Caddy Immobiliser issue?
burnbrae
C?ID=68599 (NRRT)
Car starts and then stops a few seconds later, dash lights. Gauges etc dont come on with the ignition. Dash has been tested and is all good. Any help or guidance appreciated.
Monday,06,September,2021,15:48:54:61714
VCDS Version: 18.9.1.0 (x64)
VIN: WV1ZZZ2KZ7X087424   License Plate: CADDY
Mileage: 31840km-19784mi   Repair Order:
Chassis Type: 2K (1K0)
Scan: 01 02 03 09 15 16 17 19 25 42 44 46 52 56
VIN: WV1ZZZ2KZ7X087424   Mileage: 31840km-19784miles
17-Instruments -- Status: Sporadic communication error 1000
25-Immobilizer -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 021 AR    HW: 028 101 246 9
   Component: R4 1,9L EDC  000AG  7818
   Revision: --H06---    Serial number: VWZ7Z0F7199559
   Coding: 0000038
   Shop #: WSC 35110 377 00175
   VCID: 6FE604C17E6C1E3234-803A
006229 - Powertrain Data Bus
               P1855 - 000 - Software Version Monitoring
                    Mileage: 31847 km
                    Time: 00:05:33
                    Voltage: 11.93 V
                    Temperature: 24.3°C
                    Temperature: 18.0°C
                    Temperature: 19.8°C
005488 - Engine Start Blocked by Immobilizer
               P1570 - 000 -  - MIL ON
                    Fault Status: 11110000
                    Mileage: 31847 km
                    Time: 00:08:23
                    RPM: 1008 /min
                    Voltage: 11.63 V
                    Bin. Bits: 11000000
                    Bin. Bits: 11000000
                    Bin. Bits: 00100001
   Part No SW: 02E 300 043 L    HW: 02E 927 770 AE
   Component: GSG DSG         070 1301
   Revision: 04507000    Serial number: 00000612141253
   Shop #: WSC 35110 377 08192
   VCID: 1D3A0E09C440DCA2D6-8048
18270 - Powertrain Data Bus
            P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
                    Fault Frequency: 255
                    Mileage: 31847 km
   Part No: 1K0 907 379 P
   Coding: 0017106
   Shop #: WSC 00017 210 90604
   VCID: 3F8694816E8CAEB2E4-806A
   Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006540622
   Coding: 00884F030004100007000000000000000008FB075C0001
   VCID: 6BDE10D14A74E21218-803E
   Subsystem 1 - Part No: 2K2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 050107 020  0501
   Coding: 00038805
   Shop #: WSC 35110
                    Fault Status: 00101100
                    Reset counter: 182
                    Mileage: 31354 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.15 V
                    Fault Status: 00101001
                    Reset counter: 182
                    Mileage: 31847 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.30 V
01800 - Light Switch (E1)
                    Reset counter: 182
                    Mileage: 31847 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.30 V
                    Reset counter: 182
                    Mileage: 31847 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.00 V
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 09 AIRBAG VW52  023 2400
   Revision: 04023000    Serial number: 0037TD0CW7R1
   Coding: 0012345
   Shop #: WSC 35110 377 00155
   VCID: 7DFA2E8924007CA2B6-8028
            004 - No Signal/Communication - Intermittent - MIL ON
   Part No SW: 1K0 953 549 AN    HW: 1K0 953 549 AN
   Component: Lenksäulenmodul 636 0070
   Coding: 0010002
   VCID: 7EF82985290667BAAF-802A
   Part No SW: 1T0 920 953 C    HW: 1T0 920 953 C
   Revision: V0003000    Serial number: VWZ7Z0F7199559
   Coding: 0016401
   Shop #: WSC 54705 002 1048576
   VCID: 346CCBAD57CA7DEA09-8060
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 11100602000237
   Coding: 3F0F014007007401
   VCID: 2F66C4C1BEEC5E3274-807A
                    Reset counter: 182
                    Fault Status: 00110100
                    Reset counter: 182
                    Reset counter: 182
                    Mileage: 31847 km
                    Time: 16:19:03
   Component: IMMO            VDD 1610
Address 42: Door Elect, Driver        Labels: 1K0-959-793.lbl
   Part No: 1K0 959 793
   Component: Tuersteuergeraet 02 0160
   Coding: 0000000
   VCID: 76E831A501362FFAF7-8022
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.140 H07 1806
   Shop #: WSC 35110 666 38454
   VCID: 356AF6A95CB064E23E-8060
00750 - Warning Lamp
                    Mileage: 31840 km
                    Temperature: 12.0°C
                    Voltage: 11.00 V
                    Voltage: 10.80 V
   Part No: 1K0 959 433 CP
   Coding: 808A0C087F2D84054858030010C0
   VCID: 0004577D53F2114ADD-8054
Address 52: Door Elect, Pass.        Labels: 1K0-959-792.lbl
   Part No: 1K0 959 792
   Coding: 0000000
   VCID: 75EA36A91C3024E2FE-8020
   Part No SW: 1K0 035 186 T    HW: 1K0 035 186 T
   Component: Radio BVX       034 0046
   Revision: 00034000    Serial number: VWZ1Z2G4473343
   Coding: 0020200
   VCID: 3776FCA146BC96F22C-8062
End-------------------------(Elapsed Time: 01:34)--------------------------
Viking
C?ID=151455
Westbury, UK
Your VCDS software is out of date.
VERY out-of-date (3 years), definitely a very good idea to update.
OP you have an intermittent communication problem with the instruments (& immobilizer), worth clearing the fault codes and seeing which come back.
  • Agree
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
This is Mk5 Golf platform , so if cluster was tested on table and lights up, and in car do not , then you have 12v or Ground problem.
Here is the Pin out , check and see what you missing when you turn ignition On:
PIN:
1 - terminal 15 positive (Igntion 12 volts)
2 - terminal 30, positive (All the time 12 volts)
19 - terminal 31, earth (ground)
