Audi A3 8P ABS MK60EC1, Lost coding..
totaltuning
C?ID=255206
Hi, in the shop is a 2009MY Audi A3 8P Chassis, you guessed it, ABS lost it's coding! According to the customer they tried a used Instrument cluster and the rest is history as they say. I've tried a few online calculators without success, if anyone can calculate it would be a big help. Thanks
Monday,13,September,2021,14:09:53:23287
VCDS Version: 21.3.0.0 (x64)
VIN: WAUZZZ8P19A099970   License Plate: AUDI_A3_8P/-1.9TDI
Mileage: 230730km-143368mi   Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: WAUZZZ8P19A099970   Mileage: 230730km-143368miles
04-Steering Angle -- Status: Sporadic communication error 1000
16-Steering wheel -- Status: Sporadic communication error 1000
17-Instruments -- Status: Sporadic communication error 1000
25-Immobilizer -- Status: Malfunction 1010
44-Steering Assist -- Status: Malfunction 1010
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 021 TP    HW: 03G 906 021 AN
   Component: R4 1,9L EDC  000SG  2595
   Revision: --H08---    Serial number: XXXXXXXXXXXXXX
   Coding: 0000071
   Shop #: WSC 06314 000 00000
   VCID: 000A0D825359F48BC3-8054
005712 - Powertrain Data Bus
               P1650 - 000 - Missing Message from Instrument Cluster - Intermittent
                    Fault Frequency: 69
                    Mileage: 280110 km
                    Date: 2021.07.28
                    Time: 00:00:14
                    RPM: 966 /min
                    Voltage: 14.14 V
                    Bin. Bits: 00000000
                    Torque: 156.2 Nm
                    Torque: 0.0 Nm
053273 - Control Module for Instrument Cluster
               U1019 - 000 - Missing Signal for Oil Level/Temperature - Intermittent
                    Fault Frequency: 38
                    Mileage: 280110 km
                    Date: 2021.07.28
                    Time: 00:00:15
                    RPM: 966 /min
                    Voltage: 14.14 V
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    (no units): 33.0
005660 - Glowplug for Cylinder 3 (Q12)
               P161C - 000 - Open Circuit
                    Fault Status: 01110000
                    Voltage: 11.40 V
                    Bin. Bits: 00000100
                    Temperature: 16.2°C
                    Bin. Bits: 00110000
005441 - Fuel Pump Relay (J17)
               P1541 - 000 - Open Circuit - Intermittent
                    Mileage: 210554 km
                    Date: 2021.03.29
                    Time: 00:16:36
                    Voltage: 11.32 V
                    Bin. Bits: 00000100
                    Bin. Bits:        0
                    (no units): 0.0
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 000000000000000000000000000000000000
   VCID: 7EF6737AE9AD827BB1-802A
03306 - Coding Not Valid
                    Reset counter: 125
                    Mileage: 230733 km
                    Date: 2020.12.30
                    Time: 05:40:19
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 4161
                    Count: 43776
                    Reset counter: 124
                    Mileage: 230732 km
                    Date: 2020.12.10
                    Time: 02:11:31
                    Count: 16391
                    Count: 2
                    Count: 8192
                    Count: 195
                    Count: 46848
                    Count: 512
   Part No SW: 8P0 820 043 BG    HW: 8P0 820 043 BG
   Component: KlimavollautomatH09 0100
   Revision: 000580      Serial number: 8P0820043BG
   VCID: 72EE574A6DF5D61BC5-8026
            007 - Short to Ground
                    Fault Status: 01100111
                    Fault Frequency: 68
                    Reset counter: 125
                    Mileage: 273950 km
                    Date: 2021.02.23
                    Time: 16:21:18
                    Temperature: 9.5°C
                    Fault Frequency: 15
                    Reset counter: 163
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
   Component: Bordnetz-SG     H54 2801
   Revision: 00H54000    Serial number: 00000008798411
   Coding: 11A82F81B0141380EF00001C0000000000084E0564010403002800000000
   Shop #: WSC 06314 000 08192
   VCID: 489AD5A23BE90CCB4B-801C
   Subsystem 1 - Part No: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350   H10 0040
   Coding: 00056595
   Shop #: WSC 06314
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 125
                    Voltage: 12.60 V
                    Reset counter: 163
                    Voltage: 11.90 V
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 J    HW: 8P0 959 655 J
   Component: Airbag AU1042 H06 0090
   Revision: --------    Serial number: 003000000000
   Coding: 303142383038303030374A55305238503053
   ROD: EV_Airba10AURB4_AU35.rod
   VCID: 499CD0A6E8E3F5C354-801C
   Serial number: 3572DRB400007A20C31L
   Serial number: 3582DRB400007A24C0CY
   Serial number: 35128RB400003FB062FR
   Serial number: 35228RB400003FB29B5W
   Serial number: 35547RB400004001283+
   Serial number: 35647RB400003F63FE1
12670208 - No Communication with Instrument Cluster
          U0155 00 [008] - -
                    Fault Frequency: 16
                    Reset counter: 163
13637376 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [008] - -
                    Reset counter: 155
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0002012
   VCID: 418CC88618D33D838C-8014
   Component: E0221           H02 0030
   Part No SW: 8P0 920 982 C    HW: 8P0 920 982 C
   Component: KOMBIINSTR. VDO H19 0860
   Revision: D0H19007    Serial number: 2240I007013543
   Coding: 0006428
   VCID: 397CA06670036543C4-806C
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K0880108A5
   Coding: E9807F061002022103
   VCID: 3564AC565C1B812320-8060
8 Faults Found:
                    Reset counter: 125
                    Mileage: 260265 km
                    Date: 2019.06.13
                    Time: 17:12:17
                    Fault Frequency: 20
                    Reset counter: 163
                    Fault Frequency: 14
                    Reset counter: 163
                    Fault Frequency: 97
                    Reset counter: 163
                    Reset counter: 155
                    Reset counter: 155
                    Reset counter: 155
                    Fault Status: 00101110
                    Reset counter: 163
   Revision: D0H19007    Serial number: AUX7Z0I0FNC08Z
16346 - Control Module - ROM Error
            014 - Defective
   Part No SW: 8P0 959 801 K    HW: 8P0 959 801 K
   Component: Tuer-SG         H03 0060
   Coding: 0000692
   VCID: 4380C28E02CF2F939E-8016
01706 - Switch for Mirror-Adjust (E43)
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 232    2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A5E8F2A85A5DEDBBD-807E
                    Fault Frequency: 17
                    Reset counter: 173
                    Voltage: 13.00 V
                        DU
                    Temperature: 27.0°C
                    RPM: 819 /min
                    Fault Status: 00101101
                    Reset counter: 165
                    Voltage: 11.75 V
                        DD
                    Temperature: 28.0°C
                    Reset counter: 165
                    Voltage: 11.75 V
                        DD
                    Temperature: 28.0°C
00750 - Warning Lamp
                    Reset counter: 175
                    Mileage: 210554 km
                    Date: 2021.03.29
                    Time: 00:00:02
                    Voltage: 11.00 V
                        DD
                    Temperature: 23.0°C
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 J
   Component:    KSG          H11 0080
   Coding: 1980200002186D0985054C9FC637
   Subsystem 2 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
   Subsystem 3 - Part No: 8P0 951 177
   Component: Innenraumueberw.H04 0020
00332 - Control Circuit for Tank Flap
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P4 035 382 D    HW: 8P4 035 382 D
   Component: AB2 SUBWOOFERBOXH06 0180
   Revision: 00005       Serial number: 30674802784188
00421 - Rear Left DSP Midrange Speaker (R105)
                    Fault Status: 00101011
                    Reset counter: 155
                    Mileage: 279646 km
                    Date: 2021.07.16
                    Time: 00:00:22
                    Temperature: 38.0°C
   Part No SW: 8P0 959 802 K    HW: 8P0 959 802 K
   Coding: 0000692
   VCID: 4482C19207C128ABA7-8010
   Part No SW: 8P0 035 186 P    HW: 8P0 035 186 P
   Component: R Concert2+     H03 0270
   Revision: 00H03000    Serial number: AUZ1Z3H8949702
   Coding: 0330211
   VCID: 3F88CE7E6E274B73FA-806A
                    Fault Status: 00100001
                    Reset counter: 155
                    Fault Frequency: 16
                    Reset counter: 164
00857 - CD Changer Unit (R41)
                    Reset counter: 115
                    Mileage: 279646 km
                    Date: 2021.07.16
                    Time: 11:41:20
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 E    HW: 8P4 959 801 E
   Component: Tuer-SG         H04 0040
   Coding: 0000144
   Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 E    HW: 8P4 959 802 E
   Coding: 0000144
   VCID: 428EC78A1DD5269B95-8016
End-------------------------(Elapsed Time: 02:23)--------------------------
iichel
Eindhoven, NB, NL
C?ID=284912
Is the original instrument cluster back in?
Jef
HQ
Indeed... do make sure all the "VIN Data" is a match:
I agree and with that X'd out (Serial number: XXXXXXXXXXXXXX) serial we should look at the Adv ID - 1A logs from 01, 17 and 25.
If 01-Engine has an Immo defeat or different VIN than 17/25 we're gonna have a bad time. Using the [Save] button from the Advanced ID Screen when connected to each module (01, 17 and 25) will allow you to paste the content into your thread similar to the bottom of post #1 here https://forums.ross-tech.com/index.php?threads/18430/
totaltuning
C?ID=255206
Thanks, the customer told me it's original but I'll remove it an check. Inform soon!
