2010 Q5 0B5 2.0FSI DSG No drive
naushad2982
Kenya
C?ID=58306
Hey guys,
I have the above vehicle. We had to replace the mechatronic unit as usual on this model. the part was supplied by Audi Germany(the owner supplied it himself when he travelled there) and the component protection was also released by a technician from Audi using the VasPC. also the Mechatronic was installed as per instructions from ELSA.
for some reason there is no drive to the wheels even though the gear lever moves through the entire range from P to S.
Have I missed something?
Monday,04,May,2015,16:37:00:40454
VCDS Version: 15.3.0.0
Data version: 20150314
VIN: WAUZZZ8R9AA103351   License Plate: UAQ 550H
Mileage: 43980km-27327mi   Repair Order: Kenneth Q5
Chassis Type: 8R (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2E 42 46 47 52 53 56 62 72
          77
VIN: WAUZZZ8R9AA103351   Mileage: 43980km-27327miles
Address 01: Engine (CL0MA-CDNC)       Labels: 06H-907-115-CAB.clb
   Part No SW: 8R0 907 115 A    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H16 0006
   Revision: E1H16---
   Coding: 0121000C240F0060
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_ECM20TFS8R0907115A A02007
   ROD: EV_ECM20TFS0118K2907115AJ.rod
   VCID: 326DA2D365B167A801-8067
2937 - Please Check Fault Codes in Transmission Control Module
          U1026 00 [044] - -
                    Mileage: 43984 km
                    Date: 2015.05.04
                    Time: 15:49:09
Readiness: 1110 0001
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 8R0 927 156 AB    HW: 0B5 927 156 E
   Component: 0B5 20TFSIRdW H04 0006
   Revision: --H04---    Serial number: 0000001658
   Shop #: WSC 04940 001 00001
   ASAM Dataset: EV_TCMDL501 A02087
   ROD: EV_TCMDL501.rod
   VCID: 7BF34FF7F27B66E092-802E
8938 - Base Measurements
          P17CA 00 [109] - Implausible Data
                    Mileage: 43984 km
Address 03: ABS Brakes (J104)       Labels: 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 L    HW: 8R0 907 379 L
   Component: ESP8 quattro  H07 0010
   Coding: 021540
   VCID: 499FE53FE027047050-801C
                    Fault Status: 00101101
                    Reset counter: 152
                    Mileage: 43984 km
                    Date: 2015.05.04
                    Time: 15:49:08
                    Hex Value: 0x00C0
                    Hex Value: 0x0782
                    Hex Value: 0x000A
                    Hex Value: 0x238F
                    Hex Value: 0x00FF
Address 05: Acc/Start Auth.        Labels: 8K0-907-064-05.clb
   Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
   Component: BCM2 1.1      H02 0328
   Coding: 011500
   VCID: 010F3D1F98970C30C8-FFFF
   Part No SW: 8T2 820 043 AD    HW: 8T2 820 043 AD
   Component: KLIMA 1 ZONE  H08 0171
   Revision: B0000000    Serial number: 01140420100576
   Coding: 64050000
   VCID: 74E164CBD7252998D3-8021
   Part No SW: 8K0 907 063 L    HW: 8K0 907 063 L
   Component: BCM1 1.0      H29 0380
   Revision: 07029001    Serial number: 00000000516731
   Coding: 690040B10034A7010001000000005F5F001D460802000101000000
   VCID: 387990FB8BCD8DF83F-806D
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 100309  H10 0041
   Coding: 01DD13
   Component: RLS  H04 0003
   Coding: 024D25
   Component: E1 - LDS  H08 0090
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 Q    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0070
   Revision: 11001001    Serial number: 51241010915250
   Coding: 000105
   VCID: 479BE307F633F20046-8012
Address 15: Airbags
   Revision: --------    Serial number: 90304JDE0009F
   Coding: 000013
   VCID: 3D7781EFA4EFA8D0EC-8068
   Component: E221 - MFL  H02 0010
Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 980 J    HW: 8R0 920 980 J
   Component: KOMBIINSTR.   H11 0255
   Revision: 00200000    Serial number: CJJ73UL3A
   Coding: 2F06220002002600010000
   VCID: 4089F81BD31DC53887-8015
   Part No SW: 8T0 907 468 AB    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0117
   Revision: GB800053    Serial number: 5300G104118016
   Coding: 00CB03
   VCID: 010F3D1F98970C30C8-8054
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0140
            000 -  -  - Intermittent
                    Reset counter: 192
                    Mileage: 43984 km
                    Date: 2015.05.04
                    Time: 14:19:22
                    Bin. Bits:    10111
                    Voltage: 11.40 V
                    Count: 6
Address 2E: Media Player 3 (R199)       Labels: 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020202
   VCID: 397F95FFB0C794F0C0-806C
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000010501164
   Coding: 011002205001440004
   VCID: 4587E90FCC3FE010B4-8010
   Revision: 00002001    Serial number: 0128845987
   Coding: 013B0622203900940430053280000000
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H01 0220
   Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J394EE20SKB13  H01 0220
Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
   Part No SW: 8R0 035 223 F    HW: 8R0 035 223 E
   Component: DSP STD       H11 0440
   Revision: 00000000    Serial number: 00000000000001
   Coding: 0203010102
   VCID: 2F6BABA77E834A406E-807A
02247 - Subwoofer (R148/R157)
                    Reset counter: 152
                    Voltage: 12.40 V
                    Temperature: 27.0°C
                    Bin. Bits: 00000100
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000010501729
   VCID: 4481F40BC705D918A3-8011
   Revision: 00000003    Serial number: 10000000488065
   VCID: 3461A4CB97A5699813-8061
Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
   Part No SW: 8T2 035 186 P    HW: 8T2 035 186 P
   Component: Concert3      H06 0350
   Revision: 00000010    Serial number: AUZ5Z6J1388706
   Coding: 0402008201058D00015B070800
   Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
   Component: Display
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000103462486
   Coding: 010002204001240004
   VCID: 428DF213DD11D72891-8017
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Revision:             Serial number: 0000103462483
   Part No SW: 8T0 862 335 D    HW: 8T0 862 335 D
   Component: FSE_256x BT     H39 0600
   Revision: 00000000    Serial number: 00000005182439
   Coding: 0010320
   VCID: 3B738FF77AFBA6E0D2-806E
End-------------------------(Elapsed Time: 07:32)--------------------------
dubTECH
Northern ireland
C?ID=104757
As Dana has already pointed out, you need to run the basic settings to set the travel paths for the selectors or it won't drive. This should have been stated in Elsa.
naushad2982
Kenya
C?ID=58306
Results
Results:
[Basic Settings - 04]
- From the pull down list select one of the following at a time, press
[Go] and when it has completed press [Stop].
[Erase counter for start and stop processes]-error request out of range
[Clutch valve calibration]- Aborted safety reasons
[Distance sensor calibration]- finished sucessfully.
car now has drive and no faults logged in the memory.
thank you people
