Cruise Control not working, "005784 - Please Check DTC Memory of Steering Wheel Electronics", No code in steering wheel
Npab21
C?ID=450488
Hi,
Recently bought VCDS after buying a 2009 Golf 2.0 TDI GT as it had a couple problems, solved some already!
The most confusing one at the moment is "005784 - Please Check DTC Memory of Steering Wheel Electronics", while steering wheel electronics has no code?
It comes back straight away once cleared.
Ive seen 2 previous thread about this same issue, but they never posted the solution:
https://www.vwvortex.com/threads/cruise-control-inop-no-code.7048903/ (apologies, different forum)
Any ideas?
Thanks,
Nick
Sunday,19,September,2021,19:07:38:49130
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: WVWZZZ1KZ9W440121   License Plate:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZ9W440121   Mileage: 197100km-122472miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 LA    HW: 03L 906 022 G
   Component: R4 2.0l TDI G000SG  9978
   Revision: 13H01---    Serial number:
   Coding: 0001072
   Shop #: WSC 00674 210 10053
   VCID: 6FBBDA580B96F2D34EB-803A
   VINID: 9E69EAAAA05BA899C410004204155A8037
               P1698 - 000 -  - Intermittent
                    Mileage: 197105 km
                    Date: 2016.02.10
                    Time: 00:15:10
                    (no units): 255.0
                    (no units): 255.0
                    Bin. Bits: 00000000
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 163B400D092600FA680C02E6901A00823400
   Shop #: WSC 63569 001 1048576
   VCID: 7EA5F71C50FC8B5BD5D-802A
   Part No SW: 3C8 907 336     HW: 3C8 907 336
   Component: Climatic      120 0102
   Revision: 00004001
   Coding: 0000000000
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6A8DCB4C3CF417FB195-803E
   Part No SW: 1K0 937 086     HW: 1K0 937 086
   Component: BCM PQ35  M   020 0358
   Revision: 00020000
   Coding: 48180A3A9825F1C044080080100081E441010088524D8960648000000000
   VCID: 6D87C0500D9A00C37C7-8038
   Component: Wischer 05110  21  0501
   Coding: 009795
   Subsystem 2 - Part No: 1K8 951 171
                    Reset counter: 251
                    Mileage: 196900 km
                    Date: 2016.02.10
                    Time: 19:53:07
                    Voltage: 12.35 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 5K0 919 475     HW: 5K0 919 475
   Component: PARKHILFE 8K  H07 0002
   Revision: --------    Serial number: 60630827504721
   Coding: 100001
   VCID: 73B3D6286BBED633AA3-8026
16347 - Control Module - EEPROM Error
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 0
                    Temperature: 10.0°C
   Part No SW: 5K0 959 655     HW: 5K0 959 655
   Component: AirbagVW10    022 0507
   Serial number: 003C2D05TTEL
   Coding: 00003136
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01003
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 77ABE2387F46BA1396B-8022
   Component: S.Sens.Fahr.V  U01 ----
   Serial number: 386C3543ZZZZZZZZZZZZ
   Component: S.Sens.Beif.V  U01 ----
   Serial number: 3E180245ZZZZZZZZZZZZ
   Serial number: 12201623ZZZZZZZZZZZZ
   Serial number: 0E571245ZZZZZZZZZZZZ
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Component: J0527           055 0111
   Coding: 0000732
   Shop #: WSC 00198 210 01865
   VCID: 78A9E1047ED8B56B9F1-802C
   Subsystem 1 - Part No: 3C8 959 537 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP   H4ÿ 0021
   Coding: 00000226
   Part No SW: 5K0 920 970 E    HW: 5K0 920 970 E
   Component: KOMBI         H21 0029
   Coding: 470B00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
   VCID: 30391924DAA8AD2B171-8064
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533  Gateway   H07 0071
   Revision:   H07 01    Serial number: 011108F1002436
   Coding: E9A07F06000612000003
   VCID: 372B223833467A1356B-8062
   Component: IMMO          H21 0029
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Component: SG EXT.PLAYER H13 0084
   Revision: A1001003    Serial number: 7667312958
   VCID: 2615FF7CE8ECF39BFDD-8072
   Part No SW: 1K0 959 701 AM    HW: 1K0 959 701 AM
   Component: Tuer-SG         008 2016
   Coding: 0000692
   VCID: 79AFE40045D2AC63E0F-802C
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   Shop #: WSC 01324 785 00200
   VCID: 2A0D0B4CF0F4D7FBD95-807E
   Part No SW: 1K0 959 702 AN    HW: 1K0 959 702 AN
   Coding: 0000948
   VCID: 7BA3FE084FEE9E73F23-802E
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  012 0029
   Revision: 00000000    Serial number: VWZ1Z2H5867360
   Coding: 0100040004
   VCID: 6597B870D56A3883347-8030
   Part No SW: 1K0 959 703 AL    HW: 1K0 959 703 AL
   Component: Tuer-SG         007 2009
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   VCID: 7AADFB0C40D4A77BE95-802E
   Part No SW: 1K0 959 704 AL    HW: 1K0 959 704 AL
   Coding: 0000144
Address 77: Telephone        Labels: 3C0-035-730.lbl
   Part No SW: 5N0 035 730 A    HW: 5N0 035 730 A
   Component: J412                4100
   Revision: 00015000    Serial number: 0000B7A015746
   Coding: 0020145
   VCID: 2615FF7CE4ECF39BFDD-8072
End----------(Elapsed Time: 01:17, VBatt start/end: 12.5V/12.4V)-----------
Hi and welcome.
I wonder if the thing the ECU is upset about is actually 10 - Park/Steer Assist (J446) rather than 16 - Steering wheel ?
What type of cruise control controls does this car have? 16-Steering Wheel is coded for: Cruise Control System (CCS) with 4 Positions via Blinker Stalk -- is that correct?
Npab21
C?ID=450488
Hi and welcome.
Thanks. Interesting point, you wouldn't think that parking sensor error would affect cruise control, but I don't know. Needs to be fixed anyway, so no harm in trying.
But seeing as that parking sensor error seems to be common, it doesn't seem to trip the cruise control for other people?
Not 100% sure what you mean by 4 positions, its this type of stalk:
Well, it's not a "parking sensor" that's being problematic, but rather the module.
Have you checked measuring values in 16-Steering Wheel and in the ECU to verify that these modules see the state of the cruise control switches changing when you change them?
Npab21
C?ID=450488
Sorry, yes, knew that, just poor wording.
Measured the values in the ECU and it's seeing the main switch for sure, but as soon as that is touched, it puts it into the error state, so can't see any other state changes. Can't see the two side buttons doing any state changes, but wouldn't expect to see them unless the main switch was on and not in fault mode?
What about measuring values in the Steering Wheel controller? MVB 004.
Npab21
C?ID=450488
Interestingly, it always says the main switch is off! Its definitely not doing nothing, as it is the main switch turning on that sets the fault off in the ECU (11xxxxxxx in 006 ECU) (error on the MFD).
Could the stalk be at fault somehow?
That is not inconceivable. Given that this is a ~12 year old car, perhaps try some contact cleaner?
Npab21
C?ID=450488
I have taken it apart and cleaned, still the same. Strange that the ecu reacts to it but it appears in steering wheel as if it isn't doing anything.
Indeed. I'm not sure what to make of that.
@Npab21: I'm guessing of course - but @Uwe advice above sounds abundantly reasonable to me!!!
It's difficult to predict how a defective EEPROM in the hex10 module will effect other modules like the ECU, or CC function - but there can be little doubt that the module needs changing.
Have you done this as a first-order task (i.e. prior to focusing on the stalk switch)? If so, please clear DTCs and post a fresh auto-scan.
Npab21
C?ID=450488
Ordered a new PDC module, will update when fitted, with a fresh scan.
MartinsX
Riga, Latvia
C?ID=268515
I'd continue with stalk CCS switch. If MVB004/1 and 004/2 in 0x16 do not show any changes when touching CCS switches/buttons on stalk, then stalk is bad (99%), something wrong with contact pins between stalk and module (0,9%) or 0x16 module is bad (0,1%).
I have replaced a big amount of stalks because of not working/poor working CCS switches. I'd suggest OEM part only. Cheap alternative parts do not work immediately or stops working after couple weaks. If You want cheap solution, go with used OEM stalk, buy couple or three and test them on car.
Npab21
C?ID=450488
Working now! You were infact correct, I was am going to fit the new PDC module tomorrow, but I got a £14 ebay stalk just to see, and it works now! clearly a half broken connection, hence why there was still some feedback from the switch. Now need to order a decent stalk (or just wait and see how long the ebay one lasts).
Thanks for all the help guys, started with quite a few problems on this car, now just one to go, parking module!
