12 Jetta won't drive after shifter swap -u0103/01044
Onelowvdub
Edmonton, Canada
C?ID=492415
The plastic tab on my 12 Jetta DSG shifter broke so I grabbed a 17 Jetta tiptronic shifter and actually plugged it into my car and now I think ingot component protection .took it to the dealer and there next step was a shifter swap I bought vcds and I still can't clear codes I tried everything and I can't shift the car .I can do it by pressing yellow button but nothing is selecting in trans .do I need another shifter ? I swapped all the guts from the 12 shifter into the 17 shifter case and it's still there . attached video of what it's doing .
Codes are u0103 no communication with gear shift module
And 01044 control module incorrectly incoded
Hi, and welcome. You are going to need to post a full, unedited > Auto-scan < so that you can be accurately advised.
Onelowvdub
Edmonton, Canada
C?ID=492415
Tuesday,14,September,2021,18:35:25:03940
VCDS Version: 21.9.0.2 (x64)  HEX-V2 CB: 0.4555.4
VIN: 3VW467AJ5CM369905   License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 47 4F 52
          56 62 72
VIN: 3VW467AJ5CM369905   Mileage: 155860km-96846miles
08-Auto HVAC -- Status: Not registered 0001
15-Airbags -- Status: Not registered 0011
16-Steering wheel -- Status: Not registered 0001
17-Instruments -- Status: Not registered 0001
2B-Steer. Col. Lock -- Status: Not registered 0001
2E-Media Player 3 -- Status: Not registered 0001
46-Central Conv. -- Status: Not registered 0001
4F-Centr. Electr. II -- Status: Not registered 0001
52-Door Elect, Pass. -- Status: Not registered 0001
62-Door, Rear Left -- Status: Not registered 0001
72-Door, Rear Right -- Status: Not registered 0001
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 997 029 D    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 03 1509
   Revision: P3H07---    Serial number:
   Coding: 0403010A1C070160
   Shop #: WSC 00001 000 00000
   VCID: 382920A25E537D8B5F1-806C
VINID: 0E69C418745A1537431892401409436C5F
049682 - Steering Column Control Module
               U0212 - 000 - No Communications
                    Mileage: 155865 km
                    Date: 2016.01.27
                    Time: 16:32:41
                    Temperature: 41.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 930.0 mbar
                    Voltage: 11.557 V
005668 - MIL Request Signal Active (Check TCM for errors too!)
               P1624 - 000 -  - Intermittent
                    Mileage: 155865 km
                    Date: 2016.01.27
                    Time: 21:24:29
                    RPM: 1400 /min
                    Load: 19.2 %
                    Temperature: 18.0°C
                    Temperature: 18.0°C
                    Voltage: 11.303 V
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early
                    Temperature: -40.0°C
                    Voltage: 12.700 V
000604 - Fuel Pump Control Module
               P025C - 000 - Short to Ground - MIL ON
                    Fault Status: 11100000
                    Voltage: 12.700 V
Readiness: 1110 0101
   Part No SW: 02E 300 057 Q    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 3108
   Revision: 05351113    Serial number: 00001111042148
   Shop #: WSC 00066 000 00000
   VCID: 270BF3DE83EDE273C6B-8072
28775 - No Communication with Gear Selector Module
            U0103 - 000 -
                    Fault Frequency: 255
                    Mileage: 155865 km
                    Date: 2016.02.05
                    Time: 00:16:44
            U0103 - 004 -
                    Reset counter: 0
                    Mileage: 155865 km
                    Date: 2016.02.05
                    Time: 00:16:48
   Revision: 00H31001
Coding: A14B600C49280003851406E4921E0041391800
   Shop #: WSC 12345 123 61029
   VCID: 7DA7F1B63DF198A3CC7-8028
                    Fault Status: 01101000
                    Reset counter: 148
                    Mileage: 155865 km
                    Date: 2016.02.05
                    Time: 00:16:44
                    Count: 2
                    Count: 2
                    Count: 28672
                    Count: 8212
                    Count: 45056
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434 B
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0156965323
   Coding: 030C0C
   VCID: 343114924EBB99EB739-8060
   Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
   Component: Climatronic   H18 1112
   Revision: 00001004
   Coding: 0000004002
   Shop #: WSC 00066 000 00123
   VCID: 005988424A83F54BA71-8054
   Part No SW: 5K0 937 086 N    HW: 5K0 937 086 N
   Component: BCM PQ35 M    021 0064
   Revision: BJ021001
Coding: E7200A3A8C2B3EC400880000000003EC47808C0054808D3000802004A040
   VCID: 3FDB4BBE777D4AB39EB-806A
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   014 0808
   Serial number: 003GTM03P3FU
   Coding: 00003937
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
   ROD: EV_AirbaVW10SMEVW360.rod
   Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
   Component: BF-Gewichtss.  H10 0045
   Serial number: 6940000Y110000A8G508
   Coding: 303043
   Serial number: 3572MSME44360166ZZZN
   Serial number: 3582MSME0B630166ZZZR
   Serial number: 3516KSME0A600516ZZZH
   Serial number: 3526KSME44467915ZZZU
   Serial number: 3556LSME3D032C35ZZZZ
   Serial number: 3566LSME5D497E14ZZZ9
12854016 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [009] - -
          [Control Unit in Dashboard implausible signale]
                    Reset counter: 148
                    Mileage: 155865 km
                    Date: 2021.09.14
                    Time: 00:16:53
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20111215300319
   Coding: 0012140000
   Shop #: WSC 00066 000 00199
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DA7F1B63D7198A3CC7-8028
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H08 0010
   Coding: 830000
   Part No SW: 5C6 920 871     HW: 5C6 920 871
   Component: KOMBI         H04 0617
   Coding: 371C00
   VCID: 698FB5E659F9140310F-803C
   Part No SW: 7N0 907 530 P    HW: 1K0 907 951
   Component: J533  Gateway H40 1623
   Revision:   H40       Serial number: 24121101290100
   Coding: 351002
   Shop #: WSC 29384 004 1048576
   VCID: 3D2731B67D7158A38C7-8068
                    Mileage: 155865 km
                    Date: 2016.02.05
                    Time: 00:16:45
   Component: IMMO          H04 0617
   Coding: 000007
   Shop #: WSC 11572 002 1048576
   VCID: 6A8DCAEA5CFF1F1B195-803E
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000241511002
   Coding: 4900000000000000
   Shop #: WSC 00066 790 50316
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2E0506FAA097B33B05D-807A
   Revision: A1001003    Serial number: 7661008437
   Coding: 020000
   VCID: 290FF5E699F9D403D0F-807C
   Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
   Component: RNS315-NAR    H34 0265
   Serial number: VWZAZ2L8487232
   Coding: 04090001010006000000100A
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_RNS315NARV2UDS A01004
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 2313E7CEFB550E539A3-8076
   Component: NAR_V2  0002
          B11CF 53 [009] - Deactivated
                    Reset counter: 148
                    Mileage: 155865 km
                    Date: 2021.09.14
                    Time: 00:16:45
   Component: TUER-SG FT    002 0515
   Revision: 13110009    Serial number: 0003711990
   Coding: 0004B5
   VCID: 5BE39F2E83A57693923-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  007 1508
   Serial number: 00000006184790
   Coding: 000490
          B11EC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 148
                    Mileage: 155865 km
                    Date: 2021.09.14
                    Time: 00:16:45
   Part No: 1K0 909 144 N
   Component: EPS_ZFLS Kl. 70     3301
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 35372996494180E3447-8060
            000 - - - MIL ON
                    Mileage: 155865 km
                    Date: 2016.02.05
                    Time: 00:16:43
                    Battery Volts: 12.5 V
                        DD
                    Temperature: 26.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Part No SW: 3T0 035 456 B    HW: 3T0 035 456 B
   Component: KonzernAmp10K H06 0362
   Revision: --------    Serial number: BP225319961567
ROD: EV_AudioVerst10KanalSTT3_VW36.rod
   VCID: 30391882BAA3A5CB171-8064
9463059 - Rear Left Bass Speaker
          B1065 13 [009] - Open Circuit
                    Reset counter: 148
                    Mileage: 155865 km
                    Date: 2021.09.14
                    Time: 00:16:45
   Component: EZE_2         H40 1623
   Coding: 01030100
   VCID: 6FBBDBFE679DFA334EB-803A
   Subsystem 1 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.022  H09 0007
   Serial number:     WRH0003UFQ1
   Coding: 180000
   Component: TUER-SG BT    002 0515
   Revision: 15110009    Serial number: 0003715860
   Coding: 0004B4
   VCID: 5CE19C3286AB71AB9B9-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 B    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  007 1508
   Serial number: 00000006192464
   Coding: 000490
End----------(Elapsed Time: 01:13, VBatt start/end: 12.5V/12.5V)-----------
Wow, that car is a mess.
I would start by fixing the Gateway Installation List.
[Select]
[19 - CAN Gateway]
[Installation List]
- Put a checkmark next to each of the items that shows "Status: Not registered" in the above scan.
[Save/Write Coding]
Next, clear all the fault codes to see what comes back and post a fresh scan.
Onelowvdub
Edmonton, Canada
C?ID=492415
Yes I has typical light codes froms LEDs bulbs .power steering codes been there for ever and since I got it tuned I have a steering wheel communication fault car ran fine forever with it.
I will try with what you suggested I found some wiring manuals also and checked all fuses and everything seems fine there it's like the 17 tiptronic shifter being plugged in to the 12 DSG car it freaked out .I know that after 14 they were away from canbus so it must be a different system cause I see the gateway is different is even has a blue plug versus my res plug on my gateway which can also be found on the later mk5
Maybe try the correct shifter for your car?
iichel
Eindhoven, NB, NL
C?ID=284912
Jetta 2012 + CCTA engine:
Jetta 2017:
No specific shifter available for CCTA engine.
As Jack would probably tell (or yell), FOD?
Onelowvdub
Edmonton, Canada
C?ID=492415
[Select]
[19 - CAN Gateway]
[Installation List]
[Save/Write Coding]
          56 62 72
2B-Steer. Col. Lock -- Status: Not registered 0011
                    Mileage: 155865 km
                    Date: 2016.02.05
                    Time: 00:46:12
                    RPM: 767 /min
                    Load: 14.5 %
                    Temperature: 75.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 920.0 mbar
                    Voltage: 14.097 V
               P1624 - 000 -
                    Temperature: 12.0°C
                    Temperature: 14.0°C
                    Voltage: 11.938 V
            U0103 - 000 -  - MIL ON
                    Mileage: 155865 km
                    Date: 2016.02.05
                    Time: 00:41:46
            U0103 - 004 -
                    Reset counter: 0
                    Mileage: 155865 km
                    Date: 2016.02.05
                    Time: 00:41:51
   Revision: 00H31001
                    Reset counter: 148
                    Mileage: 155865 km
                    Date: 2016.02.05
                    Time: 00:36:07
                    Count: 16384
                    Count: 2
                    Count: 29184
                    Count: 8212
                    Count: 50944
                    Count: 255
                    Count: 7424
Onelowvdub
Edmonton, Canada
C?ID=492415
Jetta 2017:
Mine I had in there was 5k1 713 025 BJ ..
The 17 shifter had a different selector for the prnds on the board and was for not can bus but same body harness connector
Onelowvdub
Edmonton, Canada
C?ID=492415
I reverted back to original electronic module in the 17 casing .so it should see it as a 11 now but same codes still are there .can't remove
Onelowvdub
Edmonton, Canada
C?ID=492415
Here shop rate is 200 an hour with taxs and fees .dealer said next step in their manual was replace shifter .quoted $2000 cad and it might not be the issue they said might be deeper .I put alot of money and time into this car and not about to lose it to a wrecker So I bought a rosstech cable to be able to do what the dealer and shop can do for the most part and stop me from trailing it around spending $ on people guessing what it is and spending someone else's $ .would even a used 12 GLI shifter which matches old code work ? Or should I be digging in the wiring diagrams
iichel
Eindhoven, NB, NL
C?ID=284912
I would get a bj shifter
