New Beetle 1.8T ECM Incorrectly Equipped after swap tranny
bassnaba
Thailand
C?ID=315869
New Beetle 2006-2010 1.8T
Stock car no reflashed
Autoscan
 Thursday,16,September,2021,15:02:20:41464
VCDS Version: 21.9.0.2 (x64)  HEX-NET CB: 0.4555.4
VIN: WVWZZZ9CZ8M554859   License Plate:
Mileage: 164410km-102159mi   Repair Order:
Chassis Type: 9C (9C - VW New Beetle (1999 > 2010))
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
VIN: WVWZZZ9CZ8M554859   Mileage: 164410km-102159miles
   Part No: 06A 906 032 RS
   Component: 1.8l 5VT NB/NBC     5433
   Coding: 00003
   VCID: 004C634D02A2FB8941-50F4
   WVWZZZ9CZ8M554859     VWZ5Z0G9048222
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 01N-927-733.lbl
   Part No: 01N 927 733 ED
   Component: AG4 Getriebe 01N    4533
   Coding: 00000
   VCID: 77BE0891576CBC3170-0962
            54-00 - Incorrectly Equipped
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 M
   Coding: 0019970
   Shop #: WSC 00066 000 00000
   VCID: 3424FF9D569A972995-5118
   Part No: 1C0 909 605 A
   Component: 47 AIRBAG VW51 03   0010
   Coding: 13367
   Shop #: WSC 00066
   VCID: 220809C5A96E099977-8076
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            36-00 - Open Circuit
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
            32-00 - Resistance Too High
00589 - Airbag Igniter 1; Passenger Side (N131)
Address 17: Instruments        Labels: 1C0-920-x4x.lbl
   Part No: 1C0 920 034 D
   Component: KOMBI+WEGFAHRS. M73 V04
   Coding: 07122
   VCID: 1A783125843E4159AF-4AE0
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    V042
   Coding: 00006
   Shop #: WSC 00066
   VCID: 70AC338D3202EB09B1-4AE0
            49-00 - No Communications
Address 35: Centr. Locks        Labels: 1C0-962-258-III.lbl
   Part No: 1C0 962 258 AB
   Component: 0X Zentr.Verriegel. 0004
   Coding: 00017
   Shop #: WSC 00066
   VCID: 679E58D107CC2CB1E0-4AC2
Address 54: Rear Spoiler        Labels: 1C0-959-733.lbl
   Part No: 1C0 959 733 J
   Component: Heckspoiler         0002
   VCID: 3228F985FC8E991987-5184
End----------(Elapsed Time: 03:32, VBatt start/end: 12.1V/12.1V)-----------
After swap tranny from 01m to 01n car has a code and when put R always die and jerk If D car will jerk too much when change from 1 2 3 4
Still same Code after
1.Clear all
2.change ECU CLUSTER from my another 1.8T
3.change 01N to 01M TCU
Thank you for advice
Check parts catalog to be sure, but I suspect that ECU software 06A 906 032 RS is specific to the transmission type and the only fix here will be to reflash it with software appropriate to the transmission now installed in the car.
iichel
Eindhoven, NB, NL
C?ID=284912
0GG = Emission standard EU4
bassnaba
Thailand
C?ID=315869
Old TCU I think it's missing because my friend car take a car to shop and swap tranny but why I try to change all set like ECU CLUSTER TCU still same problem
