EVAP CODE P0441
cschmitz20
Verified VCDS-Lite User
C?ID=385099
Just replaced the evap N80 but still get incorrevt flow. Does this mean the purge valve is crap or there another leak somewhere. It passes the leak test but fails and says evap is not ok
We need more information. Please post the complete Auto-Scan. If you are using VCDS-Lite the button will be labeled [Copy Results] rather than [Copy] in that video.
cschmitz20
C?ID=385099
Version: 21.3.0.0 (x64)  HEX-V2 CB: 0.4543.4
VIN: WAUAT48H63K022250   License Plate:
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
          63 65 67 73 75 76 77
VIN: WAUAT48H63K022250   Mileage: 213350km-132569miles
Address 01: Engine        Labels: 06C-909-559-ASN.lbl
   Part No SW: 8E0 909 559 E    HW: 8E0 909 059
   Component: 3.0L V6/5V      G   0004
   Coding: 0016584
Shop #: WSC 00672 785 00200
   VCID: 372B2A1BC350F2F37E9-5160
16805 - Warm Up Catalyst; Bank 1
            P0421 - 001 - Efficiency Below Threshold
Readiness: 0000 1101
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No: 01J 927 156 FE
   Component: V30 01J 3.0l 5V USA 3031
   Coding: 01001
Shop #: WSC 03213
   VCID: 74B1DD1797A659EB9BB-5160
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517 G
Component: ABS/ESP front 2328
   Coding: 04499
Shop #: WSC 00672
   VCID: 2C0105770F16412B03B-51F2
   Part No: 8E0 820 043 L
   Component:   A4 Klimaautomat   1116
   Coding: 00100
Shop #: WSC 00672
   VCID: 2A0D036F05E25F1BF17-513C
            41-10 - Blocked or No Voltage - Intermittent
00716 - Air recirculation Flap Positioning Motor (V113)
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 E
   Component: int. Lastmodul  USA 0305
   Coding: 00013
Shop #: WSC 00672
   VCID: 34311D17D72619EB5BB-4B00
Address 15: Airbags        Labels: 8H0-959-655-84.lbl
   Part No: 8H0 959 655 B
   Component: Airbag 8.4EC        1015
   Coding: 0010105
   VCID: 392F2C23F544E48388D-5160
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0308
   Coding: 02041
Shop #: WSC 00672
   VCID: 3E253F3FE96AC3BBBDF-4B00
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8H0 920 950 E
   Component: KOMBI+WEGFAHRS. RB4 D16
   Coding: 02201
Shop #: WSC 03213
   VCID: 2E050F7F390A333B2DF-5160
   WAUAT48H63K022250     AUZ6Z0B0400950
            27-00 - Implausible Signal
Address 26: Auto Roof        Labels: 8H0-959-255.lbl
   Part No: 8H0 959 255 B
   Component:  VSG  B6 CABRIO     7195
Shop #: WSC 02101 444 12602
   VCID: 35372013D95C00E36C5-5160
   Part No: 8H0 959 760
   Component: Sitzmemory EE H04   X013
   Coding: 00002
Shop #: WSC 00065
   VCID: 74B1DD17979659EB9BB-4B1E
   Part No: 8H0 959 433 C
   Component: Komfortgerát T7B    1412
   Coding: 11788
Shop #: WSC 00672
   Subsystem 1 - Part No: 8H1959801
   Component: Tõrsteuer.FS BRM 0001
   Component: Tõrsteuer.BF BRM 0001
            37-10 - Faulty - Intermittent
            49-00 - No Communications
00955 - Key 1
            35-10 - - - Intermittent
            80-10 - Single-Wire Operation - Intermittent
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00070
Shop #: WSC 00672
   VCID: 04518DD7C736696BABB-4B00
   Part No: 8E0 035 195 F
   Component: symphony II NP2    0051
   Coding: 00205
Shop #: WSC 40313
   VCID: 2A0D036F05D25F1BF17-4E62
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
            36-00 - Open Circuit
00856 - Radio Antenna
Address 63: Entry Assist,D        Labels: None
   Part No: 8H0 959 760 A
   Component: EasyEntry F M H11   X023
   Coding: 00006
Shop #: WSC 00065
   VCID: 35372013DC6C00E36C5-4B1E
Address 73: Entry Assist, P        Labels: None
   Component: EasyEntry BF  H11   X023
   Coding: 00005
            80-00 - Single-Wire Operation
01794 - Control Module - Incorrect Chassis (VIN) Number
            35-00 - -
End----------(Elapsed Time: 05:43, VBatt start/end: 12.3V/12.2V)-----------
Address 01: DTCs cleared
cschmitz20
C?ID=385099
Auto scan posted
You already had a Auto-scan posted!
Did you ever check this (below) from your other post (btw, I would not start multiple threads , for obvious reasons, for the same vehicle concerns). Members and RT employees , post #2, are joining in repeating all the same questions.
Much better. That one is readable.
If it were mine, I think the first thing I would try is pulling the oxygen sensors and swapping them from Bank 1 and Bank 2. Give them a cleaning while they're out. The ECU will flag CAT efficiency based on oxygen sensor behavior and it's not unheard of for an old sensor to be just lame enough to cause such a fault without the ECU flagging the sensor as bad.
While you have the sensors out, you might want to stick a borescope camera in there and visually inspect the CATs for obvious damage. If the matrix is has visible damage, then it's probably replacement time. At 130,000 miles it's not inconceivable to have a bad CAT, especially if the engine has had misfire issues at some point during its life.
Problem is OEM CATs are expensive, and aftermarket ones generally don't work well enough for the ECU to be happy with them for very long.
Yea trying just see where these sensors are is a nightmare let alone trying to attempt to get them out. Obviously designed so you cant do it yourself and have to take it to a stealer. What a joke.
Yes, you bet, this can be challenging work! If you are not comfortable with it or do not have the necessary tool collection, you may have to take it to a private shop or dealer.
Ultimately, you are going to have to do some disassembly and testing and then let the forum know what you find.
