2014 RS5 - Do not exceed 6000RPM message and coolant temp rising
ando1
MA, USA
C?ID=429032
I am a new owner of this car that had all service done previously at the dealership by the previous owner. It has 48,000 miles on it and last week when getting on the freeway I got a message on the console saying "Do Not Exceed 6000RPMs" with a yellow warning light. I was close to home and drove straight there and immediately ran an auto scan on the car. No codes were found. After doing some research, I checked the coolant level in the reservior and found that it was a little below the min mark when the car was cold so I filled it to the halfway point between min/max and took the car out for a test drive. While driving in the city all seemed well, but when I got on the freeway again the same thing happened with the 6000RPM warning. I scanned the car again and no codes. I have called a couple of shops near by and they said that if I get that rev warning there should be a code associated with it. I am running the Auto Scan feature on my car and am not seeing any codes. Am I doing something wrong?
ando1
MA, USA
C?ID=429032
Hi Bruce,
Here is the scan.
Andy
Sunday,12,September,2021,13:04:56:39250
VIN: WUAC6AFH8EN900172   License Plate:
Mileage: 77770km-48324mi   Repair Order:
Chassis Type: FH-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 22 26 36 3C 42 44 46 47 52
          53 56 5F 62 6C 72
VIN: WUAC6AFH8EN900172   Mileage: 77770km-48324miles
Address 01: Engine (------CFSA)       Labels:. 079-907-560-CFS.clb
   Part No SW: 8T2 907 560 F    HW: 8T1 907 560
   Component: 4.2l V8HDZ /  H04 0005
   Revision: NAH04---
   Coding: 2225003225A6080D3000
   Shop #: WSC 02789 002 1048576
   ASAM Dataset: EV_ECM42FSI0118T2907560F 001004
   ROD: EV_ECM42FSI011_AU48.rod
   VCID: 3FDB485477F429D3B69-806A
   Part No SW: 8T0 927 156 H    HW: 0B5 927 156 J
   Component: 0B5 42 FSINAR H02 0006
   Revision: --H02---
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL501021 001025
   ROD: EV_TCMDL501021.rod
   VCID: 42DD41A00406443BD97-8016
   Part No SW: 8T0 907 379 F    HW: 8T0 907 379 F
   Component: ESP8 quattro  H09 0100
   Coding: 341D1A
   VCID: 45D75ABC15A87303FC5-8010
   Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
   Component: BCM2 2.0      H12 0633
   Coding: 0D830F40000000000000
   VCID: 045187B85E128A0BABB-8050
   Serial number: 2313000106921005
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 F    HW: 8T0 959 760 F
   Component: MEM-BFS       H10 0076
   Revision: AA000000    Serial number: 00000062251600
   Coding: C80370250D2400001000
   VCID: 46D55DB028AE781BF5F-8012
                    Reset counter: 3
                    Mileage: 77187 km
                    Date: 2021.08.20
                    Time: 18:33:46
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 AL    HW: 8K1 820 043 AL
   Revision: C3000000    Serial number: 01120620130644
   Coding: 4803200E00
   VCID: 72BDD16074A6B4BB897-8026
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000627536001
   Coding: 06000091043CAFE0250048C0000039094F9CD388A209022100000B004000010200040074000000
   VCID: 7AADF9402CD6CCFBC17-802E
   Subsystem 1 - Part No SW: 8F1 955 119     HW: 8K1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 110613  H07 0080
   Serial number: SWF13060115327
   Coding: 00FD11
   Serial number: 21422127
   Coding: 02005D
   Subsystem 3 - Part No SW: 8K0 941 531 AQ    HW: 8K0 941 531 AQ
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002705130094
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R6ELW02
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 1428C1B6000000000001
Address 15: Airbags (J234)       Labels:| 8F0-959-655.clb
   Part No SW: 8F0 959 655 E    HW: 8F0 959 655 E
   Component: AirbagVW-AU10 H12 0430
   Serial number: 003KKD808MX+
   Coding: 303741353731303030304A55304C38463053
   ASAM Dataset: EV_AirbaAU10SMEAU485 001004
   ROD: EV_AirbaECUVWAUDI010.rod
   VCID: 3A2D39406CD60CFB817-806E
   Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
   Component: BF-Gewichtss.  H02 0060
   Serial number: 5810000R130000DQXT
   Serial number: 6334MSME7954614EN
   Serial number: 6344MSME7B242D2BQ
   Serial number: 6352QSME11324B7EK
   Serial number: 6362QSME073219404
   Serial number: 63732SME3934585C5
   Serial number: 63832SME39342C7A7
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372MEN000M8
   Coding: 000036
   VCID: 44D147B81E924A0BEBB-8010
   Part No SW: 8T0 920 984 H    HW: 8T0 920 984 H
   Component: KOMBIINSTR.   H35 0563
   Revision: 00500000    Serial number: WVZ35996E
   Coding: 8BBF19008B01D705020000
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0056
   Revision: 1Z110028    Serial number: 2841Z13529014E
   Coding: 80E3031600
   VCID: 4CC16F9836C2824B23B-8018
   Serial number: 0779180603
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H14 0100
   Serial number: 001506130001413
   VCID: 2F3B1814A794D953269-807A
Address 26: Auto Roof (J256)       Labels:* 8F0-959-255.clb
   Part No SW: 8F0 959 255     HW: 8F0 959 255
   Component: VSG-AUDI-B8   H12 0190
   Coding: 030000
   ASAM Dataset: EV_ElectRoofContr 001008
   ROD: EV_ElectRoofContr.rod
   VCID: 71BFDE6C71208FA370D-8024
   Component: MEM-FS        H10 0076
   Revision: AA000000    Serial number: 00000062251817
   Coding: C81B7B250D2400001000
                    Reset counter: 3
                    Mileage: 77187 km
                    Date: 2021.08.20
                    Time: 18:33:46
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Component: SWA Master    H04 0060
   Serial number: 0306692379
   Coding: 010211
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H04 0060
   Serial number: 0305822649
   Coding: 000102
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 011C53724E08332C03
   VCID: 56F58DF0F80EC89B85F-8002
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0010572409
   Coding: 100000010001
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 343117784EB2FA8B5BB-8060
   Revision: 00002001    Serial number: 0309031354
   Coding: 010606BA00FA402180B0033200000000
   Subsystem 1 - Part No SW: 8F0 959 719 B    HW: 8K0 959 719
   Component: GTO BF  H01 0080
   Serial number: 00000000000000677792
   Part No SW: 8F1 035 223 A    HW: 8F1 035 223 A
   Revision: 00005001    Serial number: 94833015988702
   VCID: 1F1BE8D4D7B449D3969-804A
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   Coding: 011C53324E08332C03
   VCID: 55F78AFCE508C3838C5-8000
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 00000001323561
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 392F264C69D007E388D-806C
   Part No SW: 4G0 035 082 H    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0138
   Revision: AB001007    Serial number: 156F-0D7814810
   Coding: 020007010000000101
   VCID: 2517FA3CF5E89303DC5-8070
   Part No SW: 8R1 035 746 K    HW: 8R1 035 746 D
   Component: H-BNT-NA      H40 1040
   Revision: --------    Serial number: 204F.0D7583517
   Coding: 150200030306E1EF55028B4E00000401150000000000000000
   VCID: 3FDB4854777429D3B69-806A
   Subsystem 1 - Part No: 8R0 060 884 BD
   Component: NAR 2013/2014  0802
   Component: DU7 High  H42 0104
   Serial number: A130EP0D2745333
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001533139
   Component: CD-Database  5298
                    Reset counter: 210
                    Mileage: 76866 km
                    Date: 2021.08.04
                    Time: 09:54:22
                    Text: DUA130,Front,M,0,0,6
00658 - Control Head
                    Reset counter: 18
                    Time Indication: 15
                    Voltage: 12.20 V
02244 - Button in Control Head is Stuck
                    Reset counter: 21
                    Mileage: 77727 km
                    Date: 2021.09.11
                    Time: 15:57:03
                    Voltage: 12.10 V
                    Hex Value: 0x0005
                        not available
03389 - Data Set Implausible
                    Reset counter: 210
                    Mileage: 76866 km
                    Date: 2021.08.04
                    Time: 09:54:20
                    Voltage: 12.00 V
                    Bin. Bits:      010
   Part No SW: 8T0 959 795 F    HW: 8T0 959 795 F
   Component: TSG HL        H08 0305
   Coding: 010C13304008372C03
   VCID: 4EC56590C0DEB05B4DF-801A
   Part No SW: 8F0 907 441     HW: 4L0 907 441 B
   Revision: --H08---    Serial number: 525PA8-J35B0DJ
   Coding: 1020009
   VCID: 678BB034436441132E9-8032
   Component: TSG HR        H08 0305
End----(Elapsed Time: 02:04, VBatt start/end: 11.9V/12.0V. VIgn 12.0V)-----
Hmm. ECU reports "No fault code found.".
Gateway reports: "01-Engine -- Status: OK"
If it were mine, I would have a look at what the ECU thinks the coolant temp is when this happens. No, not the gauge; the gauge is a joke. The measuring value in the ECU:
IDE00025-ENG167462 -- Coolant temperature
Trowbridge, UK
Those engine ECUs include software that detects the coolant (and oil temperatures IIRC - at least that was true on my RS4) and eithers advises or limits the RPM if the temperatures are too low to safely allow high revs to be used.
ando1
MA, USA
C?ID=429032
Thanks @Uwe and @PetrolDave I checked the coolant temp with an old BT ODBII device and Torque Pro. I did it this way as my VCDS adapter is cabled and wanted to be able to hold the tablet in front of me. The coolant temp reached 245 degrees F before the 6000RPM warning showed. That's also when the Temp gauge on the car started to rise. I have read that the normal operating temp should be around 212F so I think that is a bit high. I immediately shut the car off when it hit that number.
Trowbridge, UK
Sounds like you have a problem with either the thermostat or a coolant pump - if the temperature gauge isn't starting to rise until the water temp reaches 245F then something isn't opening up the coolant circuit to the radiator correctly. Time to get a diagram of the coolant circuit and doing some mechanical investigation IMHO.
  • Agree
ando1
MA, USA
C?ID=429032
Thanks PetrolDave. I suspect it may be the thermostat or the water pump as well. I spoke to a mechanic yesterday that said most likely the T-Stat as the water pumps has a metalic impeller and he said those don't fail as often. I am going to schedule a day to have the car serviced next week.
It sounds like this one also advises (and/or limits?) if the coolant temp gets too high...?
Zenerdiode
Newcastle, England
C?ID=24330
Is this one of those faults that may be reported in Aggressive mode @Uwe ?
I also can’t remember if Aggressive mode is enabled by default.
On almost all modules it is. There was a transmission or two where it isn't because all of them report a plethora of faults that way at all times. In any case, I'm pretty confident it is enabled in that ECU.
