Hi All,
driving a VW Polo 2011 1.6 TDI CAYB, stock conditions, 9972 ECU software, having injector issues for the 3rd time. Had a glow plug and check engine for a few times (not always). Since the injector issues keep coming, I wanted to know more about it and finally purchased a VCDS HEX-V2. Previous 2 injectors were replaced by reconditioned.
Autoscan below, apparently also the EGR valve has a malfunction.
About the injectors. Injector 3 and 4 were replaced 10k km ago, now injector 1 seems to have failed. One time the injector stopped with engine running on 3 cylinders. I sometimes notice a difficult start with longer cranking than usual.
I read different failure modes are described on the internet (electrical, clogged, leaking). I checked the resistance between the 2 pins, still 200 kOhms for all 4 injectors, capcity of the piezo stack is around 2.8 µF for all 4 injectors. Can I exclude electrical failure if the fault is intermittent and I have 200 kOhms? No megger available for checking the insulation resistance. Can I derive something from the "Injection valve 1: voltage-V_INJ_MAIN[0]: 45.61 V"?
Only using on premium diesel, but could it be contamination? Could I find out more what could be the reason? In case of a clogged injector maybe a Liqui Moly diesel purge could help?
I did a check on the injector deviation (cold engine, idling). Is it true that the spec for deviation is max. +/- 2.8 mg/stroke? I notice the other injectors (even the replaced ones no. 3 and 4) have higher deviations than the faulty injector 1...
About the EGR valve malfunction. Any means to find out more details about the malfunction (clogged, seized motor or something else? I guess a sensor fault will give a different code, as well as clogged would give P0401 - Insufficient Flow). Would an immedate replacement be required or could a enthusiastic drive on the highway clean up some of the gunk inside, any recommendations? Are there any tests (Basic settings or Output Test?) available before replacement?
I also notice the 2nd Readiness bit is 1, is this related to the EGR?
No idea what to think about the other error code related to voltage adress 09 and 17 (date or mileage seems incorrect btw).
Any comments are feedback are well appreciate!
Autoscan:
IDE00365-ENG99400 Injection quantity deviation cylinder 1-FAC_CYL_BAL1 -0.5034 mg/stroke
IDE00366-ENG101187 Injection quantity deviation cylinder 2-FAC_CYL_BAL2 -1.3786 mg/stroke
IDE00367-ENG101684 Injection quantity deviation cylinder 3-FAC_CYL_BAL3 1.2596 mg/stroke
IDE00368-ENG103465 Injection quantity deviation cylinder 4-FAC_CYL_BAL4 0.6356 mg/stroke
18:20:56
IDE00365-ENG99400 Injection quantity deviation cylinder 1-FAC_CYL_BAL1 -0.5788 mg/stroke
IDE00366-ENG101187 Injection quantity deviation cylinder 2-FAC_CYL_BAL2 -1.3570 mg/stroke
IDE00367-ENG101684 Injection quantity deviation cylinder 3-FAC_CYL_BAL3 0.9245 mg/stroke
IDE00368-ENG103465 Injection quantity deviation cylinder 4-FAC_CYL_BAL4 1.2753 mg/stroke
Autoscan:
Sunday,19,September,2021,13:19:00:06492
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
VIN: WVWZZZ6RZBYxxxxxx License Plate:
Mileage: 79630km-49479mi Repair Order:
Chassis Type: 6R-VW25 (6R0)
Scan: 01 03 08 09 15 17 19 25 44 56 61
VIN: WVWZZZ6RZBYxxxxxx Mileage: 79630km-49479miles
Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 EP HW: 03L 906 023 D
Component: 1,6l R4 CR td H13 9972
Revision: --H13--- Serial number: CVN: 355EDC8C
Coding: 00114016000401080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM16TDI02103L906023EP 003009
ROD: EV_ECM16TDI02103L906023EP_003.rod
VCID: 78A8EBFBB252DE0B9F1-802C
VINID: 9E69EAAAA1A2A92A411041C4000939CF26
7462 - EGR Valve (N18)
P0403 00 [104] - Malfunction
Fault Frequency: 6
Mileage: 79603 km
Date: 2021.08.17
Time: 07:29:57
Engine RPM: 1617.50 /min
Normed load value: 17.3 %
Vehicle speed: 27 km/h
Coolant temperature: 29 °C
Intake air temperature: 18 °C
Voltage terminal 30: 12.424 V
Accelerator position: normalized-Accelerator position: 0.00 %
EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 84.253 %
EGR Solen.val.: actual value-ANG_EGRV[0]: 4.138 %
Air mass: actual value (mg/stroke)-MAF_MES: 396.618 mg/stroke
Sensor for engine block temperature: raw value-Coolant temperature: 50 °C
7461 - EGR Valve (N18)
Mileage: 79599 km
Date: 2021.07.29
Time: 13:51:51
Engine RPM: 1800.75 /min
Normed load value: 2.7 %
Vehicle speed: 30 km/h
Coolant temperature: 70 °C
Intake air temperature: 26 °C
Voltage terminal 30: 12.988 V
Unlearning counter according OBD: 37
Accelerator position: normalized-Accelerator position: 16.02 %
EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 40.114 %
EGR Solen.val.: actual value-ANG_EGRV[0]: 67.480 %
Air mass: actual value (mg/stroke)-MAF_MES: 112.714 mg/stroke
Sensor for engine block temperature: raw value-Coolant temperature: 77 °C
9837 - Injector: Cylinder 1 (N30)
P0201 00 [096] - Circuit Malfunction
Mileage: 79624 km
Date: 2021.08.30
Time: 13:33:43
Engine RPM: 2747.75 /min
Normed load value: 32.9 %
Vehicle speed: 45 km/h
Coolant temperature: 84 °C
Intake air temperature: 32 °C
Error information regarding selected piezo output stage-LF_STATE_PPS_SPI[0]: 0
Injector valve 1: capacity-CAPA_INJ_MAIN[0]: 31.6816 µF
Voltage load of main injection cylinder 1-CHR_INJ_MAIN[0]: 1444.9 µAs
Measured energy of main injection cylinder 1-EGY_INJ_MAIN[0]: 32.945 mJ
Supply voltage of analog output 1-VCC_1: 5.00 V
Supply voltage of analog output 2-VCC_2: 4.99 V
Readiness: 0100 0000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3417100B6842C14E682D100521100
VCID: 06549503C866B8FB9DD-8052
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
Part No SW: 6R0 820 045 F HW: 6R0 820 045 F
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 313E16DF1128CF4318F-8064
002 - Lower Limit Exceeded
Fault Status: 01100010
Fault Frequency: 27
Reset counter: 223
Mileage: 78313 km
Date: 2011.02.22
Time: 10:42:59
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R0 937 088 F HW: 6R0 937 088
Component: BCM PQ25 Re4 H46 0355
Revision: BU046001 Serial number: 0379 269100365
Coding: 24B02BBF08A10000003009F02D2B0CD0DF00612F7E060449A00000000000
Shop #: WSC 22131 002 1048576
VCID: 41DE461FA1885FC3E8F-8014
Subsystem 1 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0903
Serial number: KU0-KU006.10.1015690
Coding: 58BC30
Subsystem 2 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU007.10.1012910
Coding: 48BC30
Subsystem 3 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Serial number: KU0-KU018.10.1011131
Coding: 48BC32
Subsystem 4 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Serial number: KU0-KU013.10.1014809
Coding: 48BC32
00532 - Supply Voltage B+
Fault Status: 00100001
Reset counter: 7
Mileage: 79590 km
Date: 2015.07.07
Time: 11:51:22
Fault Frequency: 6
Reset counter: 11
Mileage: 79497 km
Date: 2015.04.28
Time: 09:09:53
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10Airbag01M H09 0020
Revision: -------- Serial number: 003GX009RVYO
Coding: 00314D
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACC61339C3E9C9B395-801E
Serial number: 3575HRB405907A9Q8HJH
Serial number: 3585HRB405907A9Q61J0
Serial number: 3515RRB404P04QLUA8JF
Serial number: 3525RRB405P04QLU8G26
Part No SW: 6R0 920 861 E HW: 6R0 920 861 E
Component: KOMBI H04 0304
Coding: 140200
VCID: 372A28C7FFCC117356B-8062
13893888 - Function Restricted due to Excessive Voltage
U1401 00 [008] - -
Reset counter: 12
Mileage: 79631 km
Date: 2021.09.19
Time: 12:08:02
Address 19: CAN Gateway (J533) Labels:. 6R0-907-530-V2.clb
Part No SW: 6R0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H38 0025
Revision: H38 Serial number: 301010F2000798
Coding: 2500C2
VCID: 33321CD7EB34FD536A3-8066
Component: IMMO H04 0304
VCID: 6A8CC1B3FCFE7C9B195-803E
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 00788
VCID: 2F3A10A70E5CD9B30EB-807A
Part No SW: 5M0 035 156 C HW: 5M0 035 156 C
Component: Radio H30 0072
Revision: R0000000 Serial number: VWZAZ1K0532087
Coding: 0000020002
VCID: 290EFEBF39F8B783D0F-807C
Part No SW: 6R0 907 534 HW: 1K0 907 951
Component: Batt.regelung H38 0025
Coding: 030B1A5A
VCID: 74B0DFCBAEBABA6BB39-8020
Subsystem 1 - Part No SW: 6R0 915 181 B HW: 6R0 915 181
Component: J367-BDM H07 0150
Serial number: 00000000009370163018
End----------(Elapsed Time: 01:06, VBatt start/end: 12.3V/12.3V)-----------
