Configure RAW UDS Adaptions
AINils
Germany (AIB)
C?ID=56975
In VCDS you can adapt every single adaption channel from nearly every ECU. If I do ADPMAP in RAW there will be Groups which are saved. But in VCDS there's no option to bring these Groups as modified Version back! Other tools will give you this options as it is comfortable in case of retrofit or if car from US will be a EU car
Actually know 2 scenarios which this would be helpful:
1. Ambience Light Colors
Ambientelicht Farbliste,0A28,30,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Ambientelicht Farbliste LIN,0B3F,30,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2. Light Configuration
Leuchtenkonfiguration,0D0B,224,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 05 44 00 4B 46 00 7F 08 09 7F 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 0A 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 38 00 22 12 00 7F 00 00 00 00 00 00 00 00 00 06 42 00 23 13 00 7F 00 00 00 00 00 00 00 00 00
These are just examples from my own car, but it would be nice if there would be an option in VCDS to change these values. Actually choose polish tool or other tool which is OEM like
AINils
Germany (AIB)
C?ID=56975
0A28 (HEX) is 2600 in decimal. Same like tool from polish guys is given to user
TBAx
C?ID=287144
0A28 is basically the location or offset where this adaption is found.
Isn‘t it possible to get the raw data as posted above, then remove all entries, that are irrelevant and restore them using the function in VCDS?
Eric
HC800000
Yeah I don't understand what is being asked here. You want VCDS to become a text editor?
