Clearing camshaft code fixes rough idle for 2 to 5 seconds. What???
precursor
Midwest, USA
C?ID=433554
First: I will post a complete Autoscan if necessary, but at present the car has enough battery-related codes and random nonsense that I think it will only muddy the waters.
I've been trying to run down the reason for intermittent periods of extremely rough, jerky idle on my 2005 A6 3.2, often beginning 10 minutes or so after starting the car, but occasionally presenting on cold start. Leading candidates were engine mounts, fuel pump, fouled injectors, or timing chain issues.
In the course of testing ideas, I found that the oil was overfilled, so I drained it down to acceptable levels. I then started the car and ran it a bit, and cleared the codes to see what would come back. I noticed that the car had a few seconds of perfect idle as I cleared the codes, but I thought nothing of it.
The only engine code that reappeared was:
Camshaft Position Sensor B Bank 1 (G300)
P0366-006 Implausible Signal
I cleared it again, just to make sure it was going to stick. This time, something really struck me: I got 2 or 3 seconds of buttery-smooth idle, the very instant I cleared the code. Then rough idle and code reappeared simultaneously.
I tested it again and again. Worked every time: I would without fail get between 2 and 5 seconds of perfect idle every time I cleared that code.
This goes against my understanding of how the codes work. I thought they were just messages to help the mechanic. I didn't think that clearing them could do anything meaningful to how the car actually ran. I figured that was where coding and testing came in.
Based on what I described, does anyone have any ideas of what is going on here? Does my ability to (briefly) achieve perfect idle by clearing that code point to the source of my idle problems?
Thanks!
Westbury, UK
I suggest you do a clear all codes to get rid of irrelevant historical ones, then do another auto-scan and post it here so we can see not only the fault codes but how your car is equipped.
precursor
Midwest, USA
C?ID=433554
Scan from today:
Tuesday,21,September,2021,07:39:30:45339
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: WAUDG74F75N072759   License Plate: BL
Mileage: 247530km-153808mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 42 46 47 4F 52 53
          55 56 61 62 72 77
VIN: WAUDG74F75N072759   Mileage: 247530km-153808miles
Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
   Part No SW: 4F1 910 559 B    HW: 4F1 907 559 A
   Component: 3.2l V6 FSI         0040
   Revision: --H15---    Serial number:
   Coding: 01050106190F0120
   Shop #: WSC 02325 785 00200
   VCID: 2A0D0884C0F438EBD95-807E
   VINID: 9D19545C71161C57801C21C52477045136
16750 - Camshaft Position Sensor B Bank 1 (G300)
            P0366 - 006 - Implausible Signal - MIL ON
                    Fault Status: 11100001
                    Mileage: 247533 km
                    Date: 2021.09.20
                    Time: 17:43:16
                    RPM: 864 /min
                    Mass Air / Rev.: 92.7 mg/str
                    Temperature: 70.5°C
                        Idle
                    Bin. Bits: 00010000
18975 - Low Pressure Fuel Sensor (G410)
            P2543 - 009 - Intermittent
                    Mileage: 247533 km
                    Date: 2021.09.20
                    Time: 17:43:30
                    RPM: 704 /min
                    Mass Air / Rev.: 207.1 mg/str
                    Temperature: 69.0°C
                        Idle
                    Pressure: 4.9 bar
Readiness: 0110 0101
   Part No SW: 4F1 910 156 H    HW: 09L 927 156
   Component: AG6 09L 3.2 FSI USA 0020
   Revision: --H01---    Serial number:        0068901
   Coding: 0001002
   Shop #: WSC 02327 785 00200
   VCID: 290FF788C5F233F3D0F-807C
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 E    HW: 4F0 614 517 A
   Component: ESP8 quattro    H03 0010
   Coding: 0020895
   VCID: 2615FCB4D4EC1C8BFDD-8072
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H30 0130
   Revision: 30040401    Serial number: 10600300088265
   Coding: 0000011
   Shop #: WSC 02323 785 00200
   VCID: 6393A5A0E75EA9A3DA3-8036
   Subsystem 1 - Part No: 4F0 910 131 J
   Component: FBSAUDIC6 EZS   H43 0070
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H36 0040
01049 - Supply Voltage Term 50
            006 - Short to Plus
                    Fault Status: 01100110
                    Reset counter: 225
                    Mileage: 247533 km
                    Date: 2021.09.20
                    Time: 17:39:57
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
   Part No SW: 4F0 910 730 E    HW: 4E0 035 729
   Component: Interfacebox    H43 1070
   Revision: 00000000    Serial number: 360KO047510393
   Coding: 0000003
   VCID: 2313E5A0A7DEE9A39A3-8076
   Subsystem 1 - Part No: 4F0 910 609
   Component: Bedienteil MMIC6H07 0870
   Subsystem 2 - Serial number: 00000000076477
   Subsystem 3 - Serial number: 0105.11.040000000100010296ÿ
   Subsystem 4 - Serial number: 010296ÿ
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043     HW: 4F1 820 043 J
   Component: KLIMABETAETIGUNGH11 0110
   Revision: 00000023    Serial number: 00000000081314
   Coding: 0524326
   VCID: 5BE39D40DF2E9163923-800E
   Part No SW: 4F0 910 279     HW: 4F0 907 279
   Component: ILM Fahrer      H14 0080
   Coding: 0013123
   Shop #: WSC 02335 785 00200
   VCID: 6695BCB4146CDC8B3DD-8032
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00141886
   Shop #: WSC 02335
   Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0430
   Revision: 00000000    Serial number: AUZ5ZBD7100824
   VCID: 1B63DD409FAED163523-804E
Address 0F: Digital Radio        Labels: None
   VCID: 55F78B78BD0A4713A47-8000
No Faults Found
Address 15: Airbags        Labels: 4F0-910-655-8R.clb
   Part No SW: 4F0 910 655 B    HW: 4F0 959 655 A
   Component: 56 AIRBAG AUDI8RH29 0230
   Revision: 10H29000    Serial number: 00359D080X8-
   Coding: 0013622
   Subsystem 1 - Part No: 4F0 910 339
   Component: BF-Gewichtsens. 002 0040
   Subsystem 2 - Serial number: 6332CSME0747167F8
   Subsystem 3 - Serial number: 6342CSME07164C0D5
   Subsystem 4 - Serial number: 6351HSME050E46646
   Subsystem 5 - Serial number: 6361HSME0475042D3
   Subsystem 6 - Serial number: 6371VSME04290826E
   Subsystem 7 - Serial number: 6381VSME04260F0DO
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H07 0230
   Revision: 00H07000    Serial number: 90025043020303
   Coding: 0002041
   Component: Lenkradmodul    H05 0080
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 900 A    HW: 4F0 920 950 M
   Component: KOMBIINSTR. M73 H09 0460
   Revision: 00300000    Serial number: 4I211H3C4
   Coding: 0065263
   Shop #: WSC 12345 111 45725
   VCID: 1E65D4548CBCC44BB5D-804A
Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 B
   Component: Gateway         H09 0030
   Revision: 09          Serial number: 0800804A200180
   Coding: 6CFE73CC1B1904
   VCID: 270BF1B0D3E60583C6B-8072
   Part No SW: 4F0 910 760     HW: 4F0 959 760
   Component: Sitzmemory FS   H04 0050
   Revision: 00000000    Serial number: 00000000896400
   Coding: 0082946
   VCID: 619FAFA8FD42BBB3C8F-8034
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
   Component: TSG FA          H10 0020
   Revision: 00000000    Serial number: s1
   Coding: 0035563
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 E    HW: 4F0 907 289 E
   Component: Komfortgeraet   H14 0090
   Revision: 00900014    Serial number: 01001538210000
   Coding: 0423997
   VCID: 2C010E9CCA0026DB2B9-8078
                    Reset counter: 9
                    Mileage: 247521 km
                    Date: 2021.09.19
                    Time: 14:10:36
            014 - Defective
                    Fault Status: 01101110
                    Fault Frequency: 21
                    Reset counter: 225
                    Mileage: 247519 km
                    Date: 2021.09.15
                    Time: 10:46:25
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F5 910 223 C    HW: 4F5 035 223 D
   Component: DSP-High C6     H14 0240
   Revision: PROD_01     Serial number: 00000000012607
   Coding: 0000016
   Part No SW: 4F0 910 280     HW: 4F0 907 280 A
   Component: ILM Beifahrer   H09 0050
   Revision:             Serial number: 00000000045758
   Coding: 0001114
   VCID: 5EE59454CC3C844BF5D-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
   Component: TSG BF          H10 0020
   Revision: 00000000    Serial number: C1
   Coding: 0035563
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0005022
   Shop #: WSC 02334 785 00200
   VCID: 5DE79358C13A9F53EC7-8008
   Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
   Coding: 0000016
   Subsystem 1 - Part No: 4F0 941 329 A
   Component: AFS-Modul links H05 0010
   Subsystem 2 - Part No: 4F0 941 329 A
   Component: AFS-Modul rechtsH05 0010
   Part No SW: 4E0 910 541 F    HW: 4F0 035 541 B
   Component: TUNER EU/US/RDW H42 0480
   Revision: 00000000    Serial number: 394KN047500440
   Coding: 0000002
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: ENERGIEMANAGER  H11 0400
   Revision: 00000000    Serial number: 00000000079009
   Shop #: WSC 02665 444 54596
   Subsystem 1 - Part No: 4F0 915 105 C
   Component: von VA0  4411050223
   Coding: 344630393135313035432056413034343131303530323233
   Shop #: WSC 02335 823 59926
00003 - Control Module
            014 - Defective
                    Fault Frequency: 255
                    Mileage: 246685 km
                    Date: 2021.06.30
                    Time: 14:13:36
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 795
   Component: TSG HL          H09 0010
   Coding: 0035370
   VCID: 698FB7880572F3F310F-803C
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 794
   Component: TSG HR          H09 0010
   Coding: 0035370
   Part No SW: 4F0 910 336 A    HW: 4E0 862 335
   Component: Handyvorb2      H10 0120
   Revision: 00000000    Serial number: 00000007507343
   Coding: 0010900
   VCID: 211FEFA8BDC2FBB388F-8074
End----------(Elapsed Time: 02:51, VBatt start/end: 12.2V/12.2V)-----------
Address 01: DTCs cleared
precursor
Midwest, USA
C?ID=433554
I've been thinking this over some more. Since clearing the code briefly creates good idle, I guess some of my purely mechanical theories can't be the problem. Like: it's probably not engine mounts (which do have electronic connectors on this car, but I assume they're basically just sensors, not some sort of active adjustment). Clogs in the fuel system are probably out as well, as vcds can't control that.
If it's a faulty G300 camshaft position sensor (or faulty wiring to that sensor), maybe it makes sense that clearing the code smooths out the idle. Maybe clearing the code removes all the bad data it's been passing to the ECM, and it takes a few seconds for the ECM to process the new flow of bad data, post-code-clearing. But eventually it does get that new, bad data, so the idle turns rough again.
Whaddaya think? Plausible?
(And if so, is there any reasonable way to test the sensor itself, vs. the wiring? Or would most of you just change the sensor and hope that's it?))
Thank you for that Auto-scan , as recommended by @PetrolDave , Just a observation, but I thought it odd that the Immobilizer address-25 doesn't show up in the scan (?) , others I'm sure will comment on that.
I thought this was a good YT video for > Testing that Cam P.S. < ; Also, how much extra oil did you drain out? You may have a leaking injector or one that is not atomizing properly ; See Ross-Tech video for > testing fuel rail pressure. <
precursor
Midwest, USA
C?ID=433554
I'd say it had close to a quart too much oil.
I'll look into the youtube videos. Thanks for the leads.
Also, a couple of additional thoughts: I would plan on changing your oil, as unless you know otherwise (like you just did a oil change and know you overfilled it) it is probably not pure oil any longer! It most likely has a bunch of fuel in it. (leaking , clogged, carbon build up injector(s) or leaking High Pressure fuel pump(s). Why did you happen to check the oil ? Have you had a history of this over level condition (misfires etc. ) in the past ?
precursor
Midwest, USA
C?ID=433554
Was looking at oil because oil was changed about a month ago, and that very roughly correlates with when this started. I will change it again, soon.
However, oil level can't be the main issue here... it just wouldn't explain the code situation. The main issue seems to be very much related to the camshaft position sensor. The fact that I can get a 100% pure idle for a few seconds every time I clear the camshaft code... (I just tested it again some more. Still works every single time the code gets cleared).
I tested the wiring to the camshaft sensor, and the sensor itself. It's a little different from the video linked, because the Audi has 5v coming from both the battery and the sensor/ECM (I verified that's how it's supposed to be). Hooking up the sensor to the multimeter with the car switched on, I could indeed get the voltage on the sensor wire to drop from 5v to 0v when bringing a metal object near the sensor. However, while this may be a result of shaky connections on my test setup, I didn't feel like the voltage dropped as easily and automatically as shown in the video. I suppose it's possible the sensor is just flaky, and "sorta" works. Which would possibly explain that implausible signal code.
I have an automotive reference guide that mentions using oscilloscopes to make sure the camshaft sensor is producing a certain waveform. I'd imagine the "put a metal object next to the sensor and see if the sensor wire voltage drops" trick is a fairly crude test, and could miss some things.
Man, this is killing me. The fact that I can Make Things Better for a few seconds every time I clear that code... I feel like that must be a very obvious tell to someone with experience working on these things. Urgh.
precursor
Midwest, USA
C?ID=433554
I shouldn't say, by the way, that oil level "can't" be the main issue. I have way too little experience to speak in absolutes. ;)
I appreciate your input as I muddle through this.
Next step is probably to grab a new camshaft position sensor. I hate throwing $ at speculative parts, but a defective sensor seems like a reasonable possibility, and I don't think they cost too much.
precursor
Midwest, USA
C?ID=433554
I figured out the issue! Thanks for the help. I'd meant to just leave it alone and have a pro take a look, after wasting way too much of my time on it... but I couldn't get it out of my mind, and kept looking for answers online.
Lots and lots of googling on this:
finally pointed me toward the variable valve timing solenoids. I pulled the two solenoids closest to the G300 sensor (the one that was implicated by the fault codes), and jolted them repeatedly with a battery from my power tool collection (this "shock therapy" was mentioned in some places as a way to get sticky valve timing solenoids back to life).
Honestly, the shock therapy was mostly just to test that the solenoids opened and closed properly when supplied with voltage. (If the higher voltage somehow helped to make them less sticky, then that was just an added bonus.)
I believe the real fix was that I retrieved a metal shaving from inside the solenoid closest to the camshaft sensor. It was small, but sharp and inflexible, and was lodged between the inner core and the outer, sliding part of the solenoid. I believe it was interfering with the open/close sliding action. My understanding is that this would have prevented the engine from properly acting upon the data it received from the camshaft position sensor. The result would be a slight loss of sync between camshaft and crankshaft.
In retrospect: every time I cleared the fault code for the camshaft position sensor, I believe what was happening was, I got a couple seconds of grace period while the sensor data reset. During this time, the ECM wasn't trying to adjust anything about the timing chain, via the solenoids. (In effect, during those couple of seconds, I got a "vanilla" idle based on preset values, with no ECM interference.) But then the sensor data started flowing again, and the ECM started trying to use the solenoids to make adjustments, but one of the solenoids wasn't doing what it was supposed to do. The result was a loss of sync.
Also in retrospect, while the oil overfill might have been blameless, it also might have pressurized the engine or whipped the oil into a froth, thus causing whatever (hopefully minor) damage led to that little metal flake stuck in the solenoid. Or, maybe not actually doing damage, but whipping up some little bits of debris that got in the engine on previous occasions, and giving them the chance to get stuck somewhere harmful.
I hope this will help someone in the future, as they try to run down possible reasons for Camshaft Position Sensor - Implausible Signal codes.
Thank you for the follow up and the additional information; I'm certain the next member who comes along with this issue will find it very helpful. If you can, a few pictures of the VVT solenoids and where you found the foreign debris may also help. Congratulations and don't you think that was much more rewarding that taking it to a dealer? ;)
precursor
Midwest, USA
C?ID=433554
I didn't take pics (will try to remember in the future) but I will look for one I can grab online, and mark it up to show the spot.
I very much like fixing things myself, but I don't have much experience and I was having a really hard time pinning this down. Since the possibilities included major stuff like full timing chain replacement (which would effectively total the car, given its value) and engine mounts (which I haven't done, and would probably try, but which I suspect would be a lot of grief on this model), I broke down and was planning to get a pro diagnosis. There are a number of less-concerning things for me to fix on the car, but I wanted to avoid the rabbit hole of pouring lots of time and sweat into a car that I might have to get rid of.
Just for example, I don't have a great idea of exactly how much play the engine should have when it's idling or moving. And it's hard to get a great feel for something like that from youtube videos. So, while a pro might be able to look at it and say: yeah, the engine is flopping around, it's the mounts... I didn't know how to reach any certainty about that. And I hate replacing parts that don't need to be replaced.
Fortunately I have a little indie shop that specializes in VW Audi, within walking distance of my house. And they're great. The only downside is it's hard to book with them, as they're always busy. But in this case that was a positive, as it gave me a couple of weeks to try to solve things in the meantime.
precursor
Midwest, USA
C?ID=433554
The code I kept getting was:
This illustration shows the G300 camshaft sensor (labeled 5), which turned out to be fine... and also the variable timing valve/solenoid (labeled 1), which is officially called N318 Camshaft Adjustment Valve 1 (Exhaust). That's what turned out to be the actual problem. Note that this view is of the passenger side of the engine (North America). You need to remove the air intake hose and the top of the air box in order to get this view.
g300.jpg%22 alt=%22g300%22 border=%220%22>
This is what the variable timing valve looks like when you pull it. It consists of an outer metal sleeve with holes drilled in it, and an inner core which also has holes drilled in it. The core slides up and down when voltage is applied. Depending on whether the core is up or down, oil can either flow through the holes (when holes in core and sleeve line up) or will be blocked (when the holes are not aligned).
Sending voltage through the electrical connector should cause a loud, definite click as the core snaps into its new position. When I applied voltage to this one, I got a somewhat unsatisfying click. Inspecting it, I found a mostly-flat chip of metal in one of the holes, sitting on the inner core. It was held in place by some oil. It partially obstructed the sliding action. I used a small tool to remove it, and cleaned the rest of the part with rubbing alcohol. Now when I applied voltage, it made a much more definitive click. I replaced it, and my idle was good again. I no longer got the P0366 code.
Beautiful!
