Audi A6 4G FL 2016 adjust frame speed and ACC light intensity (leds from 0 to 250 km / h)
torrebasetez
Spain
C?ID=354490
Hi there. I did an ACC retrofit on my audi a6 4g 2016 Fl vehicle. For this I had to change the instrument cluster. I have noticed that the speed of the frame is different in seven or eight kilometers with the gps speed. Is it possible to adjust this with vcds ?. Another question, when I activate ACC the lights on the speed chart going up to 250 km / h have soft illumination. Would it be possible to increase the intensity of the ACC light? Thank you.
Wednesday,15,September,2021,19:55:13:58101
VCDS Version: 21.9.0.1 (x64)  HEX-V2 CB: 0.4555.4
Data version: 20210824 DS330.0
Workshop Code: 123 12345 023456
VIN: WAUZZZ4G7GN133678   License Plate:
Mileage: 81977km-50938mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 3B 3C 42 44 46 52 53 5F
          62 6C 6D 72 85 8B 8E 8F 90 AC 47
VIN: WAUZZZ4G7GN133678   Mileage: 81977km-50938miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FQ    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 1649
   Revision: 85H23---    CVN: 00F3A24DC19C777138D3FF82
   Coding: 0A254012244401080000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TDI01104L906021FQ 002004
   ROD: EV_ECM20TDI01104L906021FQ_002.rod
   VCID: 79AFEFA639577D93E0C-802C
   VINID: 9D196AAAA1171D77810C3187207573691D
   Part No SW: 4G1 927 153 B    HW: 0CK 927 156 S
   Component: 0CK 20TDI RdW H04 0002
   Revision: --H04---    Serial number: 0000000396 CVN: B3F32B1E
   Coding: 100001
   ASAM Dataset: EV_TCMDL382021 002020
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 290FFFE689770D13D0C-807C
   MTF pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  HB1 0572
   Serial number: 75117051150265000574
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 06A29E49604579929B00
   Shop #: WSC 59427 004 104857
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41DF47461107E553E8C-8014
   Part No SW: 4H0 907 064 GP    HW: 4H0 907 064 GP
   Component: BCM2 2.0      H37 0572
   Coding: 05A86F0E000000000000
   VCID: 7DA7FBB62DFF41B3CC4-8028
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 CA    HW: 4G0 820 043 CA
   Component: KLIMA 2 ZONEN H14 0112
   Serial number: 11121500111108
   Coding: 34010908250000
   ASAM Dataset: EV_AirCondiBasisUDS 003009
   ROD: EV_AirCondiBasisUDS_003.rod
   VCID: 6099A2C2BACD8C5BC72-8034
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0311
   Revision: 15020001    Serial number: 00001240863602
   Coding: 2600001500749FE2818140C000001D0CCF9CC308AE09022100000420610114020040002D0B0000
   VCID: 71BFD78661A735D358C-8024
   Component: WWS57X 151013  H38 0080
   Serial number:         151104195000
   Coding: 0045F7
   Serial number: 61164683
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
   Component: E1 - LDS  H07 0044
   Serial number: 14 12 2015  00000414
   Subsystem 4 - Part No SW: 4G0 907 410     HW: 4H0 907 410
   Component: EHL2 V07.03  H30 0030
   Serial number: 0000002274537R0Z1Q01
   Subsystem 5 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: 3A98C1E7000000000001
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0055
   Coding: 7E04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002015
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1007WPNU
   Coding: 30333130313630323638554A304C34473053
   VCID: 3B2335AE73EB8F83B20-806E
   Serial number: 3575HRB404R3N8CE4P1S
   Serial number: 3585HRB405N3N8CE20JH
   Serial number: 3515JRB404T3KVP45PAG
   Serial number: 3525JRB404V3KVP4M0DE
   Serial number: 3554VRB405N3I38KG1ET
   Serial number: 3564VRB405P3I38KDGQD
   Revision: --------    Serial number: 90372MC60001Q
   Coding: 0000FC
   VCID: 372B299E4F43ABE3568-8062
   Part No SW: 4G8 920 935 A    HW: 4G8 920 935 A
   Component: TDieRdwAcc    H14 0225
   Revision: 11001108    Serial number: 658220616596002
   Coding: 138F09040F55000C050000
   ASAM Dataset: EV_RBD4K 004060
   ROD: EV_RBD4K_AU57.rod
   VCID: 30391282AAAD7CDB172-8064
   Part No SW: 4G8 907 468 H    HW: 4G8 907 468
   Revision: --------    Serial number: 00000002255266
   Coding: C0CD078118
   Shop #: WSC 59427 004 1048576
   GVL: FD8DC904D8A3600F40040000
   VCID: 3D273BB66DFF81B38C4-8068
   Serial number: 1085088603
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
   Serial number: 151006000000000004FC
12290 - Quiescent Current
          U1406 00 [008] - Too High
                    Reset counter: 120
                    Mileage: 81860 km
                    Date: 2021.09.15
                    Time: 11:36:06
                    Voltage terminal 30: 12.2 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 29 °C
                    System status: LIN_active
                    IN ESP_standstill flag: no standstill detected
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status via CAN: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 02018264747464545425363E00
   VCID: 7CA1F6B236E548BBFBA-8028
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA820ASA3C
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3635249A48C952EB4DE-8062
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H08 0060
   Serial number: 0389946338
   Coding: 040311
   VCID: 392F2FA679D7BD93A0C-806C
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0060
   Serial number: 0391174110
   Coding: 040311
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0511
   Coding: 011F17015C00628002080013
   VCID: 45D7535605AFC973D44-8010
   Component: RCevo         H53 0202
   Revision: 00000001    Serial number: 0000525526
   Coding: 101001010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2D30AA7CD1B68BA96-806E
   Revision: 00002001    Serial number: 0391229514
   Coding: 011E0E3800B97081C320080508030E4F0000000000000000000000000000
   Shop #: WSC 12345 123 23456
   Component: GTO BF  H01 0080
   Serial number: 00000000000000086048
   Subsystem 2 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93708073
   Component: TSG BF        H03 0511
   Coding: 011F17015E00628002080002
   VCID: 46D5545A38A9C26BDDE-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001703096
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D070BF6BD9F11333C4-8078
Address 5F: Information Electr. (J794)       Labels:| 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 021 G    HW: 4G1 035 021 D
   Component: MU-H-LND-EU   053 0910
   Serial number: A733B0H7533174
   Coding: 017501010000000013110002000A00102F0006E5F1700100DF
   VCID: 1E65DC3AC039FAABB5E-804A
   Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Multimedia System 1:
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9FY801AJX
   Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
   Component: E380 BDT C7  H11 0204
   Serial number: 90349MCE000L3
   Compact disc data bank:
   Component: Gracenote  --- 1010
          B201A 00 [009] - -
                    Reset counter: 79
                    Mileage: 81845 km
                    Date: 2021.09.15
                    Time: 07:57:02
                    Voltage terminal 30: 11.9 V
                    Status_Software_Version_Management-module_name: MDUA009/Front
   Component: TSG HL        H03 0511
   Coding: 010F15004000628002080002
   VCID: 49CF5F6629B72D1330C-801C
   Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
   Component: TopView       H09 0380
   Revision: 11001001    Serial number: 82330JG0450621
   Coding: 0211000001010002000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
   VCID: 2F3B11FEB79363230E8-807A
9616786 - Surroundings Camera Front
          B127C F0 [009] - Calibration Failed
                    Reset counter: 79
                    Mileage: 81845 km
                    Date: 2021.09.15
                    Time: 07:56:55
                    Voltage terminal 30: 11.5 V
                    Terminal 15 status: Terminal 15 on
9616787 - Surroundings Camera Rear
          B127D F0 [009] - Calibration Failed
                    Reset counter: 79
                    Mileage: 81845 km
                    Date: 2021.09.15
                    Time: 07:56:55
9616788 - Surroundings Camera Left
          B127E F0 [009] - Calibration Failed
                    Reset counter: 79
                    Mileage: 81845 km
                    Date: 2021.09.15
                    Time: 07:56:55
9616789 - Surroundings Camera Right
          B127F F0 [009] - Calibration Failed
                    Reset counter: 79
                    Mileage: 81845 km
                    Date: 2021.09.15
                    Time: 07:56:55
10489856 - No Basic Setting
          B2010 00 [009] - -
          [TopView system not calibrated]
                    Reset counter: 79
                    Mileage: 81845 km
                    Date: 2021.09.15
                    Time: 07:56:55
   Part No SW: 4G5 959 107 C    HW: 4G5 959 107 A
   Component: HDSG-Modul    H02 0049
   Revision: 13002001    Serial number: 157500068
   Coding: 111104C020
   ASAM Dataset: EV_HDSGAu571 001022
   ROD: EV_HDSGAu571.rod
   VCID: 323D188AA4A14ECB616-8066
   Component: TSG HR        H03 0511
   Component: DPC-SG        H27 0081
   Coding: 6A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C0106F28685183B2BA-8078
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7E04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
   VCID: 270BF9DE9F633B63C68-8072
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000621712157
   Coding: 04C0B9181111
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Component: RGS-VL        H14 0080
   Coding: 0006E008031F0300070308014244CA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F1786A1A775D318C-8064
   Component: RGS-VR        H14 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 153221760
   ROD: EV_RDCMA00100.rod
   Part No SW: 4G5 035 223 E    HW: 4G5 035 223
   Component: MIB2_amp_P    H03 0440
   Serial number: 00000000113460
   Coding: 31755108018AF03A5A0000010F03
   Shop #: WSC 00001 123 12345
   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
   ROD: EV_AMPMst16C4Gen2BOSE_AU57.rod
   VCID: 2411EED2EE55D07BE3A-8070
End----(Elapsed Time: 02:32, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
TBAx
C?ID=287144
Do you happen to have an Auto-Scan prior to changing the cluster?
torrebasetez
Spain
C?ID=354490
Yes..
Sunday,16,May,2021,18:51:06:58101
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 08 09 15 16 17 19 20 3B 3C 42 44 46 52 53 5F 62
          6C 6D 72 85 8E 8F 90 AC
VIN: WAUZZZ4G7GN133678   Mileage: 75238km-46750miles
   Revision: 85H23---
   Coding: 0A254012242401080000
   VCID: 79AFEFA639577D93C8D-802C
   Coding: 100001
   VCID: 290FFFE689770D13F8D-807C
   MTF pump:
   Coding: 06A29E41604579829B00
   VCID: 41DF47461107E553C0D-8014
   VCID: 7DA7FBB62DFF41B3E45-8028
   VCID: 6099A2C2BACD8C5BEF3-8034
   Coding: 2600001500749FE08181408000001D0CCF9CC308AE0902210000042061011402004000250B0000
   VCID: 71BFD78661A735D370D-8024
   Coding: 0045F7
   Coding: 02006D
   VCID: 3B2335AE73EB8F839A1-806E
   Coding: 0000F4
   VCID: 372B299E4F43ABE37E9-8062
                    Reset counter: 30
                    Mileage: 74458 km
                    Date: 2021.04.11
                    Time: 12:23:07
   Part No SW: 4G8 920 934 D    HW: 4G8 920 934 D
   Component: TDieRdw       H11 0106
   Revision: 08001098    Serial number: 658141215592055
   Coding: 13AF8A000B550008050000
   ASAM Dataset: EV_RBD4K 004055
   VCID: 323D188AA4A14ECB497-8066
   Part No SW: 4G5 907 468 F    HW: 4G0 907 468 AC
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000002085041
   Coding: C0CD074418
   ASAM Dataset: EV_GatewPkoUDS 001028
   VCID: 38292AA242DDA49B773-806C
   Voltage stabilizer:
0267 - Optical data bus
          U1049 00 [009] - Open circuit
                    Reset counter: 234
                    Mileage: 74458 km
                    Date: 2021.04.11
                    Time: 12:26:13
                    Voltage terminal 30: 12.0 V
                    Control Module temperature: 35 C
                    System status: Awake_Timer_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 0
   Revision: AA001002
   VCID: 7CA1F6B236E548BBD3B-8028
   ROD: EV_SARA2.rod
   VCID: 3635249A48C952EB65F-8062
   Coding: 040311
   VCID: 392F2FA679D7BD9388D-806C
   Coding: 040311
   Component: TSG FA        H03 0511
   Coding: 011F17015C00628002080012
   VCID: 47CB595E3FA3DB630E9-8012
   VCID: 3A2D30AA7CD1B68B817-806E
   VCID: 46D5545A38A9C26BF5F-8012
   VCID: 2D070BF6BD9F1133145-8078
   Coding: 01750101FF0A000013110001000A00102F0006E5F1700100DF
   VCID: 1E65DC3AC039FAAB9DF-804A
          B201A 00 [009] - -
                    Reset counter: 234
                    Mileage: 74458 km
                    Date: 2021.04.11
                    Time: 12:23:17
                    Voltage terminal 30: 12.1 V
                    Status_Software_Version_Management-module_name: MKBD_FC7/KBD
   VCID: 49CF5F6629B72D1318D-801C
   ROD: EV_CamerSysteTopViewAUDI_008_AU57.rod
   VCID: 2F3B11FEB7936323269-807A
                    Reset counter: 234
                    Mileage: 74458 km
                    Date: 2021.04.11
                    Time: 12:23:10
                    Voltage terminal 30: 11.8 V
                    Reset counter: 234
                    Mileage: 74458 km
                    Date: 2021.04.11
                    Time: 12:23:10
                    Reset counter: 234
                    Mileage: 74458 km
                    Date: 2021.04.11
                    Time: 12:23:10
                    Reset counter: 234
                    Mileage: 74458 km
                    Date: 2021.04.11
                    Time: 12:23:10
          B2010 00 [009] - -
                    Reset counter: 234
                    Mileage: 74458 km
                    Date: 2021.04.11
                    Time: 12:23:10
   Coding: 111104C020
   Coding: 72060000
   VCID: 2C0106F28685183B03B-8078
   Coding: 0440B9181111
   ROD: EV_BC7.rod
   ROD: EV_RGS_L.rod
   VCID: 313F1786A1A775D330D-8064
   ROD: EV_RGS_R.rod
End----(Elapsed Time: 02:09, VBatt start/end: 11.1V/11.1V. VIgn 11.1V)-----
torrebasetez
Spain
C?ID=354490
Hi there. I have tried to change the encoding in unit 17, byte 03 to how it was previously before changing the frame and I get error 31. Can anyone help? Why does this happen and it does not allow the encoding to be changed? Thank you.
torrebasetez
Spain
C?ID=354490
No one can tell me why I get error 31 out of range and I can't change it?
Error 31 "Request Out of Range" means the the software in the module itself is rejecting that value.
What are the exact changes you are trying to make?
torrebasetez
Spain
C?ID=354490
Hi there. I wanted to put the same encoding that I had in my previous unit 17 in byte 03, which was 00. My car is 4G. By now putting byte 03 in 04 it is car 4G2. I don't know if that will influence something or the speed difference.
