 00000000000009789778
   Coding: 090000
   Part No SW: 3Q0 035 840 C    HW: 3Q0 035 840 C
   Component: MU-S--ER      724 0890
   Coding: 02730000FF00000051110001000938801F0103C40120010000
   Shop #: WSC 00066 790 00405
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2B03032C13827EA3223-807E
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H52 8130
   Serial number: VWZ6ZJV1626432
          B201A 00 [009] - -
                    Reset counter: 198
                    Mileage: 55642 km
                    Date: 2021.08.28
                    Time: 12:15:15
                    Voltage terminal 30: 13.8 V
                    Status_Software_Version_Management-module_name: C
          [Anti-theft protection - component protection active (0xEA6100)]
                    Reset counter: 198
                    Mileage: 55642 km
                    Date: 2021.08.28
                    Time: 12:15:15
1637 - Interface for External Media
          U11B8 00 [008] - No Communications
          [USB - communication error]
                    Reset counter: 12
                    Mileage: 55863 km
                    Date: 2021.09.04
                    Time: 11:07:10
                    Voltage terminal 30: 13.9 V
                    Interface for external media: status-Status: Open circuit
   Coding: 01840201E2002017000040
13705478 - Databus
          [message Parkhilfe_01 not received]
                    Reset counter: 198
                    Mileage: 55642 km
                    Date: 2021.08.28
                    Time: 12:15:15
                    passive
End----(Elapsed Time: 01:40, VBatt start/end: 13.9V/13.9V. VIgn 0.0V)------
Coil packs really shouldn't be needed on five year old car with only 56,000 km on it, at least not unless they are a batch that is known to be problematical.
You say you've replaced the spark plugs and the coil packs. What was the source of the replacement parts?
What do your fuel trims look like?
Fraysa
Israel
C?ID=416169
Hi Uwe,
Appreicate the quick reply.
The coil packs replacement was mainly for ruling out this cause and sort of some preventive maintenance. I got a retail price on them so I didn’t mind replacing them too. Both coil packs and spark plugs are NGK, genuine authentic parts from a well-respected parts store here in Israel.
I’ve seen VCDS YouTube videos on how to check fuel trims. Should I post the results here? What exactly am I looking for?
EDIT: After watching Ross-Tech videos (and included videos) on fuel trims I understand the general idea but I don't really understand the values themselves and what am I expecting. Also, no more measuring blocks so all I could find was:
  • Long-term fuel trim bank 1 idle
  • Short term adaptation of mixture formation bank 1
At -2.5%, that looks entirely fine.
I'd like to see one under load as well, but I'm having trouble finding that in the data for this ECU.
Wait, let's try:
IDE03953 -- Oxygen control: adaptation value at partial load
Fraysa
Israel
C?ID=416169
Another thought I had is spark plug wires. I don't suspect it's an air/fuel issue or else the car would throw another fault code.
The spark plug wires is the last thing I did not test.
Are there even spark plug wires in the Golf MK7? The coil sits on top of the spark plug so I'm not sure...
Trowbridge, UK
Since each coil is directly attached to the spark plug there are no 'spark plug wires'.
  • Agree
Fraysa
Israel
C?ID=416169
Thanks for the re-assurance.
So considering the issue is not spark plugs or ignition coils as both been replaced by new OEM NGK ones, any other directions to look for then?
Needless to say the issue is intermittent and only seems to happen when idle (and weird hissing noise, which I'm not sure it has to do it with or not) so my direction is probably an air leak somewhere...
I tried to look for information online on how to read fuel trims but again it's a very complex matter and all the videos are old and refer to measuring blocks which are not supported by my car.
Trowbridge, UK
Needless to say the issue is intermittent and only seems to happen when idle (and weird hissing noise, which I'm not sure it has to do it with or not).
Wiring to the coils?
I seem to remember Jack (RIP) often mentioning adding 'overlay' wires to this part of the wiring, especially the ground and power feeds.
Fraysa
Israel
C?ID=416169
I can try to check them visually, but not sure how to test them further than that.
I uploaded a video of the engine noise in idle after a 40-minute drive. If you listen closely, you can hear the weird "roaring" noise that keeps coming back.
After I heard that noise, I immediately hooked up VCDS and the misfire fault showed at the same time that noise was playing.
Jef
HQ
  • Check compression for all cylinders and report back the values.
  • Get a small oil sample, does it have a gasoline (petrol) smell about it?
  • Do a fuel rail pressure drop test as shown in THIS VIDEO. What are the results?
Fraysa
Israel
C?ID=416169
Thanks for the comment.
I'm planning to do a compression test in my local garage later this week, so in the mean time I preformed a fuel pressure drop test:
As you can see, in working temperature, the pressure is ~14,000kPa and expands to ~22,500kPa after shutting down the engine and waiting for 6 minutes.
Results look okay to me (comparing to other videos I found online, besides the fact that mine is 14K while others are 4K to 8K) - but please let me know what you think.
As for the oil sample - I smelled the oil cap while performing the test and could not identify any gasoline smell. I read some stuff online, which suggested to smell the oil cap when the engine is cold so I'll try to do that again later today.
